RS8559XP
RS8559XP
    RUNIC(润石)
    SOIC14
    IC OPAMP ZERO-DRIFT 4CIRC 14SOP
RS8559XP 数据手册
RS8557,RS8558,RS8559 Zero-Drift, Rail-to-Rail I/O CMOS Operational Amplifiers FEATURES • • • • • • • • • • • • DESCRIPTION The RS8557, RS8558, RS8559 series of CMOS operational amplifiers use auto-zero techniques to simultaneously provide very low offset voltage (20μV max) and near-zero drift over time and temperature. This family of amplifiers has ultralow noise, offset and power. Low Offset Voltage: 3uV Input Offset Drift: 0.03μV/°C High Gain Bandwidth Product: 4.3MHz Rail-to-Rail Input and Output High Gain, CMRR, PSRR:120dB High Slew Rate: 2.5V/μs Low Noise: 0.93uVp-p (0.01~10Hz) Low Power Consumption: 650μA /op amp Overload Recovery Time:1us Low Supply Voltage: +2.7 V to +5.5 V No External Capacitors Required Extended Temperature: -40°C to +125°C This miniature, high-precision operational amplifiers offset high input impedance and rail-to-rail input and rail-to-rail output swing. With high gain-bandwidth product of 4.3MHz and slew rate of 2.5V/μs. Single or dual supplies as low as +2.7V (±1.35V) and up to +5.5V (±2.75V) may be used. APPLICATIONS • • • • • • • • The RS8557/RS8558/RS8559 are specified for the extended industrial and automotive temperature range (-40°C to 125°C). The RS8557 single amplifier is available in 5-lead SOT23, 8-lead MSOP8 and 8lead SOIC packages, The RS8558 dual amplifier is available in 8-lead SOIC and 8-lead MSOP narrow surface mount packages, The RS8559 quad amplifier is available in 14-lead SOIC and 14-lead narrow TSSOP packages. Temperature Sensors Medical/Industrial Instrumentation Pressure Sensors Battery-Powered Instrumentation Active Filtering Weight Scale Sensor Strain Gage Amplifiers Power Converter/Inverter Device Information (1) PART NUMBER RS8557 RS8558 RS8559 PACKAGE SOT23-5 SOIC-8(SOP8) MSOP-8 SOIC-8(SOP8) MSOP-8 SOIC-14(SOP14) TSSOP-14 BODY SIZE(NOM) 2.90mm×1.60mm 4.90mm×3.90mm 3.00mm×3.00mm 4.90mm×3.90mm 3.00mm×3.00mm 8.65mm×3.90mm 5.00mm×4.40mm (1) For all available packages, see the orderable addendum at the end of the data sheet. REV B.3 1 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS8557,RS8558,RS8559 Pin Configuration and Functions (Top View) RS8557 RS8557 V- 2 +IN 3 5 + - NC 1 -IN 2 +IN 3 V- 4 V+ 4 + 1 - OUT 8 NC 7 V+ 6 OUT -IN SOT23-5 5 NC SOIC-8(SOP8),MSOP-8 Pin Description PIN NAME -IN +IN NC OUT VV+ RS8557 SOT23-5 4 3 1 2 5 RS8557 SOIC-8(SOP8)/MSOP8 2 3 1,5,8 6 4 7 I/O DESCRIPTION I I O - Negative (inverting) input Positive (noninverting) input No internal connection (can be left floating) Output Negative (lowest) power supply Positive (highest) power supply RS8558 OUT A 1 -IN A 2 +IN A 3 V- + A B+ 4 8 V+ 7 OUTB 6 -IN B 5 +IN B SOIC-8(SOP8),MSOP-8 Pin Description NAME -INA +INA -INB +INB OUTA OUTB VV+ PIN SOIC-8(SOP8)/MSOP8 2 3 6 5 1 7 4 8 I/O DESCRIPTION I I I I O O - Inverting input, channel A Noninverting input, channel A Inverting input, channel B Noninverting input, channel B Output, channel A Output, channel B Negative (lowest) power supply Positive (highest) power supply 2 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS8557,RS8558,RS8559 Pin Configuration and Functions (Top View) RS8559 OUT A 1 -IN A 2 +IN A 14 OUT D 13 -IN D 3 12 +IN D V+ 4 11 V- +IN B 5 10 +IN C -IN B 6 9 -IN C OUT B 7 8 OUT C A - + - + B D + - + C SOIC-14(SOP14),TSSOP-14 Pin Description NAME -INA +INA -INB +INB -INC +INC -IND +IND OUTA OUTB OUTC OUTD VV+ PIN SOIC-14(SOP14)/TSSOP-14 2 3 6 5 9 10 13 12 1 7 8 14 11 4 I/O DESCRIPTION I I I I I I I I O O O O - Inverting input, channel A Noninverting input, channel A Inverting input, channel B Noninverting input, channel B Inverting input, channel C Noninverting input, channel C Inverting input, channel D Noninverting input, channel D Output, channel A Output, channel B Output, channel C Output, channel D Negative (lowest) power supply Positive (highest) power supply 3 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS8557,RS8558,RS8559 SPECIFICATIONS Absolute Maximum Ratings Over operating free-air temperature range (unless otherwise noted) (1) MIN MAX 7 (V-)-0.5 (V+) +0.5 (V-)-0.5 (V+) +0.5 -10 10 -55 55 Continuous -40 125 150 -65 150 Supply, Vs=(V+) - (V-) Signal input pin (2) Signal output pin (3) Signal input pin (2) Signal output pin (3) Output short-circuit (4) Operating range, TA Junction, TJ Storage, Tstg Voltage Current Temperature UNIT V mA mA °C (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. (2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.5V beyond the supply rails should be currentlimited to 10mA or less. (3) Output terminals are diode-clamped to the power-supply rails. Output signals that can swing more than 0.5V beyond the supply rails should be currentlimited to ±55mA or less. (4) Short-circuit to ground, one amplifier per package. ESD Ratings V(ESD) Electrostatic discharge Human-body model (HBM) Machine Model (MM) VALUE UNIT 5000 400 V Recommended Operating Conditions Over operating free-air temperature range (unless otherwise noted) Supply voltage,Vs= (V+) - (V-) MIN 2.7 ±1.35 -40 Single-supply Dual-supply Specified temperature NOM MAX 5.5 ±2.75 125 UNIT V °C Thermal Information:RS8557 RS8557 THERMAL METRIC (1) 5PINS SOT23-5 273.8 SOIC-8 116 8PINS MSOP-8 165 UNIT °C/W RϴJA Junction-to-ambient thermal resistance RϴJC(top) Junction-to-case(top) thermal resistance 126.8 60 53 °C/W RϴJB Junction-to-board thermal resistance 85.9 56 87 °C/W ѰJT ѰJB Junction-to-top characterization parameter Junction-to-board characterization parameter Junction-to-case(bottom) thermal resistance 10.9 84.9 12.8 98.3 4.9 85 °C/W °C/W N/A N/A N/A °C/W RϴJC(bot) 4 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS8557,RS8558,RS8559 Thermal Information:RS8558 RS8558 8PINS THERMAL METRIC (1) UNIT SOIC-8 116 MSOP8 165 °C/W RϴJC(top) Junction-to-case(top) thermal resistance 60 53 °C/W RϴJB Junction-to-board thermal resistance 56 87 °C/W ѰJT ѰJB Junction-to-top characterization parameter Junction-to-board characterization parameter Junction-to-case(bottom) thermal resistance 12.8 98.3 4.9 85 °C/W °C/W N/A N/A °C/W RϴJA Junction-to-ambient thermal resistance RϴJC(bot) Thermal Information:RS8559 RS8559 14PINS THERMAL METRIC (1) UNIT SOIC-14 83.8 TSSOP-14 120.8 °C/W RϴJA Junction-to-ambient thermal resistance RϴJC(top) Junction-to-case(top) thermal resistance 70.7 34.3 °C/W RϴJB Junction-to-board thermal resistance 59.5 62.8 °C/W ѰJT ѰJB Junction-to-top characterization parameter Junction-to-board characterization parameter Junction-to-case(bottom) thermal resistance 11.6 37.7 1 56.5 °C/W °C/W N/A N/A °C/W RϴJC(bot) 5 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS8557,RS8558,RS8559 PACKAGE/ORDERING INFORMATION Orderable Device Package Type Pin Channel Op Temp(°C) Device Marking Package Qty RS8557XF SOT23-5 5 1 -40℃~125℃ 8557 Tape and Reel,3000 RS8557XK SOIC-8(SOP8) 8 1 -40℃~125℃ RS8557 Tape and Reel,2500 RS8557XM MSOP-8 8 1 -40℃~125℃ RS8557 Tape and Reel,3000 RS8558XK SOIC-8(SOP8) 8 2 -40℃~125℃ RS8558 Tape and Reel,2500 RS8558XM MSOP-8 8 2 -40℃~125℃ RS8558 Tape and Reel,3000 RS8559XP SOIC-14(SOP14) 14 4 -40℃~125℃ RS8559 Tape and Reel,2500 RS8559XQ TSSOP-14 14 4 -40℃~125℃ RS8559 Tape and Reel,3000 6 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS8557,RS8558,RS8559 ELECTRICAL CHARACTERISTICS Boldface limits apply over the specified temperature range, TA = –40°C to +125°C. (At TA = +250C, Vs=5V, RL = 10kΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.) PARAMETER RS8557, RS8558, RS8559 CONDITION MIN TYP UNIT MAX OFFSET VOLTAGE Input Offset Voltage VS Temperature VS Power Supply Vos VCM = Vs/2 dVos/dT PSRR VS = +2.7V to +5.5V, VCM = 0 105 Channel Separation, dc 3 20 μV 0.03 0.2 μV/0C 120 dB 0.13 μV/V 50 pA 10 pA INPUT BIAS CURRENT Input Bias Current IB Input Offset Current Ios VCM = Vs/2 NOISE PERFORMANCE Input Voltage Noise Input Voltage Noise enp-p f=0.01Hz to 10Hz 0.93 enp-p f=0.01Hz to 1Hz 0.32 μVpp μVpp Input Voltage Noise Density en f=1KHz 45 nV/√Hz Input Current Noise Density in f=10Hz 2.3 fA/√Hz INPUT VOLTAGE RANGE Common-Mode Voltage Range VCM (V-)-0.2 Common-Mode Rejection Ratio CMRR (V–) – 0.2V < VCM < (V+)+ 0.2V 105 (V+)+0.2 V 120 dB Differential 1 pF Common-Mode 5 pF 120 dB INPUT CAPACITANCE OPEN-LOOP GAIN Open-Loop Voltage Gain AOL RL=10KΩ, VO=0.3V to 4.7V, -40°C~125°C SR G=+1 105 DYNAMIC PERFORMANCE Slew Rate Gain-Bandwidth Product GBW Overload Recovery Time 2.5 V/μs 4.3 MHz 1 us V OUTPUT CHARACTERISTICS Output Voltage High VOH Output Voltage Low VOL Short-Circuit Current ISC RL=100 KΩ to GND 4.99 4.998 RL=10 KΩ to GND 4.95 4.98 V RL=100 KΩ to V+ 1 10 mV RL=10 KΩ to V+ 10 30 mV 48 mA POWER SUOOLY Operating Voltage Range Quiescent Current/ Amplifier 2.7 IQ 650 7 5.5 V 900 uA www.run-ic.com 010-67713792 sale@starttodo.com.cn RS8557,RS8558,RS8559 TYPICAL CHARACTERISTICS At TA = +25C, Vs=5V, RL = 10kΩ connected to VS/2, VOUT = VS/2, unless otherwise noted. OFFSET VOLTAGE PRODUCTION DISTRIBUTION Population Number Of Amplifiers 6 OFFSET VOLTAGE DRIFT PRODUCTION DISTRIBUTION 5 4 3 2 1 0 -20 -15 -10 -5 0 5 10 15 20 -30 -25 -20 -15 -10 -5 0 5 10 15 20 25 30 Offset Voltage (uV) Input Offset Drift (nV/℃) OPEN−LOOP GAIN AND PHASE vs FREQUENCY Open-Loop Gain(dB) 120 Phase 100 130 110 90 80 70 60 50 40 30 20 Input Bias Current(pA) Gain Phase Margin (°) 140 INPUT BIAS CURRENT vs TEMPERATURE 10K 100 10 0 -20 10 1K 10 -10 10M 100K Frequency(Hz) -40 -20 0 20 40 60 80 100 120 140 Temperature(℃) POWER−SUPPLY REJECTION RATIO vs FREQUENCY 140 140 120 COMMON−MODE REJECTION RATIO vs FREQUENCY 120 100 100 CMRR(dB) PSRR(dB) 1K 80 60 40 80 60 40 20 20 0 100 1K 10K 100K 1M 0 10M 100 Frequency(Hz) 8 1K 10K 100K Frequency(Hz) 1M 10M www.run-ic.com 010-67713792 sale@starttodo.com.cn RS8557,RS8558,RS8559 TYPICAL CHARACTERISTICS At TA = +25C, Vs=5V, RL = 10kΩ connected to VS/2, VOUT = VS/2, unless otherwise noted. QUIESCENT CURRENT vs TEMPERATURE QUIESCENT CURRENT vs TEMPERATURE 660 650 Quiescent Current(uA) Quiescent Current(uA) 660 640 630 620 610 650 640 630 620 610 600 -40 -20 0 -40 -20 0 20 40 60 80 100 120 140 Temperature(℃) Vs=2.7V 20 40 60 80 100 120 140 Temperature(℃) Vs=5V SINK CURRENT vs TEMPERATURE 65 65 Sink Current(mA) 70 60 55 50 60 55 50 45 45 40 40 -40 -20 0 -40 -20 0 20 40 60 80 100 120 140 Temperature(℃) 20 40 60 80 100 120 140 Temperature(℃) LARGE−SIGNAL STEP RESPONSE SMALL−SIGNAL STEP RESPONSE CL=100PF CL=100PF 1V/div 50mV/div Source Current(mA) SOURCE CURRENT vs TEMPERATURE 70 200ns/div 1us/div 9 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS8557,RS8558,RS8559 TYPICAL CHARACTERISTICS At TA = +25C, Vs=5V, RL = 10kΩ connected to VS/2, VOUT = VS/2, unless otherwise noted. VIN 0V 0V VS=±2.5V G=-100 VS=±2.5V G=-100 VOUT 200ns/DIV 200ns/DIV 400nV/div 0.01Hz TO 10Hz NOISE AT Vs=2.7V 200nV/div 0.01Hz TO 10Hz NOISE AT Vs=5V 10s/div 10s/div 0.01Hz TO 1Hz NOISE AT Vs=5V 0.01Hz TO 1Hz NOISE AT Vs=2.7V 200nV/div 100nV/div 0V 1V/div VOUT 200mV/div VIN 1V/div 0V NEGATIVE OVERVOLTAGE RECOVERY 200mV/div POSITIVE OVERVOLTAGE RECOVERY 10s/div 10s/div 10 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS8557,RS8558,RS8559 Detailed Description Overview The RS8557, RS8558, RS8559 series op amps are unity-gain stable and free from unexpected output phase reversal. They use auto-zeroing techniques to provide low offset voltage and very low drift over time and temperature. Good layout practice mandates use of a 0.1µF capacitor placed closely across the supply pins. For lowest offset voltage and precision performance, circuit layout and mechanical conditions should be optimized. Avoid temperature gradients that create thermoelectric (Seebeck) effects in thermocouple junctions formed from connecting dissimilar conductors. These thermally-generated potentials can be made to cancel by assuring that they are equal on both input terminals. • Use low thermoelectric-coefficient connections (avoid dissimilar metals). • Thermally isolate components from power supplies or other heat-sources. • Shield op amp and input circuitry from air currents, such as cooling fans. Following these guidelines will reduce the likelihood of junctions being at different temperatures, which can cause thermoelectric voltages of 0.1µV/°C or higher, depending on materials used. OPERATING VOLTAGE The RS8557, RS8558, RS8559 series op amps operate over a power-supply range of +2.7V to +5.5V (±1.35V to ±2.75V). Supply voltages higher than 7V (absolute maximum) can permanently damage the amplifier. Parameters that vary over supply voltage or temperature are shown in the Typical Characteristics section of this data sheet. 11 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS8557,RS8558,RS8559 APPLICATION NOTE Typical Applications Bidirectional Current-Sensing This single-supply, low-side, bidirectional current-sensing solution detects load currents from –1 A to 1 A. The single-ended output spans from 110 mV to 3.19 V. This design uses the RS8557, RS8558, RS8559 because of its low offset voltage and rail-to-rail input and output. One of the amplifiers is configured as a difference amplifier and the other provides the reference voltage. VCC VCC VREF R5 + U1B R6 ILOAD VBUS + R2 R1 + VSHUNT + RSHUNT VOU T U1A R3 VCC RL R4 Figure 4. Bidirectional Current-Sensing Schematic Design Requirements This solution has the following requirements: • Supply voltage: 3.3 V • Input: –1 A to 1 A • Output: 1.65 V ±1.54 V (110 mV to 3.19 V) Detailed Design Procedure The load current, ILOAD, flows through the shunt resistor (RSHUNT) to develop the shunt voltage, VSHUNT. The shunt voltage is then amplified by the difference amplifier, which consists of U1A and R1 through R4. The gain of the difference amplifier is set by the ratio of R4 to R3. To minimize errors, set R2 = R4 and R1 = R3. The reference voltage, VREF, is supplied by buffering a resistor divider using U1B. The transfer function is given by Equation 1. VOUT=VSHUNT×Gain Diff_Amp +VREF Where VSHUNT=ILOAD×RSHUNT Gain Diff_Am p = R4 R3 (1) There are two types of errors in this design: offset and gain. Gain errors are introduced by the tolerance of the shunt resistor and the ratios of R4 to R3 and, similarly, R2 to R1. Offset errors are introduced by the voltage divider (R5 and R6) and how closely the ratio of R4/R3 matches R2/R1. The latter value impacts the CMRR of the difference amplifier, which ultimately translates to an offset error. Because this is a low-side measurement, the value of VSHUNT is the ground potential for the system load. Therefore, it is important to place a maximum value on VSHUNT. In this design, the maximum value for VSHUNT is set to 100 mV. Equation 2 calculates the maximum value of the shunt resistor given a maximum shunt voltage of 100 mV and maximum load current of 1 A. V RSHUNT(Max) = SHUNT(Max) = 100 mV = 100 m ILOAD(Max) 1A (2) The tolerance of RSHUNT is directly proportional to cost. For this design, a shunt resistor with a tolerance of 0.5% was selected. If greater accuracy is required, select a 0.1% resistor or better. The load current is bidirectional; therefore, the shunt voltage range is –100 mV to 100 mV. This voltage is 12 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS8557,RS8558,RS8559 divided down by R1 and R2 before reaching the operational amplifier, U1A. Take care to ensure that the voltage present at the noninverting node of U1A is within the common-mode range of the device. Therefore, it is important to use an operational amplifier, such as the RS8557, RS8558, RS8559, that has a common-mode range that extends below the negative supply voltage. Finally, to minimize offset error, note that the RS8557, RS8558, RS8559 has a typical offset voltage of ±3µV (±20µV maximum). Given a symmetric load current of – 1 A to 1 A, the voltage divider resistors (R5 and R6) must be equal. To be consistent with the shunt resistor, a tolerance of 0.5% was selected. To minimize power consumption, 10kΩ resistors were used. To set the gain of the difference amplifier, the common-mode range and output swing of the RS8557, RS8558, RS8559 must be considered. Equation 3 and Equation 4 depict the typical common-mode range and maximum output swing, respectively, of the RS8557, RS8558, RS8559 given a 3.3V supply. -100mV
RS8559XP 价格&库存
很抱歉,暂时无法提供与“RS8559XP”相匹配的价格&库存,您可以联系我们找货
RS8559XP
  • 1+7.06320
  • 10+5.58360
  • 30+4.83840
  • 100+4.10400
库存:2970
