QUARTZ CRYSTAL UNIT SPECIFCATION
Customer:
Customer P/N:
1. Frequency:
2. Holder type :
3. Frequency tolerance:
4. Equivalent resistance:
5. Storage temperature range:
6. Operable temperature range:
7. Temperature drift:
8. Loading capacitance (CL) :
9. Drive level:
10. Shunt Capacitance:
11. Insulation resistance :
12. Mode of oscillation:
13. Circuit:
14. Shocking :
Variation :
15. Aging:
16. Note:
HELE P/N : X5H012288FI1H
Date :2015/05/29
12.288000MHz
HSX530G
+/-30 ppm at 25deg.C +/-3deg.C
100 ohms Max. / SERIES
-40 deg.C To +85 deg.C
-20 deg.C To +75 deg.C
+/-30ppm
-20deg.C To +75 deg.C
18.0pF
10 uW (300uW Max.)
7.0pF Max.
More than 500M ohms at DC 100V
Fundamental
Measured in HP/E5100A,S&A 250B
Dropping from 75 cm height 3 times on firm wood
Frequency less than +/-5 ppm
Resistance less than +/- 15 ﹪or 2ohms max.
Less than +/-5ppm/Year
Marking :
*Marking should be printed as following:
Nominal Frequency, Logo, Manufactured year & month
*Nominal frequency ()= 3 number after decimal point MAX.
( ex. 12.000 MHz 12.000 )
*Manufacturing Lot No.
(Y: year) ex. 2000 shall be marked as ‘ 0 ’
Year
2000 2001 2002 2003 2004 2005 2006 2007 2008 2009
2010 2011 2012 2013 2014 2015 2016 2017 2018 2019
Code
2
3
4
5
6
7
8
9
(M: month) ex. June shall be marked as ‘ F ‘
Jan. Feb. Mar. Apr. May. Jun. Jul. Aug. Sep. Oct. Nov. Dec.
A
B
C
D
E
F
G
H
J
K
L
M
Marking : Laser marking.
HARMONY ELECTRONICS CORP.
很抱歉,暂时无法提供与“X5H012288FI1H”相匹配的价格&库存,您可以联系我们找货
