MCW-0650-100-S1
MCW-0650-100-S1
    HOTLAND(合泰盟方)
    IND_6.6X7MM_SM
    功率电感
MCW-0650-100-S1 数据手册
    方         合 Low profile:Thickness max.5.0mm 盟 合 泰       合 合 Voltage regulator VRM for server       合   盟 方 泰 合 方 盟 泰 合     方 ⑥ Material Type; 方 ⑤ The Material Code;   ④ Inductance Value:2R2=2.2µH; 盟 泰 合 18 S 1  ⑤ ⑥ 盟   方 盟 泰 合 - 泰 2R2   ④   -       方 盟 0650 ③ ③ Dimensions(unit:mm):6.0x6.0x5.0; 泰 泰 合 泰 合   - ② 合 盟 泰 合   ① (C)3.0±0.3   方 盟 盟 方 Suggested pad layout Dimensions are in mm The rated current as listed is either the saturation current or the MC W   3,5       8,4 方 cooling provision all affect the part temperature.Part temperature   3,7       component.PWB trace size and thickness, airflow and other heating current depending on which value is lower.     盟 方 泰 合 合   125℃ under the worst case operating conditions.Circuit design, 泰 盟 方 盟 (D)5.0Max 泰 合       方 盟 泰 泰 合     The part temperature (ambient + temp rise ) should not exceed should be verified in the end application. (E)0~0.15   方 泰 盟 合     方   盟 (F)1,6±0.3 Operat between temperature range -55℃ to +125℃   (B)6,6±0.2 方         (A)6.95±0.35 Isat :DC current (A) that will cause L0 to drop approximately 20%   泰 盟 泰 DC/DC converters for laptop motherboards/CPU Idc: DC current (A) that will cause an approximate △T of 40℃ ② Mold Categories:W;   ※ Application Thin type of on-board power supply module for Test Condition:100KHz,1.0Vrms ※ Regulation of Part number 方     盟 方   方 方     100% lead (Pb) free meet RoHS standards ※ Dimensions in inches (unit:mm) 方 盟 泰 合           Low loss and low resistance All test data is reference to 25℃ ambient. ① Molding Choke; 合 泰 盟   合 High performance (Isat) realizde by metal dust core. Capable of corresponding high frequency (3MHz) 盟 合 泰         泰 盟 泰 合     方   盟 方 ※Note: 方 ※ Features 方   泰 盟 方 盟 方           方 盟 www.sz-hotland.com     MCW-0650-XXX-S1 Series
MCW-0650-100-S1 价格&库存
很抱歉,暂时无法提供与“MCW-0650-100-S1”相匹配的价格&库存,您可以联系我们找货
