MCW-1040-XXX-N2 Series
www.sz-hotland.com
※ Features
High performance (Isat) realizde by metal dust core.
Low profile:Thickness max.4.0mm
Low loss and low resistance
Capable of corresponding high frequency (1MHz)
100% lead (Pb) free meet RoHS standards
※ Application
DC/DC converters for laptop motherboards/CPU
Thin type of on-board power supply module for
Voltage regulator VRM for server
※ Dimensions in inches (unit:mm)
(A)11.15±0.35
All test data is reference to 25℃ ambient.
(E)0~0.15
(B)10.0±0.3
(C)3.5±0.5
※Note:
(D)4.0Max
(C)3.0±0.5
(D)4.0Max
(E)0~0.15
(B)10.0±0.3
(A)11.15±0.35
Test Condition:100KHz,1.0Vrms
Idc: DC current (A) that will cause an approximate △T of 40℃
(F)2.0±0.5
(F)2.0±0.5
5,4
5,4
Operat between temperature range -55℃ to +125℃
4,1
The part temperature (ambient + temp rise ) should not exceed
125℃ under the worst case operating conditions.Circuit design,
cooling provision all affect the part temperature.Part temperature
Suggested pad layout
Dimensions are in mm
the diagram above applies
to values 0.56uH and
above
to values 0.56uH and below
should be verified in the end application.
The rated current as listed is either the saturation current or the
heating current depending on which value is lower.
MC F
①
②
12,2
12,2
component.PWB trace size and thickness, airflow and other
※ Regulation of Part number
4,1
Isat :DC current (A) that will cause L0 to drop approximately 30%
1040
③
2R2
④
N 2
⑤ ⑥
① Molding Choke;
④ Inductance Value:2R2=2.2µH;
② Mold Categories:F;
⑤ The Material Code;
③ Dimensions(unit:mm):10.0x10.0x4.0;
⑥ Material Type;
9
很抱歉,暂时无法提供与“MCF-1040-5R6-N2”相匹配的价格&库存,您可以联系我们找货
