MCF-1030-2R2-N2
MCF-1030-2R2-N2
    HOTLAND(合泰盟方)
    功率电感
MCF-1030-2R2-N2 数据手册
MCW-1030-XXX-N2 Series www.sz-hotland.com ※ Features High performance (Isat) realizde by metal dust core. Low profile:Thickness max.3.0mm Low loss and low resistance Capable of corresponding high frequency (1MHz) 100% lead (Pb) free meet RoHS standards ※ Application DC/DC converters for laptop motherboards/CPU Thin type of on-board power supply module for Voltage regulator VRM for server ※ Dimensions in inches (unit:mm) (C)3.0±0.5 (E)0~0.15 (D)3.0Max (B)10.0±0.3 (A)11.15±0.35 ※Note: All test data is reference to 25℃ ambient. Test Condition:100KHz,1.0Vrms Idc: DC current (A) that will cause an approximate △T of 40℃ Isat :DC current (A) that will cause L0 to drop approximately 30% (F)2.0±0.5 Operat between temperature range -55℃ to +125℃ The part temperature (ambient + temp rise ) should not exceed 5,4 4,1 125℃ under the worst case operating conditions.Circuit design, component.PWB trace size and thickness, airflow and other 12,2 cooling provision all affect the part temperature.Part temperature should be verified in the end application. Suggested pad layout Dimensions are in mm The rated current as listed is either the saturation current or the heating current depending on which value is lower. ※ Regulation of Part number MC F ① ② - 1030 - ③ 2R2   ④ - N 2 ⑤ ⑥ ① Molding Choke; ④ Inductance Value:2R2=2.2µH; ② Mold Categories:F; ⑤ The Material Code; ③ Dimensions(unit:mm):10.0x10.0x3.0; ⑥ Material Type; 8
MCF-1030-2R2-N2 价格&库存
很抱歉,暂时无法提供与“MCF-1030-2R2-N2”相匹配的价格&库存,您可以联系我们找货
