LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS
KMS
Downsized snap-ins, 105℃
KHS
Series
Downsizing
・For solar power generation
・Endurance with ripple current : 105℃ 3,000 hours
・Rated voltage range : 160 to 600V
・Capacitance range : 47 to 3,300µF
・Non solvent resistant type
・RoHS2 Compliant
KMS
LXS
Longer life
Downsizing
KMM
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-25 to +105℃
160 to 600Vdc
±20% (M)
I≦3 CV
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
Rated voltage (Vdc)
160 to 400V
420 to 600V
tanδ (Max.)
0.15
0.20
Rated voltage (Vdc)
160 to 400V
420 to 600V
Z(-25℃)/Z(+20℃)
4
8
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20℃, 120Hz)
(at 20℃ after 5 minutes)
(at 20℃, 120Hz)
Shelf Life
◆DIMENSIONS [mm]
Sleeve (PET : Brown)
●Terminal
PC board pin-out
(View from Solder side)
Negative mark
φD+1max.
10
2-φ2
4.0±0.5
L±2.5
Vent
Code : LI (φ35)
Negative mark
Vent
PC board pin-out
4.2±0.5
Code : VS (φ22 to φ35) : Standard
2-1.2×6
φD+1max.
●Terminal
5±0.5
L±2.5
4.5±1
14.2±1
The standard design has no plastic disc.
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E KMS A A A V S N A A A M A A A S
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 100µF:101, 1,000µF:102)
Dummy terminal code
Terminal code (VS, LI)
Voltage code (ex. 160V:161, 400V:401)
Series code
Category
Please refer to "Product code guide (snap-in type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001T
Snap-in
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for 3,000 hours at 105℃.
Capacitance change
≦±20% of the initial value
D.F. (tanδ)
≦200% of the initial specified value(600Vdc:≦300%)
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
≦±15% of the initial value
D.F. (tanδ)
≦150% of the initial specified value
Leakage current
Endurance
KMSSeries
◆STANDARD RATINGS
WV
(Vdc)
160
180
200
Cap
(µF)
470
680
680
820
820
1,000
1,000
1,000
1,000
1,200
1,200
1,200
1,200
1,500
1,500
1,800
1,800
1,800
2,200
2,200
2,700
2,700
2,700
3,300
390
560
560
680
820
820
820
1,000
1,000
1,000
1,000
1,000
1,200
1,200
1,200
1,500
1,500
1,500
1,800
1,800
2,200
2,200
2,700
2,700
390
470
560
560
680
680
820
820
820
1,000
1,000
1,000
1,000
1,200
1,200
1,200
1,200
1,500
1,500
Rated ripple
current
Case size
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
22 ×25
22 ×30
25.4 ×25
22 ×35
25.4 ×30
22 ×40
22× 45
25.4× 35
30× 25
22× 50
25.4× 40
30× 30
35× 25
25.4× 45
30× 35
25.4× 50
30× 40
35× 30
30× 45
35× 35
30× 50
35× 40
35× 45
35× 50
22× 25
22 × 30
25.4×25
22×35
22×40
25.4×30
30×25
22× 45
22 ×50
25.4×35
25.4×40
30×30
25.4× 45
30× 35
35×25
25.4× 50
30× 40
35 ×30
30×45
35×35
30×50
35× 40
35× 45
35× 50
22×25
22×30
22×35
25.4×25
22×40
25.4×30
22 ×45
25.4×35
30 ×25
22 ×50
25.4×40
30 ×30
35 ×25
25.4×45
25.4×50
30 ×35
35 ×30
30 ×40
35 ×35
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
1.47
1.86
1.84
2.09
2.08
2.35
2.40
2.40
2.50
2.69
2.68
2.77
2.91
3.05
3.17
3.40
3.57
3.62
4.05
4.07
4.56
4.67
4.78
5.40
1.34
1.68
1.67
1.90
2.13
2.08
2.26
2.40
2.45
2.40
2.45
2.52
2.73
2.83
2.91
3.10
3.26
3.31
3.66
3.68
4.11
4.22
4.78
4.88
1.34
1.54
1.72
1.67
1.94
1.89
2.17
2.17
2.26
2.45
2.45
2.52
2.66
2.73
2.78
2.83
2.96
3.26
3.36
Part No.
EKMS161VSN471MP25S
EKMS161VSN681MP30S
EKMS161VSN681MQ25S
EKMS161VSN821MP35S
EKMS161VSN821MQ30S
EKMS161VSN102MP40S
EKMS161VSN102MP45S
EKMS161VSN102MQ35S
EKMS161VSN102MR25S
EKMS161VSN122MP50S
EKMS161VSN122MQ40S
EKMS161VSN122MR30S
EKMS161VSN122MA25S
EKMS161VSN152MQ45S
EKMS161VSN152MR35S
EKMS161VSN182MQ50S
EKMS161VSN182MR40S
EKMS161VSN182MA30S
EKMS161VSN222MR45S
EKMS161VSN222MA35S
EKMS161VSN272MR50S
EKMS161VSN272MA40S
EKMS161VSN272MA45S
EKMS161VSN332MA50S
EKMS181VSN391MP25S
EKMS181VSN561MP30S
EKMS181VSN561MQ25S
EKMS181VSN681MP35S
EKMS181VSN821MP40S
EKMS181VSN821MQ30S
EKMS181VSN821MR25S
EKMS181VSN102MP45S
EKMS181VSN102MP50S
EKMS181VSN102MQ35S
EKMS181VSN102MQ40S
EKMS181VSN102MR30S
EKMS181VSN122MQ45S
EKMS181VSN122MR35S
EKMS181VSN122MA25S
EKMS181VSN152MQ50S
EKMS181VSN152MR40S
EKMS181VSN152MA30S
EKMS181VSN182MR45S
EKMS181VSN182MA35S
EKMS181VSN222MR50S
EKMS181VSN222MA40S
EKMS181VSN272MA45S
EKMS181VSN272MA50S
EKMS201VSN391MP25S
EKMS201VSN471MP30S
EKMS201VSN561MP35S
EKMS201VSN561MQ25S
EKMS201VSN681MP40S
EKMS201VSN681MQ30S
EKMS201VSN821MP45S
EKMS201VSN821MQ35S
EKMS201VSN821MR25S
EKMS201VSN102MP50S
EKMS201VSN102MQ40S
EKMS201VSN102MR30S
EKMS201VSN102MA25S
EKMS201VSN122MQ45S
EKMS201VSN122MQ50S
EKMS201VSN122MR35S
EKMS201VSN122MA30S
EKMS201VSN152MR40S
EKMS201VSN152MA35S
WV
(Vdc)
200
250
315
400
Cap
(µF)
1,800
1,800
1,800
2,200
2,700
270
330
390
390
470
470
560
560
560
680
680
680
680
820
820
1,000
1,000
1,000
1,200
1,200
1,200
1,500
1,500
1,800
180
220
220
270
330
330
330
390
390
390
470
470
470
560
560
560
560
680
680
820
820
820
1,000
1,200
120
150
180
180
220
220
270
270
270
330
330
330
330
390
Rated ripple
current
Case size
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
30 × 45
30 × 50
35 × 40
35 × 45
35 × 50
22 × 25
22 × 30
22 × 35
25.4 × 25
22 × 40
25.4 × 30
22 × 45
25.4 × 35
30 × 25
22 × 50
25.4 × 40
30 × 30
35 × 25
25.4 × 45
30 × 35
25.4 × 50
30 × 40
35 × 30
30 × 45
30 × 50
35 × 35
35 × 40
35 × 45
35 × 50
22 × 25
22 × 30
25.4 × 25
22 × 35
22 × 40
25.4 × 30
30 × 25
22 × 45
22 × 50
25.4 × 35
25.4 × 40
30 × 30
35 × 25
25.4 × 45
25.4 × 50
30 × 35
35 × 30
30 × 40
35 × 35
30 × 45
30 × 50
35 × 40
35 × 45
35 × 50
22 × 25
22 × 30
22 × 35
25.4 × 25
22 × 40
25.4 × 30
22 × 45
25.4 × 35
30 × 25
22 × 50
25.4 × 40
30 × 30
35 × 25
25.4 × 45
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
3.66
3.72
3.81
4.32
4.88
1.11
1.29
1.44
1.40
1.61
1.57
1.79
1.79
1.87
2.02
2.02
2.08
2.19
2.26
2.34
2.53
2.66
2.70
2.99
3.04
3.00
3.48
3.56
3.98
0.95
1.10
1.10
1.24
1.40
1.38
1.43
1.56
1.59
1.57
1.76
1.73
1.82
1.96
1.99
1.93
2.02
2.19
2.26
2.47
2.51
2.57
2.91
3.25
0.77
0.90
1.02
0.99
1.15
1.13
1.29
1.30
1.29
1.47
1.47
1.45
1.52
1.63
Part No.
EKMS201VSN182MR45S
EKMS201VSN182MR50S
EKMS201VSN182MA40S
EKMS201VSN222MA45S
EKMS201VSN272MA50S
EKMS251VSN271MP25S
EKMS251VSN331MP30S
EKMS251VSN391MP35S
EKMS251VSN391MQ25S
EKMS251VSN471MP40S
EKMS251VSN471MQ30S
EKMS251VSN561MP45S
EKMS251VSN561MQ35S
EKMS251VSN561MR25S
EKMS251VSN681MP50S
EKMS251VSN681MQ40S
EKMS251VSN681MR30S
EKMS251VSN681MA25S
EKMS251VSN821MQ45S
EKMS251VSN821MR35S
EKMS251VSN102MQ50S
EKMS251VSN102MR40S
EKMS251VSN102MA30S
EKMS251VSN122MR45S
EKMS251VSN122MR50S
EKMS251VSN122MA35S
EKMS251VSN152MA40S
EKMS251VSN152MA45S
EKMS251VSN182MA50S
EKMS3B1VSN181MP25S
EKMS3B1VSN221MP30S
EKMS3B1VSN221MQ25S
EKMS3B1VSN271MP35S
EKMS3B1VSN331MP40S
EKMS3B1VSN331MQ30S
EKMS3B1VSN331MR25S
EKMS3B1VSN391MP45S
EKMS3B1VSN391MP50S
EKMS3B1VSN391MQ35S
EKMS3B1VSN471MQ40S
EKMS3B1VSN471MR30S
EKMS3B1VSN471MA25S
EKMS3B1VSN561MQ45S
EKMS3B1VSN561MQ50S
EKMS3B1VSN561MR35S
EKMS3B1VSN561MA30S
EKMS3B1VSN681MR40S
EKMS3B1VSN681MA35S
EKMS3B1VSN821MR45S
EKMS3B1VSN821MR50S
EKMS3B1VSN821MA40S
EKMS3B1VSN102MA45S
EKMS3B1VSN122MA50S
EKMS401VSN121MP25S
EKMS401VSN151MP30S
EKMS401VSN181MP35S
EKMS401VSN181MQ25S
EKMS401VSN221MP40S
EKMS401VSN221MQ30S
EKMS401VSN271MP45S
EKMS401VSN271MQ35S
EKMS401VSN271MR25S
EKMS401VSN331MP50S
EKMS401VSN331MQ40S
EKMS401VSN331MR30S
EKMS401VSN331MA25S
EKMS401VSN391MQ45S
CAT. No. E1001T
KMSSeries
◆STANDARD RATINGS
400
420
450
Cap
(µF)
390
390
470
470
560
560
560
680
680
820
100
120
120
150
180
180
180
220
220
220
220
270
270
270
330
330
330
330
390
390
470
470
560
680
82
120
120
120
150
150
180
180
180
220
220
220
220
270
270
270
270
330
390
390
390
470
470
560
Rated ripple
current
Case size
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
25.4×50
30 ×35
30 ×40
35 ×30
30× 45
30× 50
35 × 35
35 × 40
35 ×45
35 ×50
22 ×25
22 ×30
25.4 ×25
22 ×35
22× 40
25.4× 30
30 × 25
22 × 45
22 × 50
25.4× 35
30 ×30
25.4×40
25.4×45
35 ×25
25.4×50
30 ×35
30×40
35×30
30×45
35×35
30×50
35×40
35×45
35×50
22× 25
22×30
22×35
25.4×25
22×40
25.4×30
22×45
25.4×35
30×25
22×50
25.4×40
30×30
35×25
25.4×45
25.4×50
30×35
35×30
30×40
30×45
30×50
35 × 35
35 ×40
35 ×45
35× 50
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
1.66
1.61
1.82
1.85
2.04
2.07
2.05
2.34
2.40
2.69
0.70
0.81
0.81
0.93
1.04
1.02
1.06
1.17
1.20
1.18
1.18
1.33
1.36
1.38
1.52
1.48
1.52
1.55
1.70
1.71
1.90
1.95
2.17
2.45
0.64
0.81
0.83
0.81
0.94
0.93
1.06
1.06
1.06
1.20
1.20
1.18
1.24
1.36
1.38
1.34
1.40
1.52
1.70
1.73
1.71
1.95
1.99
2.22
Part No.
EKMS401VSN391MQ50S
EKMS401VSN391MR35S
EKMS401VSN471MR40S
EKMS401VSN471MA30S
EKMS401VSN561MR45S
EKMS401VSN561MR50S
EKMS401VSN561MA35S
EKMS401VSN681MA40S
EKMS401VSN681MA45S
EKMS401VSN821MA50S
EKMS421VSN101MP25S
EKMS421VSN121MP30S
EKMS421VSN121MQ25S
EKMS421VSN151MP35S
EKMS421VSN181MP40S
EKMS421VSN181MQ30S
EKMS421VSN181MR25S
EKMS421VSN221MP45S
EKMS421VSN221MP50S
EKMS421VSN221MQ35S
EKMS421VSN221MR30S
EKMS421VSN271MQ40S
EKMS421VSN271MQ45S
EKMS421VSN271MA25S
EKMS421VSN331MQ50S
EKMS421VSN331MR35S
EKMS421VSN331MR40S
EKMS421VSN331MA30S
EKMS421VSN391MR45S
EKMS421VSN391MA35S
EKMS421VSN471MR50S
EKMS421VSN471MA40S
EKMS421VSN561MA45S
EKMS421VSN681MA50S
EKMS451VSN820MP25S
EKMS451VSN121MP30S
EKMS451VSN121MP35S
EKMS451VSN121MQ25S
EKMS451VSN151MP40S
EKMS451VSN151MQ30S
EKMS451VSN181MP45S
EKMS451VSN181MQ35S
EKMS451VSN181MR25S
EKMS451VSN221MP50S
EKMS451VSN221MQ40S
EKMS451VSN221MR30S
EKMS451VSN221MA25S
EKMS451VSN271MQ45S
EKMS451VSN271MQ50S
EKMS451VSN271MR35S
EKMS451VSN271MA30S
EKMS451VSN331MR40S
EKMS451VSN391MR45S
EKMS451VSN391MR50S
EKMS451VSN391MA35S
EKMS451VSN471MA40S
EKMS451VSN471MA45S
EKMS451VSN561MA50S
WV
(Vdc)
500
550
600
Cap
(µF)
47
56
68
82
82
100
100
120
120
120
150
150
150
180
180
180
220
220
270
270
330
390
470
82
82
100
100
100
120
120
120
120
150
150
180
180
180
220
220
270
270
330
330
470
100
100
120
150
150
180
180
180
220
220
220
270
330
Rated ripple
current
Case size
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
22 × 25
22 × 30
25.4 × 25
22 × 35
25.4 × 30
22 × 45
30 × 25
22 × 50
25.4 × 35
30 × 30
25.4 × 45
30 × 35
35 × 25
25.4 × 50
30 × 40
35 × 30
30 × 45
35 × 35
30 × 50
35 × 40
35 × 45
35 × 50
35 × 60
22 × 35
25.4× 30
22 × 45
25.4 × 35
30 × 25
22 × 50
25.4 × 40
30 × 30
35 × 25
25.4 × 45
30 × 35
25.4 × 50
30 × 40
35 × 30
30 × 45
35 × 35
30 × 50
35 × 40
35 × 45
35 × 50
35 × 60
30 × 30
35 × 25
30 × 35
30 × 40
35 × 30
30 × 45
30 × 50
35 × 35
30 × 60
35 × 40
35 × 45
35 × 50
35 × 60
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.51
0.58
0.65
0.72
0.74
0.83
0.82
0.93
0.93
0.91
1.08
1.04
0.99
1.20
1.17
1.10
1.33
1.23
1.50
1.42
1.60
1.78
2.03
0.72
0.74
0.83
0.85
0.82
0.93
0.95
0.91
0.88
1.08
1.04
1.20
1.17
1.10
1.33
1.23
1.50
1.42
1.60
1.64
2.03
0.83
0.85
0.93
1.07
1.06
1.20
1.22
1.18
1.40
1.35
1.38
1.56
1.79
Part No.
EKMS501VSN470MP25S
EKMS501VSN560MP30S
EKMS501VSN680MQ25S
EKMS501VSN820MP35S
EKMS501VSN820MQ30S
EKMS501VSN101MP45S
EKMS501VSN101MR25S
EKMS501VSN121MP50S
EKMS501VSN121MQ35S
EKMS501VSN121MR30S
EKMS501VSN151MQ45S
EKMS501VSN151MR35S
EKMS501VSN151MA25S
EKMS501VSN181MQ50S
EKMS501VSN181MR40S
EKMS501VSN181MA30S
EKMS501VSN221MR45S
EKMS501VSN221MA35S
EKMS501VSN271MR50S
EKMS501VSN271MA40S
EKMS501VSN331MA45S
EKMS501VSN391MA50S
EKMS501VSN471MA60S
EKMS551VSN820MP35S
EKMS551VSN820MQ30S
EKMS551VSN101MP45S
EKMS551VSN101MQ35S
EKMS551VSN101MR25S
EKMS551VSN121MP50S
EKMS551VSN121MQ40S
EKMS551VSN121MR30S
EKMS551VSN121MA25S
EKMS551VSN151MQ45S
EKMS551VSN151MR35S
EKMS551VSN181MQ50S
EKMS551VSN181MR40S
EKMS551VSN181MA30S
EKMS551VSN221MR45S
EKMS551VSN221MA35S
EKMS551VSN271MR50S
EKMS551VSN271MA40S
EKMS551VSN331MA45S
EKMS551VSN331MA50S
EKMS551VSN471MA60S
EKMS601VSN101MR30S
EKMS601VSN101MA25S
EKMS601VSN121MR35S
EKMS601VSN151MR40S
EKMS601VSN151MA30S
EKMS601VSN181MR45S
EKMS601VSN181MR50S
EKMS601VSN181MA35S
EKMS601VSN221MR60S
EKMS601VSN221MA40S
EKMS601VSN221MA45S
EKMS601VSN271MA50S
EKMS601VSN331MA60S
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Frequency(Hz)
160 to 250Vdc
315 to 450Vdc
500 to 600Vdc
50
0.81
0.77
0.70
120
1.00
1.00
1.00
300
1.17
1.16
1.16
1k
1.32
1.30
1.30
10k
1.45
1.41
1.41
50k
1.50
1.43
1.43
The endurance of capacitors is reduced with internal heating produced by
ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple
current has to be reduced.
CAT. No. E1001T
Snap-in
WV
(Vdc)
