Aluminum Electrolytic Capacitors
RXB
Features
‧ 105℃, 5,000 hours assured
‧ Suitable for switching power supplies, UPS, Ballast
‧ Smaller size with large permissible ripple current
‧ RoHS Compliance
Sleeve & Marking Color: Brown & White
SPECIFICATIONS
Items
Category Temperature Range
Performance
160 ~ 400V
450V
-40℃ ~ +105℃
-25℃ ~ +105℃
(at 120Hz, 20℃)
±20%
Capacitance Tolerance
Time
Leakage Current (at 20℃)
Dissipation Factor
(Tanδat 120Hz, 20℃)
Low Temperature
Characteristics (at 120Hz)
Endurance
after 5 minutes
CV ≦ 1,000
CV > 1,000
Leakage Current
I = 0.03CV(µA)
I = 0.02CV(µA)
Where, C = rated capacitance in µF V = rated DC working voltage in V
Rated Voltage
160
200
250
350
400
450
Tanδ(max)
0.20
0.20
0.20
0.24
0.24
0.24
Impedance ratio shall not exceed the values given in the table below.
Rated Voltage
160
200
250
350
400
450
Impedance
Z(-25) /Z(+20℃)
3
3
3
3
5
6
Ratio
Z(-40) /Z(+20℃)
4
4
4
4
6
Test Time
5,000 Hrs
Capacitance Change
Within ±20% of initial value
Dissipation Factor
Less than 200% of specified value
Leakage Current
Within specified value
* The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied
with rated ripple current for 5,000 hours at 105℃.
Test Time
Shelf Life Test
1,000 Hrs
Capacitance Change
Dissipation Factor
Leakage Current
* The above specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000
hours at 105℃ without voltage applied. The rated voltage shall be applied to the capacitors before the
measurements (Refer to JIS C 5101-4 4.1).
Ripple Current &
Frequency Multipliers
2011 Version
Freq.(Hz)
Cap. (µF)
2.2 to 82
120
1k
10k
100k up
1.00
1.20
1.40
1.50
100 up
1.00
1.18
1.35
1.45
RXB
DIAGRAM OF DIMENSIONS
15 min
Sleeve
Unit: mm
LEAD SPACING AND DIAMETER
φD+βmax
φd
L+α max
φD
P
φd
α
β
P±0.5
Vent≧10φ
4 min
V.DC
160V (2C)
φD×L
µF
200V (2D)
Ripple Current
120 Hz 100k Hz
φD×L
12.5
16
5.0
0.6
18
7.5
0.8
1.5
0.5
Dimension: φD × L(mm)
Ripple Current: mA/rms at 105°C
DIMENSION & PERMISSIBLE RIPPLE CURRENT
Contents
10
250V (2E)
Ripple Current
120 Hz 100k Hz
φD×L
350V (2V)
Ripple Current
120 Hz 100k Hz
φD×L
400V (2G)
Ripple Current
120 Hz 100k Hz
2.2
φD×L
10×16
Ripple Current
120 Hz 100k Hz
70
105
3.3
10×16
72
108
10×16
82
123
4.7
10×16
85
128
10×16
98
147
6.8
10×16
100
150
10×16
120
180
10
10×16
130
195
10×16
150
225
10×16
155
233
10×20
160
240
10×20
170
255
22
10×20
210
315
10×20
230
345
12.5×20
210
315
12.5×25
305
460
12.5×25
320
480
33
12.5×20
300
450
12.5×20
320
480
12.5×20
335
505
16×25
410
615
16×25
425
635
47
12.5×25
340
510
12.5×25
365
548
16×25
560
840
16×31.5
510
765
16×31.5
530
795
68
16×25
535
800
16×25
560
840
16×25
600
900
18×31.5
580
870
18×31.5
600
900
100
16×25
610
885
16×25
645
935
16×31.5
700
1,015
18×35.5
665
965
18×40
700
1,015
120
16×31.5
685
990
16×31.5
710
1,030
18×31.5
790
1,145
18×40
715
1,035
18×45
780
1,130
150
16×31.5
720
1,045
16×31.5
750
1,090
18×35.5
875
1,270
180
18×31.5
800
1,160
18×31.5
830
1,205
18×40
980
1,420
220
18×35.5
870
1,260
18×35.5
900
1,305
18×45
1,100
1,595
270
18×40
980
1,420
18×40
1,100
1,595
330
18×45
1,050
1,520
18×45
1,250
1,815
V. DC
Contents
450V (2W)
φD×L
µF
Ripple Current
120 Hz 100k Hz
85
128
3.3
10×16
4.7
10×16
105
158
6.8
10×20
170
255
10
12.5×20
280
420
22
16×25
405
610
33
16×31.5
490
735
47
18×31.5
575
865
68
18×40
665
1,000
2011 Verison
很抱歉,暂时无法提供与“RXB4R7M2WBK-1016P”相匹配的价格&库存,您可以联系我们找货
