H.ELE.
Specifications for Approval
CUSTOMER
PRODUCT TYPE
Quartz Crystal SMD-49
NOMINAL FREQUENCY
12.000000MHz
H.ELE. SAMPLE O/N
EOS-H20016-2
H.ELE. P/N
XSA012000DK1H-OX
RELEASE DATE
2017/02/09
VERSION
00
MSL
Level 01
GREEN PRODUCT
Pb free RoHS Compliant
HF-Halogen free REACH Compliant
CUSTOMER P/N
APPLICATION & MODEL
APPROVED BY CUSTOMER
(DATE)
Harmony Electronics Corp.
F. S. TSAI
(APPROVE)
KAOHSIUNG
Y. W. LEE
Country of Origin:
U. F. CHEN
(CHECK)
(PREPARE)
Taiwan Factory
Thailand Factory
China Factory
HARMONY ELECTRONICS CORPRATION
TAIPEI
TEL: 886-2-26588883
THAILAND
SHENZHEN
SUZHOU
Email: contactus@hele.com.tw
REV. No.
DATE
REASON
New
KAOHSIUNG
REVISE CONTENTS
TAIPEI
TEL: 886-2-26588883
THAILAND
SHENZHEN
SUZHOU
Contents
ITEM
PAGE
1. QUARTZ CRYSTAL UNIT SPECIFICATION
1
2. DIMENSIONS
2
3. MARKING
2
4. INSIDE STRUCTURE
3
5. EMBOSS CARRIER TAPE&REEL
3-4
6. PACKAGE
4
7. MECHANICAL PERFORMANCE
4-5
8. ENVIRONMENTAL PERFORMANCE
5
9. APPENDIX
KAOHSIUNG
TAIPEI
TEL: 886-2-26588883
THAILAND
SHENZHEN
SUZHOU
1. QUARZ CRYSTAL UNIT SPECIFICATION
Electrical Spec.
Items
Min
1. Frequency (FL)
Type
Max
12.000000
2. Mode of oscillation:
Unit
MHz
Fundamental
3. Frequency tolerance
AT-cut
-20
+20
ppm
4. Equivalent resistance (RR)
50
Ω
5. Storage temperature range
-40
+85
6. Operable temperature range
-40
+85
7. Temperature stability
-50
+50
ppm
8. Loading capacitance (CL)
20.0
pF
9. Drive level (DL)
50
300
μW
10. Shunt Capacitance (C0)
7.0
pF
500
MΩ
12. Aging:
-5
+5
ppm/ year
13. Circuit:
Measured in HP/E5100A,S&A 250B
11. Insulation resistance
Notes
at 25℃±3℃
SERIES
-40℃ ~ +85℃
at DC 100V
Note:
KAOHSIUNG
TAIPEI
TEL: 886-2-26588883
THAILAND
1
SHENZHEN
SUZHOU
2. DIMENSION
3.8 Max.
4.9 0.2
MARK
4.8 Max.
3.75 Max.
0.8 0.1
TOP VIEW
12.1-0.1/+0.3
11.0 0.2
BOTTOM VIEW
TOP VIEW
Land Pattern Layout
H
2.0
10.15 Max.
4.5
4.0
4.5
13.0
H
Value
3.2 max
3.7 max
4.5 max
V
3. MARKING
H
H.ELE.
Date Code:MY
Nominal frequency
ex.14.31818 MHz=>14.318
Note:
1. Laser marking.
2. Date Code:
M=Month
Jan.
Feb.
Mar.
Apr.
May.
Jun.
Jul.
Aug.
Sep.
Oct.
Nov.
Dec.
Code
A
B
C
D
E
F
G
H
J
K
L
M
Y=Year
Code
KAOHSIUNG
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
2023
2024
2025
2026
2027
2028
2029
2
3
4
5
6
7
8
9
TAIPEI
TEL: 886-2-26588883
THAILAND
2
SHENZHEN
SUZHOU
4. INSIDE STRUCTURE
Reference drawing
No.
Component
(1)
Base
(2)
Can
(3)
Lead
(4)
Glass
(5)
Support
(6)
Insulator
(7)
Blank
(8)
Electrode
Connective
(9)
Adhesive
Note
Free Pb
※The use prohibition chemistry substance of Table 1 of DHE-0204-1 (HE-QA-24) is not included in
this item.
5. EMBOSS CARRIER TAPE AND REEL
Carrier Tape
2.0±0.1
1.55±0.05
24.0±0.3
11.5±0.1
1.75±0.1
0.35±0.05
12±0.1
4.0±0.1
4.6±0.1
5.0±0.1
12.0±0.1
User Direction of feed
Terminal
Empty Sealed
Empty Sealed
Components
Ledder
H12.000MY
H12.000MY
H12.000MY
H12.000MY
160mm(Min)
400mm(Min)
40mm(min)
Top Cover tape
Embossed Carrier tape
Reel
330±2.0
99±1.0
13.5±0.5
2.5±0.5
12
24±2
Standard Packing Quantity: 1,000PCS / REEL
KAOHSIUNG
28.6±2
TAIPEI
TEL: 886-2-26588883
THAILAND
3
SHENZHEN
SUZHOU
Joint of tape
The carrier-tape and top cover-tape should not be jointed.
Release strength of cover tape
It has to between 0.1N to 0.7N under
following condition.
Pulling direction: 165° to 180°
Speed: 300mm/min.
Other standards shall be based on JIS C 0806-1990.
Otherwise unless specified.
6. PACKAGE
Label Contents:
One reel quantity: 1000pcs
Reel
The label will be stickled on all reels.
Descriptions:
Carton Size(mm)
Carton
Pb F
1. One carton will pack 10 reels (10,000 pcs
totally) or 5 reels (5,000pcs of SMD-49
totally).
2. The cartoon will be placed 1.5cm thinFoam-rubber cushions on the bottom and
bottom for protection.
10 reels
ree
5 reels
Carton (Corrugated Carton)
Thickness:7±1mm
Item
1
Specifications
code
Test Methods
Dropping from 50 cm height 3 times on 30 mmm Concrete Floor
Shock
A
Refer to: JIS C 60068-2-6.
(1)Vibration Frequency 10~55Hz
2
Vibration
KAOHSIUNG
(2)Cycle
2 rounds
(3)Amplitude
0.8mm
A
TAIPEI
TEL: 886-2-26588883
THAILAND
4
SHENZHEN
SUZHOU
(4)Direction
X.Y.Z
(5)Time
2hr for each direction
3
Leakage Test Dipping in the FC-40 at +125±5℃ for 30 min. Not exceed specifications
4
Solder ability
After applying ROSIN Flux, dipping in solder bath at 245deg.C ±5deg.C for 3 ±0.5 sec.
B
Refer to: JIS C 60068-2-20
8. ENVIRONMENT PERFORMANCE
Item
Specifications
Code
Test Methods
Temperature 60℃±2℃, RH 90~95%, duration of 240 hours.
1
Humidity
A
Back to room temperature first, then in 1~2 hours, the component shall
be checked. Refer to: JIS C 60068-2-3
2
3
Storage in Low
Temperature
Storage in High
Temperature
-40deg.C ±2deg.C, duration of 240 hours.
A
Back to the room temperature first, then in 1~2 hours, the component
shall be checked. Refer to: JIS C 60068-2-1
+85deg.C ±2deg.C, duration of 240 hours.
A
shall be checked. Refer to: JIS C 60068-2-2
-30deg.C +/-2deg.C (30min) ↔ +85deg.C +/-2deg.C (30min) 25 cycles.
4
Temperature
cycles
And Temperature Increasing/reducing time<3mins. Back to the room
A
temperature first, then in 1~2 hours, the component shall be checked.
Refer to: JIS C 0025
Specifications code
A
B
KAOHSIUNG
Specifications
Frequency variation shall be within ±5ppm and equivalent resistance shall be within
±15% or 2Ω
More than 90% of lead shall be covered by new solder.
TAIPEI
TEL: 886-2-26588883
THAILAND
5
SHENZHEN
SUZHOU
FACTORY LOCATION
HEAD OFFICE/TAIWAN FACTORY
NO.39, HUADONG RD., DALIAO DIST., DAFA INDUSTRIAL
PARK, KAOHSIUNG CITY 831, TAIWAN.
CHINA FACTORY
JU YUAN INDUSTRIAL PARK, QIAO TANG ROAD, TANG
WEI COMMUNITY, FUYONG, BAOAN DISTRICT, SHEN
ZHEN CITY, CHINA (Post Code:518103).
THAILAND FACTORY
66MOO 5, KAONGU-BEOKPRAI RD., T.BEOKPRAI, A.
BANPONG, RATCHABURI PROVINCE 70110, THAILAND.
SERVICE CENTER
TAIPEI OFFICE
2F., NO.409, SEC.2, TIDING BLVD., NEIHU DISTRICT,
TAIPEI CITY 114, TAIWAN
TEL: 886-2-26588883
FAX: 886-2-26588683
CONTACT INFORMATION
E-MAIL: contactus@hele.com.tw
很抱歉,暂时无法提供与“XSA012000DK1H-OX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.20582
- 50+0.95861
- 150+0.85266
