Organic Conductive Polymer Capacitors
OVH
Features
˙105℃, 2,000 hours assured
˙Ultra low ESR, solid capacitors of SMD type
˙RoHS Compliance
Marking color: Blue
SPECIFICATIONS
Items
Category Temperature Range
Capacitance Tolerance
Performance
-55℃ ~ +105℃
±20%
(at 120Hz, 20℃)
Rated voltage applied, after 2 minutes at 20℃.
See Standard Ratings
Leakage Current (at 20℃ )*
Dissipation Factor
(Tanδ at 120Hz, 20℃ )
ESR (at 100k ~ 300k Hz, 20℃ )
Test Time
2,000 Hrs
Within ±20% of initial value
Capacitance Change
Dissipation Factor
Less than 150% of specified value
ESR
Leakage Current
Within specified value
* The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied
for 2,000 hours at 105℃.
Endurance
Test Time
1,000 Hrs
Capacitance Change
Dissipation Factor
ESR
Leakage Current
* The above specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them at 60℃,
90 to 95% RH for 1,000 hours. Leakage current should be tested after voltage treatment*.
Moisture Resistance
Within ±10% of initial value
Less than 130% of specified value
Capacitance Change
Dissipation Factor
ESR
Leakage Current
Resistance to Soldering Heat *
(Please refer to page 23 for reflow
soldering conditions)
Ripple Current &
Frequency Multipliers
Frequency (Hz)
120 ≦ f < 1k
1k ≦ f < 10k
Multiplier
0.05
0.3
10k ≦ f < 100k 100k ≦ f < 500k
0.7
1.0
* For any doubt about measured values, measure the leakage current again after the following voltage treatment.
Voltage treatment: Applying DC rated voltage to the capacitors for 2 hours at 105 oC.
DIAGRAM OF DIMENSIONS
B±0.2
φD±0.5
LEAD SPACING AND DIAMETER
φD
6.3
8
10
10
W
L
0.3 Max
A±0.2
0.4 max
L
A
5.9 +0.1 / -0.3 6.6
6.7 ± 0.3
8.4
7.7 ± 0.3
10.4
9.9 +0.1 / -0.3 10.4
B
6.6
8.4
10.4
10.4
Unit: mm
C
7.4
9.2
11.2
11.2
P ± 0.2
W
0.5 ~ 0.8
2.0
0.7 ~ 1.1
3.1
0.7 ~ 1.1
4.7
0.7 ~ 1.1
4.7
P
C±0.2
MARKING
φD = 6.3
Negative
polarity
φD = 8 ~ 10
a1
10
16H
Date code
Rated cap.
Rated voltage
& Series code
Negative
polarity
a1
OVH
470
6.3V
Date code
Series name
Rated cap.
Rated voltage
2011 Verison
Dimension: φD× L(mm)
Ripple Current: mA/rms at 100k Hz, 105℃
STANDARD RATINGS
W. V. (V)
2.5V (0E)
4V (0G)
6.3V (0J)
2011 Version
Capacitance
(µF)
Size
φD×L(mm)
390
6.3×5.9
560
OVH
Tanδ
(120Hz, 20℃ )
0.12
LC
(µA)
ESR
(mΩ/at 100k ~ 300k Hz, 20℃ Max)
Rated R. C.
(mA/rms at 100k Hz, 105℃ )
293
10
3,900
6.3×5.9
0.12
420
10
3,900
8×6.7
0.12
420
9
4,200
680
8×6.7
0.12
510
9
4,500
1,200
10×7.7
0.12
900
9
5,000
2,200
10×9.9
0.12
1,650
8
6,000
330
6.3×5.9
0.12
396
10
3,900
470
8×6.7
0.12
564
9
4,500
560
8×6.7
0.12
894
9
4,500
1,000
10×7.7
0.12
1,200
9
5,000
1,800
10×9.9
0.12
2,160
8
6,000
220
6.3×5.9
0.12
416
10
3,900
330
8×6.7
0.12
624
9
4,500
390
8×6.7
0.12
737
9
4,500
820
10×7.7
0.12
1,550
9
5,000
1,500
10×9.9
0.12
2,835
8
6,000
很抱歉,暂时无法提供与“OVH221M0JTR-0606”相匹配的价格&库存,您可以联系我们找货
