Approval Sheet
for
Metal Glazed Film Resistors
High Voltage & High Ohmic Type
HHV series
±1%, ±5%
YAGEO CORPORATION
Headquarters: 3F, No.233-1, Pao Chiao Rd., Xindian, Taipei, Taiwan, R.O.C.
Tel: 886-2-6629-9999 Fax: 886-2-6628-8885
URL: www.yageo.com
Page-1
Rev.
Description
Issue Date
Drawn
Approved
00
issue new spec.
Jul 16, 2007
Sara Lin
Joyce Chung
01
Update description
Sep 04, 2007
Lynn Chen
Joyce Chung
Environmental Characteristics revised
02
HHV1WS data is included
Jan 09, 2008
Lynn Chen
Joyce Chung
03
The 5th color band is changed to yellow
Jan 16, 2008
Lynn Chen
Joyce Chung
for tolerance 5% to represent high HHV
04
Lead Length 26mm is included
Apr 18, 2008
Lynn Chen
Joyce Chung
05
Series adjustment
Aug 29, 2008
Lynn Chen
Joyce Chung
06
HHV1SS data is included
Feb 25, 2009
Lynn Chen
Ken Hsu
07
Revised the product description
Apr 07, 2009
Lynn Chen
Ken Hsu
08
Adjust Index
May 05, 2009
Lynn Chen
Ken Hsu
09
Series adjustment
Sep 02, 2009
Lynn Chen
Ken Hsu
10
Jan 15, 2010
Lynn Chen
Ken Hsu
11
HHV200 is deleted and HHV3SS is
included.
1) T26 packing method for HHV-50 &
HHV1SS series is deleted.
2) HHV100 series is deleted.
The environmental characteristics are
adjusted;
Coated with epoxy lacquer type and
part number suffix of “Y” are included
Modify tape on box packing data
Aug 03,2010
Feng Ye
Ken Hsu
Aug 12, 2010
Feng Ye
Ken Hsu
Dec 30, 2010
Feng Ye
Ken Hsu
Apr 07, 2011
Feng Ye
Ken Hsu
Jun 27, 2011
Feng Ye
Ken Hsu
12
13
14
15
th
16
Revise product description of “the 5
color band is yellow” to “the last color
band is yellow”;
Revise band-code cutline.
Feb 03, 2012
Feng Ye
Ken Hsu
17
Added “52-“ type taping for
HHV2WS&HHV3SS.
May.21, 2014
Feng Ye
Flora Shen
18
Added reel type taping
Nov. 28, 2014 Feng Ye
Flora Shen
Page-2
Rev.
Description
Issue Date
Drawn
Approved
19
Update reel type dimension A , Add
Jan 13, 2020
Hui Chen
Feng Ye
dimension B
Forming dimensions are included.
Apr. 09, 2020
Mingfa Liu
Feng Ye
21
F&FK&FFK&FKK types for HHV-
Apr. 15, 2020
Hui Chen
Feng Ye
50&1SS series are included
Description
Metal Glazed Film Resistors, High Voltage & High Ohmic Type
Series
HHV
Rev.
Page-3
21
1. PRODUCT:
A metal glazed film is deposited on a high grade ceramic body, the resistors are coated with a pink
silicone lacquer or a blue epoxy lacquer (on request), the last color band is yellow to represent high
voltage resistors.
1. PART NUMBER:
Part number of the high voltage & high ohmic metal glazed film resistor is identified by the name, power,
tolerance, packing, temperature coefficient, special type, resistance value and suffix.
Example:
HHV
-50
(1)
Series
Name
(2)
Power
Rating
J
T
(3)
Resistance
Tolerance
52-
100K
Y
(4)
(5)
(6)
(7)
(8)
Packing Temperature Special Resistance Suffix
Style
Coefficient
Type Value
of Resistance
(1) Style: HHV SERIES
(2) Power Rating: -25=1/4W、50S=1/2W、-50=1/2W、1SS=1W、1WS=1W、2SS=2W、2WS=2W、
3SS=3W
(3) Tolerance: F = ± 1% , J = ± 5%
(4) Packaging Type:
T=Tape on Box Packing
B=Bulk Packing
R=Paper Taping Reel
(5) Temperature Coefficient : “-“=base on spec.
(6) Special Type:
26- = 26mm
52- = 52.4mm
73- = 73mm
M=M-Type Forming for Bulk
MB = MB Type Forming for Bulk
F = F Type Forming for Bulk
FK = FK Type Forming
FFK = FFK Type Forming
FKK = FKK Type Forming
PN=PANAsert ( rated watts from 1/4W to 2SS size only )
AV=Avlsert ( rated watts from 1/4W to 2SS size only )
(7) Resistance Value: 100K-68MΩ for E24&E96 Series.
(8) Suffix:
Y = coated with a blue epoxy lacquer
None = coated with a pink silicone lacquer.
Page-4
1. BAND-CODE:
COLOR
1st BAND
2nd BAND
3rd BAND
MULTIPLIER
BLACK
1Ω
BROWN
1
1
1
10Ω
RED
2
2
2
100Ω
ORANGE
3
3
3
1KΩ
YELLOW
4
4
4
10KΩ
GREEN
5
5
5
100KΩ
BLUE
6
6
6
1MΩ
VIOLET
7
7
7
10MΩ
GREY
8
8
8
WHITE
9
9
9
GOLD
0.1Ω
SILVER
0.01Ω
* TOL: ± 1 % ( F )--- 6 color band.
rd
* TOL: ± 5 % ( J )--- 5 color band.(3 BAND is not included)
TOLERANCE
±1%(F)
HHV Series
±5%(J)
1. ELECTRICAL CHARACTERISTICS
TABLE I
STYLE
Power Rating at 70 ℃
Maximum Working Voltage(DC)
Maximum Overload Voltage(DC)
Voltage Proof (Silicone Type)
Voltage Proof (Epoxy Type)
Resistance Range
Operating Temp. Range
HHV-25 HHV50S HHV-50 HHV1SS
1/4W
1/2W
1W
1600V
3500V
3000V
7000V
300V
500V
500V
100K ~ 68MΩ for E24 & E96 series value
- 55 ℃ to + 155 ℃
± 200 ppm /℃
* Below or over this resistance on request
5. DERATING CURVE
Page-5
HHV1WS HHV2SS HHV2WS HHV3SS
2W
3W
5000V
7000V
10000V
14000V
600V
700V
Rated Load (%)
70℃
100
80
60
40
60
80
100
120
140
155
180
Ambient Temperature (℃)
6. DIMENSIONS
ψd
L
H
ψD
DIMENSIONS(unit:mm)
STYLE
Ψd
L
H
ψd
Normal
Miniature
HHV-25
HHV50S
6.3±0.5
2.4±0.2
28±2.0
0.55±0.05
HHV-50
HHV1SS
9.0±0.5
3.3±0.3
26±2.0
0.55±0.05
HHV1WS
HHV2SS
11.5±1.0
4.5±0.5
35±2.0
0.80±0.05
HHV2WS
HHV3SS
15.5±1.0
5.0±0.5
33±2.0
0.80±0.05
7. ENVIRONMENTAL CHARACTERISTICS
1.
Short Time Over Load Test
At 2.5 times of the rated voltage. Or the maximum load voltage, whichever is the less, applied for 5
seconds, the resistor should be free from defects after the resistor is released from load for about 30
minutes
Short Time Overload Voltage =
2.5 * Power Rating ´ Resistance Value
The change of the resistance value should be within ± 2.0 % + 0.05Ω
(2) Voltage Proof
The resistor shall be clamped in the trough of a 90° metal V Block. Apply the insulation voltage specified
in the “Table I “ between the terminals connected together with the block for about 60 seconds.
The resistor shall be able to withstand without breakdown or flashover.
1.
Temperature Coefficient Test
Page-6
Test of resistors above room temperature 100°C ± 2°C ( Testing Temperature 115°C to 130°C ) at the
constant temperature silicon plate for over 5 minutes. Then measure the resistance value.
The Temperature Coefficient is calculated by the following equation and its value should be within the
range of requested.
Re sistor Temperatur e Coefficien t =
R
R0
t
to
1.
R - R0
1
´ 10 6
R0
t - t0
= Resistance value under the testing temperature
= Resistance value at the room temperature
= The testing temperature
= Room temperature
Insulation Resistance
Apply “measuring voltage” between protective coating and termination for 1 min.,then measure. The
measuring voltage shall be either 100V±15V d.c. for resistors with an insulation voltage lower than 500V
or 500V±50V d.c. for resistors with an insulatin voltage equal to or greater than 500V.
The test resistance should be high than 10,000M ohm.
1.
Solderability
Immerse the specimen into the solder pot at 245 ± 5 °C for 3 ± 0.5 seconds.
At least 95% solder coverage on the termination.
1.
Solvent Resistance of Marking
The specimen into the appropriate solvent of IPA condition of ultrasonic machine for 5± 0.5 minutes.
The specimen is no deterioration of coatings and color code
1.
Robustness of Terminations
Direct Load – Resistors shall be held by one terminal and the load shall be gradually applied in the
direction of the longitudinal axis of the resistor unit the applied load reached the requirement.
The load shall be held for 10 seconds. The load of weight shall be ≧ 2.5 kg ( 24.5N ).
1.
Periodic-Pulse Overload
Apply 4 times of rated voltage to the specimen at the 1 second on and 25 seconds off cycle, subjected
to voltage application cycles specified in 10,000 time.
The change of the resistance value shall be within ± 1.0% + 0.05 Ω
1.
Damp Heat Steady State
Place the specimen in a test chamber at 40 ± 2 °C and 90 ~ 95 % relative humidity. Apply the 0.1 times
rated voltage to the specimen at the 1.5 hours on and 0.5 hour off cycle. The total length of test is 56
days.
The change of the resistance value shall be within ± 5.0 % + 0.05 Ω
1.
Endurance at 70 °C
Placed in the constant temperature chamber of 70 ± 3 °C the resistor shall be connected to the lead wire
at the point of 25mm. Length with each terminal, the resistors shall be arranged not much effected
mutually by the temperature of the resistors and the excessive ventilation shall not be performed, for 90
minutes on and 30 minutes off under this condition the rated D.C. voltage is applied continuously for
1000+48/-0 hours then left at no-load for 1hour, measured at this time the resistance value。
The change of the resistance value shall be within ± 5.0 % + 0.05 Ω.
There shall be no remarkable change in the appearance and the color code shall be legible after the test..
Page-7
(11) Temperature Cycling Test
The temperature cycle shown in the following table shall be repeated 5 times consecutively. The
measurement of the resistance value is done before the first cycle and after ending the fifth cycle,
leaving in the room temperature for about 1 hour.
Temperature Cycling Conditions:
Step
Temperature(°C)
Time (minute)
1
-55 ± 3
30
2
25 ± 3
2~3
3
155 ± 3
30
4
25 ± 3
2~3
The change of the resistance value shall be within ± 1.0 % + 0.05 Ω
After the test the resistor shall be free from the electrical or mechanical damage.
(12) Resistance to Soldering Heat
The terminal lead shall be dipped into the solder pot at 260 ± 3 °C for 10 ± 1.0 seconds up to 2.5 ~ 3.5
mm.
(13) Accidental Overload Test (Only for silicone lacquer type)
At 4 times of the rated voltage or the maximum load voltage, whichever is the less, applied for 1 minute
Overload Test Voltage =
4 * Power Rating ´ Resistance Value
The resistor shall be able to no evidence of flaming arcing.
1. PACKING METHODS
Bandolier for Axial leads
STYLE
Normal
Miniature
a
HHV-25
HHV50S
6 ± 0.5
HHV-50
HHV1SS
6 ± 0.5
HHV1WS
HHV2SS
6 ± 0.5
HHV2WS
HHV3SS
6 ± 0.5
DIMENIONS
A
B1-B2
52.4 ± 1.0
1.2
26.0 ± 1.0
1.0
Unit::mm
S (spacing) T (max. deviation of spacing)
5
52.4 ± 1.0
73.0 ± 1.5
1.2
1.5
5
52.4 ± 1.0
73.0 ± 1.5
52.4 ± 1.0
1.2
1.5
1.2
5
Page-8
10
1 mm per 10 spacing
0.5 mm per 5 spacing
1. TAPE ON REEL PACKING
STYLE
1.
TAPE ON REEL
Normal
Miniature
A
B
Qty per reel
HHV-25
HHV50S
40/66.5
49/75.5
5,000
HHV-50
HHV1SS
66.5
75.5
2,500
HHV1WS
HHV2SS
87
96
2,000
HHV2WS
HHV3SS
87
96
1,000
TAPE ON BOX PACKING
STYLE
Standard Lead Length
Short Lead Length
Unit: mm
Qty per box
Normal
Miniature
W(A)
H(B)
L(C)
W(A)
H(B)
L(C)
HHV-25
HHV50S
81
104
260
48
102
255
HHV-50
HHV1SS
73
45
258
HHV1WS
HHV2SS
103
78
260
81
91
260
1,000
HHV2WS
HHV3SS
103
94
260
81
91
260
1,000
Page-9
5,000
1,000
11. SPECIAL TYPE (FORMING DIMENSIONS)
M TYPE
STYLE
DIMENSIONS
UNIT:mm
Normal
Miniature
L
Ψd
ψd
P
H
HHV-25
HHV50S
6.3 ± 0.5
2.4 ± 0.2
0.55 ± 0.05
10.0 ± 1
10.0 ± 1
HHV-50
HHV1SS
9.0 ± 0.5
3.3± 0.3
0.55 ± 0.05
12.5 ± 1
10.0 ± 1
HHV1WS
HHV2SS
11.5 ± 1.0
4.5 ± 0.5
0.8 ± 0.05
15.0 ± 1
12.5 ± 1
HHV2WS
HHV3SS
15.5 ± 1.0
5.0 ± 0.5
0.8 ± 0.05
20.0 ± 1
15.0 ± 1
MB TYPE
STYLE
DIMENSIONS
UNIT:mm
Normal
Miniature
L
Ψd
ψd
P
H1
H2
t
HHV-25
HHV50S
6.3 ± 0.5
2.4± 0.2
0.55 ± 0.05
10.0 ± 1
6.0 ± 1
5.0 ± 1
1.2 ± 0.2
HHV-50
HHV1SS
9.0 ± 0.5
3.3± 0.3
0.8± 0.05
12.5 ± 1
6.0 ± 1
5.0 ± 1
1.4± 0.2
HHV1WS
HHV2SS
11.5 ± 1.0
4.5 ± 0.5
0.8 ± 0.05
15.0 ± 1
6.0 ± 1
5.0 ± 1
1.4 ± 0.2
HHV2WS
HHV3SS
15.5 ± 1.0
5.0 ± 0.5
0.8 ± 0.05
20.0 ± 1
10.0 ± 1
5.0 ± 1
1.4 ± 0.2
Page-10
F TYPE
UNIT:mm
DIMENSIONS
STYLE
Normal
Miniature
L
Ψd
ψd
P
h1
H1 max
E max
HHV-50
HHV1SS
9.0 ± 0.5
3.3± 0.3
0.55± 0.05
6.0 ± 1
5.0 ± 1
18.5
3.5
HHV1WS
HHV2SS
11.5 ± 1.0
4.5 ± 0.5
0.8 ± 0.05
6.0 ± 1
5.0 ± 1
HHV2WS
HHV3SS
15.5 ± 1.0
5.0 ± 0.5
0.8 ± 0.05
8.0 ± 1
5.0 ± 1
25
3.5
STYLE
UNIT:mm
DIMENSIONS
Normal
Miniature
L
ψD
ψd
P
h
H max
E max
HHV-50
HHV1SS
9.0 ± 0.5
3.3± 0.3
0.55± 0.05
6.0 ± 1
8.0 ± 1
22
3.5
HHV1WS
HHV2SS
11.5 ± 1.0
4.5 ± 0.5
0.8 ± 0.05
6.0 ± 1
8.0 ± 1
24
3.5
HHV2WS
HHV3SS
15.5 ± 1.0
5.0 ± 0.5
0.8 ± 0.05
8.0 ± 1
8.0 ± 1
28
3.5
Page-11
PN Type Forming for Taping (rated watts from 1/4W to 2SS size only)
AV Type Forming for Taping (rated watts from 1/4W to 2SS size only)
12. Plant Address
A.
China Dongguan Plant
7-1, Gaoli Road, Gaoli Industrial Zone
Tangxia Zhen, Dongguan, Guangdong, China
(廣東省東莞市塘廈鎮高麗工業區高麗路 7-1 號)
Tel. 86-769-8772 0275
Fax. 86-769-8772 0275 #4333
B.
China Mudu Plant
No.158, Jinchang Road, No.1 Building of NanBangIND.Zone,
Mu Du New District, Suzhou, China
(江蘇省蘇州市木瀆新區金長路 158 號南濱工業區 1 號)
Tel. 86-512-66518889
Fax. 86-512-66519889
Page-12
