Hybrid Conductive Polymer Type / Radial Lead Type
RoHS指令対応品
RoHS compliance
125℃
HEP Series
High Voltage
125℃ 1,500~3,000時間
125℃ 2,000~3,000hours
耐洗浄品(2分間以内)
Solvent proof (within 2 minutes)
HET
HEP
HEPF
High Ripple
HEPZ
low
■ Specifications
Items
Rated voltage
Surge voltage
(V)
(V)
Category temperature range (℃)
Capacitance tolerance
Dissipation Factor(tanδ )
Leakage current(LC)
Endurance
Condition
Room temperature
120Hz/20℃
tanδ (max) 120Hz/20℃
μ A/after 2minutes (max)
16V
Test
25V≦
125℃
Δ C/C
rated voltage applied
(With the rated
tanδ
ripple current)
ESR
LC
16
135℃
High Cap.
Specifications
40
50
63
80
50
63
79
100
-55 to +125
M:±20
0.16
The greater value of either 0.05CV or 100
φ 6.3:2,000hours, D≧φ 8:2,500hours
φ 6.3:2,000hours, D≧φ 8:3,000hours
Within ±30% of the initial value
Less than 200% of the specified value
Less than the specified value
25
32
35
44
100
125
■ Marking, Dimensions
(Unit:mm)
Polarity (Cathode)
Lot No.
84T
33
63P
Rated Capacitance
Series Symbol
Rated Voltage
φD
L
F
φd
6.3
7.2
2.5
0.45
8
9.5
3.5
0.6
10
9.5
5.0
0.7
10
11.5
5.0
0.7
■ Size, ESR, Rated Ripple Current
V
μ F
27
47
56
68
100
120
150
220
270
330
470
560
16
10
12
15
18
22
33
47
56
82
6.3×7.2
40
8×9.5
26
1540
21
15
2010
2320
45
980
8×9.5
27
1330
10×9.5
10×11.5
22
16
1520
1740
100
740
50
6.3×7.2
80
840
8×9.5
35
1170
8×9.5
30
1260
23
17
1480
1700
10×9.5
10×11.5
25
19
1390
1590
40
40
30
30
22
Case size ; φ D×L(mm)
870
32
1220
10×9.5
10×11.5
24
18
1440
1650
70
70
50
100
900
900
1100
10×9.5
10×9.5
10×11.5
80
80
60
870
870
1000
1090
1090
1260
1260
1440
Rated ripple current
mArms(100kHz, 125℃)
63 HE P 33 M S T
Sn plating terminal option
Rated capacitance code
Series code
Type code
Rated voltage
70
8×9.5
80
10×9.5
10×9.5
10×11.5
8×9.5
8×9.5※
10×9.5
10×9.5
10×11.5
6.3×7.2
910
10×9.5
10×11.5
63
6.3×7.2
63 HE P 33 M T
6.3×7.2
60
40
1160
10×9.5
10×11.5
ESR (mΩ )
max at 100kHz,20℃
35
6.3×7.2
V
μ F
25
※S type
S type code
Series code
Type code
Rated voltage
Web
很抱歉,暂时无法提供与“63HEP56MT”相匹配的价格&库存,您可以联系我们找货
