C823A102J40C350
C823A102J40C350
    FARATRONIC(法拉)
    Radial
    薄膜电容 径向
C823A102J40C350 数据手册
 MMKP82 Double sided metallized polypropylene film capacitor (Box-type) ■ Outline Drawing W±0.4, H±0.4, T±0.4 ■ Features ● Double sided metallized polypropylene structure ● Low loss and small inherent temperature rise ● Negative temperature coefficient of capacitance ● Excellent active and passive flame resistant abilities ■ Typical Application ● Widely used in high voltage, high frequency and pulse circuit ● Electronic ballasts and compact lamps ● SNUBBER and SCR commutating circuits ■ Specifications Reference Standard Climatic Category Rated Temperature Operating Temperature Range GB/T 10190 (IEC 60384-16) 40/105/56 85℃ for UR (dc); 75℃ for UR (ac) -40℃~105℃ (+85℃ to +105℃: decreasing factor 1.25% per ℃ for UR (dc)) (+75℃ to +105℃: decreasing factor 1.35% per ℃ for UR (ac)) Rated Voltage 250V, 400V, 630V, 1 000V, 1 600V, 2 000V Capacitance Range Capacitance Tolerance Voltage Proof Dissipation Factor 0.00022F~3.9F 2 (G), 3 (H), 5 (J), 10 (K), 20 (M) 1.60UR (5s) ≤10×10-4 (1kHz, 20℃) Insulation Resistance R≥100 000M , CN≤0.33μF RCN≥30 000s, CN>0.33μF Maximum Pulse Rise Time(dV/dt): If the working voltage(U) is lower than the rated voltage(UR),the capacitor can be worked at a higher dV/dt. In this case, the maximum allowed dV/dt is obtain by multiplying the right value with U R/ U. UR(V) 250 400 630 1 000 1 600 2 000 P=7.5 1 200 1 800 3 200 6 000 --- P=10.0 1 000 1 500 3 200 6 000 --- (20℃, 100V,1min) dV/dt(V/us) P=15.0 P=22.5 550 250 900 500 2 500 1 500 3 300 2 100 6 000 3 000 10 000 5 000 P=27.5 200 300 900 1 000 2 000 2 200  MMKP82 ■ Part number system The 18 digits part number is formed as follow: 1 2 3 C 8 2 Digit 1 to 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 Series code C82=MMKP82 Digit 4 to 5 D.C. rated voltage 2E=250V 2G=400V 2J=630V 3A=1000V 3C=1600V 3D=2000V Digit 6 to 8 Rated capacitance value For example : 103=10×103 pF= 0.01μF Digit 9 Capacitance tolerance G=±2%, H=±3% J=±5%, K=±10%, M=±20% Digit 10 Pitch 3=7.5mm 4=10mm 6=15mm 9=22.5mm B=27.5mm Digit 11 Internal use Digit 12 to 15 Lead form and packaging code Digit 16 to 18 Internal use Table1 Lead form and packaging code Digit 12 Digit 13 Digit 14 code explanation code explanation code A ammo-pack 3 4 6 F=7.5mm F=10.0mm F=15.0mm 0 C straight lead “C” in the figure above code 00 45 35 32 explanation standard lead length (18mm~26mm) lead length 4.5mm lead length 3.5mm lead length 3.2mm explanation straight Digit 15 code explanation 1 Each cap. among two consecutive holes P3=12.7mm,H=18.5mm (For pitch=7.5mm) 5 P3=25.4mm;H=18.5mm (For pitch=10/15mm) 0 Length tolerance ±0.5mm Or standard length 2 Length tolerance ±0.3mm  MMKP82 ■ Dimensions(mm) 250Vdc(180Vac) 250Vdc(180Vac) CN (F) W ±0.4 H ±0.4 T ±0.4 P ±0.4 d ±0.05 Part number CN (F) W ±0.4 H ±0.4 T ±0.4 P ±0.4 d ±0.05 Part number 0.0068 10.5 9.0 4.0 7.5 0.6 C822E682-30****+++ 0.22 26.5 15.0 6.0 22.5 0.8 C822E224-90****+++ 0.0082 10.5 9.0 4.0 7.5 0.6 C822E822-30****+++ 0.27 26.5 15.0 6.0 22.5 0.8 C822E274-90****+++ 0.010 10.5 9.0 4.0 7.5 0.6 C822E103-30****+++ 0.33 26.5 15.0 6.0 22.5 0.8 C822E334-90****+++ 0.012 10.5 9.0 4.0 7.5 0.6 C822E123-30****+++ 0.39 26.5 16.0 7.0 22.5 0.8 C822E394-90****+++ 0.015 10.5 9.0 4.0 7.5 0.6 C822E153-30****+++ 0.47 26.5 16.0 7.0 22.5 0.8 C822E474-90****+++ 0.018 10.5 9.0 4.0 7.5 0.6 C822E183-30****+++ 0.56 26.5 17.0 8.5 22.5 0.8 C822E564-90****+++ 0.022 10.5 9.0 4.0 7.5 0.6 C822E223-30****+++ 0.68 26.5 18.5 10.0 22.5 0.8 C822E684-90****+++ 0.027 10.5 11.0 5.0 7.5 0.6 C822E273-30****+++ 0.82 26.5 18.5 10.0 22.5 0.8 C822E824-90****+++ 0.033 10.5 11.0 5.0 7.5 0.6 C822E333-30****+++ 1.0 26.5 22.0 12.0 22.5 0.8 C822E105-90****+++ 0.039 10.5 12.0 6.0 7.5 0.6 C822E393-30****+++ 0.82 32.0 18.0 9.0 27.5 0.8 C822E824-B0****+++ 0.047 10.5 12.0 6.0 7.5 0.6 C822E473-30****+++ 1.0 32.0 20.0 11.0 27.5 0.8 C822E105-B0****+++ 0.027 13.0 9.0 4.0 10.0 0.6 C822E273-40****+++ 1.2 32.0 20.0 11.0 27.5 0.8 C822E125-B0****+++ 0.033 13.0 9.0 4.0 10.0 0.6 C822E333-40****+++ 1.5 32.0 22.0 13.0 27.5 0.8 C822E155-B0****+++ 0.039 13.0 9.0 4.0 10.0 0.6 C822E393-40****+++ 1.8 32.0 24.5 15.0 27.5 0.8 C822E185-B0****+++ 0.047 13.0 11.0 5.0 10.0 0.6 C822E473-40****+++ 2.2 32.0 24.5 15.0 27.5 0.8 C822E225-B0****+++ 0.056 13.0 11.0 5.0 10.0 0.6 C822E563-40****+++ 2.7 32.0 33.0 18.0 27.5 0.8 C822E275-B0****+++ 0.068 13.0 12.0 6.0 10.0 0.6 C822E683-40****+++ 3.3 32.0 33.0 18.0 27.5 0.8 C822E335-B0****+++ 0.082 13.0 12.0 6.0 10.0 0.6 C822E823-40****+++ 3.9 32.0 33.0 18.0 27.5 0.8 C822E395-B0****+++ 0.068 17.5 11.0 5.0 15.0 0.8 C822E683-60****+++ 0.082 17.5 11.0 5.0 15.0 0.8 C822E823-60****+++ 0.10 17.5 11.0 5.0 15.0 0.8 C822E104-60****+++ 0.12 17.5 12.0 6.0 15.0 0.8 C822E124-60****+++ 0.15 17.5 12.0 6.0 15.0 0.8 C822E154-60****+++ 0.18 17.5 13.5 7.5 15.0 0.8 C822E184-60****+++ 0.22 17.5 13.5 7.5 15.0 0.8 C822E224-60****+++ 0.27 17.5 14.5 8.5 15.0 0.8 C822E274-60****+++ 0.33 17.5 16.0 10.0 15.0 0.8 C822E334-60****+++ 0.39 17.5 16.0 10.0 15.0 0.8 C822E394-60****+++ Note: 1. “-”=capacitance tolerance code, M=±20%,K=±10%,J=±5%, H=±3%, G=±2% 2. “****”=lead form and packaging code (refer to table 1)  MMKP82 ■ Dimensions(mm) 400Vdc(250Vac)@ 400Vdc(250Vac)@ CN (F) W ±0.4 H ±0.4 T ±0.4 P ±0.4 d ±0.05 Part number CN (F) W ±0.4 H ±0.4 T ±0.4 P ±0.4 d ±0.05 Part number 0.0027 10.5 9.0 4.0 7.5 0.6 C822G272-30****+++ 0.033 17.5 11.0 5.0 15.0 0.8 C822G333-60****+++ 0.0033 10.5 9.0 4.0 7.5 0.6 C822G332-30****+++ 0.039 17.5 11.0 5.0 15.0 0.8 C822G393-60****+++ 0.0039 10.5 9.0 4.0 7.5 0.6 C822G392-30****+++ 0.047 17.5 11.0 5.0 15.0 0.8 C822G473-60****+++ 0.0047 10.5 9.0 4.0 7.5 0.6 C822G472-30****+++ 0.056 17.5 11.0 5.0 15.0 0.8 C822G563-60****+++ 0.0056 10.5 9.0 4.0 7.5 0.6 C822G562-30****+++ 0.068 17.5 12.0 6.0 15.0 0.8 C822G683-60****+++ 0.0068 10.5 9.0 4.0 7.5 0.6 C822G682-30****+++ 0.082 17.5 12.0 6.0 15.0 0.8 C822G823-60****+++ 0.0082 10.5 9.0 4.0 7.5 0.6 C822G822-30****+++ 0.10 17.5 13.5 7.5 15.0 0.8 C822G104-60****+++ 0.010 10.5 9.0 4.0 7.5 0.6 C822G103-30****+++ 0.12 17.5 13.5 7.5 15.0 0.8 C822G124-60****+++ 0.012 10.5 9.0 4.0 7.5 0.6 C822G123-30****+++ 0.15 17.5 14.5 8.5 15.0 0.8 C822G154-60****+++ 0.015 10.5 11.0 5.0 7.5 0.6 C822G153-30****+++ 0.18 17.5 16.0 10.0 15.0 0.8 C822G184-60****+++ 0.018 10.5 11.0 5.0 7.5 0.6 C822G183-30****+++ 0.22 17.5 16.0 10.0 15.0 0.8 C822G224-60****+++ 0.022 10.5 12.0 6.0 7.5 0.6 C822G223-30****+++ 0.27 17.5 19.0 11.0 15.0 0.8 C822G274-60****+++ 0.027 10.5 12.0 6.0 7.5 0.6 C822G273-30****+++ 0.12 26.5 15.0 6.0 22.5 0.8 C822G124-90****+++ 0.010 13.0 9.0 4.0 10.0 0.6 C822G103-40****+++ 0.15 26.5 15.0 6.0 22.5 0.8 C822G154-90****+++ 0.012 13.0 9.0 4.0 10.0 0.6 C822G123-40****+++ 0.18 26.5 15.0 6.0 22.5 0.8 C822G184-90****+++ 0.015 13.0 9.0 4.0 10.0 0.6 C822G153-40****+++ 0.22 26.5 16.0 7.0 22.5 0.8 C822G224-90****+++ 0.018 13.0 9.0 4.0 10.0 0.6 C822G183-40****+++ 0.27 26.5 17.0 8.5 22.5 0.8 C822G274-90****+++ 0.022 13.0 9.0 4.0 10.0 0.6 C822G223-40****+++ 0.33 26.5 17.0 8.5 22.50 0.8 C822G334-90****+++ 0.027 13.0 11.0 5.0 10.0 0.6 C822G273-40****+++ 0.39 26.5 18.5 10.0 22.5 0.8 C822G394-90****+++ 0.033 13.0 11.0 5.0 10.0 0.6 C822G333-40****+++ 0.47 26.5 18.5 10.0 22.5 0.8 C822G474-90****+++ 0.039 13.0 12.0 6.0 10.0 0.6 C822G393-40****+++ 0.56 26.5 22.0 12.0 22.5 0.8 C822G564-90****+++ 0.047 13.0 12.0 6.0 10.0 0.6 C822G473-40****+++ 0.68 26.5 22.0 12.0 22.5 0.8 C822G684-90****+++ 0.39 32.0 18.0 9.0 27.5 0.8 C822G394-B0****+++ 0.47 32.0 18.0 9.0 27.5 0.8 C822G474-B0****+++ 0.56 32.0 20.0 11.0 27.5 0.8 C822G564-B0****+++ 0.68 32.0 20.0 11.0 27.5 0.8 C822G684-B0****+++ 0.8 0.82 32.0 22.0 13.0 27.5 1.0 32.0 24.5 15.0 27.5 0.8 C822G105-B0****+++ 1.2 32.0 24.5 15.0 27.5 0.8 C822G125-B0****+++ 1.5 32.0 33.0 18.0 27.5 0.8 C822G155-B0****+++ 1.8 32.0 33.0 18.0 27.5 0.8 C822G185-B0****+++ Note: 1. “-”=capacitance tolerance code, M=±20%,K=±10%,J=±5%, H=±3%, G=±2% 2. “****”=lead form and packaging code (refer to table 1) 3. “@” Not suitable for across-the-line applications. Pls refer to the Interference Suppression Capacitor. C822G824-B0****+++  MMKP82 ■ Dimensions(mm) 630Vdc(400Vac) 630Vdc(400Vac) CN (F) W ±0.4 H ±0.4 T ±0.4 P ±0.4 d ±0.05 Part number CN (F) W ±0.4 H ±0.4 T ±0.4 P ±0.4 d ±0.05 Part number 0.00068 10.5 9.0 4.0 7.5 0.6 C822J681-30****+++ 0.039 17.5 12.0 6.0 15.0 0.8 C822J393-60****+++ 0.00082 10.5 9.0 4.0 7.5 0.6 C822J821-30****+++ 0.047 17.5 12.0 6.0 15.0 0.8 C822J473-60****+++ 0.0010 10.5 9.0 4.0 7.5 0.6 C822J102-30****+++ 0.056 17.5 13.5 7.5 15.0 0.8 C822J563-60****+++ 0.0012 10.5 9.0 4.0 7.5 0.6 C822J122-30****+++ 0.068 17.5 14.5 8.5 15.0 0.8 C822J683-60****+++ 0.0015 10.5 9.0 4.0 7.5 0.6 C822J152-30****+++ 0.082 17.5 14.5 8.5 15.0 0.8 C822J823-60****+++ 0.0018 10.5 9.0 4.0 7.5 0.6 C822J182-30****+++ 0.10 17.5 16.0 10.0 15.0 0.8 C822J104-60****+++ 0.0022 10.5 9.0 4.0 7.5 0.6 C822J222-30****+++ 0.12 17.5 19.0 11.0 15.0 0.8 C822J124-60****+++ 0.0027 10.5 9.0 4.0 7.5 0.6 C822J272-30****+++ 0.047 26.5 15.0 6.0 22.5 0.8 C822J473-90****+++ 0.0033 10.5 9.0 4.0 7.5 0.6 C822J332-30****+++ 0.056 26.5 15.0 6.0 22.5 0.8 C822J563-90****+++ 0.0039 10.5 9.0 4.0 7.5 0.6 C822J392-30****+++ 0.068 26.5 15.0 6.0 22.5 0.8 C822J683-90****+++ 0.0047 10.5 9.0 4.0 7.5 0.6 C822J472-30****+++ 0.082 26.5 15.0 6.0 22.5 0.8 C822J823-90****+++ 0.0056 10.5 9.0 4.0 7.5 0.6 C822J562-30****+++ 0.10 26.5 15.0 6.0 22.5 0.8 C822J104-90****+++ 0.0068 10.5 11.0 5.0 7.5 0.6 C822J682-30****+++ 0.12 26.5 16.0 7.0 22.5 0.8 C822J124-90****+++ 0.0082 10.5 11.0 5.0 7.5 0.6 C822J822-30****+++ 0.15 26.5 17.0 8.5 22.5 0.8 C822J154-90****+++ 0.010 10.5 12.0 6.0 7.5 0.6 C822J103-30****+++ 0.18 26.5 17.0 8.5 22.5 0.8 C822J184-90****+++ 0.012 10.5 12.0 6.0 7.5 0.6 C822J123-30****+++ 0.22 26.5 18.5 10.0 22.5 0.8 C822J224-90**** +++ 0.0039 13.0 9.0 4.0 10.0 0.6 C822J392-40****+++ 0.27 26.5 22.0 12.0 22.5 0.8 C822J274-90****+++ 0.0047 13.0 9.0 4.0 10.0 0.6 C822J472-40****+++ 0.33 26.5 22.0 12.0 22.5 0.8 C822J334-90****+++ 0.0056 13.0 9.0 4.0 10.0 0.6 C822J562-40****+++ 0.39 26.5 22.0 12.0 22.5 0.8 C822J394-90****+++ 0.0068 13.0 9.0 4.0 10.0 0.6 C822J682-40****+++ 0.15 32.0 18.0 9.0 27.5 0.8 C822J154-B0****+++ 0.0082 13.0 9.0 4.0 10.0 0.6 C822J822-40****+++ 0.18 32.0 18.0 9.0 27.5 0.8 C822J184-B0****+++ 0.010 13.0 11.0 5.0 10.0 0.6 C822J103-40****+++ 0.22 32.0 18.0 9.0 27.5 0.8 C822J224-B0****+++ 0.012 13.0 11.0 5.0 10.0 0.6 C822J123-40****+++ 0.27 32.0 18.0 9.0 27.5 0.8 C822J274-B0****+++ 0.015 13.0 12.0 6.0 10.0 0.6 C822J153-40****+++ 0.33 32.0 20.0 11.0 27.5 0.8 C822J334-B0****+++ 0.018 13.0 12.0 6.0 10.0 0.6 C822J183-40****+++ 0.39 32.0 20.0 11.0 27.5 0.8 C822J394-B0****+++ 0.012 17.5 11.0 5.0 15.0 0.8 C822J123-60****+++ 0.47 32.0 22.0 13.0 27.5 0.8 C822J474-B0****+++ 0.015 17.5 11.0 5.0 15.0 0.8 C822J153-60****+++ 0.56 32.0 22.0 13.0 27.5 0.8 C822J564-B0****+++ 0.018 17.5 11.0 5.0 15.0 0.8 C822J183-60****+++ 0.68 32.0 24.5 15.0 27.5 0.8 C822J684-B0****+++ 0.022 17.5 11.0 5.0 15.0 0.8 C822J223-60****+++ 0.82 32.0 28.0 14.0 27.5 0.8 C822J824-B0****+++ 0.027 17.5 11.0 5.0 15.0 0.8 C822J273-60****+++ 1.0 32.0 33.0 18.0 27.5 0.8 C822J105-B0****+++ 0.033 17.5 12.0 6.0 15.0 0.8 C822J333-60****+++ 1.2 32.0 33.0 18.0 27.5 0.8 C822J125-B0****+++ Note: 1. “-”=capacitance tolerance code, M=±20%,K=±10%,J=±5%, H=±3%, G=±2% 2. “****”=lead form and packaging code (refer to table 1)  MMKP82 ■ Dimensions(mm) 1 000Vdc(600Vac) 1 000Vdc(600Vac) CN (F) W ±0.4 H ±0.4 T ±0.4 P ±0.4 d ±0.05 Part number CN (F) W ±0.4 H ±0.4 T ±0.4 P ±0.4 d ±0.05 Part number 0.00047 10.5 9.0 4.0 7.5 0.6 C823A471-30****+++ 0.0082 17.5 11.0 5.0 15.0 0.8 C823A822-60****+++ 0.00056 10.5 9.0 4.0 7.5 0.6 C823A561-30****+++ 0.010 17.5 11.0 5.0 15.0 0.8 C823A103-60****+++ 0.00068 10.5 9.0 4.0 7.5 0.6 C823A681-30****+++ 0.012 17.5 11.0 5.0 15.0 0.8 C823A123-60****+++ 0.00082 10.5 9.0 4.0 7.5 0.6 C823A821-30****+++ 0.015 17.5 11.0 5.0 15.0 0.8 C823A153-60****+++ 0.0010 10.5 9.0 4.0 7.5 0.6 C823A102-30****+++ 0.018 17.5 13.5 7.5 15.0 0.8 C823A183-60****+++ 0.0012 10.5 11.0 5.0 7.5 0.6 C823A122-30****+++ 0.022 17.5 13.5 7.5 15.0 0.8 C823A223-60****+++ 0.0015 10.5 11.0 5.0 7.5 0.6 C823A152-30****+++ 0.027 17.5 14.5 8.5 15.0 0.8 C823A273-60****+++ 0.0018 10.5 11.0 5.0 7.5 0.6 C823A182-30****+++ 0.033 17.5 14.5 8.5 15.0 0.8 C823A333-60****+++ 0.0022 10.5 11.0 5.0 7.5 0.6 C823A222-30****+++ 0.039 17.5 16.0 10.0 15.0 0.8 C823A393-60****+++ 0.0027 10.5 12.0 6.0 7.5 0.6 C823A272-30****+++ 0.047 17.5 19.0 11.0 15.0 0.8 C823A473-60****+++ 0.0033 10.5 12.0 6.0 7.5 0.6 C823A332-30****+++ 0.027 26.5 15.0 6.0 22.5 0.8 C823A273-90****+++ 0.0010 13.0 9.0 4.0 10.0 0.6 C823A102-40****+++ 0.033 26.5 15.0 6.0 22.5 0.8 C823A333-90****+++ 0.0012 13.0 9.0 4.0 10.0 0.6 C823A122-40****+++ 0.039 26.5 15.0 6.0 22.5 0.8 C823A393-90****+++ 0.0015 13.0 9.0 4.0 10.0 0.6 C823A152-40****+++ 0.047 26.5 16.0 7.0 22.5 0.8 C823A473-90****+++ 0.0018 13.0 9.0 4.0 10.0 0.6 C823A182-40****+++ 0.056 26.5 16.0 7.0 22.5 0.8 C823A563-90****+++ 0.0022 13.0 9.0 4.0 10.0 0.6 C823A222-40****+++ 0.068 26.5 17.0 8.5 22.5 0.8 C823A683-90****+++ 0.0027 13.0 9.0 4.0 10.0 0.6 C823A272-40****+++ 0.082 26.5 18.5 10.0 22.5 0.8 C823A823-90****+++ 0.0033 13.0 9.0 4.0 10.0 0.6 C823A332-40****+++ 0.10 26.5 18.5 10.0 22.5 0.8 C823A104-90****+++ 0.0039 13.0 11.0 5.0 10.0 0.6 C823A392-40****+++ 0.12 26.5 22.0 12.0 22.5 0.8 C823A124-90****+++ 0.0047 13.0 11.0 5.0 10.0 0.6 C823A472-40****+++ 0.15 26.5 22.0 12.0 22.5 0.8 C823A154-90****+++ 0.0056 13.0 12.0 6.0 10.0 0.6 C823A562-40****+++ 0.10 32.0 18.0 9.0 27.5 0.8 C823A104-B0****+++ 0.0068 13.0 12.0 6.0 10.0 0.6 C823A682-40****+++ 0.12 32.0 20.0 11.0 27.5 0.8 C823A124-B0****+++ 0.15 32.0 20.0 11.0 27.5 0.8 C823A154-B0****+++ 0.18 32.0 22.0 13.0 27.5 0.8 C823A184-B0****+++ 0.22 32.0 22.0 13.0 27.5 0.8 C823A224-B0****+++ 0.27 32.0 24.5 15.0 27.5 0.8 C823A274-B0****+++ 0.33 32.0 28.0 14.0 27.5 0.8 C823A334-B0****+++ 0.39 32.0 33.0 18.0 27.5 0.8 C823A394-B0****+++ 0.47 32.0 33.0 18.0 27.5 0.8 C823A474-B0****+++ Note: 1. “-”=capacitance tolerance code, M=±20%,K=±10%,J=±5%, H=±3%, G=±2% 2. “****”=lead form and packaging code (refer to table 1)  MMKP82 ■ Dimensions(mm) 1 600Vdc(650Vac) 1 600Vdc(650Vac) CN (F) W ±0.4 H ±0.4 T ±0.4 P ±0.4 d ±0.05 Part number CN (F) W ±0.4 H ±0.4 T ±0.4 P ±0.4 d ±0.05 Part number 0.00068 17.5 11.0 5.0 15.0 0.8 C823C681-60****+++ 0.015 26.5 15.0 6.0 22.5 0.8 C823C153-90****+++ 0.00082 17.5 11.0 5.0 15.0 0.8 C823C821-60****+++ 0.018 26.5 15.0 6.0 22.5 0.8 C823C183-90****+++ 0.0010 17.5 11.0 5.0 15.0 0.8 C823C102-60****+++ 0.022 26.5 15.0 6.0 22.5 0.8 C823C223-90****+++ 0.0012 17.5 11.0 5.0 15.0 0.8 C823C122-60****+++ 0.027 26.5 15.0 6.0 22.5 0.8 C823C273-90****+++ 0.0015 17.5 11.0 5.0 15.0 0.8 C823C152-60****+++ 0.033 26.5 16.0 7.0 22.5 0.8 C823C333-90****+++ 0.0018 17.5 11.0 5.0 15.0 0.8 C823C182-60****+++ 0.039 26.5 17.0 8.5 22.5 0.8 C823C393-90****+++ 0.0022 17.5 11.0 5.0 15.0 0.8 C823C222-60****+++ 0.047 26.5 18.5 10.0 22.5 0.8 C823C473-90****+++ 0.0027 17.5 11.0 5.0 15.0 0.8 C823C272-60****+++ 0.056 26.5 18.5 10.0 22.5 0.8 C823C563-90****+++ 0.0033 17.5 11.0 5.0 15.0 0.8 C823C332-60****+++ 0.068 26.5 22.0 12.0 22.5 0.8 C823C683-90****+++ 0.0039 17.5 11.0 5.0 15.0 0.8 C823C392-60****+++ 0.082 26.5 22.0 12.0 22.5 0.8 C823C823-90****+++ 0.0047 17.5 11.0 5.0 15.0 0.8 C823C472-60****+++ 0.039 32.0 18.0 9.0 27.5 0.8 C823C393-B0****+++ 0.0056 17.5 11.0 5.0 15.0 0.8 C823C562-60****+++ 0.047 32.0 18.0 9.0 27.5 0.8 C823C473-B0****+++ 0.0068 17.5 11.0 5.0 15.0 0.8 C823C682-60****+++ 0.056 32.0 18.0 9.0 27.5 0.8 C823C563-B0****+++ 0.0082 17.5 12.0 6.0 15.0 0.8 C823C822-60****+++ 0.068 32.0 18.0 9.0 27.5 0.8 C823C683-B0****+++ 0.010 17.5 12.0 6.0 15.0 0.8 C823C103-60****+++ 0.082 32.0 20.0 11.0 27.5 0.8 C823C823-B0****+++ 0.012 17.5 13.5 7.5 15.0 0.8 C823C123-60****+++ 0.10 32.0 20.0 11.0 27.5 0.8 C823C104-B0****+++ 0.015 17.5 13.5 7.5 15.0 0.8 C823C153-60****+++ 0.12 32.0 22.0 13.0 27.5 0.8 C823C124-B0****+++ 0.018 17.5 14.5 8.5 15.0 0.8 C823C183-60****+++ 0.15 32.0 24.5 15.0 27.5 0.8 C823C154-B0****+++ 0.022 17.5 14.5 8.5 15.0 0.8 C823C223-60****+++ 0.18 32.0 24.5 15.0 27.5 0.8 C823C184-B0****+++ 0.027 17.5 16.0 10.0 15.0 0.8 C823C273-60****+++ 0.22 32.0 33.0 18.0 27.5 0.8 C823C224-B0****+++ 0.033 17.5 19.0 11.0 15.0 0.8 C823C333-60****+++ 0.27 32.0 33.0 18.0 27.5 0.8 C823C274-B0****+++ 0.33 32.0 33.0 18.0 27.5 0.8 C823C334-B0****+++ Note: 1. “-”=capacitance tolerance code, M=±20%, K=±10%,J=±5%, H=±3%, G=±2% 2. “****”=lead form and packaging code (refer to table 1)  MMKP82 ■ Dimensions(mm) 2 000Vdc(700Vac) 2 000Vdc(700Vac) CN (F) W ±0.4 H ±0.4 T ±0.4 P ±0.4 d ±0.05 Part number CN (F) W ±0.4 H ±0.4 T ±0.4 P ±0.4 d ±0.05 Part number 0.00022 17.5 11.0 5.0 15.0 0.8 C823D221-60****+++ 0.0010 26.5 15.0 6.0 22.5 0.8 C823D102-90****+++ 0.00027 17.5 11.0 5.0 15.0 0.8 C823D271-60****+++ 0.0012 26.5 15.0 6.0 22.5 0.8 C823D122-90****+++ 0.00033 17.5 11.0 5.0 15.0 0.8 C823D331-60**** +++ 0.0015 26.5 15.0 6.0 22.5 0.8 C823D152-90****+++ 0.00039 17.5 11.0 5.0 15.0 0.8 C823D391-60****+++ 0.0018 26.5 15.0 6.0 22.5 0.8 C823D182-90****+++ 0.00047 17.5 11.0 5.0 15.0 0.8 C823D471-60****+++ 0.0022 26.5 15.0 6.0 22.5 0.8 C823D222-90****+++ 0.00056 17.5 11.0 5.0 15.0 0.8 C823D561-60****+++ 0.0027 26.5 15.0 6.0 22.5 0.8 C823D272-90****+++ 0.00068 17.5 11.0 5.0 15.0 0.8 C823D681-60****+++ 0.0033 26.5 15.0 6.0 22.5 0.8 C823D332-90****+++ 0.00082 17.5 11.0 5.0 15.0 0.8 C823D821-60****+++ 0.0039 26.5 15.0 6.0 22.5 0.8 C823D392-90****+++ 0.0010 17.5 11.0 5.0 15.0 0.8 C823D102-60****+++ 0.0047 26.5 15.0 6.0 22.5 0.8 C823D472-90****+++ 0.0012 17.5 11.0 5.0 15.0 0.8 C823D122-60****+++ 0.0056 26.5 15.0 6.0 22.5 0.8 C823D562-90****+++ 0.0015 17.5 11.0 5.0 15.0 0.8 C823D152-60****+++ 0.0068 26.5 15.0 6.0 22.5 0.8 C823D682-90****+++ 0.0018 17.5 11.0 5.0 15.0 0.8 C823D182-60****+++ 0.0082 26.5 15.0 6.0 22.5 0.8 C823D822-90****+++ 0.0022 17.5 11.0 5.0 15.0 0.8 C823D222-60****+++ 0.010 26.5 15.0 6.0 22.5 0.8 C823D103-90****+++ 0.0027 17.5 11.0 5.0 15.0 0.8 C823D272-60****+++ 0.012 26.5 15.0 6.0 22.5 0.8 C823D123-90****+++ 0.0033 17.5 12.0 6.0 15.0 0.8 C823D332-60****+++ 0.015 26.5 16.0 7.0 22.5 0.8 C823D153-90****+++ 0.0039 17.5 12.0 6.0 15.0 0.8 C823D392-60****+++ 0.018 26.5 16.0 7.0 22.5 0.8 C823D183-90****+++ 0.0047 17.5 12.0 6.0 15.0 0.8 C823D472-60****+++ 0.022 26.5 17.0 8.5 22.5 0.8 C823D223-90****+++ 0.0056 17.5 13.5 7.5 15.0 0.8 C823D562-60****+++ 0.027 26.5 18.5 10.0 22.5 0.8 C823D273-90****+++ 0.0068 17.5 13.5 7.5 15.0 0.8 C823D682-60****+++ 0.033 26.5 18.5 10.0 22.5 0.8 C823D333-90****+++ 0.0082 17.5 14.5 8.5 15.0 0.8 C823D822-60****+++ 0.039 26.5 22.0 12.0 22.5 0.8 C823D393-90****+++ 0.010 17.5 16.0 10.0 15.0 0.8 C823D103-60****+++ 0.047 26.5 22.0 12.0 22.5 0.8 C823D473-90****+++ 0.012 17.5 16.0 10.0 15.0 0.8 C823D123-60****+++ 0.022 32.0 18.0 9.0 27.5 0.8 C823D223-B0****+++ 0.015 17.5 19.0 11.0 15.0 0.8 C823D153-60****+++ 0.027 32.0 18.0 9.0 27.5 0.8 C823D273-B0****+++ 0.033 32.0 18.0 9.0 27.5 0.8 C823D333-B0****+++ 0.039 32.0 20.0 11.0 27.5 0.8 C823D393-B0****+++ 0.047 32.0 20.0 11.0 27.5 0.8 C823D473-B0****+++ 0.056 32.0 22.0 13.0 27.5 0.8 C823D563-B0****+++ 0.068 32.0 22.0 13.0 27.5 0.8 C823D683-B0****+++ 0.082 32.0 24.5 15.0 27.5 0.8 C823D823-B0****+++ 0.10 32.0 28.0 14.0 27.5 0.8 C823D104-B0****+++ 0.12 32.0 33.0 18.0 27.5 0.8 C823D124-B0****+++ 0.15 32.0 33.0 18.0 27.5 0.8 C823D154-B0****+++ Note: 1. “-”=capacitance tolerance code, M=±20%,K=±10%,J=±5%, H=±3%, G=±2% 2. “****”=lead form and packaging code (refer to table 1)  MMKP82 ■ MAX. VOLTAGE(Vr.m.s) VERSUS FREQUENCY Note: sinusoidal wave-form, environment temperature≤85℃,internal temperature rise △ T=10℃, p (pitch) in mm..  MMKP82 ■ MAX. CURRENT(Ir.m.s) VERSUS FREQUENCY Note: sinusoidal wave-form,environment temperature≤85℃,internal temperature rise △ T=10℃, p (pitch) in mm.  MMKP82 ■ Test Method And Performance No. Item Performance 1 Solderability Initial measurement Test method(IEC 60384-16) Solder temperature: 245˚C 5˚C Immersion time: 2.0s0.5s Good quality of tinning Capacitance Tg: 1kHz,C1.0F 10kHz,C1.0F There shall be no visible damage Terminal strength 2 Resistance to solder heat Final measurement Initial measurement Rapid change of temperature Vibration There shall be no visible damage, legible marking C/C 2(relative to the initial value) Increase of tg: 0.002 (10kHz,C1.0μF) 0.002 (1kHz, C>1.0μF) Capacitance Tg(10kHz) There shall deterioration. There shall deterioration. be no evidence of be no evidence of 3 Bump Final measurement Initial measurement There shall be no evidence of deterioration. There shall be no visible damage C/C 2(relative to the initial value) Increase of tg: 0.002 (10kHz) IR:  50 of the rated value Capacitance Tg: 10kHz Climate sequence Amplitude 0.75mm or acceleration 98m/s2 (whichever is the smaller severity), f: 10Hz to 500Hz.Three directions, 2h for each direction, total 6h. 4 000 times, Acceleration: 390m/s2,Pulse duration, 6ms Test Db, Severity: b, the first cycle -40℃, 2h Cold 4 A=-40˚C, B =+105˚C 5 cycles Duration: t=30min +105℃, 16h Dry heat Damp heat, Cyclic Low air pressure Damp heat, cyclic other Final measurement Tense: 0.50d≤0.80, 10N 0.80d≤1.25, 20N Bend: 0.50d≤0.80, 5N 0.80d≤1.25, 10N The terminals shall be bent 2 times in each direction Solder temperature:260˚C5˚C Immersion time: 10s1s There shall be no permanent breakdown, flashover or other harmful deformation when applying UR at the last 1 minute. Applying UR for 1 minute after 15 minutes the test finished . There shall be no visible damage, legible marking C/C 3(relative to the initial value) Increase of tg:0.003(10kHz) I.R.:  50 of the rated value 15℃~35℃, 8.5kPa, 1h Test Db, Severity b, the other cycles,  MMKP82 No. 5 Item Damp heat steady state 6 Endurance 7 Temperature characteristic 8 9 Performance There shall be no visible damage, legible marking C/C 5(relative to the initial value) Increase of tg:0.002 (10kHz) I.R.:  50 of the rated value There shall be no visible damage, legible marking C/C 5(relative to the initial value) Increase of tg:0.0015 (10kHz) I.R.:  50 of the rated value Measuring capacitance at test point b, d, f: Characteristic at lower category temperature -40˚C: 0(Cb-Cd)/Cd+3 Characteristic at upper category temperature +105˚C: -4(Cf-Cd)/Cd0 I.R. (test at point f ): IR2500M CR≤0.33μF IR750s CR>0.33μF C/C 5(relative to the initial value) increase of tg:0.005 (10kHz) I.R.:  50 of the rated value Charging and discharging Passive flammability The flaming time of each capacitor shall not go beyond 30s after it is taken apart from the flame. Drop of each capacitor caused by flame shall not fire the tissue below Test method(IEC 60384-16) Temperature:40˚C 2˚C 2 Humidity: 93  3 %RH Duration: 56 days Temperature: +85℃ Voltage: 1.25×UR(50Hz) Duration: 1 000h Static method: The Capacitors should be kept at the following temperature in turn: a(20±2) ˚C, b(–40±3) ˚C, d(20±2) ˚C, f(105±2) ˚C, g(20±2) ˚C Times: 10 000 Duration of charging: 0.5s Duration of discharging: 0.5s Charging voltage: rated voltage UR Charging resistance: 220/CR() Discharging resistance: UR÷CR÷dV/dt() CR: rated capacitance (μF) dV/dt value: see page9 table IEC 695-2-2 Needle flame test The category of passive flammability: C , Expose time in flame : 1 time Capacitor volume Exposing time V250mm3 5s 250mm310mm Taping specification for box-type capacitors ▲ Outline Drawing Fig.2 P=10.0、15.0mm Fig.1 P=5.0、7.5mm ▲ Taping Dimensions(mm) Technology index title Code Taping type — Part number AmmoDigit12-15 pack Taping pitch P3 Feed hole pitch P0 ▲ Packing Quantity Dimensions P=5.0 P=7.5 P=10.0 P=15.0 Tolerance Fig 1 Fig 1 Fig2 Fig 2 A201 A301 A405 A605 12.7 12.7 12.7 12.7 25.4 12.7 25.4 12.7 ±1.0 ±0.2 —— Center of wire P1 3.85 2.6 7.7 5.2 ±0.7 Center of body Pitch of taping wire Component alignment Height of component from tape center P2 6.35 6.35 12.7 12.7 5.0 7.5 10.0 15.0 ±1.3 +0.6 -0.1 △S 0 0 0 0 ±2.0 H*** 18.5 18.5 18.5 18.5 ±0.5 W 18.0 18.0 18.0 18.0 +1.0 -0.5 W0 6min 10min 10min 10min —— W1 9.0 9.0 9.0 9.0 ±0.5 W2 3max 3max 3max 3max —— D0 t 4.0 0.7 4.0 0.7 4.0 0.7 4.0 0.9 ±0.2 ±0.2 Carrier tape width Hold down tape width Hole position Hold down tape sition Feed hole dia. Tape thickness ** F Pitch (mm) 5.0 7.5 10.0/ 15.0 15.0 Box thinkness T(mm) 2.5 3.5 4.5 5.0 6.0 3.5 4.0 5.0 6.0 4.0 5.0 6.0 7.5 8.5 10.0 11.0 Ammo-pack (pcs/box) Domestic Export 2500 1 700 1 400 1 200 1 000 2 000 1 500 1 300 1 000 800 1 700 1 500 1 200 1 000 750 600 500 400 350 300 250 1 500 1 300 1 000 800 650 500 450 350 300 250 200 Note: * P0=15mm is also available; **F can be other lead spacing; ***H=16.5mm is available;  MMKP82 ■ Packing box sizes(mm) 1. Out packing box for bulk 3. Box sizes for Ammo-pack 2. Inner packing box for bulk
C823A102J40C350 价格&库存
很抱歉,暂时无法提供与“C823A102J40C350”相匹配的价格&库存,您可以联系我们找货
