VEC3R0107QG
VEC3R0107QG
    VINATECH
    AEC_D22X45MM_TM
    超级电容器 AEC_D22X45MM_TM
VEC3R0107QG 数据手册
EDLC 3.0V 100F FEATURES Electric double layer capacitor Higher power density with ultra low ESR Semi-permanent, quick charge and discharge than batteries Suitable for short-term peak power assistance application UL and ISO/TS certificated, RoHS compliant Radial design with 2-pin snap-in terminal type 2015-12-01 DIMENSIONS Dimensions in mm L ± 2.0 Z ± 1.0 45.0 6.0 D +1.5 Max Φ22.0 Dimens P ± 0.2 10.0 This drawing is not to be scaled. SPECIFICATIONS Rated Voltage, VR Rated Capacitance AC ESR 1kHz (V) (F) (mΩ) (mΩ) (A) (㎃) (J) (mm) (g) VEC 3R0 107 QG 3.0 100. 6.00 * Maximum Current: 1 second discharge to ½ ·V R 10.00 75. 0.300 450.0 22.0 x 45.0 20.0 Part Number DC IR Maximum Current Leakage Current Stored Energy Dimension DxL Weight * Leakage Current: After 72hours at VR and 25℃ 2015-12-01 09:05:41 Item Characteristics Rated Voltage(VR) 3.0V Capacitance Tolerance -10 ~ 30% Remarks |Δcap| ≤ 30% of initial value at 25℃ Operating Temperature (Tmin ~ Tmax) -40 ~ +65℃ Storage Temperature -40 ~ 70℃ |ΔESR| ≤ 100% of specified value at 25℃ After 1,000 hours application of VR at Tmax |Δcap| ≤ 30% of initial value at 25℃ Cycle Life 500,000 cycles |ΔESR| ≤ 100% of specified value at 25℃ Cycles from VR to ½ ·VR under constant current at 25℃ |Δcap| ≤ 10% of initial value at 25℃ Shelf Life 2 years |ΔESR| ≤ 50% of specified value at 25℃ Without electrical charge under Tmax Tel: +82-31-455-3064 E-mail: hycap@vina.co.kr Web: www.vina.co.kr Design and specifications are subjected to change without notice. version 9.1 on November 23, 2015
VEC3R0107QG 价格&库存
很抱歉,暂时无法提供与“VEC3R0107QG”相匹配的价格&库存,您可以联系我们找货
