6R3AREP331M06X8E11
6R3AREP331M06X8E11
    APAQ(钰邦)
    AEC_D6.3X8MM_TM
    贴片铝电解电容 AEC_D6.3X8MM_TM
6R3AREP331M06X8E11 数据手册
CUSTOMER: 凱澤鑫 Doc No: MES003213 Rev: A0 承認書 RoHS Comp. Halogen Free APPROVAL SHEET Specifications description : APAQ P/N : Customer P/N AREP EXX Series : Approved by Date Checked by APAQ R&D 2017.03.02 APPROVAL Approved by Customer (Signing or stamping here) : Approved Date : 鈺邦科技股份有限公司 APAQ TECHNOLOGY CO., LTD 竹南科學園區 苗栗縣竹南鎮科東三路 2&6 號 4 樓 4F., No.2 & 6, Kedong 3rd Rd., Chunan Science Park, Miaoli County 350, Taiwan ,( R.O.C.) PAGE 1 OF 16 AP-CON AREP SERIES SPECIFICATION 1. Application This specification shall be specified to conductive polymer aluminum solid electrolytic capacitors of AREP series. 2. Composition of part number 3R0 AREP 821 M Rated voltage Series code Capacitance Cap tolerance 08A2 Size code E19 Special code 2.1 Rated voltage code Table 1 Rated voltage and surge voltage Rated voltage code Rated voltage (V) Surge voltage (V) 3R0 3 3.4 6R3 6.3 7.2 100 10 11.5 160 16 18.4 2.2 Capacitance code Table 2 Rated capacitance Capacitance code Capacitance (uF) 3R3 3.3 100 10 821 820 2.3 Capacitance tolerance code Table 3 Capacitance tolerance Cap tolerance code Cap tolerance M 20% 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 2 OF 21 2.4 Size code Table 4 Dimension of radial type capacitors Size code Diameter (mm) Case length (mm) 04X5 4 5 05X7 5 7 05X8 5 8 05X9 5 9 06X5 6.3 5 06X7 6.3 7 06X8 6.3 8 06X9 6.3 9 06A0 6.3 10 08X6 8 6 08X8 8 8 08A2 8 11.5 08A6 8 16 08B0 8 20 10X7 10 7 10A0 10 10 10A2 10 11.5 10A6 10 16 10B0 10 20 2.5 Special code Special code EXX Remark E10:ESR 10mΩ E11:ESR 11mΩ 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 3 OF 21 3. Rating 3.1 Category temperature range -55 to +105 oC 3.2 Surge voltage Rated voltage * 1.15 3.3 Rated ripple current Rated ripple current shall be in accordance with standard ratings list. These current are rms values of sine wave of 100kHz at 105 oC. 3.4 Standard ratings Table 5 Standard ratings Leakage ESR WV/Vdc Cap Size (SV) (μF) Code 270 05X7 340 0.10 15 3,130 6R3AREP271M05X7E15 330 05X8 500 0.10 11 3,700 6R3AREP331M05X8E11 330 06X5 500 0.10 20 2,980 6R3AREP331M06X5E20 390 05X8 500 0.10 14 3,200 6R3AREP391M05X8E14 470 06X8 592 0.10 11 4,000 6R3AREP471M06X8E11 560 06X8 705 0.10 11 4,000 6R3AREP561M06X8E11 6.3 680 06X8 857 0.10 11 4,000 6R3AREP681M06X8E11 (7.2) 820 06X8 1,033 0.10 11 4,000 6R3AREP821M06X8E11 820 06A0 1,033 0.10 11 4,000 6R3AREP821M06A0E11 820 08X8 1,033 0.10 10 5,100 6R3AREP821M08X8E10 1000 08A2 1,260 0.10 10 5,100 6R3AREP102M08A2E10 1500 08A2 1,890 0.10 10 5,000 6R3AREP152M08A2E10 1500 10A2 1,890 0.10 10 5,560 6R3AREP152M10A2E10 2200 10A2 2,772 0.10 10 5,560 6R3AREP222M10A2E10 Current tanδ (μA) (mΩmax/20%, 100k to300kHz) Rated Ripple Current 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION Part No. (mArms/ 105℃/100kHz) APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 4 OF 21 Leakage ESR WV/Vdc Cap Size (SV) (μF) Code 560 06X8 762 0.10 11 4,000 6R8AREP681M06X8E11 500 05X8 750 0.10 15 3,200 7R5AREP501M05X8E15 680 08X8 1,360 0.10 15 4,000 100AREP681M08X8E15 1000 08A2 2,000 0.10 11 5,000 100AREP102M08A2E11 330 06X9 1,056 0.10 23 2,900 160AREP331M06X9E23 330 06A0 1,056 0.10 19 3,600 160AREP331M06A0E19 16 470 08A2 1,505 0.10 13 4,600 160AREP471M08A2E13 (18.4) 680 08A2 2,176 0.10 13 4,600 160AREP681M08A2E13 820 08A6 2,624 0.10 13 5,400 160AREP821M08A6E13 1000 10A2 3,200 0.10 15 5,000 160AREP102M10A2E15 6.8 (7.8) 7.5 (8.6) 10 (11.5) Current tanδ (μA) (mΩmax/20%, 100k to300kHz) Rated Ripple Current 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION Part No. (mArms/ 105℃/100kHz) APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 5 OF 21 4. Construction and dimensions. 4.1 Construction Radial type capacitors shall be enclosed wound element, where anode and cathode foils with lead wire termination shall be winded together with separator, with conductive polymer electrolyte in a plastic coated aluminum case and sealed up tightly with rubber. Fig. 1 Cross-section view Table 6 Construction Compositions Anode foil Materials Aluminum 1 Element Cathode foil Aluminum Separator Synthetic fiber 2 Seal Rubber 3 Aluminum tab Aluminum 4 Lead wire Tinned Lead 5 Case Plastic coated aluminum 4.2 Outer dimensions Outer dimensions shall be in accordance with Fig. 2, and the dimensions in each size shall be specified on Table 7. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 6 OF 21 Table 7 Size code D±0.5max Dimension (mm) L (mm) α (mm) d0.05 (mm) F±0.4 (mm) H0.3 (mm) 04X5 4 5 1 0.45 1.5 3.2 05X6 5 6 1 0.5 2 3.2 05X7 5 7 1 0.5 2 3.2 05X8 5 8 1 0.5 2 3.2 05X9 5 9 1 0.5 2 3.2 05A1 5 11 1 0.5 2 3.2 06X5 6.3 5 1 0.45 2.5 3.2 06X7 6.3 7 1 0.6 2.5 3.2 06X8 6.3 8 1 0.6 2.5 3.2 06X9 6.3 9 1 0.6 2.5 3.2 06A0 6.3 10 1 0.6 2.5 3.2 06A1 6.3 11 1 0.6 2.5 3.2 08X6 8 6 1 0.6 3.5 3.2 08X8 8 8 1 0.6 3.5 3.2 08A2 8 11.5 1.5 0.6 3.5 3.2 08A6 8 16 1.5 0.6 3.5 3.2 08B0 8 20 1.5 0.6 3.5 3.2 10X7 10 7 1 0.6 5 3.2 10A0 10 10 1 0.6 5 3.2 10A2 10 11.5 1.5 0.6 5 3.2 10A3 10 12.5 1.5 0.6 5 3.2 10A6 10 16 1.5 0.6 5 3.2 10B0 10 20 1.5 0.6 5 3.2 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 7 OF 21 5. Marking The following items shall be marked on each capacitor, as showed in Fig. 3. (1) Polarity (2) Series (3) Year code: U-2014,V-2015,W-2016,X-2017 (4) Production period code (5) Manufacturer's identification mark (6) Rated capacitance (7) Rated voltage (8) The color of marking ink is red Figure 3 Marking 6. The electrical and mechanical performance and testing method 6.1 Measurement condition Each measurement shall be conducted at a temperature of 15 to 35 oC, and relative humidity of 45 to 85%. Furthermore, these measurements shall be preferably conducted at a temperature of 202 oC, and relative humidity of 60 to 70%, while the capacitors shall be kept enough time in the measuring temperature. 6.2 Voltage treatment If leakage current is doubtful, measure it after performing voltage treatment, which shall contain the following steps: (1) Applied DC rated voltage to the capacitors for 60 minutes at 1052 oC. (2) Cooled down to room temperature with applying voltage. (3) Discharged through a resistor of approximately 1/V. 6.3 Electrical performance 6.3.1 Tolerance on rated capacitance Rated capacitance shall meet within -20% to +20% (M) tolerance against the rated capacitance measured at 120Hz10% at 202 oC. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 8 OF 21 6.3.2 Leakage current DC rated voltage shall be applied between anode and cathode lead wire terminations of a capacitor through 1k protective resistance, and the leakage current shall be less than or equal to the value listed in table 5 after 2 minutes with the voltage reaching the rated value at 202 oC. If the value is doubtful, measure the leakage current after performing voltage treatment as described in section 6.2. 6.3.3 Tangent of loss angle (tan) Tan values shall be less than or equal to 0.1 measured at 120Hz10% at 202 oC. 6.3.4 Equivalent Series Resistance (ESR) ESR at 100kHz measured under the following conditions listed in Table 8 shall be less than or equal to the value in Table 5. Table 8 Measurement requirement of ESR Equipment Agilent Technology 4263B or equivalent Test Fixture Agilent Technology 16047E or equivalent Compensation Short and Open compensation would be required. Short correction is performed using the shorting plate made of 0.5 thickness copper plate with gold coating. Signal Level 500mV Frequency 100kHz Measurement Point Point of lead wire within 1mm form the body 6.3.5 Impedance at high and low temperature Impedance at 100kHz at -553 oC or 1052 oC shall meet the values listed in Table 9. Table 9 Impedance at low or high temperature Impedance ratio Performance Z(-55 oC)/Z(+20 oC)  1.25 Z(105 oC)/Z(+20 oC)  1.25 6.4 Mechanical performance 6.4.1 Pull strength of lead wire terminations With the body of a capacitor fixed, the load listed in Table 10 shall be applied to the lead wire termination in its draw out direction, gradually up to the specified value and held for 101 seconds. After this test, that capacitor shall not appear any change defective in use. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 9 OF 21 Table 10 Pull strength load of lead wire terminations Case diameter (mm) Load strength (N) Load strength (kgf) 4 2.5 0.255 5 5 0.51 6.3 5 0.51 8 10 1.0 10 10 1.0 6.4.2 Bending strength of lead wire terminations Bending strength load listed in Table 11 shall be hung at the end of the lead wire termination, and the body of a capacitor shall be bent 90o and return to its original position. This operation shall be performed around 2 to 3 seconds. Then the body shall be bent 90°at the opposite direction and return to its original position at same speed. At this test, that capacitor shall no appear any change defective in use. Table 11 Bending strength load of lead wire terminations Case diameter (mm) Load strength (N) Load strength (kgf) 4 1.25 0.127 5 5 0.51 6.3 2.5 0.255 8 5 0.51 10 5 0.51 6.4.3 Vibration Vibration cycle should vary from 10 to 55Hz with total amplitude of 1.5mm and return to 10Hz in about 1 minute. Vibration applied to a capacitor should be three directions, which each perpendicular to the other two as longitudinal axis of capacitor set as z axis, and last for 2 hours in each direction. During this test, measured electrical value shall be stabilized when that capacitor is measured 5 times within 30 minutes before completion of test, and the appearance shall not appear any remarkable abnormality. A capacitor shall be fixed at the point of 4mm or less from the body as shown in Figure 4. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 10 OF 21 Figure 4 Vibration test 6.4.4 Solderability A lead wire termination shall be dipped for 20.5 seconds in the flux of ethanol or isopropylalcohol solution (252%) of colophonium. Then that lead wire terminations shall be immersed to a solder (H60A, H60S or H63A) of 2355 oC and up to the point 1.5 to 2.0mm from the body and kept for 20.5 seconds, and pulling it out. After this test, at least 95% of circumferential surface of the dipped portion of termination shall be covered with new solder. 6.4.5 Resistance to soldering heat A Capacitor shall be inserted to a printed circuit board having a thickness of 1.6mm up to the point 1.5 to 2.0mm from the body. Then the lead wire termination shall be dipped for 5 to 10 seconds in the flux of ethanol solution (252%) of colophonium. And then the lead wire termination shall be immersed to the solder (H60A, H60S or H63A) of 2605 o C and up to the point of the Printed circuit board and kept for 101 seconds, and pulling it out. After this test, characteristics shall meet the value in Table 12. Table12 Characteristics Soldering heat resistance Performance Capacitance change Within 5% of the value before test tan Leakage current Not exceed than the value in Table 6 Visual No remarkable abnormality Not exceed than the value in Table 6 6.4.6 Resistance to solvent A Capacitor shall be immersed for 305 seconds in isopropylalcohol at 20 to 25 oC and then pull it out. After this test, marking and visual shall meet the requirement in Table 13. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 11 OF 21 Table 13 Solvent resistance Characteristics Performance Marking Easily readable Appearance Not appear any abnormality 6.5 Environmental performance 6.5.1 Damp heat, steady state A capacitor shall be subjected to a temperature of 602 oC and relative humidity of 90 to 95% without voltage applied for a period of 1000+24/-0 hours. Then that capacitor shall be take out from the above condition to a temperature of 20 oC and it shall meet the characteristics in Table 14. Table 14 Damp heat performance Characteristics Performance Appearance No significant damage Capacitance change  20% of the initial value tan  150% of the initial specified value ESR  150% of the initial specified value Leakage current  the initial specified value 6.5.2 Endurance A capacitor shall be subjected to a temperature of 1052 oC with test voltage applied for a period of 3,000+72/-0 hours and take out from the above condition to a temperature of 20 oC. After this test, that capacitor shall meet the characteristics in Table 15. Besides, the applied voltage shall increase up from 0V to test voltage step by step (maximum 5 minutes), and the impedance of the source shall be equal to about 3/V. Table 15 Endurance performance Characteristics Performance Appearance No significant damage Capacitance change  20% of the initial value tan ESR  150% of the initial specified value Leakage current  the initial specified value  150% of the initial specified value 6.5.3 Surge voltage The following specifications in Table 16 shall be satisfied when the capacitors are restored to +20 oC after the surge voltage is applied at a cycle of 360 seconds which consists charge for 30±5 seconds through a protective resistor of 1k and discharge for 330 seconds, for 1000 cycles at 1052 oC. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 12 OF 21 Table 16 Surge voltage performance Characteristics Performance Appearance No significant damage Capacitance change  20% of the initial value tan ESR  150% of the initial specified value Leakage current  the initial specified value  150% of the initial specified value Fig. 5 Surge voltage circuit 6.5.4 Rapid temperature change The characteristics of a capacitor kept under the temperature cycle indicated in Figure 6 for 5 cycles and followed the voltage treatment as described in section 6.2 shall meet the characteristics in Table 17. Fig. 6 Table 17 Rapid temperature change profile Rapid temperature change performance Characteristics Performance Appearance No significant damage Capacitance change  10% of the initial value tan  the initial specified value ESR  the initial specified value Leakage current  the initial specified value 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 13 OF 21 7. Instructions of Capacitors 7.1 Cautions on use of Capacitor 7.1.1 Polarity Solid electrolytic capacitors are polarized capacitors. Use capacitors after verifying their positive and negative polarities. If these capacitors are installed in the reverse polarity, its life may shorten because of increasing leakage current or short circuit. 7.1.2 Types of circuits in which capacitors are prohibited from being used AREP series may be heated by soldering to increase in its leakage current slightly. This may have some influence on the characteristics capacitors in the following circuits. (1) Time constant circuit (2) Coupling circuit (3) High impedance voltage holding circuit (4) Connection of two or more capacitors in series for higher withstand voltage. 7.1.3 Over voltage If AREP series is applied a voltage higher than the rated voltage for an instantaneous period, it may be defected due to short circuit. Note that the voltage over the rated voltage must not be applied to capacitors. 7.1.4 Repeat of rapid charging and discharging If AREP series is used in a rapid charging and discharging circuit or receive the flow of excess rush current, its life may shorten by large leakage current or short circuit. The charging and discharging current through AREP series should be less than 10A. 7.1.5 Soldering Capacitors should be soldered under the soldering conditions defined in the delivery specifications. Some improper soldering condition may cause the leakage current of capacitors to increase or other parameters to change. 7.1.6 Use of capacitors for industrial equipment When capacitors are used for industrial equipment, the circuits should be designed to have sufficient margins in the ratings of capacitors including capacitance and impedance. Without sufficient margins in the characteristics, the reliability of the capacitors may be reduced by their shorter life. Always contact us if you want to use capacitors for equipment affecting human lives such as space, aviation, atomic power, and medical devices. Never use capacitors for the used without our prior approval. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 14 OF 21 7.2 Notes on circuit designs for capacitors 7.2.1 Rating and performance Use capacitors within the rating and performance ranges defined in the brochures and delivery specification of capacitors after checking the operating and installation environments. 7.2.2 Operating temperature If AREP series is used at a temperature higher than the upper specified temperature (105oC), its life may be remarkably shortened or the leakage current may increase to cause defective. 7.2.3 Ripple current Never make current larger than the rated ripple current through AREP series. If excess ripple current flows through AREP series, internal heat may be generated largely to make its life shortened or cause it to be defected due to short circuit. 7.2.4 Leakage current Depending on the soldering conditions, the leakage current of AREP series may increase slightly. The application of DC voltage enables the capacitors to be repaired by itself. This leads the leakage current to be smaller gradually. The leakage current can be reduced fast if the DC voltage, which is less than the rating voltage, is applied at the temperature close to the upper specified temperature. 7.2.5 Applied voltage (1) To secure the reliability of capacitors, it is recommended that the voltage applied to them should be less than 80% of the rated voltage. (2) The peak value of the ripple voltage superimposed with the DC voltage should be less than the rated voltage. 7.2.6 Failure mode AREP series contains a conductive polymer as material of cathode electrode. Therefore, like other solid electrolyte capacitors, the life ends mostly due to random failure mode, mainly short circuit. If a current continuously flow through the capacitor due to short circuit, the capacitor would be overheated higher than 300°C and then aluminum case of the capacitor would be removed by increasing internal pressure due to the vaporization of materials. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 15 OF 21 7.2.7 Insulation (1) Plastic coated case of capacitors is not secured to insulate. Do not use capacitors in areas requiring insulation. (2) Isolate the case of AREP series from the positive and negative terminals and adjacent circuit patterns. 7.2.8 Design of printed circuit board Take note on the following subjects when capacitors are installed on printed circuit boards: (1) Verify that the lead spacing fit hole pitches on printed circuit board. (2) Do not place heating components on boards to be close to capacitors or in the backside of them. (3) If capacitors are mounted on a double-sided PC board, design the board so that extra or through holes may not be opened below them. 7.2.9 Parallel connection If AREP series is connected with another type of a capacitor in parallel, larger ripple current may flow through one of capacitors. Take the current balance among them into account in circuit designs. 7.2.10 Using temperature and frequency The electric characteristics of capacitors depend on the variations of the ambient temperature and frequency. Check the variations in designing circuits. 7.3 Notes on installation of capacitors 7.3.1 Notes on pre-installation of capacitors (1) Do not reuse capacitors installed in a unit with the power supply turned on for another unit. No used capacitors shall be reused excluding those removed to measure their electric characteristics in periodical inspection. (2) If AREP series stored for a long period may often increase in its leakage current, connect a resistor of approximately 1k to the capacitors for voltage treatment. 7.3.2 Notes at installation of capacitors (1) Install capacitors in a unit after confirming that their ratings (rated capacitance and rated voltages) meet the conditions of the unit. (2) Install capacitors in the correct polarities. (3) Take care not to drop capacitors on floors. Do not use capacitors dropped on floors. (4) Do not deform capacitors to install them in units. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 16 OF 21 (5) Install AREP series on a printed circuit board after confirming that its lead pitch is equivalent to the corresponding hole pitch. (6) At the picking, mounting, and locating by an automatic inserter or the cutting of the leads of AREP series by an automatic mounter, some stress may be applied to the AREP series. Take note on the shock. (7) Do not apply any excess force with the terminals of capacitors. 7.3.3 Heating In preheating or heating for adhesion and fixing of other electronic components, the temperature put to capacitors should be less than 120°C. The total heating period should be shorter the 90 seconds. 7.3.4 Soldering by soldering iron (1) Capacitors should be soldered under the conditions as follows: The iron tip at the temperature of 40010°C or less may be put to each lead of AREP series for shorter than 3+1 seconds. (2) The lead wire terminations of capacitors may be required to be processed because the distance between the terminals is not equivalent to that of corresponding holes on the printed circuit board. Process the terminations so that no stress may be applied to the capacitors itself before soldering. (3) Do not make the tip of a soldering iron be in contact with capacitors themselves. (4) The leakage current of soldered capacitors may increase slightly depending on several conditions including pre-heating, soldering temperature and period, and board material and thickness. However, the leakage current decreases gradually by the self-repair characteristic of capacitors when they are used with voltage application. 7.3.5 Flow soldering (1) Do not dip capacitors themselves into melted solder in soldering. Only provide soldering for the board surface in the backside of the surface on which the capacitors are mount (2) Solder capacitors under the soldering conditions as follows. (a) Pre-heat condition: atmosphere temperature 120°C or less for up to 90 seconds (b) Soldering condition: solder temperature 260°C or less for up to 10 seconds. (3) Note that flux may not adhere to any substances except lead wires. (4) Do not make any other components fallen at capacitors in soldering. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 17 OF 21 Figure 7 Flow Curve 7.3.6 Handling of capacitors after soldering (1) Do not incline, bend, and twist capacitors. (2) Do not grab capacitors as a handle to carry the printed circuit board. (3) Do not hit objects against capacitors. When printed circuit boards are piled up, do not make them and/or other components be in contact with capacitors. (4) Do not drop printed circuit boards with capacitors installed. 7.3.7 Cleaning of printed circuit board As long as the cleaning agents prescribed in the catalogue or the specification sheet are used, the cleaning does not give the capacitors any damage. For CFCs substitutions and other cleaning agents, consult us before actual use. 7.3.8 Fixing and coating materials Contact us for fixing and coating materials appropriate for capacitors and their heat curing conditions. 7.4 Notes on use of capacitors in unit (1) Never make your fingers contact with the lead wire terminations of capacitors. (2) Do not make lead wire terminations of AREP series be in contact with each other through an conductor. Do not put conductive liquid such as acid and alkali solutions on capacitors. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 18 OF 21 (3) Confirm that the unit including capacitors is placed in proper conditions. Do not place the unit in the following areas: (a) Area in which they are directly exposed to water, brine, or oil or in condensation status. (b) Area filled with poisonous gases including hydrogen sulfide, sulfurous acid, nitrous acid, chlorine and ammonia. (c) Area to which ultraviolet and/or radial rays are radiated (4) Provide aging for a unit containing capacitors within the period defined for them. (5) It is recommended to use a unit containing capacitors in the normal temperature range of 15oC to 35oC and the normal humidity range of 75% or less. 7.5 Action at emergency (1) At the occurrence of short circuit in AREP series, some heat is generated from it if the short-current rather small. If the short current exceeds the above value, the capacitors is heated excessively. If so, turn off the power of the unit without your face and hands being close to the capacitors. (2) Never lick the electrolyte of conductive polymer in capacitors. If the electrolyte is put on your skin, wash it away carefully with soap. (3) The materials of seal rubber used for capacitors are flammable. If an adjacent component is burned, seal rubber of the capacitors may burn. Take sufficient note on the installation procedures and locations of capacitors and the pattern designs of printed circuit boards. 7.6 Storage (1) Store capacitors in an area in the temperature range between 15°C to 35°C and the relative humidity of 75% or less without direct sunshine. In addition, store them in the package states if possible. (2) Capacitors should be stored for up to one year to maintain their good soldering features and characteristics. (3) Capacitors are recommended that you shall open the bag just before use and capacitors shall be used up. If some quantity was not need, please seal it with adhesive tape. (4) Never store capacitors in any area in which they are directly exposed to water, brine, or oil or in condensation status. (5) Never store capacitors in any area filled with poisonous gases including hydrogen sulfide, sulfurous acid, nitrous acid, chlorine, and ammonia. (6) Never store capacitors in any area to which ultraviolet and/or radial rays are radiated. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 19 OF 21 7.7 Exhaustion of capacitors Capacitors are composed of organic compounds, resins and metals. Request an industrial dispose company to dispose of used capacitors. 8. Export Trade Control Ordinance Item 41-4 in Section 2 of Appendix Table 1 (Section 49 in Chapter 1 of MITI' s Ordinance) and Item 7 in Section 7 of Appendix Table 1 (Section 6 in Chapter 6 of MITI' s Ordinance) state export regulations on pulse use capacitors (750V of higher) and high voltage use capacitors(5,000V or higher). However, aluminum electrolytic capacitors are less than 750V in their voltage range, so that the regulations do not apply to the aluminum electrolytic capacitors. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 20 OF 21 9. Package The capacitors should be packed in the following quantities listed in Table 19. Table 19 Quantity of package Case size PE bag ψ4 1,000 PCS ψ5 500 PCS 06X5 500 PCS 06X7 500 PCS 06X8 500 PCS 06X9 500 PCS 06A0 500 PCS 06A1 500 PCS 08X6 500 PCS 08X8 500 PCS 08A2 500 PCS 08A6 500 PCS 08B0 400 PCS 10A2 500 PCS 10A6 400 PCS 10B0 350 PCS inner box outer box 24 bags 5 inner boxes (24,000 PCS) (120,000 PCS) 8 bags 5 inner boxes (4,000 PCS) (20,000 PCS) 12 bags 5 inner boxes (6,000 PCS) (30,000 PCS) 8 bags 5 inner boxes (4,000 PCS) (20,000 PCS) 8 bags 5 inner boxes (4,000 PCS) (20,000 PCS) 8 bags 5 inner boxes (4,000 PCS) (20,000 PCS) 6 bags 5 inner boxes (3,000 PCS) (15,000 PCS) 6 bags 5 inner boxes (3,000 PCS) (15,000 PCS) 6 bags 5 inner boxes (3,000 PCS) (15,000 PCS) 6 bags 5 inner boxes (3,000 PCS) (15,000 PCS) 4 bags 5 inner boxes (2,000 PCS) (10,000 PCS) 4 bags 5 inner boxes (2,000 PCS) (10,000 PCS) 4 bags 5 inner boxes (1,600 PCS) (8,000 PCS) 4 bags 5 inner boxes (2,000 PCS) (10,000 PCS) 4 bags 5 inner boxes (1,600 PCS) (8,000 PCS) 4 bags 5 inner boxes (1,400 PCS) (7,000 PCS) 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:鍾佳玲 TITLE:AP-CON AREP SERIES SPECIFICATION APAQ CHECKED TECHNOLOGY BY:林軒逸 DOCUMENT NO. CO., LTD APPROVED BY:錢明谷 REV MES003212 A0 PAGE 21 OF 21
6R3AREP331M06X8E11 价格&库存
很抱歉,暂时无法提供与“6R3AREP331M06X8E11”相匹配的价格&库存,您可以联系我们找货
