35CE680KX+D
35CE680KX+D
    SUNCON
    SMD,D12.5xL13.5mm
    贴片铝电解电容 AEC_D12.5X13.5MM_SM
35CE680KX+D 数据手册
Aluminum Electrolytic Type / Surface Mount Type Aluminum Electrolytic Capacitors Surface Mount Type CE-KX RoHS compliance Low Impedance Series CE-ZX (P.50) 10 to 20% less impedance than CE-AX series at hight frequencies. ● 105℃ 1,000 to 2,000hours ● Solvent proof (within 2 minutes) ● CE-LX (P.52) Low ESR Long Life CE-KX Low Impedance CE-AX (P.46) ■ Specifications Items Condition Specifications Rated voltage (V) − 6.3 10 16 25 35 50 63 80 100 CE-BE Surge voltage (V) Room temperature 8.0 13 20 32 44 63 79 100 125 CE-BD Category temperature range (℃) − CE-BS Capacitance tolerance (%) 120Hz/20℃ CE-BSS CE-FE CE-LD CE-FSS CE-FS CE-FS(High Voltage) CE-FH Dissipation Factor(tan δ) Leakage current (LC) CE-ZX M : ±20 φ4 to φ6.3 0.24 0.20 φ8 to φ16 0.28 0.24 0.14 0.12 0.12 0.10 0.08 0.07 0.20 0.16 0.14 0.14 0.12 0.10 0.08 The greater value of either 0.01CV or 3 Impedance ratio at Iow temperature Based on the value at −40℃ Z/Z20℃ 120Hz, +20℃ −55℃ Z/Z20℃ Endurance 105℃ rated voltage applied (With the rated ripple current) CE-ZC 0.16 Exceeding 1,000μF, +0.02 every 1,000μF μA/after 2minutes (max) CE-AX CE-KX tanδ (max) 120Hz/20℃ −55 to +105 3 2 2 2 2 2 2 2 2 5 4 4 3 3 3 3 3 3 Test CE-LX φ4 to φ6.3 : 1,000hours, φ8 to φ16 : 2,000hours △C/C Within ±25% of the initial value tanδ Less than 200% of the specified value LC Less than the specified value CE-GA CE-LS CE-PH Polarity (Cathode) 8D 470 16 K CE-PS CE-PF CE-TH CE-JX CE-NP CE-FN 48 0.3max W Lot No. Rated Capacitance Series Symbol Rated Voltage(6.3V→6) [ φD≥12.5 ] Polarity (Cathode) 8DT 3300 16 K (Unit : mm) C CE-LF CE-PC [ φD≤10 ] (P) CE-LL ■ Marking, Dimensions H CE-LH(High Voltage) φD CE-LH Lot No. Indicated Only φD=16 Rated Capacitance Series Symbol Rated Voltage(6.3V→6) L R (+) A pressure relief vent is provided for φD=8 or bigger (P)reference size D±0.5 L±0.3 W±0.2 H±0.2 C±0.2 R P 4 6.0 4.3 4.3 5.0 0.5 to 0.8 1.0 5 6.0 5.3 5.3 6.0 0.5 to 0.8 1.4 6.3 6.0 6.6 6.6 7.3 0.5 to 0.8 2.2 6.3 7.7 6.6 6.6 7.3 0.5 to 0.8 2.2 8 10.2 8.3 8.3 9.0 0.7 to 1.0 3.2 10 10.2 10.3 10.3 11.0 1.0 to 1.4 4.6 12.5 13.5±0.5 12.8 12.8 13.5 1.0 to 1.4 4.6 16 16.5±0.5 16.3 16.3 17.3 1.7 to 2.1 7.0 Aluminum Electrolytic Type / Surface Mount Type RoHS compliance ■ Size, Impedance, Rated Ripple Current 10 16 25 35 10 15 22 4×6.0 27 33 1.45 90 → 47 5×6.0 0.70 170 56 5×6.0 0.70 170 → 4×6.0 1.45 90 5×6.0 0.70 170 → 1.45 90 4×6.0 1.45 90 5×6.0 0.70 170 4×6.0 1.45 90 5×6.0 0.70 170 5×6.0 0.70 170 5×6.0 0.70 170 5×6.0 0.70 170 5×6.0 0.70 170 6.3×6.0 0.39 250 6.3×6.0 0.39 250 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×7.7 → 6.3×6.0 0.39 250 6.3×6.0 0.39 250 0.30 300 CE-BE 6.3×6.0 0.39 250 6.3×7.7 0.30 300 8×10.2 0.15 600 CE-BD 250 6.3×7.7 0.30 300 8×10.2 0.15 600 8×10.2 0.15 600 CE-BS 0.30 300 6.3×7.7 0.30 300 8×10.2 0.15 600 8×10.2 0.15 600 CE-BSS 300 8×10.2 0.15 600 8×10.2 0.15 600 8×10.2 0.15 600 10×10.2 0.080 850 CE-FE 8×10.2 0.15 600 8×10.2 0.15 600 8×10.2 0.15 600 10×10.2 0.080 850 12.5×13.5 0.058 1150 CE-LD 680 8×10.2 0.15 600 10×10.2 0.080 850 12.5×13.5 0.058 1150 CE-FSS 1000 8×10.2 0.15 600 1500 10×10.2 0.080 850 6.3×6.0 → 100 6.3×6.0 0.39 250 150 6.3×6.0 0.39 250 6.3×6.0 0.39 220 6.3×6.0 0.39 250 6.3×7.7 330 6.3×7.7 0.30 470 → 10×10.2 0.080 250 0.39 6.3×6.0 68 0.39 4×6.0 850 12.5×13.5 0.058 1150 12.5×13.5 0.058 1150 12.5×13.5 0.058 1150 3300 16×16.5 0.035 1800 CE-FS 16×16.5 0.035 1800 CE-FS (High Voltage) 16×16.5 0.035 1800 12.5×13.5 0.058 1150 2200 16×16.5 0.035 1800 CE-KX 16×16.5 0.035 1800 6800 CE-FH CE-AX 16×16.5 0.035 1800 4700 Surface Mount Type 6.3 4.7 Aluminum Electrolytic Capacitors V μF CE-ZX CE-ZC CE-LX V μF 50 63 80 CE-GA 100 2.2 6.3×6.0 2.70 42 3.3 6.3×6.0 2.40 45 45 6.3×6.0 2.40 45 6.3×7.7 4×6.0 2.55 64 5×6.0 2.00 10 6.3×6.0 0.52 215 6.3×6.0 22 6.3×6.0 0.52 215 6.3×7.7 33 6.3×7.7 0.44 47 6.3×7.7 0.44 4.7 55 6.3×6.0 2.40 1.00 90 6.3×7.7 2.00 65 2.00 65 0.80 135 8×10.2 0.90 140 8×10.2 0.90 140 243 8×10.2 0.35 280 8×10.2 0.90 140 10×10.2 0.50 220 243 8×10.2 0.35 280 10×10.2 0.50 220 12.5×13.5 0.24 500 8×10.2 0.35 280 12.5×13.5 0.24 500 12.5×13.5 0.24 500 10×10.2 0.20 480 12.5×13.5 0.24 500 16×16.5 0.14 800 12.5×13.5 0.24 500 16×16.5 0.14 800 16×16.5 0.14 800 68 100 8×10.2 0.22 400 150 220 10×10.2 0.13 585 330 12.5×13.5 0.10 800 800 CE-LH CE-LH (High Voltage) CE-LL CE-LF CE-PC CE-PH CE-PS CE-PF CE-TH CE-JX CE-NP CE-FN 16×16.5 0.065 1410 470 1000 12.5×13.5 0.14 CE-LS 16×16.5 0.060 1610 →Please use the higher voltage model in the next. Please refer to page 14 for ripple current frequency coefficients. ■ Part number KX Case size:φDxL(mm) 16×16.5:CE-KXT Rated ripple current mArms(100kHz, 105℃) Impedance(Ω) max at 100kHz, 20℃ KXT 16 CE 3300 KX T 16 CE 470 KX Series code Rated capacitance Type code Rated voltage Sn plating terminal option Series code Rated capacitance Type code Rated voltage 49
35CE680KX+D 价格&库存
很抱歉,暂时无法提供与“35CE680KX+D”相匹配的价格&库存,您可以联系我们找货
