Si MEMS OSCILLATOR
SERIES 7NM, EPOXY MOLDING 5.0X3.2MM SURFACE MOUNT PACKAGE
深圳市晶科鑫实业有限公司
样品承认书
客户代码:
物料名称:
贴片晶振
规格型号:
5032 MEMS OSC 11.2896MHZ
P N/ SJK:
7NM11289AC33YC
环保属性:
■RoHS
版
A1
次:
湿敏等级:
■REACH
制定
□PAHS
□其它
最小包装:
应
商
承
认
签
1000pcs/real
认
核 准
章
工 程 师
)公 司 承 认
审 核
批 准
黄灏东
SJK 支持
18682088994 (Mr.黄)
盖章签署
FAE_EMAIL
sjk-fae@q-crystal.com
日
日
-40~85℃ LVCOMS
一级
审 核
贺丹斌
■HF
2017-5-10 初版
承
供
1.8~3.3V
期
期
批示: □接受
□有条件接受
备注:
电话:0755-88352810-837(Mr.huang) 传真:0755-88353718
http://www.q-crystal.com
公司地址: 深圳市龙岗区天安云谷产业园一期 3 栋 C 座 12 楼 1204~1206 室
1 /7
Si MEMS OSCILLATOR
1. ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature : 25±5℃
Relative humidity : 40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
Ambient temperature : 25±3℃
Measure equipment
Electrical characteristics measured by MD 37WX-05M or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Parameters
1
2
3
SYM
Electrical Spec.
MIN
Nominal Frequency
AT 25℃
Over Operating
Temperature range
Operating Temperature
Frequency
Stability
TYPE
MAX
Notes
UNITS
11.289600
MHZ
±10
PPM
±15
PPM
Topr
-40
25
85
-55
125
4
Storage Temperature
Tstg
5
Supply Voltage
VDD
6
Input Current
Icc
7
Enable Control
8
Output Load : CMOS
CL
9
Output Voltage High
VoH
10
Output Voltage Low
VoL
10%
Vdd
V
11
Rise Time
Tr
5
ns
10%→ 90%VDD
Level
12
Fall Time
Tf
5
ns
90%→ 10%VDD
Level
13
Symmetry (Duty ratio)
TH/T
55
14
Start-up Time
Tosc
10
ms
15
Enable Voltage High
Vhi
16
Disable Voltage Low
Vlo
17
Aging
18
Output Disable Delay Time
T off
150
us
19
Output Enable Delay Time
T on
150
us
3.3 ±10%
V
10
1.62~3.63V
mA
Yes
Pad1
15
pF
90%
Vdd
45
V
70%
Vdd
V
30%
Vdd
±3
V
ppm/yr.
1st. Year at 25℃
2 /7
Si MEMS OSCILLATOR
Phase Jitter (12KHZ~20MHZ)
2. DIMENSIONS
0.5
1.0
ps
(Units :mm)
3. MARKING
3 /7
Si MEMS OSCILLATOR
4. TEST CIRCUIT
Control input (output enable/disable)
Logic 1 or open on pad 1: Oscillator output
Logic 0 on pad 1 : Disable output to high impedance
5. WAVEFORM CONDITIONS
Waveform measurement system should
have a min. bandwidth of 5 times the
frequency being tested.
4 /7
Si MEMS OSCILLATOR
6. OUTPUT ENABLE / DISABLE DELAY
The following figure shows the oscillator timing during normal operation . Note that when the device is in
standby,
the oscillator stops. When standby is released, the oscillator starts and stable oscillator output occurs after a
short delay
8. SUGGESTED REFLOW PROFILE
5 /7
Si MEMS OSCILLATOR
Total time : 200 sec. Max / Solder melting point :220 ℃
7. RELIABILITY TEST SPECIFICATION
1.Mechanical Endurance
No.
Test Item
Test Methods
REF. DOC
1
Drop Test
75 cm height,3 times on concrete floor .
JIS C6701
Device are shocked to half sine wave ( 1000
G ) three mutually
perpendicular axes each 3 times. 0.5m sec.
duration time
Frequency range 10 ~ 2000 Hz
Amplitude 1.52 mm/20G
Sweep time 20 minutes
Perpendicular axes each test time 4 Hrs
(Total test time 12 Hrs)
Standard Sample For Automatic Gross Leak
Detector, Test Pressure: 2kg / cm2
2
Mechanical Shock
3
Vibration
4
Gross Leak
5
Fine Leak
Helium Bomging 4.5 kgf / cm 2 for 2 Hrs
Solderability
Temperature 245 ℃ ± 5℃
Immersing depth 0.5 mm minimum
Immersion time 5 ± 1 seconds
Flux Rosin resin methyl alcohol
solvent ( 1 : 4 )
6
MIL-STD-202F
MIL-STD-883E
MIL-STD-883E
MIL-STD-883E
2.Environmental Endurance
6 /7
Si MEMS OSCILLATOR
No.
Test Item
Test Methods
REF. DOC
1
Resistance To Soldering
Heat
Pre-heat temperature 125 ℃
Pre-heat time 60 ~ 120 sec.
Test temperature 260 ± 5 ℃
Test time 10 ± 1 sec.
MIL-STD-202F
2
High Temp. Storage
+ 125 ℃ ± 3 ℃ for 1000 ± 12 Hrs
3
Low Temp. Storage
- 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs
MIL-STD-883E
Total 100 cycles of the following temperature
cycle
4
Thermal Shock
MIL-STD-883E
5
Pressure Cooker
Storage
121 ± 3℃ , RH100% , 2 bar , 240 Hrs
JIS C6701
6
High Temp&Humidity
85℃ ± 3℃, RH 85% , 1000 Hrs
JIS C5023
7 /7
很抱歉,暂时无法提供与“7NM11289AC33YC”相匹配的价格&库存,您可以联系我们找货
