CRYSTAL OSCILLATOR
SERIES 6N, SEAM SEALED CERAMIC 7.0X5.0MM SURFACE MOUNT PACKAGE
深圳市晶科鑫实业有限公司
样品承认书
客户代码:
物料名称:
贴片钟振
规格型号:
SMD7050 OSC 26.000MHZ 3.3V
P N/ SJK:
6N26000G33YC
环保属性:
■RoHS
版
A1
次:
湿敏等级:
■REACH
□其它
一级
应
商
承
认
签
认
章
制定
审 核
核 准
贺丹斌
李相同
刘惠光
SJK 支持
)公 司 承 认
工 程 师
审 核
批 准
盖章签署
FAE_EMAIL
日
□PAHS
2017-5-10 初版
承
供
■HF
LVCMOS -40~85℃
日
期
期
备注:
电话:0755-82507042
传真:0755-88353718
http://www.q-crystal.com.cn
公司地址: 深圳市龙岗区天安云谷产业园一期 3 栋 C 座 12 楼 1204~1206 室
1 /5
CRYSTAL OSCILLATOR
1. ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature : 25±5℃
Relative humidity : 40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
Ambient temperature : 25±3℃
Measure equipment
Electrical characteristics measured by MD 37WX-05M or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
SYM
Parameters
1
2
Electrical Spec.
MIN
Nominal Frequency
Frequency
Stability
TYPE
MAX
Notes
UNITS
26.000000
MHZ
AT 25℃
±10
PPM
Over Operating
Temperature range
±20
PPM
-40~85℃
3
Operating Temperature
Topr
-40
25
85
4
Storage Temperature
Tstg
-55
125
5
Supply Voltage
VDD
6
Input Current
Icc
7
Enable Control
8
Output Load : CMOS
CL
9
Output Voltage High
VoH
10
Output Voltage Low
VoL
10%
Vdd
V
11
Rise Time
Tr
5
ns
10%→ 90%VDD
Level
12
Fall Time
Tf
5
ns
90%→ 10%VDD
Level
13
Symmetry (Duty ratio)
TH/T
55
14
Start-up Time
Tosc
10
ms
15
Enable Voltage High
Vhi
16
Disable Voltage Low
Vlo
17
Aging
18
Output Disable Delay Time
T off
150
us
19
Output Enable Delay Time
T on
150
us
电话:0755-82507042
3.3 / ±10%
V
5
mA
Yes
Pad1
15
90%
Vdd
45
pF
V
70%
Vdd
V
30%
Vdd
±3
传真:0755-88353718
ppm/yr.
1st. Year at 25℃
2 /5
V
CRYSTAL OSCILLATOR
Phase Jitter (12KHZ~20MHZ)
2. DIMENSIONS
0.5
1.0
ps
(Units :mm)
3. MARKING
4. TEST CIRCUIT
Control input (output
enable/disable)
Logic 1 or open on pad 1:
Oscillator output
Logic 0 on pad 1 : Disable
output to high impedance
电话:0755-82507042
传真:0755-88353718
3 /5
CRYSTAL OSCILLATOR
5. WAVEFORM CONDITIONS
Waveform measurement
system should
have a min. bandwidth of 5
times the
frequency being tested.
6. OUTPUT ENABLE / DISABLE DELAY
The following figure shows the oscillator timing during normal operation . Note that when the device is in
standby,
the oscillator stops. When standby is released, the oscillator starts and stable oscillator output occurs after a
short delay
7. SUGGESTED REFLOW PROFILE
Total time : 200 sec. Max / Solder melting point :220 ℃
电话:0755-82507042
传真:0755-88353718
4 /5
CRYSTAL OSCILLATOR
8. RELIABILITY TEST SPECIFICATION
1.Mechanical Endurance
No.
Test Item
Test Methods
REF. DOC
1
Drop Test
75 cm height,3 times on concrete floor .
JIS C6701
Device are shocked to half sine wave ( 1000
G ) three mutually
perpendicular axes each 3 times. 0.5m sec.
duration time
Frequency range 10 ~ 2000 Hz
Amplitude 1.52 mm/20G
Sweep time 20 minutes
Perpendicular axes each test time 4 Hrs
(Total test time 12 Hrs)
Standard Sample For Automatic Gross Leak
Detector, Test Pressure: 2kg / cm2
2
Mechanical Shock
3
Vibration
4
Gross Leak
5
Fine Leak
Helium Bomging 4.5 kgf / cm 2 for 2 Hrs
Solderability
Temperature 245 ℃ ± 5℃
Immersing depth 0.5 mm minimum
Immersion time 5 ± 1 seconds
Flux Rosin resin methyl alcohol
solvent ( 1 : 4 )
6
2.Environmental Endurance
No.
Test Item
1
Resistance To
Soldering Heat
2
3
4
5
6
High Temp.
Storage
Low Temp.
Storage
Test Methods
Pre-heat temperature 125 ℃
Pre-heat time 60 ~ 120 sec.
Test temperature 260 ± 5 ℃
Test time 10 ± 1 sec.
+ 125 ℃ ± 3 ℃ for 1000 ± 12 Hrs
- 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs
MIL-STD-883E
MIL-STD-883E
MIL-STD-883E
REF. DOC
MIL-STD-202F
MIL-STD-883E
Total 100 cycles of the following temperature cycle
Thermal Shock
Pressure Cooker
Storage
High Temp&
Humidity
MIL-STD-202F
MIL-STD-883E
121 ± 3℃ , RH100% , 2 bar , 240 Hrs
JIS C6701
85℃ ± 3℃, RH 85% , 1000 Hrs
JIS C5023
备注
电话:0755-82507042
传真:0755-88353718
5 /5
很抱歉,暂时无法提供与“6N26000G33YC”相匹配的价格&库存,您可以联系我们找货
