YLR12-2-1F-W
YLR12-2-1F-W
    YEZHAN(业展)
    电流采样电阻 2512
YLR12-2-1F-W 数据手册
电流采样晶片电阻 Ultra Low Ohm Chip Resistors 深圳市业展电子有限公司 承 认 书 SPECIFICATION FOR APPROVAL 客户名称 Customer Name 客户料号 Customer P/N 产品名称 Product Name Ultra Low Ohm Chip Resistors – YLR-W Series 制造商料号 Manufacture P/N YLR12-3-5F-W 申请承认日期 版本 Apply Date 2019-07-02 REV. 供货商属性 □代理商 █ 制造商 深圳市业展电子有限公司 Vendor Type Agency Manufacturer Note: 禁止使用 1 级环境管理物质.遵守 ACBEL"环境管理物质规范"中所要求之含量标准. Restrict use of hazardous substances of level 1; Comply with "Specification for Hazardous Substances andMaterials Management" of ACBEL 供货商印鉴 APPROVED CHECKED PREPARED Vendor Stamp 承认印鉴 Stamp 邓小辉 Mainland China:深圳市业展电子有限公司 Shenzhen Yezhan Electronics Co., Ltd. Add: 深圳市龙华区观澜环观中路荣倡工业园 6-7 栋 Tel: 0755-26517682 Fax: 0755-29500756 深圳市业展电子有限公司 Shenzhen Yezhan Electronics Co.,Ltd Confidential and Proprietary To Shenzhen Yezhan electronics all right reserved 1 电流采样晶片电阻 Ultra Low Ohm Chip Resistors ★特征 Features ·阻值范围 Resistance value:0.5mΩ~51mΩ ·精度 Tolerance:±1%、±2%、±5% ·功率 Power:2W 3W ·温度系数 Temperature coefficient :± 50ppm/℃, ·工作温度范围 Operating temperature range:-65℃~170℃ ·定做特殊规格 Customized special specification size ★用途 Applications ·过流保护 Over current protection ·电流取样 Current sense applications ·伺服电机控制电路 Servo motor control circuits ·智能功率模块 Intelligent power modules ·工业电脑模块及精密测量系统 industrial PC modules and precision measurement system ·高速 CPU 外围设备中电流检测电路 Current detection circuits in high-speed CPU peripherals ★尺寸 Size Type L /mm W /mm A /mm 2512 6.35± 0.2 3.2± 0.2 1.7± 0.2 0.9± 0.2 D /mm 0.8± 0.1 resistance /mΩ ≤4 >4 ★推荐焊接尺寸 Recommend Solder Pad Dimension Dimensions Resistance range /mΩ a/mm ≤4 4.0 >4 b/mm L/mm 3.1 1.3 2.1 4.1 ★印字标识 Marking R001=1mΩ R050=50mΩ 深圳市业展电子有限公司 Shenzhen Yezhan Electronics Co.,Ltd Confidential and Proprietary To Shenzhen Yezhan electronics all right reserved 2 电流采样晶片电阻 Ultra Low Ohm Chip Resistors ★工作特性 Performance Characteristics Iterms Additional Requirements Reference JESD22 Temperature 1000 Cycles(-55℃ to +125℃) Cycling Measurement at 24± 2hours after test conclusion High Temperature Exposure Moisture Resistance Biased Humidity Operational Life Limits Method JA104 1000hrs.@T=125℃.Unpowered. MIL-STD-202 Measurement at 24± 2hours after test conclusion Method 108 t=24hrs/cycle.Note:Steps 7a & 7b not required. Unpowered. Measurement at 24± 2hours after test conclusion 1000hrs 85℃/85%RH。Note:Specified MIL-STD-202 Method 106 MIL-STD-202 conditions:10% of operating power. Measurement at 24± 2hours after test conclusion Condition D Steady State TA=125℃ at rated Method 103 MIL-STD-202 power. Measurement at 24± 2hours after test conclusion ± 0.5% Method 108 ± 1% ± 0.5% ± 0.5% ± 1% 95% Solderability 235℃± 5℃,2s± 0.5s J-STD-202 Coverage Minimum 5 g's for 20 min, 12 cycles each of 3 orientations. Note: Use 8"X5" PCB .031" thick 7 secure points on one long side and 2 secure points at corners Vibration of MIL-STD-202 Method 204 opposite sides. Parts mounted within 2" from ± 0.5% any secure point. Test from 10-2000 Hz. Measurement at 24± 2hours after test conclusion Resistance to 260℃± 5℃,10s± 1s MIL-STD-202 Soldering Heat Measurement at 24± 2hours after test conclusion Method 210 Short Time 5× Rated power for 5 s MIL-STD-202 Overload Measurement at 24± 2hours after test conclusion Method 201 ± 0.5% ± 0.5% 深圳市业展电子有限公司 Shenzhen Yezhan Electronics Co.,Ltd Confidential and Proprietary To Shenzhen Yezhan electronics all right reserved 3 电流采样晶片电阻 Ultra Low Ohm Chip Resistors ★功率曲线 Power Derating Curve ★温度系数曲线 Temperature Coefficient of Resistance Curve ★订购信息 Ordering Date 产品型号 Model 规格型号 Type 12:2512 额定功率 Rated Power 2:2W 阻值 Resistance 50F:50mΩ 1%精度 W: 其他 YLR 12 2 50F W 深圳市业展电子有限公司 Shenzhen Yezhan Electronics Co.,Ltd Confidential and Proprietary To Shenzhen Yezhan electronics all right reserved 4 电流采样晶片电阻 Ultra Low Ohm Chip Resistors ★包装方式 Embossed Plastic Tape Specifications 储藏条件 Storage Conditions: Temperature:5℃~35℃, Humidity:40%~75% 包装数量 Number of Package 3000 个/盘 3000 Pieces / Package Items Type A B W F E P1 P2 P0 D0 t Size YLR2512 3.6 6.9 12 5.5 1.75 4.0 2.0 4.0 Φ1.5 1.2 深圳市业展电子有限公司 Shenzhen Yezhan Electronics Co.,Ltd Confidential and Proprietary To Shenzhen Yezhan electronics all right reserved 5
YLR12-2-1F-W 价格&库存
很抱歉,暂时无法提供与“YLR12-2-1F-W”相匹配的价格&库存,您可以联系我们找货
YLR12-2-1F-W
    • 1+0.56350
    库存:20
