PIME104T-R36MS0R765
PIME104T-R36MS0R765
    CYNTEC(乾坤)
    SMD
    功率电感 SMD
PIME104T-R36MS0R765 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : PIME104T-001 REVISION : A2 PAGE : 1 OF 3 Power Choke Coil PIME104T type  Features High performance (Isat) realized by metal dust core. Low profile Thickness max. 4.0mm Low loss realized with low DCR Capable of corresponding high frequency (3MHz) 100% lead (Pb) free meet RoHS standard :  Application DC/DC converter for CPU in Notebook PC Thin type on-board power supply module for exchanger VRM for server  Outline Dimensions L A' A Code B W B' H  Dimensions (mm) L 11.15 ± 0.35 W 10 ± 0.3 T 3.8 ± 0.2 A 2.0 ± 0.5 A’ 2.5 ± 0.1 B 3.0 ± 0.5 B’ 5.0 ± 0.2 H 0 ~ +0.15 T Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown above after confirming and safety. B A C A 4.1 B 5.4 C 13.6 Unit : mm CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : PIME104T-001 REVISION : A2 PAGE : 2 OF 3 Specifications Part Number PIME104T-R36MS0R765 PIME104T-R36MS0R825 PIME104T-R45MS1R007 PIME104T-R56MS1R407 PIME104TR68MS1R607 PIME104T-R88MS2R307 PIME104T1R0MS2R307 L0 Inductance ( µH ) @ (0A) 0.36 0.36 0.45 0.56 0.68 0.88 1.0 Rdc ( mΩ) 0.76 ± 5% 0.82 ± 5% 1.0 ± 7% 1.4 ± 7% 1.6 ± 7% 2.3 ± 7% 2.3 ± 7% Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Typical Typical 40.0 37.0 35.0 30.0 28.0 27.0 25.0 40.0 40.0 38.0 35.0 33.0 32.0 30.0 :If you require another part number please contact with us. **:Inductance Tolerance ± 20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate △T of 40℃ Note 4.: Isat : DC current (A) that will cause Lo to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to + 125℃ Note 6.: The part temperature (ambient + temp rise ) should not exceed 125℃ under worse case * operating conditions. Circuit design , component placement, PWB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7. : The rated current as listed is either the saturation current or the heating current depending on which value is lower. CYNTEC CO., LTD. 乾坤科技股份有限公司 PIME104T-R36MS0R765 60 INDUCTANCE(µH) ℃ 0.21 TEMP RISE ( ) 40 0.14 ℃ 20 0.07 INDUCTANCE(µH) 0.28 TEMP RISE( ) 80 0.00 5 80 0.30 0.24 INDUCTANCE(µH) 0.18 TEMP RISE ( ) ℃ 20 0 0 5 10 15 20 60 INDUCTANCE(µH) ℃ 40 TEMP.RISE( ) ℃ 20 0.09 0.00 INDUCTANCE(µH) 0.36 TEMP. RISE( ) 80 15 20 25 30 35 DC BIAS(Amps) 40 45 50 80 INDUCTANCE(µH) 0.39 TEMP.RISE( ) 60 ℃ 40 0.26 20 0.13 0.00 ℃ 10 15 20 25 30 DC BIAS(Amps) 35 40 80 0.80 60 INDUCTANCE(µH) 0.40 TEMP.RISE( ) ℃ 40 20 0.20 0.00 0 0 5 10 15 20 25 DC BIAS(Amps) 65 100 60 INDUCTANCE(µH) ℃ 0.36 TEMP.RISE( ) 40 0.24 ℃ 20 0.12 0 5 10 15 20 25 30 35 40 45 30 35 40 PIME104T-R88MS2R307 100 0.90 80 0.72 60 0.54 INDUCTANCE(µH) 0.36 TEMP.RISE( ) ℃ 40 20 0 0 100 1.00 0.60 60 0.00 45 PIME104T-1R0MS2R307 1.20 55 0.18 ℃ TEMP. RISE( ) 5 50 80 1.08 0 0 45 0.48 0 100 0.65 0.52 40 DC BIAS(Amps) PIME104T-R68MS1R607 0.78 35 0.60 55 INDUCTANCE(µH) 10 TEMP. RISE( ) 5 30 0.00 0 0 25 PIME104T-R56MS1R407 0.72 100 0.45 0.18 40 0.12 ℃ DC BIAS(Amps) PIME104T-R45MS1R007 0.27 60 0.00 10 15 20 25 30 35 40 45 50 55 60 65 70 0.54 INDUCTANCE(µH) 100 PIME104T-R36MS0R825 DC BIAS(Amps) INDUCTANCE(µH) : 3 OF 3 0.06 0 0 INDUCTANCE(µH) PAGE 0.36 0.35 INDUCTANCE(µH) 0.42 100 : A2 TEMP RISE( ) 0.42 REVISION TEMP RISE( ) Current Characteristic : PIME104T-001 5 10 15 20 25 DC BIAS(Amps) 30 35 40 ℃ TEMP. RISE( )  DOCUMENT
PIME104T-R36MS0R765 价格&库存
很抱歉,暂时无法提供与“PIME104T-R36MS0R765”相匹配的价格&库存,您可以联系我们找货
