6R3AREP271M05X8E15PFBT
    APAQ(钰邦)
    AEC_D5X8MM_TM
    贴片铝电解电容 AEC_D5X8MM_TM
6R3AREP271M05X8E15PFBT 数据手册
CUSTOMER: 連迪 Doc No: MES010996 Rev: A0 RoHS Comp. 承認書 Halogen Free APPROVAL SHEET CAP PL 270uF 6.3V Φ5.0*8.0mm Specifications description DIP ±20%, 105℃ 3000hrs : Package Type: Taping Type APAQ P/N 6R3AREP271M05X8E15PFBT : Customer P/N : Date Approved by Checked by 陳明宗 梁名琮 APAQ R&D 2022.08.03 APPROVAL Approved by Customer (Signing or stamping here) : Approved Date : 鈺邦科技股份有限公司 APAQ TECHNOLOGY CO., LTD 竹南科學園區 苗栗縣竹南鎮科東三路 2&6 號 4 樓 4F., No.2 & 6, Kedong 3rd Rd., Chunan Science Park, Miaoli County 350, Taiwan ,( R.O.C.) PAGE 1 OF 19 AP-CON AREP SERIES SPECIFICATION 1. Application This specification shall be specified to conductive polymer aluminum solid electrolytic capacitors of AREP series. 2. Composition of part number 6R3 AREP 821 M 10A2 EXXPFBT Rated voltage Series code Capacitance Cap tolerance Size code Special code 2.1 Rated voltage code Table 1 Rated voltage and surge voltage Rated voltage code Rated voltage (V) Surge voltage (V) 6R3 6.3 7.2 7R5 7.5 8.6 100 10 11.5 120 12 13.8 160 16 18.4 250 25 28.8 350 35 40.3 500 50 57.5 101 100 115 2.2 Capacitance code Table 2 Rated capacitance Capacitance code Capacitance (uF) 3R3 3.3 100 10 821 820 122 1200 2.3 Capacitance tolerance code Table 3 Capacitance tolerance Cap tolerance code Cap tolerance M 20% 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:呂姿儀 CHECKED BY:梁名琮 TITLE:AP-CON AREP SERIES SPECIFICATION DOCUMENT NO. APAQ TECHNOLOGY CO., LTD APPROVED BY:陳明宗 REV MES010996 A0 PAGE 2 OF 19 2.4 Size code Table 4 Dimension of radial type capacitors Size code Diameter Case length (mm) (mm) 5 8 05X8 2.5 Special code Special code Remark EXX E15 : ESR 15 mΩ max PFB Pitch to pitch distance 2.5mm T Taping Type 3. Rating 3.1 Category temperature range -55 to +105 oC 3.2 Surge voltage Rated voltage * 1.15 3.3 Rated ripple current Rated ripple current shall be in accordance with standard ratings list. These current are rms values of sine wave of 100kHz at 105 oC. 3.4 Standard ratings Table 5 Standard ratings WV/Vdc Cap Size (SV) 6.3 (7.2) (μF) Code 270 05X8 Leakage Current tanδ (μA) 340 0.10 ESR Rated Ripple Current (mΩmax/20℃, (mArms/ 105℃ 100k to 300kHz) /100kHz) 15 2,950 Part No. 6R3AREP271M05X8E15PFBT 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:呂姿儀 CHECKED BY:梁名琮 TITLE:AP-CON AREP SERIES SPECIFICATION DOCUMENT NO. APAQ TECHNOLOGY CO., LTD APPROVED BY:陳明宗 REV MES010996 A0 PAGE 3 OF 19 4. Construction and dimensions. 4.1 Construction Radial type capacitors shall be enclosed wound element, where anode and cathode foils with lead wire termination shall be winded together with separator, with conductive polymer electrolyte in a plastic coated aluminum case and sealed up tightly with rubber. Fig. 1 Cross-section view Table 6 Compositions Construction Materials Anode foil Aluminum 1 Element Cathode foil Aluminum Separator Synthetic fiber 2 Seal Rubber 3 Aluminum tab Aluminum 4 Lead wire Tinned Lead 5 Case Plastic coated aluminum 4.2 Outer dimensions Outer dimensions shall be in accordance with Fig. 2, and the dimensions in each size shall be specified on Table 7. Fig. 2 Dimension 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:呂姿儀 CHECKED BY:梁名琮 TITLE:AP-CON AREP SERIES SPECIFICATION DOCUMENT NO. APAQ TECHNOLOGY CO., LTD APPROVED BY:陳明宗 REV MES010996 A0 PAGE 4 OF 19 Table 7 Dimension Size code D±0.5 05X8 (mm) L (mm) α (mm) d0.05 (mm) F±0.3 (mm) 5 8 -0.5~1 0.5 2.5 5. Marking The following items shall be marked on each capacitor, as showed in Fig. 3. (1) Polarity (2) Series (3) Year code: A-2020(WX),B-2021(WX),C-2022(WX) N-2020(HB),O-2021(HB),P-2022(HB) (4) Production period code (5) Manufacturer's identification mark (6) Rated capacitance (7) Rated voltage (8) The color of marking ink is Red - + Figure 3 Marking 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:呂姿儀 CHECKED BY:梁名琮 TITLE:AP-CON AREP SERIES SPECIFICATION DOCUMENT NO. APAQ TECHNOLOGY CO., LTD APPROVED BY:陳明宗 REV MES010996 A0 PAGE 5 OF 19 6.Specification for automatic insertion 6.1 Tape Adhesion The adhesion of the hold-down tape to the carrier tape shall be a minimum 1N. 6.2 Component Adhesion The component, when tested as shown Fig. 4 applying the force of 5N, shall not be removal the tape. Fig. 4 7. The electrical and mechanical performance and testing method 7.1 Measurement condition Each measurement shall be conducted at a temperature of 15 to 35 oC, and relative humidity of 45 to 85%. Furthermore, these measurements shall be preferably conducted at a temperature of 202 oC, and relative humidity of 60 to 70%, while the capacitors shall be kept enough time in the measuring temperature. 7.2 Voltage treatment If leakage current is doubtful, measure it after performing voltage treatment, which shall contain the following steps: (1) Applied DC rated voltage to the capacitors for 60 minutes at 1052 oC. (2) Cooled down to room temperature with applying voltage. (3) Discharged through a resistor of approximately 1/V. 7.3 Electrical performance 7.3.1 Tolerance on rated capacitance Rated capacitance shall meet within -20% to +20% (M) tolerance against the rated capacitance measured at 120Hz10% at 202 oC. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:呂姿儀 CHECKED BY:梁名琮 TITLE:AP-CON AREP SERIES SPECIFICATION DOCUMENT NO. APAQ TECHNOLOGY CO., LTD APPROVED BY:陳明宗 REV MES010996 A0 PAGE 6 OF 19 7.3.2 Leakage current DC rated voltage shall be applied between anode and cathode lead wire terminations of a capacitor through 1k protective resistance, and the leakage current shall be less than or equal to the value listed in table 5 after 2 minutes with the voltage reaching the rated value at 202 oC.If the value is doubtful, measure the leakage current after performing voltage treatment as described in section 7.2. 7.3.3 Tangent of loss angle (tan) Tan values shall be less than or equal to 0.10 measured at 120Hz10% at 202 oC. 7.3.4 Equivalent Series Resistance (ESR) ESR at 100kHz measured under the following conditions listed in Table 8 shall be less than or equal to the value in Table 5. Table 8 Measurement requirement of ESR Equipment Agilent Technology 4263B or equivalent Test Fixture Agilent Technology 16047E or equivalent Compensation Short and Open compensation would be required. Short correction is performed using the shorting plate made of 0.5 thickness copper plate with gold coating. Signal Level 500mV Frequency 100kHz Measurement Point Point of lead wire within 1mm form the body 7.3.5 Impedance at high and low temperature Impedance at 100kHz at -553 oC or 1052 oC shall meet the values listed in Table 9. Table 9 Impedance at low or high temperature Impedance ratio Performance Z(-55 oC)/Z(+20 oC)  1.25 Z(105 oC)/Z(+20 oC)  1.25 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:呂姿儀 CHECKED BY:梁名琮 TITLE:AP-CON AREP SERIES SPECIFICATION DOCUMENT NO. APAQ TECHNOLOGY CO., LTD APPROVED BY:陳明宗 REV MES010996 A0 PAGE 7 OF 19 7.4 Mechanical performance 7.4.1 Pull strength of lead wire terminations With the body of a capacitor fixed, the load listed in Table 10 shall be applied to the lead wire termination in its draw out direction, gradually up to the specified value and held for 101 seconds. After this test, that capacitor shall not appear any change defective in use. Table 10 Pull strength load of lead wire terminations Lead wire diameter (mm) Load strength (N) Load strength (kgf) 0.35
6R3AREP271M05X8E15PFBT 价格&库存
很抱歉,暂时无法提供与“6R3AREP271M05X8E15PFBT”相匹配的价格&库存,您可以联系我们找货
