6R3ARCP821M06X8PZ
6R3ARCP821M06X8PZ
    APAQ(钰邦)
    AEC_D6.3X8MM_TM
    贴片铝电解电容 AEC_D6.3X8MM_TM
6R3ARCP821M06X8PZ 数据手册
AP-CON Aluminum Solid Electrolytic Capacitor ARCP Series Charger  Rated voltage: 6.3~35Vdc    Endurance 2000hrs at 105℃ Suitable for AC-DC DC-DC converters, voltage regulators and decoupling applications RoHS Compliant Specification Category Temperature Range -55 to 105℃ Rated Capacitance Range 100 to 1500 (μF) Rated Voltage Range 6.3 to 35Vdc Capacitance Tolerance ±20% (M) Surge Voltage Rated voltage X 1.15 (at 105°C) Dissipation Factor Leakage Current Shall not exceed values shown in standard ratings. 0.1 max. (at 20°C 120Hz) (at 20°C after 2 mins.) 105℃, 2000hrs, rated voltage applied Appearance No significant damage Endurance Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value 60℃, 90 to 95% RH, 1000hrs, no voltage applied Appearance No significant damage Damp Heat (Steady State) Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value 2,000 cycles and each one includes charge with surge voltage specified at 105°C for 0.5min through a protective resistor (R=1kΩ) and discharge for 5.5min. Appearance No significant damage Surge Voltage Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value Dimensions and Marking Product Specifications are subject to change without notice. SIZE Code øD±0.5 max L α 05X7 05X8 05A0 05A1 06X6 06X8 06A0 06A1 06A4 08X8 08A2 08A6 10A2 5.0 5.0 5.0 5.0 6.3 6.3 6.3 6.3 6.3 8.0 8.0 8.0 10.0 7.0 8.0 10.0 11.0 6.0 8.0 10.0 11.0 14.0 8.0 12.0 16.0 12.0 -0.5~1.0 -0.5~1.0 -0.5~1.0 -0.5~1.0 -0.5~1.0 -0.5~1.0 -0.5~1.0 -0.5~1.0 -0.5~1.0 -0.5~1.0 -0.5~1.0 -0.5~1.0 -0.5~1.0 ød F±0.4 ±0.05 0.5 0.5 0.5 0.5 0.45 0.6 0.6 0.6 0.5 0.6 0.6 0.6 0.6 Rev.A 2.0 2.0 2.0 2.0 2.5 2.5 2.5 2.5 2.5 3.5 3.5 3.5 5.0 AP-CON Aluminum Solid Electrolytic Capacitor ARCP Series Power Standard Ratings WV/Vdc (SV) 6.3 (7.2) 7.5 (8.6) 12 (13.8) 16 (18.4) 25 (28.8) 35 (40.3) Cap (μF) Size Code Leakage Current (μA) 270 330 390 470 470 470 560 680 680 820 1000 1500 500 680 820 820 1000 1500 470 560 680 820 150 330 330 470 470 560 680 390 470 680 680 100 120 150 220 05X7 05X8 05X8 05X8 06X6 06X8 06X8 05A1 06X8 06X8 06A0 06A4 05X8 06X8 06A0 06A1 06A1 06A4 06A0 06A0 06A1 06A1 05A0 05A1 06X8 06A0 06A1 06A1 06A4 06A4 06A4 08A6 10A2 06X8 08X8 08A2 08A2 340 500 500 592 592 592 705 857 857 1,033 1,260 1,890 750 1,020 1,230 1,230 1,500 2,250 1,128 1,344 1,632 1,968 480 1,056 1,056 1,504 1,504 1,792 2,176 1,950 2,350 3,400 3,400 700 840 1,050 1,540 Rated Ripple ESR Current (mΩmax/20%, (mArms/ 105℃ 100k to300kHz) /100kHz) Product Specifications are subject to change without notice. 12 12 15 12 20 12 12 15 12 12 10 10 12 12 11 11 11 10 12 12 18 15 15 20 20 16 16 20 11 16 15 14 14 35 30 25 25 3,500 4,050 4,510 4,050 2,970 4,700 4,700 3,200 3,900 4,700 4,700 6,100 3,500 4,780 4,840 4,840 4,700 6,100 3,900 3,900 3,900 4,000 3,700 2,670 2,800 4,000 4,000 3,500 4,500 3,550 3,800 5,000 5,100 2,350 2,800 3,000 2,890 Part No. 6R3ARCP271M05X7 6R3ARCP331M05X8 6R3ARCP391M05X8 6R3ARCP471M05X8 6R3ARCP471M06X6 6R3ARCP471M06X8 6R3ARCP561M06X8 6R3ARCP681M05A1 6R3ARCP681M06X8 6R3ARCP821M06X8 6R3ARCP102M06A0 6R3ARCP152M06A4 7R3ARCP501M05X8 7R3ARCP681M06X8 7R3ARCP821M06A0 7R3ARCP821M06A1 7R3ARCP102M06A1 7R3ARCP152M06A4 120ARCP471M06A0 120ARCP561M06A0 120ARCP681M06A1 120ARCP821M06A1 160ARCP151M05A0 160ARCP331M05A1 160ARCP331M06X8 160ARCP471M06A0 160ARCP471M06A1 160ARCP561M06A1 160ARCP681M06A4 250ARCP391M06A4 250ARCP471M06A4 250ARCP681M08A6 250ARCP681M10A2 350ARCP101M06X8 350ARCP121M08X8 350ARCP151M08A2 350ARCP221M08A2
6R3ARCP821M06X8PZ 价格&库存
很抱歉,暂时无法提供与“6R3ARCP821M06X8PZ”相匹配的价格&库存,您可以联系我们找货
