6R3AREP391M05X8E14P35 数据手册
AP-CON Aluminum Solid Electrolytic Capacitor
AREP Series Power
Super low ESR, high ripple current capability, high voltage
Rated voltage: 6.3~16Vdc
Endurance 3000hrs at 105℃
Suitable for AC-DC DC-DC converters, voltage regulators and decoupling applications
RoHS Compliant
Specification
Category Temperature Range -55 to 105℃
Rated Voltage Range
Capacitance Tolerance
Surge Voltage
Rated voltage X 1.15 (at 105°C) Dissipation Factor
Leakage Current
Shall not exceed values shown in standard ratings.
6.3 to 16Vdc
±20% (M)
0.1 max. (at 20°C 120Hz)
(at 20°C after 2 mins.)
105℃, 3000hrs, rated voltage applied
Appearance
No significant damage
Endurance
Capacitance Change
≦ ±20% of the initial value
DF(tanδ)
≦ 150% of the initial specified value
ESR
Leakage current
≦ The initial specified value
60℃, 90 to 95% RH, 1000hrs, no voltage applied
Appearance
Damp Heat (Steady State)
Capacitance Change
DF(tanδ)
ESR
Leakage current
1,000 cycles and each one includes charge with surge voltage specified at 105°C for 0.5min through a
protective resistor (R=1kΩ) and discharge for 5.5min.
Appearance
Surge Voltage
Capacitance Change
DF(tanδ)
ESR
Leakage current
Dimensions and Marking
Series
Polarity
marking (-)
Date code
Capacitance
SIZE
Code
øD±0.5
max
L
α
ød
±0.05
F±0.4
05X8
06X8
06A0
06A1
08A2
08A6
10A2
10A6
10B0
5.0
6.3
6.3
6.3
8.0
8.0
10.0
10.0
10.0
8.0
8.0
10.0
11.0
11.5
16.0
11.5
16.0
20.0
1.0
1.0
1.0
1.0
1.5
1.5
1.5
1.5
1.5
0.5
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
2.0
2.5
2.5
2.5
3.5
3.5
5.0
5.0
5.0
Voltage
Product Specifications are subject to change without notice.
Rev.A
AREP Series Power
Standard Ratings
WV/Vdc
(SV)
6.3
(7.2)
7.5
(8.6)
12
(13.8)
16
(18.4)
Cap
(μF)
Size
Code
330
470
470
560
680
820
1000
1500
500
680
820
470
560
680
820
330
470
560
680
820
1000
1000
1500
2200
2500
05X8
05X8
06X8
06X8
06X8
06X8
06A0
08A2
05X8
06X8
06A1
06A0
06A0
06A1
06A1
06X8
06A1
06A1
08A2
08A2
08A6
10A2
10A6
10B0
10B0
ESR
Leakage
(mΩmax/20%,
Current
100k
(μA)
to300kHz)
500
592
592
705
857
1,033
1,260
1,890
750
1,020
1,230
1,128
1,344
1,632
1,968
1,056
1,505
1,792
2,176
2,624
3,200
3,200
4,800
7,040
8,000
8
8
8
8
8
8
8
7
12
12
10
12
12
18
15
10
10
12
10
8
8
Rated Ripple
Current
(mArms/ 105℃
/100kHz)
Part No.
4,050
4,050
4,700
4,700
4,700
4,700
4,700
6,100
3,500
4,780
5,200
3,900
3,900
3,900
4,000
2,800
4,000
3,500
5,230
5,230
6,100
5,400
6,600
8,100
8,100
6R3AREP331M05X8
6R3AREP471M05X8
6R3AREP471M06X8
6R3AREP561M06X8
6R3AREP681M06X8
6R3AREP821M06X8
6R3AREP102M06A0
6R3AREP152M08A2
7R5AREP501M05X8
7R5AREP681M06X8
7R5AREP821M06A1
120AREP471M06A0
120AREP561M06A0
120AREP681M06A1
120AREP821M06A1
160AREP331M06X8
160AREP471M06A1
160AREP561M06A1
160AREP681M08A2
160AREP821M08A2
160AREP102M08A6
160AREP102M10A2
160AREP152M10A6
160AREP222M10B0
160AREP252M10B0
