EKMR451VSN271MR30S
EKMR451VSN271MR30S
    NCC(贵弥功)
    插件,D30xL30mm
    贴片铝电解电容 AEC_D30X30MM_TM
EKMR451VSN271MR30S 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS KMR Series Downsized snap-ins, 105℃ KMR ・Downsized 5mm in height from current snap-ins KMQ series ・Max. 50% up ripple current than same case size of KMQ series ・Endurance with ripple current : 2,000 hours at 105℃ ・Rated voltage range : 160 to 450Vdc, Capacitance range : 100 to 3,300µF ・For inverter control, switching power supplies ・Non solvent resistant type ・RoHS2 Compliant Downsized KMQ ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -25 to +105℃ 160 to 450Vdc ±20% (M) I≦3 CV Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Rated voltage (Vdc) 160 to 250V 315 to 400V 420 & 450V tanδ(Max.) 0.15 0.15 0.20 Rated voltage (Vdc) 160 to 250V 315 to 400V 420 & 450V Z(-25℃)/Z(+20℃) 4 8 8 Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20℃, 120Hz) (at 20℃ after 5 minutes) (at 20℃, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 2,000 hours at 105℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±15% of the initial value D.F. (tanδ) ≦150% of the initial specified value Leakage current ≦The initial specified value Endurance Shelf Life ◆DIMENSIONS [mm] Sleeve (PET : Brown) ●Terminal PC board pin-out (View from Solder side) Negative mark φD+1max. 10 2-φ2 4.0±0.5 L±2.5 Vent Code : LI (φ35) Sleeve (PET : Brown) Negative mark PC board pin-out (View from Solder side) 4.2±0.5 Code : VS (φ22 to φ35) : Standard 2-1.2×6 φD+1max. ●Terminal Vent 5±0.5 L±2.5 4.5±1 14.2±1 The standard design has no plastic disc. ◆PART NUMBERING SYSTEM 1 2 3 4 E KMR 5 6 7 8 9 10 VS N 11 12 13 14 M 15 16 17 18 S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 100µF:101, 2,700µF:272) Dummy terminal code Terminal code (VS, LI) Voltage code (ex. 160V:161, 315V:3B1, 450V:451) Series code Category Please refer to "Product code guide (snap-in type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001V 2021 LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Downsized snap-ins, 105℃ KMRSeries ◆STANDARD RATINGS WV (Vdc) 160 180 200 Cap (µF) 560 680 820 820 1,000 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,500 1,500 1,800 1,800 1,800 1,800 2,200 2,200 2,700 2,700 3,300 470 560 680 680 820 820 1,000 1,000 1,000 1,200 1,200 1,200 1,200 1,500 1,500 1,500 1,800 1,800 2,200 2,200 2,200 2,200 2,700 560 560 680 680 820 820 820 1,000 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,500 1,800 1,800 2,200 2,200 2,700 Case size Rated ripple current φD×L(mm) (Arms/105℃,120Hz) 22 ×25 22 × 30 22× 35 25.4 ×25 22 ×40 25.4×30 30 × 25 22× 45 22 ×50 25.4×35 25.4× 40 25.4× 45 30 ×30 35 ×25 25.4× 50 30 × 35 30 ×40 35 ×30 30 ×45 35 × 35 30× 50 35 ×40 35 ×45 22 ×25 22 ×30 22 × 35 25.4 ×25 22 ×40 25.4× 30 22 × 45 25.4 ×35 30 ×25 22× 50 25.4×40 30 ×30 35 ×25 25.4× 45 25.4×50 30×35 30 ×40 35 ×30 30× 45 30×50 35 ×35 35 ×40 35× 45 22 ×30 25.4 ×25 22× 35 25.4 ×30 22 × 40 25.4×35 30 ×25 22 ×50 25.4 ×40 30 ×30 25.4×45 30× 35 35×25 25.4 ×50 30 ×40 35× 30 30×45 35 ×35 30 × 50 35 × 40 35 × 45 1.58 1.83 2.06 1.89 2.33 2.15 1.90 2.61 2.69 2.45 2.82 2.88 2.39 2.17 3.22 2.73 2.82 2.47 3.23 2.79 3.66 3.23 3.68 1.45 1.66 1.87 1.72 2.11 1.94 2.38 2.24 1.90 2.69 2.52 2.14 1.94 2.88 2.94 2.49 2.82 2.47 3.23 3.31 2.79 2.92 3.33 1.66 1.56 1.87 1.77 2.11 2.03 1.72 2.45 2.30 1.95 2.58 2.23 1.94 2.94 2.58 2.25 2.92 2.53 3.31 2.92 3.33 Part No. EKMR161VSN561MP25S EKMR161VSN681MP30S EKMR161VSN821MP35S EKMR161VSN821MQ25S EKMR161VSN102MP40S EKMR161VSN102MQ30S EKMR161VSN102MR25S EKMR161VSN122MP45S EKMR161VSN122MP50S EKMR161VSN122MQ35S EKMR161VSN152MQ40S EKMR161VSN152MQ45S EKMR161VSN152MR30S EKMR161VSN152MA25S EKMR161VSN182MQ50S EKMR161VSN182MR35S EKMR161VSN182MR40S EKMR161VSN182MA30S EKMR161VSN222MR45S EKMR161VSN222MA35S EKMR161VSN272MR50S EKMR161VSN272MA40S EKMR161VSN332MA45S EKMR181VSN471MP25S EKMR181VSN561MP30S EKMR181VSN681MP35S EKMR181VSN681MQ25S EKMR181VSN821MP40S EKMR181VSN821MQ30S EKMR181VSN102MP45S EKMR181VSN102MQ35S EKMR181VSN102MR25S EKMR181VSN122MP50S EKMR181VSN122MQ40S EKMR181VSN122MR30S EKMR181VSN122MA25S EKMR181VSN152MQ45S EKMR181VSN152MQ50S EKMR181VSN152MR35S EKMR181VSN182MR40S EKMR181VSN182MA30S EKMR181VSN222MR45S EKMR181VSN222MR50S EKMR181VSN222MA35S EKMR181VSN222MA40S EKMR181VSN272MA45S EKMR201VSN561MP30S EKMR201VSN561MQ25S EKMR201VSN681MP35S EKMR201VSN681MQ30S EKMR201VSN821MP40S EKMR201VSN821MQ35S EKMR201VSN821MR25S EKMR201VSN102MP50S EKMR201VSN102MQ40S EKMR201VSN102MR30S EKMR201VSN122MQ45S EKMR201VSN122MR35S EKMR201VSN122MA25S EKMR201VSN152MQ50S EKMR201VSN152MR40S EKMR201VSN152MA30S EKMR201VSN182MR45S EKMR201VSN182MA35S EKMR201VSN222MR50S EKMR201VSN222MA40S EKMR201VSN272MA45S WV (Vdc) 250 315 350 Cap (µF) 330 390 470 560 560 560 680 680 820 820 820 820 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,800 2,200 180 220 270 270 330 330 390 390 390 470 470 470 470 560 560 680 680 680 820 820 1,000 1,000 1,200 1,200 150 220 220 270 270 330 330 330 330 390 390 390 390 470 560 560 560 560 680 680 820 Case size Rated ripple current φD×L(mm) (Arms/105℃,120Hz) 22 × 25 22 × 30 22 × 35 22 × 40 25.4 × 30 30 × 25 22 × 45 25.4 × 35 25.4 × 40 25.4 × 45 30 × 30 35 × 25 25.4 × 50 30 × 35 30 × 40 30 × 45 35 × 35 30 × 50 35 × 40 35 × 45 35 × 50 22 × 25 22 × 30 22 × 35 25.4 × 25 22 × 40 25.4 × 30 22 × 45 25.4 × 35 30 × 25 22 × 50 25.4 × 40 30 × 30 35 × 25 25.4× 45 30 × 35 25.4 × 50 30 × 40 35 × 30 30 × 45 35 × 35 30 × 50 35 × 40 35 × 45 35 × 50 22 × 25 22 × 30 25.4× 25 22 × 35 25.4 × 30 22 × 40 22 × 45 25.4 × 35 30 × 25 22 × 50 25.4 × 40 30 × 30 35 × 25 25.4 × 45 25.4 × 50 30 × 35 30 × 40 35 × 30 30 × 45 35 × 35 30 × 50 1.21 1.38 1.56 1.74 1.61 1.42 1.97 1.85 2.08 2.13 1.77 1.60 2.40 2.03 2.31 2.38 2.06 2.73 2.41 2.72 3.10 0.91 1.06 1.20 1.15 1.37 1.30 1.52 1.48 1.39 1.72 1.67 1.57 1.52 1.86 1.78 2.10 2.03 1.90 2.31 2.13 2.61 2.46 2.78 2.86 0.84 1.06 1.04 1.20 1.18 1.37 1.40 1.36 1.28 1.56 1.52 1.43 1.38 1.71 1.90 1.78 1.84 1.72 2.10 1.94 2.36 Part No. EKMR251VSN331MP25S EKMR251VSN391MP30S EKMR251VSN471MP35S EKMR251VSN561MP40S EKMR251VSN561MQ30S EKMR251VSN561MR25S EKMR251VSN681MP45S EKMR251VSN681MQ35S EKMR251VSN821MQ40S EKMR251VSN821MQ45S EKMR251VSN821MR30S EKMR251VSN821MA25S EKMR251VSN102MQ50S EKMR251VSN102MR35S EKMR251VSN122MR40S EKMR251VSN122MR45S EKMR251VSN122MA35S EKMR251VSN152MR50S EKMR251VSN152MA40S EKMR251VSN182MA45S EKMR251VSN222MA50S EKMR3B1VSN181MP25S EKMR3B1VSN221MP30S EKMR3B1VSN271MP35S EKMR3B1VSN271MQ25S EKMR3B1VSN331MP40S EKMR3B1VSN331MQ30S EKMR3B1VSN391MP45S EKMR3B1VSN391MQ35S EKMR3B1VSN391MR25S EKMR3B1VSN471MP50S EKMR3B1VSN471MQ40S EKMR3B1VSN471MR30S EKMR3B1VSN471MA25S EKMR3B1VSN561MQ45S EKMR3B1VSN561MR35S EKMR3B1VSN681MQ50S EKMR3B1VSN681MR40S EKMR3B1VSN681MA30S EKMR3B1VSN821MR45S EKMR3B1VSN821MA35S EKMR3B1VSN102MR50S EKMR3B1VSN102MA40S EKMR3B1VSN122MA45S EKMR3B1VSN122MA50S EKMR351VSN151MP25S EKMR351VSN221MP30S EKMR351VSN221MQ25S EKMR351VSN271MP35S EKMR351VSN271MQ30S EKMR351VSN331MP40S EKMR351VSN331MP45S EKMR351VSN331MQ35S EKMR351VSN331MR25S EKMR351VSN391MP50S EKMR351VSN391MQ40S EKMR351VSN391MR30S EKMR351VSN391MA25S EKMR351VSN471MQ45S EKMR351VSN561MQ50S EKMR351VSN561MR35S EKMR351VSN561MR40S EKMR351VSN561MA30S EKMR351VSN681MR45S EKMR351VSN681MA35S EKMR351VSN821MR50S Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001V 2021 LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Downsized snap-ins, 105℃ KMRSeries ◆STANDARD RATINGS WV (Vdc) 350 400 420 Cap (µF) 820 1,000 1,200 120 180 180 220 220 270 270 270 270 330 330 330 330 390 390 470 470 470 560 560 680 680 820 820 1,000 120 150 150 180 180 220 220 220 220 270 Case size φD×L(mm) Rated ripple current (Arms/105℃, 120Hz) Part No. 2.23 2.54 2.86 0.75 0.96 0.94 1.09 1.07 1.24 1.26 1.23 1.16 1.44 1.40 1.31 1.27 1.55 1.49 1.74 1.69 1.58 1.91 1.76 2.15 2.03 2.30 2.37 2.50 0.78 0.91 0.89 1.03 1.00 1.16 1.19 1.16 1.11 1.36 EKMR351VSN821MA40S EKMR351VSN102MA45S EKMR351VSN122MA50S EKMR401VSN121MP25S EKMR401VSN181MP30S EKMR401VSN181MQ25S EKMR401VSN221MP35S EKMR401VSN221MQ30S EKMR401VSN271MP40S EKMR401VSN271MP45S EKMR401VSN271MQ35S EKMR401VSN271MR25S EKMR401VSN331MP50S EKMR401VSN331MQ40S EKMR401VSN331MR30S EKMR401VSN331MA25S EKMR401VSN391MQ45S EKMR401VSN391MR35S EKMR401VSN471MQ50S EKMR401VSN471MR40S EKMR401VSN471MA30S EKMR401VSN561MR45S EKMR401VSN561MA35S EKMR401VSN681MR50S EKMR401VSN681MA40S EKMR401VSN821MA45S EKMR401VSN821MA50S EKMR401VSN102MA50S EKMR421VSN121MP25S EKMR421VSN151MP30S EKMR421VSN151MQ25S EKMR421VSN181MP35S EKMR421VSN181MQ30S EKMR421VSN221MP40S EKMR421VSN221MP45S EKMR421VSN221MQ35S EKMR421VSN221MR25S EKMR421VSN271MP50S 35 ×40 35 × 45 35× 50 22× 25 22 ×30 25.4×25 22 × 35 25.4 ×30 22 ×40 22 × 45 25.4× 35 30 ×25 22 ×50 25.4× 40 30× 30 35 ×25 25.4×45 30 × 35 25.4× 50 30 ×40 35 ×30 30 × 45 35× 35 30 ×50 35 ×40 35 × 45 35 × 50 35 ×50 22 ×25 22 ×30 25.4× 25 22 ×35 25.4 ×30 22 ×40 22 ×45 25.4× 35 30×25 22 × 50 WV (Vdc) 420 450 Cap (µF) 270 270 270 330 330 390 390 390 470 470 560 560 680 820 100 120 150 150 180 180 220 220 220 270 270 270 270 270 330 330 330 390 470 470 470 560 560 680 Case size φD×L(mm) 25.4 × 40 30 × 30 35 × 25 25.4 × 45 30 × 35 25.4 × 50 30 × 40 35 × 30 30 × 45 35 × 35 30 × 50 35 × 40 35 × 45 35 × 50 22 × 25 22 × 30 22 × 35 25.4 × 25 22 × 40 25.4 × 30 22 × 45 25.4 × 35 30 × 25 22 × 50 25.4 × 40 25.4 × 45 30 × 30 35 × 25 25.4 × 50 30 × 35 35 × 30 30 × 40 30 × 45 30 × 50 35 × 35 35 × 40 35 × 45 35 × 50 Rated ripple current (Arms/105℃, 120Hz) Part No. 1.32 1.26 1.26 1.49 1.45 1.66 1.63 1.58 1.85 1.77 2.07 2.02 2.29 2.59 0.71 0.82 0.94 0.89 1.05 1.00 1.19 1.16 1.11 1.36 1.32 1.35 1.26 1.26 1.52 1.45 1.45 1.63 1.85 1.90 1.77 2.02 2.08 2.36 EKMR421VSN271MQ40S EKMR421VSN271MR30S EKMR421VSN271MA25S EKMR421VSN331MQ45S EKMR421VSN331MR35S EKMR421VSN391MQ50S EKMR421VSN391MR40S EKMR421VSN391MA30S EKMR421VSN471MR45S EKMR421VSN471MA35S EKMR421VSN561MR50S EKMR421VSN561MA40S EKMR421VSN681MA45S EKMR421VSN821MA50S EKMR451VSN101MP25S EKMR451VSN121MP30S EKMR451VSN151MP35S EKMR451VSN151MQ25S EKMR451VSN181MP40S EKMR451VSN181MQ30S EKMR451VSN221MP45S EKMR451VSN221MQ35S EKMR451VSN221MR25S EKMR451VSN271MP50S EKMR451VSN271MQ40S EKMR451VSN271MQ45S EKMR451VSN271MR30S EKMR451VSN271MA25S EKMR451VSN331MQ50S EKMR451VSN331MR35S EKMR451VSN331MA30S EKMR451VSN391MR40S EKMR451VSN471MR45S EKMR451VSN471MR50S EKMR451VSN471MA35S EKMR451VSN561MA40S EKMR451VSN561MA45S EKMR451VSN681MA50S ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) 160 to 250Vdc 315 to 450Vdc 50 0.81 0.77 120 1.00 1.00 300 1.17 1.16 1k 1.32 1.30 10k 1.45 1.41 50k 1.50 1.43 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001V 2021
EKMR451VSN271MR30S 价格&库存
很抱歉,暂时无法提供与“EKMR451VSN271MR30S”相匹配的价格&库存,您可以联系我们找货
EKMR451VSN271MR30S
    • 3117+15.25440
