MHCB06020-R22M-C1
MHCB06020-R22M-C1
    CHILISIN(奇力新)
    SMD
    功率电感 SMD
MHCB06020-R22M-C1 数据手册
RoHS & Halogen Free & REACH Compliance. SPECIFICATION FOR APPROVAL 超利維 Customer: Customer P/N: IE1-8B0365 Drawing No: Quantity: X Pcs. Date : 2018/11/23 MHCB06020-R22M-C1 Chilisin P/N: SPECIFICATION ACCEPTED BY: COMPONENT ENGINEER ELECTRICAL ENGINEER MECHANICAL ENGINEER APPROVED REJECTED 奇力新電子股份有限公司 東莞奇力新電子(東莞廠)有限公司 Chilisin Electronics Corp No. 29, Alley 301, Tehhsin Rd., Hukou,Hsinchu 303, Taiwan TEL:+886-3- 599-2646 FAX:+886-3- 599-9176 E-mail:sales@chilisin.com http://www.chilisin.com Chilisin Electronics (Dongguan) Co., Ltd. No. 78, Puxing Rd., Yuliangwei Administration Area, Qingxi Town, Dongguan City, Guangdong,China TEL:+86-769-8773-0251~3 FAX: +86-769-8773-0232 E-mail:cect@chilisin.com 奇力新電子(湖南廠)有限公司 奇力新電子(越南廠)有限公司 Chilisin Electronics (Vietnam) Limited No 143 - 145, Road No 10, VSIP Hai Phong, Lap Le Commune, Thuy Nguyen Dist, Haiphong City, Vietnam Tel:84-316 255 688 Fax:84-316 255 689 E-mail:sales@chilisin.com Drawn by 吳韋邑 Wayne.Wu HuNan Chilisin Electronics Technology Co., Ltd No. 8, Shaziao Liangshuijing Town, Yuanling County, Huaihua City, Hunan Province 419601, China Tel:86-745-867-5882 E-mail:cect@chilisin.com Checked by 吳韋邑 Wayne.Wu Approved by 劉建志 Richard.Liu YG16600082 MHCB06020 Series Specification 1 Scope: This specification applies to Large current and Low Loss SMD Power INDUCTOR 2 Part Numbering: 3 Rating: Operating Temperature: - 55°C ~ 125°C Storage Temperature: (on tape & reel): -20°C to +40°C; 75% RH max. 4 Marking: Ex : MHCB06020-R22M-C1 Marking : R22 Marking color : Black 5 Standard Testing Condition Temperature Humidity Unless otherwise specified Ordinary Temperature(15 to 35℃) Ordinary Humidity(25 to 85% RH) In case of doubt 20 to 30℃ 50 to 80 %RH MHCB06020 Series Specification 6 Configuration and Dimensions: Dimensions in mm TYPE MHCB06020 A 6.6±0.2 B 6.95±0.35 C 1.8±0.2 D 3.0±0.5 F 1.6±0.5 7 Electrical Characteristics: Part No. MHCB06020-R22M-C1 Inductance (uH ) Tolerance (±%) Test Freq. Irms(A) Typ Isat(A) Typ RDC(mΩ) ±7% Marking 0.22 20 100kHz,0.5V 18 36 2.9 R22 Note: 1.Operating temperature range -55℃~125℃ 2.Isat for Inductance drop 30% from its value without current. 3.Irms for a 40℃ temperature rise from 25℃ ambient. 4.The part temperature (ambient + temp rise) should not exceed 125°C under worst case operating conditions. Circuit design 125°C under worst case operating conditions. Component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 5.Absolute maximum voltage 30VDC MHCB06020 Series Specification 8 MHCB06020 Series 8.1 Construction: 8.2 Material List: MHCB06020 Series Specification 9 PACKAGING 9.1 Packaging -Cover tape The force for tearing off cover tape is 10 to 130 grams in the arrow direction. 9.2 Packaging Quantity TYPE PCS/REEL MHCB06020 1000 9.3 Reel Dimensions Dimensions in mm TYPE A B C D MHCB06020 330 100 13 16 MHCB06020 Series Specification 9 PACKAGING 9.4 Tape Dimensions in mm TYPE A0 B0 K0 D E W P P0 P2 MHCB06020 7.15 7.6 2.4 1.55 1.75 16 12 4 2 10 Recommended Pattern Dimensions in mm TYPE A(mm) MHCB06020 3.5 B(mm) C(mm) 6.05 2.35 11 Note: 1. Please make sure that your product has been evaluated and confirmed against your specifications when our product is mounted to your product. 2. Do not knock nor drop. 3. All the items and parameters in this product specification have been prescribed on the premise that our product is used for the purpose,under the condition and in the environment agreed upon between you and us. You are requested not to use our product deviating from such agreement. 4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950) 5. The moisture sensitivity level (MSL) of products is classified as level 1. MHCB06020 Series Specification 12 Graph:
MHCB06020-R22M-C1 价格&库存
很抱歉,暂时无法提供与“MHCB06020-R22M-C1”相匹配的价格&库存,您可以联系我们找货
