RoHS & Halogen Free & REACH Compliance.
SPECIFICATION FOR APPROVAL
超利維
Customer:
Customer P/N:
IE1-8B0365
Drawing No:
Quantity:
X
Pcs.
DATE:
2018/11/23
MHCB10040-2R2M-C1
Chilisin P/N:
SPECIFICATION
ACCEPTED BY:
COMPONENT
ENGINEER
ELECTRICAL
ENGINEER
MECHANICAL
ENGINEER
APPROVED
REJECTED
奇力新電子股份有限公司
東莞奇力新電子(東莞廠)有限公司
Chilisin Electronics Corp
No. 29, Alley 301, Tehhsin Rd.,
Hukou,Hsinchu 303, Taiwan
TEL:+886-3- 599-2646
FAX:+886-3- 599-9176
E-mail:sales@chilisin.com
http://www.chilisin.com
Chilisin Electronics (Dongguan) Co., Ltd.
No. 78, Puxing Rd., Yuliangwei Administration Area,
Qingxi Town, Dongguan City, Guangdong,China
TEL:+86-769-8773-0251~3
FAX: +86-769-8773-0232
E-mail:cect@chilisin.com
奇力新電子(湖南廠)有限公司
奇力新電子(越南廠)有限公司
Chilisin Electronics (Vietnam) Limited
No 143 - 145, Road No 10, VSIP Hai Phong,
Lap Le Commune, Thuy Nguyen Dist,
Haiphong City, Vietnam
Tel:84-316 255 688 Fax:84-316 255 689
Drawn by
吳韋邑 Wayne.Wu
HuNan Chilisin Electronics Technology Co., Ltd
No. 8, Shaziao Liangshuijing Town, Yuanling
County, Huaihua City, Hunan Province 419601,
China
Tel:86-745-867-5882
Checked by
吳韋邑 Wayne.Wu
Approved by
劉建志 Richard.Liu
YG14B01470
MHCB10040 Series Specification
1 Scope: This specification applies to large current and low loss SMD shielding power
inductor.
2 Part Numbering:
3 Rating:
Operating Temperature: -55℃~125℃(Including self - temperature rise)
Storage Temperature: (on tape & reel): -20°C to +40°C; 75% RH max.
4 Marking:
Ex : MHCB10040-2R2M-C1
Marking : 2R2
Marking color : Black
5 Standard Testing Condition
Temperature
Humidity
Unless otherwise specified
Ordinary Temperature(15 to 35℃)
Ordinary Humidity(25 to 85% RH)
In case of doubt
20 to 30℃
50 to 80 %RH
6 Configuration and Dimensions:
7 Electrical Characteristics:
Part No.
MHCB10040-2R2M-C1
Inductance
(uH )
Tolerance
Test Freq.
Irms(A)
Typ
Isat(A)
Typ
RDC(mΩ)
Max(Typ)
Marking
2.2
100KHz,0.5V
12
27
7.0(6.7)
2R2
Note:
1.Operating temperature range -55℃~125℃(Including self - temperature rise)
2.Isat for Inductance drop 20% from its value without current.
3.Irms for a 40℃ temperature rise from 25℃ ambient.
4.The part temperature (ambient + temp rise) should not exceed 125°C under worst case operating conditions.
Circuit design 125°C under worst case operating conditions. Component placement, PWB trace size
and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature
should be verified in the end application.
5.Absolute maximum voltage 30VDC
8 MHCB10040 Series
8.1 Construction:
8.2 Material List:
9 Packaging:
9.1 Packaging -Cover Tape
The force for tearing off cover tape is 10 to 130 grams in the arrow direction.
9.2 Packaging Quantity
TYPE
PCS/REEL
MHCB10040
500
9.3 Reel Dimensions
Dimensions in mm
TYPE
A
MHCB10040
330
B
C
D
100
13
24.4
9 Packaging:
9.4 Tape Dimensions in mm
TYPE
A0
B0
K0
D
E
W
P
P0
P2
MHCB10040
10.6
11.7
4.25
1.55
1.75
24
16
4
2
10 Recommended Land Pattern:
Dimensions in mm
TYPE
MHCB10040
A(mm)
4.0
B(mm)
9.5
C(mm)
3.5
11 Note:
1. Please make sure that your product has been evaluated and confirmed against your specifications
when our product is mounted to your product.
2. Do not knock nor drop.
3. All the items and parameters in this product specification have been prescribed on the premise that
our product is used for the purpose,under the condition and in the environment agreed upon between
you and us. You are requested not to use our product deviating from such agreement.
4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950)
5. The moisture sensitivity level (MSL) of products is classified as level 1.
12 Graph:
很抱歉,暂时无法提供与“MHCB10040-2R2M-C1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.08365
- 50+1.69668
- 150+1.53080
- 500+1.21338
