VDR Varistor
10D SERIES
METAL OXIDE VARISTOR – 10D SERIES
FEATURES
* Wide operating voltage (V1mA) range from 18V to 1100V.
* Fast responding to transient over-voltage.
* Large absorbing transient energy capability.
* Low clamping ratio and no follow-on current.
* Meets MSL level 1, per J-STD-020
* Safety number : CUL- E317616
VDE- 40028836
CQC-12001076479
ISO9001-2018
APPLICATION
*Transistor, Diode, IC, Thyristor or Triac semiconductor protection.
* Surge protection in consumer electronics.
* Surge protection in industrial electronics.
* Surge protection in electronic home appliances, gas and petroleum appliances.
* Relay and electromagnetic valve surge absorption.
General Characteristics Definition
*Operating Temperature:
(-40 ℃ ~ +85 ℃ )
o
( -40 ℃ ~ +125 ℃)
o
*Storage Temperature:
(-40 C ~ +125 C)
*Working Surface Temperature:
+115 C
> 100M Ω
Flame-Retardant to UL 94 V-0
o
*Insulation Resistance:
*Coating (Epoxy Resin):
Material
*Coating:
Epoxy Resin
*Lead Wire:
The Copper Wire
*Electrode:
*Disk:
Silver
Solder
Zinc Oxide
PART NUMBER CODE
VDR
Brand Mark
D
K
Element Diameter
Type: D: Disk , S: Square
Varistor Voltage
Tolerance : K±10%, L±15%
Sapce:Straight 85℃
H:125℃
C:Crimped , Y:Y kink
I:Inner,Tor G :Plaster
Lead Form :
Short leg : NO :
E: 4KV2KA S:6KV/3KA Y:10KV/5KA
=ABCDEF Times
J:High Surge & High Energy
PH=Ultra Surge
Taping : TA : Ammo, TR : Reel
Page-1
VDR Varistor
10D SERIES
Part No.
Part No.
T Max.
D Max.
VDR-10D180L
VDR-10D220K
VDR-10D270K
VDR-10D330K
VDR-10D390K
VDR-10D470K
VDR-10D560K
VDR-10D680K
VDR-10D820K
VDR-10D101K
VDR-10D121K
VDR-10D151K
VDR-10D181K
VDR-10D201K
VDR-10D221K
VDR-10D241K
VDR-10D271K
VDR-10D301K
VDR-10D331K
VDR-10D361K
VDR-10D391K
VDR-10D431K
VDR-10D471K
VDR-10D511K
VDR-10D561K
VDR-10D621K
VDR-10D681K
VDR-10D751K
VDR-10D781K
VDR-10D821K
VDR-10D911K
VDR-10D102K
VDR-10D112K
VDR-10D180LJ
VDR-10D220KJ
VDR-10D270KJ
VDR-10D330KJ
VDR-10D390KJ
VDR-10D470KJ
VDR-10D560KJ
VDR-10D680KJ
VDR-10D820KJ
VDR-10D101KJ
VDR-10D121KJ
VDR-10D151KJ
VDR-10D181KJ
VDR-10D201KJ
VDR-10D221KJ
VDR-10D241KJ
VDR-10D271KJ
VDR-10D301KJ
VDR-10D331KJ
VDR-10D361KJ
VDR-10D391KJ
VDR-10D431KJ
VDR-10D471KJ
VDR-10D511KJ
VDR-10D561KJ
VDR-10D621KJ
VDR-10D681KJ
VDR-10D751KJ
VDR-10D781KJ
VDR-10D821KJ
VDR-10D911KJ
VDR-10D102KJ
VDR-10D112KJ
4.5
4.6
4.7
4.9
4.8
4.9
5.0
5.2
4.1
4.3
4.5
4.8
4.3
4.4
4.5
4.6
4.9
5.0
5.1
5.2
5.4
5.7
6.0
6.2
6.5
7.1
7.6
8.0
8.1
8.3
8.8
9.3
9.9
12.5
S
H Max.
I/C/Y
16.5
17.5
L min.
20.0
F ±0.8 d + 0.05
7.5
0.8
Page-2
VDR Varistor
10D SERIES
ELECTRICAL CHARACTERISTIC
Part Number
Standard
High Surge
Maximum
Varistor
Withstanding
Energy
Allowable
Voltage
Maximum
Clamping
Voltage
Voltage
Surge Current
10/1000μS
AC (V) DC (V)
V1mA(V)
IP(A) VC(V)
I(A)
I(A)
I(A)
I(A)
Standard High Surge Standard High Surge
Typical
Rated Capacitance
Powe (Reference)
(W)
@1KHzPF
10D180L 10D180LJ
11
14
18(15.0~21.6)
5
36
500
1000
2.1
3.0
0.05
5600
10D220K 10D220KJ
14
18
22(19.5~26.0)
5
43
500
1000
2.5
5.0
0.05
4500
10D270K 10D270KJ
17
22
27(24-31)
5
53
500
1000
3.0
6.0
0.05
3700
10D330K 10D330KJ
33(29.5~36.5)
5
65
500
1000
4.0
7.0
0.05
3000
10D390K 10D390KJ
25
31
39(35 ~43)
5
77
500
1000
4.6
9.0
0.05
2400
10D470K 10D470KJ
30
38
47(42~52)
5
93
500
1000
5.5
11.0
0.05
2100
10D560K 10D560KJ
35
45
56(50~62)
5
110
500
1000
7.0
13.0
0.05
1800
10D680K 10D680KJ
40
56
68(61~75)
5
135
500
1000
8.2
15.0
0.05
1500
10D820K 10D820KJ
50
65
82(74~90)
25
135
2500
3500
12.0
17.0
0.4
1200
10D101K 10D101KJ
60
85
100(90~110)
25
165
2500
3500
15.0
18.0
0.4
1000
10D121K 10D121KJ
75
100
120(108~132)
25
200
2500
3500
18.0
21.0
0.4
830
10D151K 10D151KJ
95
125
150(135~165)
25
250
2500
3500
22.0
25.0
0.4
670
10D181K 10D181KJ
115
150
180(162~198)
25
300
2500
3500
27.0
30.0
0.4
560
10D201K 10D201KJ
130
170
200(185~225)
25
330
2500
3500
30.0
35.0
0.4
500
10D221K 10D221KJ
140
180
220(198~242)
25
360
2500
3500
32.0
39.0
0.4
450
10D241K 10D241KJ
150
200
240(216~264)
25
395
2500
3500
35.0
42.0
0.4
420
10D271K 10D271KJ
175
225
270(243~297)
25
455
2500
3500
37.0
49.0
0.4
370
10D301K 10D301KJ
190
250
300(270~330)
25
505
2500
3500
40.0
54.0
0.4
330
10D331K 10D331KJ
210
275
330(297~363)
25
550
2500
3500
43.0
58.0
0.4
300
10D361K 10D361KJ
230
300
360(324~396)
25
595
2500
3500
47.0
65.0
0.4
280
10D391K 10D391KJ
250
320
390(351~429)
25
650
2500
3500
60.0
70.0
0.4
260
10D431K 10D431KJ
275
350
430(387~473)
25
710
2500
3500
65.0
80.0
0.4
230
10D471K 10D471KJ
300
385
470(423~517)
25
775
2500
3500
67.0
85.0
0.4
210
10D511K 10D511KJ
320
415
510(459~561)
25
845
2500
3500
69.0
90.0
0.4
200
10D561K 10D561KJ
350
460
560(504~616)
25
920
2500
3500
70.0
92.0
0.4
180
10D621K 10D621KJ
385
505
620(558~682)
25
1025
2500
3500
72.0
95.0
0.4
160
10D681K 10D681KJ
420
560
680(612~748)
25
1120
2500
3500
75.0
98.0
0.4
150
10D751K 10D751KJ
460
615
750(675~825)
25
1240
2500
3500
77.0
100.0
0.4
140
10D781K 10D781KJ
485
640
780(702~858)
25
1290
2500
3500
80.0
105.0
0.4
130
10D821K 10D821KJ
510
670
820(738~902)
25
1355
2500
3500
85.0
110.0
0.4
120
10D911K 10D911KJ
550
745
910(819~1001)
25
1500
2500
3500
93.0
130.0
0.4
110
10D102K 10D102KJ
625
825
1000(900~1100)
25
1650
2500
3500
102.0
140.0
0.4
100
10D112K 10D112KJ
680
895
1100(990~1210)
25
1815
2500
3500
115.0
150.0
0.4
90
The tolerance of varistor voltage between 18V and 68V is more than 10%.
Page-3
Mechanical Ratings
VDR Varistor
10D SERIES
Reliability Test
Performance
Requirements
Test Parameter Test Condition / Description
Terminal Pull
Strength
After gradually applying the load specified below and keeping
the unit fixed for ten seconds, the terminal shall be visually
examined for any damage.
The unit shall be secured with its terminal kept vertical and the
weight specified below be applied in the axial direction. The
Terminal Bending
terminal shall gradually be bent by 90° in one direction, then 90°
Strength
in the opposite direction, and again back to the original position.
The damage of the terminal shall be visually examined.
Vibration
Solderingsolderability
SolderingResistance to
Solder Heat
Diameter
Loading
0.6mm
1.0 Kg
0.8mm
1.0 Kg
1.0mm
2.0 Kg
Diameter
Loading
0.6mm
0.5 Kg
0.8mm
0.5 Kg
1.0mm
1.0 Kg
The Specimen shall be vibrated by its lead wires with a total amplitude of 1.5㎜ and a
varying frequency of 10~55~10HZ(each minutes) for a period of 2 hours respectively in
each X,Yand Z directions.
No visible damage
No visible damage
No visible damage
△VB/VB%≦±5%
After dipping the terminal to depth of approximately 3㎜ from the specimen in a soldering
Terminations shall
bath of 260℃ for 10±1(D5: 5±1) seconds. Thereafter the terminal shall be visually
be uniformly tinned
examined.
After preheating the specimen, the specimen shall be completely immersed into a
soldering bath having a temperature of 260±5℃ for 10±1 (D5: 5±1) seconds or iron of
400±5℃ for 3±0.5 seconds. There after the change of Vb and mechanical damage shall
be examined.
No visible damage
△VB/VB%≦±5%
ENVIRONMENTAL RATINGS
The specimen shall be applied continuously the maximum allowable voltage at the
specified conditions for specified period and then stored at room temperature and normal
Dry Heat Loading humidity over 2 hours. Thereafter, the change of Vb and mechanical damage shall be
△VB/VB%≦±10%
examined.
Ambient
temp:125±2℃ ;
Period:1000±24hours.
High Temperature In a drying oven without load.
Storage
Ambient temp:125±2℃ ; period:1000±24hours
Damp Heat
Loading
△VB/VB%≦±5%
△VB/VB%≦±10%
examined.
Ambient
condition:40±2℃ , 90 to 95%R.H. ; period:1000±24 hours
Step
Temperature
Cycle
Condition the specimen to each temperature form step 1
to step 4 in this order for the period shown in the table of
specifications. The change of Vb and mechanical
damage shall be examined after 2 hours.
o
Period
o
Temp C
1
-40+3 C
30 min.
2
Room Temp
15 min.
3
85+2 C
30 min.
4
Room Temp
15 min.
o
Surge Lifetime
Rating
The change of Vb shall be measured after the impulse listed below is applied 10,000
times continuously with the interval of ten seconds at room temperature.
Voltage Proof
Voltage:2500VAC
Leakage Current≦0.5mA
Time:60 Seconds
No visible damage
△VB/VB%≦±10%
No visible damage
△VB/VB%≦±10%
No Breakdown
Page-4
VDR Varistor
10D SERIES
MARKING CODE
1 DongWoSemi Logo
2 Disk Size
3 CUL Accreditation Logo
4 “Y” &“M” Product Line Code
5 Varistor Voltage
6 VDE Accreditation Logo
7 Energy and frequency of combined wave
“J” is High Surge Code,not “J” is Standard Surge
“H” is High temperature range ,not “H” is Standard
Packaging specification / bulk packaging quantity
Unit:Pcs
Dimension
Part No.
Bag
Small Carton
Carton
10D
180L to 112K
500
5,000
10,000
10D (Short leg)
180L to 112K
500
7,500
15,000
Page-5
很抱歉,暂时无法提供与“VDR-10D391K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.43547
- 100+0.36206
- 500+0.28744
- 1000+0.25991
