SMA47xxA SERIES
Surface Mount Silicon Zener Diodes
Zener Voltage 3.3 ~ 390 V
DO-214AC(SMA)
1.0 Watt Power Dissipation
Features
● Glass passivated chip
● Built-in strain relief
● Low inductance
● High peak reverse power dissipation
● Low reverse leakage
● For use in stabilizing and clipping
with high power rating
● RoHS compliant
Mechanical Data
● Case: DO214AC Molded plastic
● Lead: Solderable per MIL-STD-750, method 2026
● Epoxy: UL 94V-0 rate flame retardant
Unit: inch(mm)
● Polarity: Color band denotes cathode end
● Mounting position: Any
Parameter
Symbols
Value
Unit
PD
1.0
W
VF
1.2
V
Junction temperature range
TJ,TSTG
-55 to +150
Storage temperature range
TJ,TSTG
-55 to +150
DC Power dissipation at TL = 75 °C
(1)
Maximum forward voltage at if=200mA
Note:
(1)TL=Lead temperature at 3/8'' (9.5mm)from body
REV.1.2,2017-12
Changzhou zhide Electronics CO.,LTD
www.cz-zhide.com
SMA47xxA SERIES
Ratings and Characteristics Curves (TA=25℃ unless otherwise noted)
REV.1.2,2017-12
www.cz-zhide.com
SMA47xxA SERIES
Part Number
Device
Marking
Code
Nominal Zener Voltage @IT
IZT(mA)
VZ AVE.(V)
SMA4727A
SMA4728A
SMA4729A
SMA4730A
SMA4731A
SMA4732A
SMA4733A
SMA4734A
SMA4735A
SMA4736A
SMA4737A
SMA4738A
SMA4739A
SMA4740A
SMA4741A
SMA4742A
SMA4743A
SMA4744A
SMA4745A
SMA4746A
SMA4747A
SMA4748A
SMA4749A
SMA4750A
SMA4751A
SMA4752A
SMA4753A
SMA4754A
SMA4755A
SMA4756A
SMA4757A
SMA4758A
SMA4759A
SMA4760A
SMA4761A
SMA4762A
SMA4763A
SMA4764A
SZ1110A
SZ1120A
SZ1130A
SZ1150A
SZ1160A
SZ1180A
SZ1200A
SZ1220A
SZ1240A
SZ1250A
SZ1270A
SZ1300A
SZ1330A
SZ1360A
SZ1390A
727A
728A
729A
730A
731A
732A
733A
734A
735A
736A
737A
738A
739A
740A
741A
742A
743A
744A
745A
746A
747A
748A
749A
750A
751A
752A
753A
754A
755A
756A
757A
758A
759A
760A
761A
762A
763A
764A
711Z
712Z
713Z
715Z
716Z
718Z
720Z
722Z
724Z
725Z
727Z
730Z
733Z
736Z
739Z
REV.1.2,2017-12
Maximum Zener Impedance
3.0
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
10.0
11.0
12.0
13.0
15.0
16.0
18.0
20.0
22.0
24.0
27.0
30.0
33.0
36.0
39.0
43.0
47.0
51.0
56.0
62.0
68.0
75.0
82.0
91.0
100.0
110.0
120.0
130.0
150.0
160.0
180.0
200.0
220.0
240.0
250.0
270.0
300.0
330.0
360.0
390.0
VZ MIN.(V)
2.85
3.14
3.42
3.71
4.09
4.47
4.85
5.32
5.89
6.46
7.13
7.79
8.65
9.50
10.45
11.40
12.35
14.25
15.20
17.10
19.00
20.90
22.80
25.65
28.50
31.35
34.20
37.05
40.85
44.65
48.45
53.20
58.90
64.60
71.25
77.90
86.45
95.00
104.50
114.00
123.50
142.50
152.00
171.00
190.00
209.00
228.00
237.50
256.50
285.00
313.50
342.00
370.50
VZ MAX.(V)
3.15
3.47
3.78
4.10
4.52
4.94
5.36
5.88
6.51
7.14
7.88
8.61
9.56
10.50
11.55
12.60
13.65
15.75
16.80
18.90
21.00
23.10
25.20
28.35
31.50
34.65
37.80
40.95
45.15
49.35
53.55
58.80
65.10
71.40
78.75
86.10
95.55
105.00
115.50
126.00
136.50
157.50
168.00
189.00
210.00
231.00
252.00
262.50
283.50
315.00
346.50
378.00
409.50
80.0
76.0
69.0
64.0
58.0
53.0
49.0
45.0
41.0
37.0
34.0
31.0
28.0
25.0
23.0
21.0
19.0
17.0
15.5
14.0
12.5
11.5
10.5
9.5
8.5
7.5
7.0
6.5
6.0
5.5
5.0
4.5
4.0
3.7
3.3
3.0
2.8
2.5
2.3
2.0
1.9
1.7
1.6
1.4
1.2
1.0
0.9
0.9
0.8
0.8
0.7
0.7
0.7
ZZT MAX.(Ω)
@IZT
ZZK MAX.(Ω)
@IZK
IZK(mA)
10.0
10.0
10.0
9.0
9.0
8.0
7.0
5.0
2.0
3.5
4.0
4.5
5.0
7.0
8.0
9.0
10.0
14.0
16.0
20.0
22.0
23.0
25.0
35.0
40.0
45.0
50.0
60.0
70.0
80.0
95.0
110.0
125.0
150.0
175.0
200.0
250.0
350.0
450.0
550.0
700.0
1000.0
1100.0
1200.0
1900.0
1600.0
1800.0
2000.0
2100.0
2300.0
2500.0
2700.0
3000.0
400.0
400.0
400.0
400.0
400.0
500.0
550.0
600.0
700.0
700.0
700.0
700.0
700.0
700.0
700.0
700.0
700.0
700.0
700.0
750.0
750.0
750.0
750.0
750.0
1000.0
1000.0
1000.0
1000.0
1500.0
1500.0
1500.0
2000.0
2000.0
2000.0
2000.0
3000.0
3000.0
3000.0
4000.0
4500.0
5000.0
6000.0
6500.0
7000.0
9990.0
8000.0
8500.0
9000.0
9000.0
9500.0
9500.0
10000.0
10000.0
1.00
1.00
1.00
1.00
1.00
1.00
1.00
1.00
1.00
1.00
0.50
0.50
0.50
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
Maximum Reverse
Leakage Current
IR(uA)@V
Maximum
DC Zener
Current
VR(V)
IZM(mA)
1.0
1.0
1.0
1.0
1.0
1.0
1.0
2.0
3.0
4.0
5.0
6.0
7.0
7.6
8.4
9.1
9.9
11.4
12.2
13.7
15.2
16.7
18.2
20.6
22.8
25.1
27.4
29.7
32.7
35.8
38.8
42.6
47.1
51.7
56.0
62.2
69.2
76.0
83.6
91.2
98.8
114.0
121.6
136.8
152.0
167.2
182.4
190.0
205.0
228.0
250.2
275.0
300.0
288.0
274.0
251.0
232.0
210.0
192.0
177.0
161.0
146.0
133.0
121.0
110.0
100.0
91.0
83.0
76.0
69.0
61.0
57.0
50.0
45.0
41.0
38.0
34.0
30.0
27.0
25.0
23.0
22.0
19.0
18.0
16.0
14.0
13.0
12.0
11.0
10.0
9.0
8.6
7.8
7.0
6.4
5.8
5.2
4.7
4.0
3.8
3.6
3.3
3.0
2.7
2.5
2.2
R
100.0
100.0
100.0
50.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
www.cz-zhide.com
很抱歉,暂时无法提供与“SMA4733A”相匹配的价格&库存,您可以联系我们找货
