BCT4221EGB-TR
BCT4221EGB-TR
    BROADCHIP(广芯)
    UQFN10
    BCT4221EGB-TR
BCT4221EGB-TR 数据手册
BCT4221 USB2.0 Hi-Speed Switches BCT4221 USB2.0 Hi-Speed Switches GENERAL DESCRIPTION FEATURES The BCT4221 is a high bandwidth, fast double-pole double-throw (DPDT) analog switch. Its wide bandwidth and low bit-to-bit skew allow it to pass high-speed differential signals with good signal integrity. Each switch is bidirectional and offers little or no attenuation of the high-speed signals at the outputs. Industry-leading advantages include a propagation delay of less than 250ps, resulting from its low channel resistance and low I/O capacitance. Its high channel-to-channel crosstalk rejection results in minimal noise interference.      VCC Operating Range: 2.7V-5.5V Analog Signal Range: 0 to VCC -3dB Bandwidth: 720MHz Off Isolation:-38dB @250MHz Crosstalk Rejection:- 38dB @250MHz     ON-Resistance:6Ω Typical Extended Temperature Range: –40°C to 85°C Green QFN2.0X1.5-10L packages ESD:HBM 8000V The BCT4221 is available in Green QFN2.0X1.5-10L packages. It operates over an ambient temperature range of -40°C to +85°C. APPLICATIONS Cell Phones Hi-Fi Audio Switching USB 2.0 High Speed Data Switching USB 3.x Type C Switching ORDERING INFORMATION Order Number Package Type Temperature Range BCT4221EGB-TR QFN2.0X1.5-10L -40°C to +85°C Marking 4221 YWTG QTY/Reel 3000 NOTE 1: Y: year, W: weeks REV1.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 1 BCT4221 USB2.0 Hi-Speed Switches PIN CONFIGURATION VCC 1D+ 1 1D- 10 9 S 2 8 D+ 2D+ 3 7 D- 2D- 4 6 /OE 5 GND TOP VIEW PIN DESCRIPTION PIN NAME FUNCTION 1 1D+ USB port 1 DATA+ 2 1D- USB Port 1 DATA- 3 2D+ USB port 2 DATA+ 4 2D- USB Port 2 DATA- 5 GND Power Ground 6 /OE Outputs enable input, active low. 7 D- USB data bus DATA- 8 D+ USB data bus DATA+ 9 S 10 VCC Logic Control, 0 select port 1 Power Supply REV1.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 2 BCT4221 USB2.0 Hi-Speed Switches Truth Table S1 /OE PORT 1 PORT 2 0 0 ON OFF 1 0 OFF ON X 1 OFF OFF TYPICAL APPLICATION CIRCUIT VCC 0.1uF USB 2.0 Controller 1D+ VCC S S 1DD+ USB 2.0 Connector BCT4221 DUSB 2.0 Controller 2D+ 2D- GND /OE /OE REV1.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 3 BCT4221 USB2.0 Hi-Speed Switches ABSOLUTE MAXIMUM RATINGS VCC to GND................................................................................................................ -0.5V to +6.0V All Other Pins to GND...........................................................................................-0.5V to (VCC + 0.3V) Continuous Current (D+/-, 1 D+/-, 2D+/-)................................................................................ ±120mA Continuous Power Dissipation......................................................................................................0.4W Operating Temperature Range ....................................................................................-40°C to +85°C Storage Temperature Range......................................................................................-65°C to +150°C Junction Temperature...............................................................................................................+150°C Lead Temperature (soldering, 10s)..........................................................................................+260°C ESD Protection Human Body Model…………………..........................................................................................8000V Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. CAUTION This integrated circuit can be damaged by ESD if you don’t pay attention to ESD protection. Broadchip recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. Broadchip reserves the right to make any change in circuit design, specification or other related things if necessary without notice at any time. Please contact Broadchip sales office to get the latest datasheet. REV1.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 4 BCT4221 USB2.0 Hi-Speed Switches ELECTRICAL CHARACTERISTICS (VCC = 2.7V to 5.5V, TA = -40°C to +85°C, unless otherwise noted. Typical values are at VCC = 3.3V, TA = +25°C.) (Note 2) PARAMETER SYM CONDITIONS MIN TYP MAX UNITS POWER SUPPLY Supply Voltage Range VCC Supply Current ICC 2.7 VCC=3.6V, S =0 or VCC , D+/-,nD+/- = floating Analog Signal Range On-Resistance On-Resistance Match On-Resistance Flatness 0.02 0 5.5 V 1 uA VCC V 12 Ω RON ISW = 30mA, VD+, VD- = 0V (Note 3) 6 △RON ISW = 30mA, VD+, VD- =0V (Note 3,4) 0.2 Ω 1 Ω RFLAT ISW = 30mA, VD+, VD- = 0 to VCC (Note 5) D+,D-,1D+,1D-,2D+,2DPower off Leakage Current IOFF VCC=0V ,VSW = 0 to 3.6V 1 uA D+,D-,1D+,1D-,2D+,2DOff Leakage Current IOZ Switch off, VSW= 0 to VCC 1 uA Input-Logic High VIH VCC =2.7 – 5.5V 1.5 VCC V Input-Logic Low VIL VCC =2.7 – 5.5V 0 0.4 V Input Leakage Current IIN VIN = 0 to VCC -1 1 uA REV1.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 5 BCT4221 USB2.0 Hi-Speed Switches ELECTRICAL CHARACTERISTICS (VCC = 2.7V to 5.5V, TA = -40°C to +85°C, unless otherwise noted. Typical values are at VCC = 3.3V, TA = +25°C.) (Note 2) PARAMETER SYM CONDITIONS MIN TYP MAX UNITS DYNAMIC CHARACTERISTICS Turn-On Time TON VnD+ or VnD- = 1.5V, RL = 50Ω, CL = 35pF, (Figure 1) 20 50 nS Turn-Off Time TOFF VnD+ or VnD- = 1.5V, RL = 50Ω, CL = 35pF, (Figure 1) 15 50 nS Break-Before-Make Time TBBM VnD+ and VnD- = 1.5V RL = 50Ω, CL = 35pF, (Figure 2) On-Channel Bandwidth -3dB BW Off-Isolation 2 15 nS RL = 50Ω, (Figure 3) 720 MHz QIRR RL = 50Ω, f = 250MHz (Note 6) -38 dB Crosstalk XTALK RL = 50Ω, f = 250MHz (Figure 4) -38 dB D+,D- Off-Capacitance COFF f = 1MHz, (Figure 5) 5 pF D+,D- On-Capacitance CON f = 1MHz, (Figure 5) 7 pF NOTES: Note 2: Devices are 100% tested at TA = +25°C. Limits across the full temperature range are guaranteed by design and correlation. Note 3: RON and RON matching specifications are guaranteed by design, Note 4: ΔRON = RON(MAX) - RON(MIN). Note 5: Flatness is defined as the difference between the maximum and minimum value of on-resistance, as measured over the specified analog signal ranges. Note 6: Between any two switches. REV1.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 6 BCT4221 USB2.0 Hi-Speed Switches Test Diagram Figure 1. tON/OFF Figure 2. tBBM (Time Break-Before-Make) Figure 3. Bandwidth -3dB REV1.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 7 BCT4221 USB2.0 Hi-Speed Switches Figure 4. Crosstalk Figure 5. Channel ON/OFF Capacitance REV1.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 8 BCT4221 USB2.0 Hi-Speed Switches PACKAGE OUTLINE DIMENSIONS QFN2.0x1.5-10L PKG REF A A1 A3 D E b b1 b2 L L1 e COMMON DIMENSIONS(mm) UT:ULTRA THIN MIN NOM 0.50 0.55 0.00 -0.15 REF 1.95 2.00 1.45 1.50 0.15 0.20 0.20 0.25 0.25 0.30 0.30 0.35 0.35 0.40 0.50 BSC MAX 0.60 0.05 2.05 1.55 0.25 0.30 0.35 0.40 0.45 REV1.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 9 BCT4221 USB2.0 Hi-Speed Switches TAPING DESCRIPTION PCB Layout Pattern: QFN2.0x1.5-10L 0.3 0.6 0.6 0.25 0.5 1.8 1.3 RECOMMENDED PCB LAYOUT PATTERN (Unit: mm) REV1.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 10
BCT4221EGB-TR 价格&库存
很抱歉,暂时无法提供与“BCT4221EGB-TR”相匹配的价格&库存,您可以联系我们找货
BCT4221EGB-TR
    • 1+2.23398
    • 10+1.82574
    • 30+1.65078
    • 100+1.43252
    • 500+1.33532
    BCT4221EGB-TR
      • 1+1.36130
