1700V N-Channel Silicon Carbide Power MOSFET
CI7N170SM
1700 V
RDS(on)
650 mΩ
ID@25℃
7.0 A
DS
Features
Package
High Blocking Voltage with Low On-Resistance
High Speed Switching with Low Capacitance
Easy to Parallel and Simple to Drive
Ultra-low Drain-gate capacitance
Benefits
Higher System Efficiency
Reduced Cooling Requirements
Increased System Reliability
Increased System Switching Frequency
Applications
Auxiliary Power Supplies
Switch Mode Power Supplies
High-voltage Capacitive
Maximum Ratings (TC=25℃ unless otherwise specified)
Symbol
Parameter
Value
Unit
Test Conditions
VDSmax
Drain-Source Voltage
1700
V
VGS=0V, ID=100μA
VGSmax
Gate-Source Voltage
-10/+25
V
Absolute maximum values
VGSop
Gate-Source Voltage
-5/+20
V
Recommended operational values
ID
ID(pulse)
PD
TJ, TSTG
7.0
Continuous Drain Current
4.5
A
VGS=20V, Tc=25℃
VGS=20V, Tc=100℃
Pulsed Drain Current
9.0
A
Pulse width tp limited by TJmax
Power Dissipation
62
W
Tc=25℃, TJ=150℃
-55 to +150
Operating Junction and Storage Temperature
www.tokmas.com
Note
CI7N170SM
Electrical Characteristics (TC=25℃ unless otherwise specified)
Symbol
Parameter
V(BR)DSS
Drain-Source Breakdown Voltage
VGS(th)
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
1700
V
2.0
2.6
4.0
1.8
V
Test Conditions
VGS=0V, ID=100μA
VDS=VGS, ID=1.0mA
VDS=VGS, ID=1.0mA, TJ=150℃
IDSS
Zero Gate Voltage Drain Current
1
100
µA
VDS=1700V, VGS=0V
IGSS+
Gate-Source Leakage Current
10
250
nA
VDS=0V, VGS=25V
IGSS-
10
250
nA
VDS=0V, VGS=-10V
650
850
1300
1.06
1.14
RDS(on)
Drain-Source On-State Resistance
gfs
Transconductance
Ciss
Input Capacitance
194
Coss
Output Capacitance
13
Crss
Reverse Transfer Capacitance
1.8
Eoss
Coss Stored Energy
6.6
EON
Turn-On Switching Energy
5
EOFF
Turn-Off Switching Energy
9.2
td(on)
Turn-On Delay Time
13.8
Rise Time
22.8
Turn-Off Delay Time
38
Fall Time
14
Internal Gate Resistance
18
QGS
Gate to Source Charge
5.4
QGD
Gate to Drain Charge
7.6
QG
Total Gate Charge
23
Typ.
Max.
4.2
3.9
tr
td(off)
tf
RG(int)
mΩ
S
VGS=20V, ID=2.0A, TJ=150℃
VDS=20 V, ID=2.0 A
VDS=20V, ID=2.0A, TJ=150℃
mJ
ns
Ω
Fig.
4,5,6
Fig.
VDS=1000V
15,16
f=1MHz
µJ
Fig. 11
VGS=20V, ID=2.0A
VGS=0V
pF
Note
VAC=25mV
VDS=1200V, VGS=-5V/20V
ID=2.0A, RG(ext)=2.5Ω, L=100μH
VDS=1200V, VGS=-5V/20V, ID=2.0A
RG(ext)=2.5Ω, RL=20Ω
f=1MHz, VAC=25mV
VDS=1200V
nC
VGS=-5V/20V
ID=2.0A
Reverse Diode Characteristics
Symbol
VSD
Parameter
Diode Forward Voltage
Unit
V
IS
Continuous Diode Forward Current
7.0
A
trr
Reverse Recover Time
25
ns
Qrr
Reverse Recovery Charge
15
nC
Irrm
Peak Reverse Recovery Current
2.8
A
Typ.
Max.
1.8
40
Test Conditions
VGS=-5V, ISD=25A
VGS=-5V, ISD=25A, TJ=150℃
Note
Fig.
8,9,10
TC=25℃
VR=1200V, ISD=2.0A
Thermal Characteristics
Symbol
Parameter
RθJC
Thermal Resistance from Junction to Case
RθJA
Thermal Resistance from Junction to Ambient
www.tokmas.com
Unit
℃/W
Test Conditions
Note
CI7N170SM
Typical Performance
Figure 1. Output Characteristics TJ = -55 ºC
Figure 3. Output Characteristics TJ = 150 ºC
Figure 5. On-Resistance vs. Drain Current
Figure 2. Output Characteristics TJ = 25 ºC
Figure 4. Normalized On-Resistance vs. Temperature
Figure 6. On-Resistance vs. Temperature
For Various Temperatures
For Various Gate Voltage
www.tokmas.com
CI7N170SM
Typical Performance
Figure 7. Transfer Characteristic for
Figure 8. Body Diode Characteristic at -55 ºC
Various Junction Temperatures
Figure 9. Body Diode Characteristic at 25 ºC
Figure 11. Threshold Voltage vs. Temperature
Figure 10. Body Diode Characteristic at 150 ºC
Figure 12. 3rd Quadrant Characteristic at -55 ºC
www.tokmas.com
CI7N170SM
Typical Performance
Figure 13. 3rd Quadrant Characteristic at 25 ºC
Figure 14. 3rd Quadrant Characteristic at 150 ºC
Figure 15. Capacitances vs. Drain-Source
Figure 16. Capacitances vs. Drain-Source
Voltage (0 - 200V)
Figure 17. Gate Charge Characteristic
Voltage (0 - 1000V)
Figure 18. Output Capacitor Stored Energy
www.tokmas.com
Package Dimensions
Package TO-247-3
www.tokmas.com
CI7N170SM
很抱歉,暂时无法提供与“CI7N170SM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+25.30440
- 10+22.65840
- 30+16.32960
- 90+14.73120
- 510+13.99680
- 1020+13.66200
