KSMBJ Series -E3/52
TRANSIENT VOLTAGE SUPPRESSOR
FEATURE
Plastic package.
Glass passivated chip junction in SMB Package
Excellent clamping capability.
Low zener impedance.
600W peak pulse power capability on 10/1000μs waveform.
Typical IR less than 1μA above 13V.
Fast response time: typically less than 1.0ps from 0 Volts to BV min.
High temperature soldering guaranteed: 265℃/10 seconds
MECHANICAL DATE
Case: JEDEC SMB Molded Plastic.
Terminals: Axial leads, solderable per MIL-STD-750, Method 2026.
Polarity: Color band denoted cathode except bidirectional.
Mounting Position: Any.
MAXIMUM RATINGS AND CHRACTERISTICS
Ratings at 25ć ambient temperature unless otherwise specified.
RATING
SYMBOL
VALUE
UNITS
Peak Pulse Power Dissipation on 10/1000us waveform
(Note1, Fig.1).
PPPM
Minimum 600
Watts
Peak Pulse Current of on 10/1000us waveform.(Note1,Fig.3)
IPPM
See Table
Amps
Steady State Power Dissipation at TL =75℃,Lead lengths.375",
(9.5mm) (Fig.5).
PM(AV)
5.0
Watts
Peak Forward Surge Current,8.3ms Single Half Sine-Wave
Superimposed on Rated Load, (JEDEC Method) (Note 2,Fig.6).
IFSM
100
Amps
TJ , TSTG
-55 to +150
Operating junction and Storage Temperature Range.
Notes:
1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25℃ per Fig. 2.
2. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per
minutes maximum.
1/4
KSMBJ Series -E3/52
Item
A
B
C
D
E
F
G
H
I
J
K
L
Millimeters
Min.
Max.
1.95
2.2
4.06
4.57
3.3
3.94
2.13
2.44
0.76
1.52
0.203
5.21
5.59
0.152
0.305
2.26
2.16
2.74
2.16
Inches
Min.
Max.
0.077
0.086
0.16
0.18
0.13
0.155
0.084
0.096
0.03
0.06
0.008
0.205
0.22
0.006
0.012
0.089
0.085
0.107
0.085
ELECTRICAL CHARACTERISTICS
Part Number
Marking
Reverse
Breakdown
Breakdown
Reverse
Test
Peak
Maximum
Stand-Off
Voltage
Voltage
Leakage
Current
Pulse
Voltage
NIN.@IT
MAX.@IT
@VRWM
Current
Clamping
Voltage
@IPP
VR(V)
UNT
BI
UNT
BI
VBL(V)
VBH(V)
IR(uA)
IT(mA)
IPP(A)
VCH(V)
KSMBJ5.0A
KSMBJ5.0CA
KE
AE
5.0
6.40
7.00
800
10
65.3
9.2
KSMBJ6.0A
KSMBJ6.0CA
KG
AG
6.0
6.67
7.37
800
10
58.3
10.3
KSMBJ6.5A
KSMBJ6.5CA
KK
AK
6.5
7.22
7.98
500
10
53.6
11.2
KSMBJ7.0A
KSMBJ7.0CA
KM
AM
7.0
7.78
8.60
200
10
50.0
12.0
KSMBJ7.5A
KSMBJ7.5CA
KP
AP
7.5
8.33
9.21
100
1
46.6
12.9
KSMBJ8.0A
KSMBJ8.0CA
KR
AR
8.0
8.89
9.83
50
1
44.2
13.6
KSMBJ8.5A
KSMBJ8.5CA
KT
AT
8.5
9.44
10.40
41.7
14.4
KSMBJ9.0A
KSMBJ9.0CA
KV
AV
9.0
10.00
11.10
10
1
39.0
15.4
KSMBJ10A
KSMBJ10CA
KX
AX
10
11.10
12.30
5
1
35.3
17.0
KSMBJ11A
KSMBJ11CA
KZ
AZ
11
12.20
13.50
1
1
33.0
18.2
KSMBJ12A
KSMBJ12CA
LE
BE
12
13.30
14.70
1
1
30.2
19.9
KSMBJ13A
KSMBJ13CA
LG
BG
13
14.40
15.90
1
1
28.0
21.5
2/4
KSMBJ Series -E3/52
Part Number
Reverse
Breakdown
Breakdown
Reverse
Test
Peak
Maximum
Stand-Off
Voltage
Voltage
Leakage
Current
Pulse
Voltage
NIN.@IT
MAX.@IT
@VRWM
Current
Clamping
Voltage
@IPP
BI
VR(V)
VBL(V)
VBH(V)
IR(uA)
IT(mA)
IPP(A)
VCH(V)
Marking
UNT
BI
KSMBJ14A
KSMBJ14CA
LK
BK
14
15.60
17.20
1
25.9
23.2
KSMBJ15A
KSMBJ15CA
LM
BM
15
16.70
18.50
1
1
24.6
24.4
KSMBJ16A
KSMBJ16CA
LP
BP
16
17.80
19.70
1
1
23.1
26.0
KSMBJ17A
KSMBJ17CA
LR
BR
17
18.90
20.90
1
1
21.8
27.6
KSMBJ18A
KSMBJ18CA
LT
BT
18
20.00
22.10
1
1
20.6
29.2
KSMBJ20A
KSMBJ20CA
LV
BV
24.50
1
1
18.6
32.4
KSMBJ22A
KSMBJ22CA
LX
BX
22
24.40
26.90
1
1
16.9
35.5
KSMBJ24A
KSMBJ24CA
LZ
BZ
24
26.70
29.50
1
1
15.5
38.9
KSMBJ26A
KSMBJ26CA
ME
CE
26
28.90
31.90
1
1
14.3
42.1
KSMBJ28A
KSMBJ28CA
MG
CG
28
31.10
34.40
1
1
13.3
45.4
KSMBJ30A
KSMBJ30CA
MK
CK
30
33.30
36.80
1
1
12.4
48.4
KSMBJ33A
KSMBJ33CA
MM
CM
33
36.70
40.60
1
1
11.3
53.3
KSMBJ36A
KSMBJ36CA
MP
CP
36
40.00
44.20
1
1
10.4
58.1
KSMBJ40A
KSMBJ40CA
MR
CR
40
44.40
49.10
1
1
9.3
64.5
KSMBJ43A
KSMBJ43CA
MT
CT
43
47.80
52.80
1
1
8.7
69.4
KSMBJ45A
KSMBJ45CA
MV
CV
45
50.00
55.30
1
1
8.3
72.7
KSMBJ48A
KSMBJ48CA
MX
CX
48
53.30
58.90
1
1
7.8
77.4
KSMBJ51A
KSMBJ51CA
MZ
CZ
51
56.70
62.70
1
1
7.3
82.4
KSMBJ54A
KSMBJ54CA
NE
DE
54
60.00
66.30
1
1
6.9
87.1
KSMBJ58A
KSMBJ58CA
NG
DG
58
64.40
71.20
1
1
6.5
93.6
KSMBJ60A
KSMBJ60CA
NK
DK
60
66.70
73.70
1
1
6.2
96.8
KSMBJ64A
KSMBJ64CA
NM
DM
64
71.10
78.60
1
1
5.9
103
KSMBJ70A
KSMBJ70CA
NP
DP
70
77.80
86.00
1
1
5.3
113
KSMBJ75A
KSMBJ75CA
NR
DR
75
83.30
92.10
1
1
5.0
121
KSMBJ78A
KSMBJ78CA
NT
DT
78
86.70
95.80
1
1
4.8
126
KSMBJ85A
KSMBJ85CA
NV
DV
85
94.4
104.0
1
1
4.4
137
KSMBJ90A
KSMBJ90CA
NX
DX
90
100.0
111.0
1
1
4.1
146
KSMBJ100A
KSMBJ100CA
NZ
DZ
100
111.0
123.0
1
1
3.7
162
KSMBJ110A
KSMBJ110CA
PE
EE
110
122.0
135.0
1
1
3.4
177
KSMBJ120A
KSMBJ120CA
PG
EG
120
133.0
147.0
1
1
3.1
193
KSMBJ130A
KSMBJ130CA
PK
EK
130
144.0
159.0
1
1
2.9
209
KSMBJ150A
KSMBJ150CA
PM
EM
150
167.0
185.0
1
1
2.5
243
KSMBJ160A
KSMBJ160CA
PP
EP
160
178.0
197.0
1
1
2.3
259
KSMBJ170A
KSMBJ170CA
PR
ER
170
189.0
209.0
1
1
2.2
275
KSMBJ180A
KSMBJ180CA
PT
ET
180
201.0
222.0
1
1
2.1
292
KSMBJ190A
KSMBJ190CA
PA
EC
190
209.0
243.0
1
1
2.0
308
KSMBJ200A
KSMBJ200CA
PV
EV
200
224.0
247.0
1
1
1.9
324
KSMBJ220A
KSMBJ220CA
PX
EX
220
246.0
272.0
1
1
1.7
356
KSMBJ250A
KSMBJ250CA
PZ
EZ
250
279.0
309.0
1
1
1.5
405
KSMBJ300A
KSMBJ300CA
QE
FE
300
335.0
371.0
1
1
1.3
486
KSMBJ350A
KSMBJ350CA
QG
FG
350
391.0
432.0
1
1
1.1
567
KSMBJ400A
KSMBJ400CA
QK
FK
400
447.0
494.0
1
1
0.9
648
KSMBJ440A
KSMBJ440CA
QM
FM
440
492.0
543.0
1
1
0.9
713
UNT
Notes: For bidirectional type having VRWM of 10 volts and less, the IR limit is double
3/4
KSMBJ Series -E3/52
RATINGS AND CHARACTERISTIC CURVES (TA=25℃ unless otherwise noted)
Figure 1 - Peak Pulse Power Rating Curve
Figure 2 - Pulse Derating Curve
Figure 3 - Pulse Waveform
Figure 4 - Typical Junction Capacitance
Uni-Directional
Figure 5 - Steady State Power Dissipation
Derating Curve
Figure 6 - Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
4/4
很抱歉,暂时无法提供与“KSMBJ15CA-E3/52”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 25+0.19122
- 250+0.16692
- 750+0.15064
- 2250+0.14254
- 12750+0.13552
- 24750+0.13174
