RoHS
Compliant
SPECIFICATION FOR APPROVAL
File No.: Q/FRK 0.GS.E.C3D-C13
Product Name
DC-Link Capacitor for PCB
Product Type:
C3D
Product Code
Customer
Customer Code
Issue Date
Approved by Customer
Xiamen Faratronic Co. Ltd.
Drafted
Checked
Approved
厦门法拉电子股份有限公司
地址: 中国厦门市海沧区新园路 99 号
Add: No.99 Xinyuan Road, Haicang District, Xiamen, China
TEL:
FAX:
Mail:
Http:
Export business
0086-592-6208609 6208608
0086-592-6208557
Vivian@faratronic.com.cn
Donny@faratronic.com.cn
james@faratronic.com.cn
www.faratronic.com.cn
HK office : Faratronic (HK) Co. Ltd.
0852-2898 9168
0852-2898 9683
hkoffice@faratronic.com.hk
kolin@faratronic.com.hk
www.faratronic.com
*.The specification are the property of Xiamen Faratronic Co.Ltd and shall not be copied or used as commercial
purposes without permission.
Page 1 of 15
C3D
Version history
Current version
Date
Author
Page 2 of 15
Change description
C3D
Outline Drawing
2 Pins
4 Pins
Square-bottom
Arc-bottom
Features
● Metallized polypropylene structure.
● Excellent electric property.
● Plastic case (UL94 V-0), Filled with resin.
● High performance DC filtering applications
(i.e. transducers, Industrial and high-end power supplies and solar inverters)
Safety Approvals
TUV
Rheinland
UL
EN 61071:2007,EN 61881-1:2011, 450Vdc ~ 3200Vdc,0.56F~220F,-40/85℃
Certificate No.:R 50266108
UL 810 (construction only),Max. 5000Vdc,90℃
File No.: E256238, CCN: CZDS2
Specifications
Reference Standard
GB/T 17702 (IEC 61071)
Climatic Category
40/85/56
Operating temperature (case)
-40℃~105℃
(+85℃ to +105℃: decreasing factor 1.35% per ℃ for UN, 85℃)
UN, 85℃
500Vdc,600Vdc,800Vdc,900Vdc,1 000Vdc,1 100Vdc,1 200Vdc
Capacitance Tolerance
J (5), K (10)
Voltage Proof
1.5UN (10s)
Insulation Resistance(IR×CN)
10 000s
Self Inductance (Ls)
1nH per mm of lead spacing
Maximum peak current Î(A)
Expected lifetime
Î=C·dV/dt
100 000h @ UN , Θhs =70℃
(20℃, 100V, 1min)
Page 3 of 15
C3D
Part number code system
The 18 digits part number is formed as follow:
1
C
2
3
3
D
4
5
6
7
8
9
10
Digit 1 to 3
Series code
C3D
Digit 4 to 5
D.C. rated voltage
2H=500V
11
12 13 14 15 16 17 18
1U=600V
3A=1 000V
2K=800V
1M=1 100V
1X=900V
3L=1 200V
Digit 6 to 8
Rated capacitance value
for example: 256=25×106pF=25.0μF
Digit 9
Capacitance tolerance
J=±5%
Digit 10
Pitch
B=27.5 mm C=30.0 mm F=37.5 mm M=52.5 mm
Digit 11
Internal use
K=±10%
Digit 12 to 15 Lead form and packaging code
Digit 16 to 18 Internal use
Table 1
lead form and packaging code
Digit 12
Digit 13 and Digit 14
Code
Explanation
Code
Explanation
Two pins (bulk)
C0
38
Standard lead length 5.5mm
lead length 3.8mm
1
2
3
4
A
B
C
D
Our pins (bulk)
b=10.0mm
Four pins (bulk)
b=12.7mm
Four pins (bulk)
b=20.0mm
Four pins (bulk)
b=15.0mm
four pins(bulk)
b=20.3mm
four pins(bulk)
b=10.2mm
four pins(bulk)
b=5.1mm
four pins(bulk)
b=15.2mm
Page 4 of 15
Digit 15
Code
Explanation
Length tolerance ±1.0mm
Length tolerance ±0.5mm
C3D
■ Technical data(mm)
UN,85℃ : 500Vdc
CN
(F)
W
±1.0
H
±1.0
tanδ×(10-4)
T
±1.0
P
±0.5
b
±0.5
d
±0.05
dV/dt
(V/μs)
1kHz
10kHz
0.8
65
10
100
ESR
@10kHz
(mΩ)
8.5
0.8
65
10
100
7.5
0.8
65
10
100
Imax
(A)
Part number
5.0
C3D2H505+B00+++***
6.5
C3D2H106+B00+++***
5.0
10.0
C3D2H226+B00+++***
5.0
32.0
20.0
11.0
27.5
10.0
32.0
24.5
15.0
27.5
22.0
32.0
37.0
22.0
27.5
30.0
42.0
40.0
20.0
37.5
10.2
1.0
30
15
150
8.0
12.5
C3D2H306+F0B+++***
35.0
42.0
36.0
24.0
37.5
10.2
1.0
30
15
150
8.0
13.5
C3D2H356+F0B+++***
40.0
41.5
37.5
27.5
37.5
10.2
1.0
30
15
150
5.0
14.5
C3D2H406+F0B+++***
50.0
41.0
43.0
28.0
37.5
12.7
1.2
30
15
150
4.0
16.0
C3D2H506+F02+++***
50.0
42.0
45.0
30.0
37.5
20.3
1.2
30
15
150
4.0
16.0
C3D2H506+F0A+++***
60.0
42.0
45.0
30.0
37.5
20.3
1.2
30
15
150
3.0
16.5
C3D2H606+F0A+++***
75.0
57.0
43.5
29.5
52.5
12.7
1.2
15
35
350
5.5
16.0
C3D2H756+M02+++***
75.0
57.0
43.5
29.5
52.5
20.3
1.2
15
35
350
5.5
16.0
C3D2H756+M0A+++***
80.0
57.0
43.5
29.5
52.5
20.3
1.2
15
35
350
5.0
16.5
C3D2H806+M0A+++***
100.0
57.0
50.0
35.0
52.5
20.3
1.2
15
35
350
4.0
18.0
C3D2H107+M0A+++***
110.0
57.0
50.0
35.0
52.5
20.3
1.2
15
35
350
4.0
19.0
C3D2H117+M0A+++***
UN,85℃ : 600Vdc
CN
(F)
W
±1.0
H
±1.0
T
±1.0
P
±0.5
b
±0.5
d
±0.05
dV/dt
(V/μs)
1kHz
10kHz
2.0
32.0
18.0
9.0
27.5
0.8
65
11
100
ESR
@10kHz
(mΩ)
47.8
3.0
32.0
20.0
11.0
27.5
0.8
65
11
100
4.0
32.0
20.0
11.0
27.5
0.8
65
11
100
5.0
32.0
22.0
13.0
27.5
0.8
65
11
6.0
32.0
24.5
15.0
27.5
0.8
65
7.0
32.0
24.5
15.0
27.5
0.8
65
8.0
32.0
28.0
14.0
27.5
0.8
tanδ×(10-4)
Imax
(A)
Part number
2.8
C3D1U205+B00+++***
31.8
4.1
C3D1U305+B00+++***
23.9
5.5
C3D1U405+B00+++***
100
19.1
6.9
C3D1U505+B00+++***
11
100
18.6
7.1
C3D1U605+B00+++***
11
100
15.9
8.3
C3D1U705+B00+++***
65
11
100
13.9
9.5
C3D1U805+B00+++***
0.8
65
11
100
12.4
10.7
C3D1U905+B00+++***
0.8
65
11
100
11.1
11.0
C3D1U106+B00+++***
0.8
65
11
100
10.8
12.0
C3D1U126+B00+++***
9.0
32.0
30.0
16.0
27.5
10.0
32.0
30.0
16.0
27.5
12.0
32.0
33.0
18.0
27.5
15.0
32.0
37.0
22.0
27.5
0.8
65
11
100
9.0
12.0
C3D1U156+B00+++***
15.0
32.0
37.0
22.0
27.5
10.2
0.8
65
11
100
7.4
16.5
C3D1U156+B0B+++***
18.0
32.0
37.0
22.0
27.5
0.8
65
11
100
8.0
12.0
C3D1U186+B00+++***
18.0
32.0
37.0
22.0
27.5
12.7
0.8
65
11
100
6.2
17.0
C3D1U186+B02+++***
10.0
41.0
30.0
16.0
37.5
30
19.5
6.2
C3D1U106+F00+++***
41.0
30.0
16.0
37.5
1.0
30
16.3
7.4
C3D1U126+F00+++***
15.0
41.0
33.5
18.5
37.5
1.0
12.0
1.0
30
C3D1U156+F00+++***
42.0
40.0
20.0
37.5
10.2
1.0
30
13.0
9.8
9.2
20.0
12.3
C3D1U206+F0B+++***
22.0
42.0
40.0
20.0
37.5
10.2
1.0
30
8.9
13.5
C3D1U226+F0B+++***
25.0
42.0
40.0
20.0
37.5
10.2
1.0
30
7.8
15.4
C3D1U256+F0B+++***
30.0
42.0
44.0
24.0
37.5
12.7
1.0
30
42.0
45.0
30.0
37.5
12.7
1.2
30
18.5
20.1
C3D1U306+F02+++***
35.0
6.5
6.0
35.0
42.0
45.0
30.0
37.5
20.3
1.2
30
6.0
20.1
C3D1U356+F0A+++***
40.0
42.0
45.0
30.0
37.5
12.7
1.2
30
5.2
23.0
C3D1U406+F02+++***
40.0
42.0
45.0
30.0
37.5
20.3
1.2
30
5.2
23.0
C3D1U406+F0A+++***
Page 5 of 15
C3D1U356+F02+++***
C3D
UN,85℃ : 600Vdc
175
ESR
@10kHz
(mΩ)
4.6
25.8
C3D1U456+F02+++***
175
4.6
25.8
C3D1U456+F0A+++***
tanδ×(10-4)
CN
(F)
W
±1.0
H
±1.0
T
±1.0
P
±0.5
b
±0.5
d
±0.05
dV/dt
(V/μs)
1kHz
10kHz
45.0
42.0
50.0
35.0
37.5
12.7
1.2
30
42.0
50.0
35.0
37.5
20.3
1.2
30
Imax
(A)
Part number
50.0
42.0
50.0
35.0
37.5
20.3
1.2
30
4.2
28.7
C3D1U506+F0A+++***
★50.0
42.0
46.0
35.0
37.5
20.3
1.2
30
4.2
28.7
C3D1U506+FAA+++***
55.0
42.0
50.0
35.0
37.5
20.3
1.2
30
3.8
31.6
C3D1U556+F0A+++***
60.0
42.0
55.0
40.0
37.5
20.3
1.2
30
3.5
34.5
C3D1U606+F0A+++***
65.0
42.0
55.0
40.0
37.5
20.3
1.2
30
3.2
35.0
C3D1U656+F0A+++***
70.0
42.0
55.0
40.0
37.5
20.3
1.2
30
3.0
35.0
C3D1U706+F0A+++***
75.0
42.0
60.0
45.0
37.5
20.3
1.2
30
2.8
35.0
C3D1U756+F0A+++***
80.0
42.0
60.0
45.0
37.5
20.3
1.2
30
2.6
35.0
C3D1U806+F0A+++***
85.0
42.0
60.0
45.0
37.5
20.3
1.2
30
2.5
35.0
C3D1U856+F0A+++***
40.0
57.0
45.0
25.0
52.5
12.7
1.2
15
36
350
9.8
12.3
C3D1U406+M02+++***
45.0
57.0
45.0
25.0
52.5
12.7
1.2
15
36
350
8.7
13.8
C3D1U456+M02+++***
50.0
57.0
45.0
25.0
52.5
12.7
1.2
15
36
350
7.8
15.4
C3D1U506+M02+++***
55.0
57.0
43.5
29.5
52.5
12.7
1.2
15
36
350
7.1
16.9
C3D1U556+M02+++***
55.0
57.0
43.5
29.5
52.5
20.3
1.2
15
36
350
7.1
16.9
C3D1U556+M0A+++***
60.0
57.0
43.5
29.5
52.5
12.7
1.2
15
36
350
6.5
18.5
C3D1U606+M02+++***
60.0
57.0
43.5
29.5
52.5
20.3
1.2
15
36
350
6.5
18.5
C3D1U606+M0A+++***
65.0
57.0
50.0
35.0
52.5
12.7
1.2
15
36
350
6.0
20.0
C3D1U656+M02+++***
65.0
57.0
50.0
35.0
52.5
20.3
1.2
15
36
350
6.0
20.0
C3D1U656+M0A+++***
70.0
57.0
50.0
35.0
52.5
20.3
1.2
15
36
350
5.6
21.5
C3D1U706+M0A+++***
75.0
57.0
50.0
35.0
52.5
20.3
1.2
15
36
350
5.2
23.1
C3D1U756+M0A+++***
80.0
57.0
50.0
35.0
52.5
20.3
1.2
15
36
350
C3D1U806+M0A+++***
57.0
55.0
45.0
52.5
20.3
1.2
15
36
350
4.9
4.8
24.6
85.0
25.1
C3D1U856+M0A+++***
90.0
57.0
55.0
45.0
52.5
20.3
1.2
15
36
350
4.6
25.8
C3D1U906+M0A+++***
95.0
57.0
55.0
45.0
52.5
20.3
1.2
15
36
350
4.4
27.3
C3D1U956+M0A+++**
100.0
57.0
55.0
45.0
52.5
20.3
1.2
15
36
350
4.2
28.7
C3D1U107+M0A+++***
110.0
57.0
55.0
45.0
52.5
20.3
1.2
15
36
350
3.8
31.6
C3D1U117+M0A+++***
120.0
57.0
65.0
45.0
52.5
20.3
1.2
15
36
350
3.5
34.5
C3D1U127+M0A+++***
130.0
57.0
65.0
45.0
52.5
20.3
1.2
15
36
350
3.2
35.0
C3D1U137+M0A+++***
140.0
57.0
65.0
45.0
52.5
20.3
1.2
15
36
350
3.0
35.0
C3D1U147+M0A+++***
UN,85℃ : 800Vdc
tanδ×(10-4)
T
±1.0
P
±0.5
b
±0.5
d
±0.05
dV/dt
(V/μs)
1kHz
10kHz
18.0
9.0
27.5
0.8
65
10
95
ESR
@10kHz
(mΩ)
45.4
20.0
11.0
27.5
0.8
65
10
95
30.3
32.0
30.0
16.0
27.5
0.8
65
10
95
32.0
25.0
13.0
27.5
0.8
65
10
95
5.0
32.0
24.5
15.0
27.5
0.8
65
10
6.0
32.0
30.0
16.0
27.5
0.8
65
7.0
32.0
30.0
16.0
27.5
0.8
8.0
32.0
33.0
18.0
27.5
0.8
9.0
32.0
33.0
18.0
27.5
10.0
32.0
37.0
22.0
27.5
CN
(F)
W
±1.0
H
±1.0
2.0
32.0
3.0
32.0
3.3
4.0
Imax
(A)
Part number
2.9
C3D2K205+B00+++***
4.4
C3D2K305+B00+++***
18.8
7.0
C3D2K335+B00+++***
22.7
5.8
C3D2K405+B00+++***
95
18.2
7.3
C3D2K505+B00+++***
10
95
15.1
8.7
C3D2K605+B00+++***
65
10
95
13.0
10.2
C3D2K705+B00+++***
65
10
95
12.5
10.5
C3D2K805+B00+++***
0.8
65
10
95
11.1
11.8
C3D2K905+B00+++***
0.8
65
10
95
11.0
12.0
C3D2K106+B00+++***
Page 6 of 15
C3D
UN,85℃ : 800Vdc
tanδ×(10-4)
Imax
(A)
Part number
95
ESR
@10kHz
(mΩ)
9.1
14.5
C3D2K106+B0B+++***
10
95
10.0
12.0
C3D2K116+B00+++***
10
95
8.3
16.0
C3D2K116+B0B+++***
65
10
95
9.3
12.0
C3D2K126+B00+++***
0.8
65
10
95
7.6
16.0
C3D2K126+B0B+++***
0.8
65
10
95
8.8
12.0
C3D2K136+B00+++***
12.7
0.8
65
10
95
8.1
16.2
C3D2K136+B02+++***
27.5
0.8
65
10
95
8.2
12.0
C3D2K146+B00+++***
27.5
12.7
0.8
65
10
95
7.6
16.5
C3D2K146+B02+++***
16.0
37.5
1.0
30
18
160
22.3
5.4
C3D2K805+F00+++***
1.0
30
18
160
19.8
6.1
C3D2K905+F00+++***
1.0
30
18
160
17.8
6.7
C3D2K106+F00+++***
1.0
30
18
160
14.9
8.1
C3D2K126+F00+++***
CN
(F)
W
±1.0
H
±1.0
T
±1.0
P
±0.5
b
±0.5
d
±0.05
dV/dt
(V/μs)
1kHz
10kHz
10.0
32.0
37.0
22.0
27.5
10.2
0.8
65
10
11.0
32.0
37.0
22.0
27.5
0.8
65
11.0
32.0
37.0
22.0
27.5
10.2
0.8
65
12.0
32.0
37.0
22.0
27.5
0.8
12.0
32.0
37.0
22.0
27.5
10.2
13.0
32.0
37.0
22.0
27.5
13.0
32.0
37.0
22.0
27.5
14.0
32.0
37.0
22.0
14.0
32.0
37.0
22.0
8.0
41.0
30.0
9.0
41.0
30.0
16.0
37.5
10.0
41.0
33.5
18.5
37.5
12.0
41.0
33.5
18.5
37.5
15.0
42.0
40.0
20.0
37.5
10.2
1.0
30
18
160
11.9
10.1
C3D2K156+F0B+++***
20.0
42.0
44.0
24.0
37.5
12.7
1.0
30
18
160
8.9
13.5
C3D2K206+F02+++***
25.0
42.0
44.0
24.0
37.5
12.7
1.0
30
18
160
7.1
16.8
C3D2K256+F02+++***
30.0
42.0
45.0
30.0
37.5
12.7
1.2
30
18
160
5.9
20.2
C3D2K306+F02+++***
30.0
42.0
45.0
30.0
37.5
20.3
18
160
50.0
35.0
37.5
20.3
30
18
160
5.9
5.5
20.2
22.0
C3D2K306+F0A+++***
42.0
1.2
1.2
30
35.0
20.3
1.2
30
18
160
4.8
25.1
C3D2K406+F0A+++***
40.0
42.0
50.0
35.0
37.5
C3D2K356+F0A+++***
45.0
42.0
55.0
40.0
37.5
20.3
1.2
30
18
160
4.2
28.3
C3D2K456+F0A+++***
50.0
42.0
55.0
40.0
37.5
20.3
1.2
30
18
160
3.8
31.4
C3D2K506+F0A+++***
20.3
1.2
30
18
160
3.5
34.5
C3D2K556+F0A+++***
55.0
42.0
60.0
45.0
37.5
★60.0
42.0
60.0
45.0
37.5
20.3
1.2
30
18
160
3.2
35.0
C3D2K606+F0A+++***
★65.0
42.0
60.0
45.0
37.5
20.3
1.2
30
18
160
2.9
35.0
C3D2K656+F0A+++***
25.0
57.0
45.0
25.0
52.5
12.7
1.2
15
33
320
14.3
8.4
C3D2K256+M02+++***
30.0
57.0
45.0
25.0
52.5
12.7
1.2
15
33
320
11.9
10.1
C3D2K306+M02+++***
★35.0
57.0
45.0
25.0
52.5
12.7
1.2
15
33
320
10.2
11.8
C3D2K356+M02+++***
40.0
57.0
43.5
29.5
52.5
12.7
1.2
15
33
320
8.9
13.5
C3D2K406+M02+++***
40.0
57.0
43.5
29.5
52.5
20.3
1.2
15
33
320
8.9
13.5
C3D2K406+M0A+++***
45.0
57.0
43.5
29.5
52.5
12.7
1.2
15
33
320
7.9
15.1
C3D2K456+M02+++***
45.0
57.0
43.5
29.5
52.5
20.3
1.2
15
33
320
7.9
15.1
C3D2K456+M0A+++***
50.0
57.0
50.0
35.0
52.5
12.7
1.2
15
33
320
7.1
16.8
C3D2K506+M02+++***
50.0
57.0
50.0
35.0
52.5
20.3
1.2
15
33
320
7.1
16.8
C3D2K506+M0A+++***
55.0
57.0
50.0
35.0
52.5
20.3
1.2
15
33
320
6.5
18.5
C3D2K556+M0A+++***
60.0
57.0
50.0
35.0
52.5
20.3
1.2
15
33
320
5.9
20.2
C3D2K606+M0A+++***
65.0
57.0
55.0
45.0
52.5
20.3
1.2
15
33
320
5.5
21.9
C3D2K656+M0A+++***
70.0
57.0
55.0
45.0
52.5
20.3
1.2
15
33
320
5.1
23.6
C3D2K706+M0A+++***
75.0
57.0
55.0
45.0
52.5
20.3
1.2
15
33
320
4.8
25.2
C3D2K756+M0A+++***
80.0
57.0
55.0
45.0
52.5
20.3
1.2
15
33
320
4.6
25.9
C3D2K806+M0A+++***
85.0
57.0
55.0
45.0
52.5
20.3
1.2
15
33
320
4.5
26.7
C3D2K856+M0A+++***
90.0
57.0
55.0
45.0
52.5
20.3
1.2
15
33
320
4.2
28.3
C3D2K906+M0A+++***
95.0
57.0
65.0
45.0
52.5
20.3
1.2
15
33
320
4.0
29.8
C3D2K956+M0A+++***
100.0
57.0
65.0
45.0
52.5
20.3
1.2
15
33
320
3.8
31.4
C3D2K107+M0A+++***
110.0
57.0
65.0
45.0
52.5
20.3
1.2
15
33
320
3.5
34.5
C3D2K117+M0A+++***
Page 7 of 15
C3D
U N,85℃ : 900Vdc
tanδ×(10-4)
CN
(F)
W
±1.0
H
±1.0
T
±1.0
P
±0.5
b
±0.5
d
±0.05
dV/dt
(V/μs)
1kHz
10kHz
1.0
2.0
3.0
32.0
32.0
32.0
18.0
20.0
22.0
9.0
11.0
13.0
27.5
27.5
27.5
0.8
0.8
0.8
70
70
70
9
9
9
90
90
90
4.0
5.0
6.0
32.0
32.0
32.0
24.5
30.0
33.0
15.0
16.0
18.0
27.5
27.5
27.5
0.8
0.8
0.8
70
70
70
9
9
9
90
90
90
7.0
32.0
33.0
18.0
27.5
0.8
70
9
8.0
8.0
32.0
32.0
37.0
37.0
22.0
22.0
27.5
27.5
ESR
@10kHz
(mΩ)
86.0
43.0
28.7
0.8
0.8
70
70
9.0
9.0
10.0
32.0
32.0
32.0
37.0
37.0
37.0
22.0
22.0
22.0
27.5
27.5
27.5
12.7
0.8
0.8
0.8
70
70
70
10.0
32.0
37.0
22.0
27.5
12.7
0.8
70
9
4.7
5.0
6.0
7.0
8.0
10.0
41.0
41.0
41.0
41.0
41.0
42.0
26.0
30.0
30.0
30.0
33.0
40.0
15.0
16.0
16.0
16.0
18.0
20.0
37.5
37.5
37.5
37.5
37.5
37.5
10.2
1.0
1.0
1.0
1.0
1.0
1.0
35
35
35
35
35
35
17
17
17
17
17
17
12.0
15.0
18.0
20.0
25.0
25.0
41.0
42.0
42.0
42.0
42.0
42.0
37.0
44.0
44.0
44.0
45.0
45.0
22.0
24.0
24.0
24.0
30.0
30.0
37.5
37.5
37.5
37.5
37.5
37.5
10.2
12.7
12.7
12.7
12.7
20.3
1.0
1.0
1.0
1.0
1.2
1.2
35
35
35
35
35
35
17
17
17
17
17
17
30.0
35.0
40.0
42.0
42.0
42.0
50.0
55.0
55.0
35.0
40.0
40.0
37.5
37.5
37.5
20.3
20.3
20.3
1.2
1.2
1.2
35
35
35
45.0
50.0
42.0
42.0
60.0
60.0
45.0
45.0
37.5
37.5
20.3
20.3
1.2
1.2
15.0
20.0
25.0
57.0
57.0
57.0
45.0
45.0
45.0
25.0
25.0
25.0
52.5
52.5
52.5
10.2
12.7
12.7
30.0
30.0
35.0
57.0
57.0
57.0
43.5
43.5
43.5
29.5
29.5
29.5
52.5
52.5
52.5
35.0
40.0
45.0
50.0
57.0
57.0
57.0
57.0
43.5
50.0
50.0
50.0
29.5
35.0
35.0
35.0
55.0
60.0
65.0
70.0
75.0
57.0
57.0
57.0
57.0
57.0
55.0
55.0
55.0
65.0
65.0
80.0
85.0
57.0
57.0
65.0
65.0
Imax
(A)
Part number
1.5
3.1
4.6
C3D1X105+B00+++***
C3D1X205+B00+++***
C3D1X305+B00+++***
21.5
17.2
18.0
6.1
7.7
6.9
C3D1X405+B00+++***
C3D1X505+B00+++***
C3D1X605+B00+++***
90
13.0
10.2
C3D1X705+B00+++***
9
9
90
90
11.5
10.7
11.4
12.3
C3D1X805+B00+++***
C3D1X805+B0B+++***
9
9
9
90
90
90
10.4
9.6
12.0
12.0
13.8
12.2
C3D1X905+B00+++***
C3D1X905+B02+++***
C3D1X106+B00+++***
90
8.6
15.4
C3D1X106+B02+++***
150
150
150
150
150
150
35.6
33.4
27.9
23.9
20.9
16.7
3.4
3.6
4.3
5.0
5.7
7.2
C3D1X475+F00+++***
C3D1X505+F00+++***
C3D1X605+F00+++***
C3D1X705+F00+++***
C3D1X805+F00+++***
C3D1X106+F0B+++***
150
150
150
150
150
150
13.9
11.1
9.3
8.4
6.7
6.7
8.6
10.8
12.9
14.4
17.9
17.9
C3D1X126+F0B+++***
C3D1X156+F02+++***
C3D1X186+F02+++***
C3D1X206+F02+++***
C3D1X256+F02+++***
C3D1X256+F0A+++***
17
17
17
150
150
150
5.6
5.1
4.5
21.5
23.4
26.8
C3D1X306+F0A+++***
C3D1X356+F0A+++***
C3D1X406+F0A+++***
35
35
17
17
150
150
4.0
3.6
30.1
33.5
C3D1X456+F0A+++***
C3D1X506+F0A+++***
1.2
1.2
1.2
15
15
15
31
31
31
300
300
300
22.3
16.7
13.4
5.4
7.2
9.0
C3D1X156+M0B+++***
C3D1X206+M02+++***
C3D1X256+M02+++***
12.7
20.3
12.7
1.2
1.2
1.2
15
15
15
31
31
31
300
300
300
11.1
11.1
9.6
10.8
10.8
12.6
C3D1X306+M02+++***
C3D1X306+M0A+++***
C3D1X356+M02+++***
52.5
52.5
52.5
52.5
20.3
20.3
20.3
20.3
1.2
1.2
1.2
1.2
15
15
15
15
31
31
31
31
300
300
300
300
9.6
8.4
7.4
6.7
12.6
14.4
16.1
17.9
C3D1X356+M0A+++***
C3D1X406+M0A+++***
C3D1X456+M0A+++***
C3D1X506+M0A+++***
45.0
45.0
45.0
45.0
45.0
52.5
52.5
52.5
52.5
52.5
20.3
20.3
20.3
20.3
20.3
1.2
1.2
1.2
1.2
1.2
15
15
15
15
15
31
31
31
31
31
300
300
300
300
300
6.1
5.6
5.1
4.8
4.7
19.7
21.5
23.3
25.1
25.7
C3D1X556+M0A+++***
C3D1X606+M0A+++***
C3D1X656+M0A+++***
C3D1X706+M0A+++***
C3D1X756+M0A+++***
45.0
45.0
52.5
52.5
20.3
20.3
1.2
1.2
15
15
31
31
300
300
4.5
4.2
26.8
28.5
C3D1X806+M0A+++***
C3D1X856+M0A+++***
10.2
Page 8 of 15
C3D
U N,85℃ : 1 000Vdc
10kHz
ESR
@10kHz
(mΩ)
Imax
(A)
Part number
8
80
76.4
1.7
C3D3A105+B00+++***
75
8
80
38.2
3.5
C3D3A205+B00+++***
0.8
75
8
80
25.5
5.2
C3D3A305+B00+++***
0.8
75
8
80
19.1
6.9
C3D3A405+B00+++***
0.8
75
8
80
15.3
8.6
C3D3A505+B00+++***
0.8
75
8
80
14.9
8.9
C3D3A605+B00+++***
0.8
75
8
80
14.5
9.4
C3D3A705+B00+++***
12.7
0.8
75
8
80
11.4
11.6
C3D3A705+B02+++***
0.8
75
8
80
13.0
10.8
C3D3A805+B00+++***
27.5
12.7
0.8
75
8
80
10.0
13.3
C3D3A805+B02+++***
16.0
37.5
1.0
37
15
140
31.2
3.8
C3D3A505+F00+++***
30.0
16.0
37.5
1.0
37
15
140
26.0
4.6
C3D3A605+F00+++***
41.0
33.0
18.0
37.5
1.0
37
15
140
22.3
5.4
C3D3A705+F00+++***
8.0
41.0
33.0
18.0
37.5
1.0
37
15
140
19.5
6.2
C3D3A805+F00+++***
10.0
42.0
40.0
20.0
37.5
1.0
37
15
140
15.6
6.7
C3D3A106+F00+++***
10.0
42.0
40.0
20.0
37.5
10.2
1.0
37
15
140
15.6
7.7
C3D3A106+F0B+++***
12.0
41.0
37.0
22.0
37.5
12.7
1.0
37
15
140
13.0
9.2
C3D3A126+F02+++***
12.0
41.0
37.0
22.0
37.5
1.0
37
15
140
15.0
8.0
C3D3A126+F00+++***
15.0
42.0
44.0
24.0
37.5
12.7
1.0
37
15
140
10.4
11.5
C3D3A156+F02+++***
18.0
42.0
45.0
30.0
37.5
12.7
1.2
37
15
140
8.7
13.8
C3D3A186+F02+++***
18.0
42.0
45.0
30.0
37.5
20.3
1.2
37
15
140
8.7
13.8
C3D3A186+F0A+++***
20.0
42.0
45.0
30.0
37.5
12.7
1.2
37
15
140
7.8
15.4
C3D3A206+F02+++***
20.0
42.0
45.0
30.0
37.5
20.3
1.2
37
15
140
7.8
15.4
C3D3A206+F0A+++***
25.0
42.0
50.0
35.0
37.5
20.3
1.2
37
15
140
6.2
19.2
C3D3A256+F0A+++***
30.0
42.0
55.0
40.0
37.5
20.3
1.2
37
15
140
5.2
23.1
C3D3A306+F0A+++***
35.0
42.0
55.0
40.0
37.5
20.3
1.2
37
15
140
4.8
25.1
C3D3A356+F0A+++***
40.0
42.0
60.0
45.0
37.5
20.3
1.2
37
15
140
4.2
28.7
C3D3A406+F0A+++***
15.0
57.0
45.0
25.0
52.5
12.7
1.2
17
28
280
20.8
5.8
C3D3A156+M02+++***
20.0
57.0
45.0
25.0
52.5
12.7
1.2
17
28
280
15.6
7.7
C3D3A206+M02+++***
25.0
57.0
45.0
25.0
52.5
12.7
1.2
17
28
280
12.5
9.6
C3D3A256+M02+++***
30.0
57.0
43.5
29.5
52.5
12.7
1.2
17
28
280
10.4
11.5
C3D3A306KM02+++***
30.0
57.0
43.5
29.5
52.5
20.3
1.2
17
28
280
10.4
11.5
C3D3A306KM0A+++***
30.0
57.0
45.0
30.0
52.5
12.7
1.2
17
28
280
10.4
11.5
C3D3A306JM02+++***
30.0
57.0
45.0
30.0
52.5
20.3
1.2
17
28
280
10.4
11.5
C3D3A306JM0A+++***
35.0
57.0
50.0
35.0
52.5
20.3
1.2
17
28
280
8.9
13.5
C3D3A356+M0A+++***
40.0
57.0
50.0
35.0
52.5
20.3
1.2
17
28
280
7.8
15.4
C3D3A406+M0A+++***
45.0
57.0
55.0
45.0
52.5
20.3
1.2
17
28
280
6.9
17.3
C3D3A456+M0A+++***
50.0
57.0
55.0
45.0
52.5
20.3
1.2
17
28
280
6.2
19.2
C3D3A506+M0A+++***
55.0
57.0
55.0
45.0
52.5
20.3
1.2
17
28
280
5.7
21.1
C3D3A556+M0A+++***
60.0
57.0
65.0
45.0
52.5
20.3
1.2
17
28
280
5.2
23.1
C3D3A606+M0A+++***
65.0
57.0
65.0
45.0
52.5
20.3
1.2
17
28
280
4.8
25.0
C3D3A656+M0A+++***
70.0
57.0
65.0
45.0
52.5
20.3
1.2
17
28
280
4.5
26.9
C3D3A706+M0A+++***
tanδ×(10-4)
CN
(F)
W
±1.0
H
±1.0
T
±1.0
P
±0.5
b
±0.5
d
±0.05
dV/dt
(V/μs)
1kHz
1.0
32.0
18.0
9.0
27.5
0.8
75
2.0
32.0
22.0
13.0
27.5
0.8
3.0
32.0
24.5
15.0
27.5
4.0
32.0
30.0
16.0
27.5
5.0
32.0
33.0
18.0
27.5
6.0
32.0
33.0
18.0
27.5
7.0
32.0
37.0
22.0
27.5
7.0
32.0
37.0
22.0
27.5
8.0
32.0
37.0
22.0
27.5
8.0
32.0
37.0
22.0
5.0
41.0
30.0
6.0
41.0
7.0
Page 9 of 15
C3D
U N,85℃ : 1 100Vdc
10kHz
ESR
@10kHz
(mΩ)
Imax
(A)
Part number
8
70
80.0
1.7
C3D1M684+B00+++***
80
8
70
59.4
2.2
C3D1M105+B00+++***
0.8
80
8
70
55.7
2.4
C3D1M155+B00+++***
0.8
80
8
70
27.9
4.7
C3D1M205JB00+++***
27.5
0.8
80
8
70
27.9
4.7
C3D1M205KB00+++***
16.0
27.5
0.8
80
8
70
20.4
6.5
C3D1M305+B00+++***
33.0
18.0
27.5
0.8
80
8
70
15.3
8.6
C3D1M405+B00+++***
32.0
37.0
22.0
27.5
0.8
80
8
70
14.0
9.8
C3D1M505+B00+++***
5.0
32.0
37.0
22.0
27.5
10.2
0.8
80
8
70
12.3
10.8
C3D1M505+B0B+++***
6.0
32.0
37.0
22.0
27.5
0.8
80
8
70
12.3
10.8
C3D1M605+B00+++***
6.0
32.0
37.0
22.0
27.5
10.2
0.8
80
8
70
10.2
12.9
C3D1M605+B0B+++***
3.0
41.0
30.0
16.0
37.5
1.0
40
15
130
48.3
2.5
C3D1M305+F00+++***
4.0
41.0
30.0
16.0
37.5
1.0
40
15
130
36.2
3.3
C3D1M405+F00+++***
4.7
41.0
33.5
18.5
37.5
1.0
40
15
130
30.8
3.9
C3D1M475+F00+++***
5.0
41.0
33.5
18.5
37.5
1.0
40
15
130
29.0
4.1
C3D1M505+F00+++***
6.0
41.0
33.5
18.5
37.5
1.0
40
15
130
24.2
5.0
C3D1M605+F00+++***
7.0
42.0
40.0
20.0
37.5
10.2
1.0
40
15
130
20.7
5.8
C3D1M705+F0B+++***
8.0
41.0
37.0
22.0
37.5
10.2
1.0
40
15
130
18.1
6.6
C3D1M805+F0B+++***
9.0
41.0
37.0
22.0
37.5
12.7
1.0
40
15
130
16.1
7.5
C3D1M905+F02+++***
10.0
42.0
44.0
24.0
37.5
12.7
1.0
40
15
130
14.5
8.3
C3D1M106+F02+++***
12.0
42.0
44.0
24.0
37.5
12.7
1.0
40
15
130
12.1
9.9
C3D1M126+F02+++***
12.0
42.0
44.0
24.0
37.5
1.0
40
15
130
14.0
8.6
C3D1M126+F00+++***
15.0
42.0
45.0
30.0
37.5
12.7
1.2
40
15
130
9.7
12.4
C3D1M156+F02+++***
15.0
42.0
45.0
30.0
37.5
20.3
1.2
40
15
130
9.7
12.4
C3D1M156+F0A+++***
18.0
42.0
50.0
35.0
37.5
20.3
1.2
40
15
130
8.1
14.9
C3D1M186+F0A+++***
20.0
42.0
50.0
35.0
37.5
20.3
1.2
40
15
130
7.2
16.6
C3D1M206+F0A+++***
25.0
42.0
55.0
40.0
37.5
20.3
1.2
40
15
130
5.8
20.7
C3D1M256+F0A+++***
30.0
42.0
60.0
45.0
37.5
20.3
1.2
40
15
130
4.8
24.8
C3D1M306+F0A+++***
★15.0
57.0
45.0
25.0
52.5
12.7
1.2
260
19.3
6.2
C3D1M156+M02+++***
20.0
57.0
43.5
29.5
52.5
12.7
1.2
260
14.5
8.3
C3D1M206+M02+++***
20.0
57.0
43.5
29.5
52.5
20.3
1.2
260
14.5
8.3
C3D1M206+M0A+++***
25.0
57.0
50.0
35.0
52.5
20.3
1.2
260
11.6
10.4
C3D1M256+M0A+++***
30.0
57.0
50.0
35.0
52.5
20.3
1.2
260
9.7
12.4
C3D1M306+M0A+++***
35.0
57.0
55.0
45.0
52.5
20.3
1.2
260
8.4
14.3
C3D1M356+M0A+++***
40.0
57.0
55.0
45.0
52.5
20.3
1.2
260
7.8
15.5
C3D1M406+M0A+++***
45.0
57.0
55.0
45.0
52.5
20.3
1.2
260
6.9
17.4
C3D1M456+M0A+++***
50.0
57.0
65.0
45.0
52.5
20.3
1.2
260
6.2
19.3
C3D1M506+M0A+++***
55.0
57.0
65.0
45.0
52.5
20.3
1.2
260
5.6
21.3
C3D1M556+M0A+++***
tanδ×(10-4)
CN
(F)
W
±1.0
H
±1.0
T
±1.0
P
±0.5
b
±0.5
d
±0.05
dV/dt
(V/μs)
1kHz
0.68
32.0
20.0
11.0
27.5
0.8
80
1.0
32.0
20.0
11.0
27.5
0.8
1.5
32.0
22.0
13.0
27.5
2.0
32.0
25.0
13.0
27.5
★2.0
32.0
25.0
13.0
3.0
32.0
30.0
4.0
32.0
5.0
Page 10 of 15
C3D
U N,85℃ : 1 200Vdc
tanδ×(10-4)
CN
(F)
W
±1.0
H
±1.0
T
±1.0
P
±0.5
b
±0.5
d
±0.05
dV/dt
(V/μs)
1kHz
10kHz
1.0
32.0
20.0
11.0
27.5
0.8
90
7
55
2.0
32.0
24.5
15.0
27.5
0.8
90
7
55
3.0
32.0
30.0
16.0
27.5
0.8
90
7
55
4.0
32.0
33.0
18.0
27.5
0.8
90
7
5.0
32.0
37.0
22.0
27.5
ESR
@10kHz
(mΩ)
39.5
0.8
90
5.0
32.0
37.0
22.0
27.5
10.2
0.8
90
3.0
41.0
30.0
16.0
37.5
1.0
4.0
41.0
30.0
16.0
37.5
5.0
41.0
33.5
18.5
37.5
6.0
42.0
40.0
20.0
37.5
7.0
41.0
37.0
22.0
37.5
8.0
42.0
44.0
24.0
37.5
9.0
42.0
44.0
24.0
10.0
42.0
44.0
12.0
42.0
12.0
42.0
15.0
Imax
(A)
Part number
3.5
C3D3L105+B00+++***
26.3
5.0
C3D3L205+B00+++***
17.5
7.5
C3D3L305+B00+++***
55
13.9
9.5
C3D3L405+B00+++***
7
55
12.7
10.4
C3D3L505+B00+++***
7
55
11.1
11.8
C3D3L505+B0B+++***
45
13
100
37.2
3.2
C3D3L305+F00+++***
1.0
45
13
100
27.9
4.3
C3D3L405+F00+++***
1.0
45
13
100
22.3
5.4
C3D3L505+F00+++***
1.0
45
13
100
18.6
6.5
C3D3L605+F00+++***
10.2
1.0
45
13
100
15.9
7.5
C3D3L705+F0B+++***
12.7
1.0
45
13
100
13.9
8.6
C3D3L805+F02+++***
37.5
12.7
1.0
45
13
100
12.4
9.7
C3D3L905+F02+++***
24.0
37.5
12.7
1.0
45
13
100
11.1
10.8
C3D3L106+F02+++***
45.0
30.0
37.5
12.7
1.2
45
13
100
9.3
12.9
C3D3L126+F02+++***
45.0
30.0
37.5
20.3
1.2
45
13
100
9.3
12.9
C3D3L126+F0A+++***
42.0
50.0
35.0
37.5
20.3
1.2
45
13
100
7.4
16.1
C3D3L156+F0A+++***
18.0
42.0
50.0
35.0
37.5
20.3
1.2
45
13
100
6.6
18.1
C3D3L186+F0A+++***
20.0
42.0
55.0
40.0
37.5
20.3
1.2
45
13
100
6.0
20.1
C3D3L206+F0A+++***
25.0
42.0
60.0
45.0
37.5
20.3
1.2
45
13
100
4.8
25.1
C3D3L256+F0A+++***
12.0
57.0
45.0
25.0
52.5
12.7
1.2
23
24
200
19.9
6.0
C3D3L126+M02+++***
15.0
57.0
45.0
25.0
52.5
12.7
1.2
23
24
200
15.9
7.5
C3D3L156+M02+++***
20.0
57.0
43.5
29.5
52.5
12.7
1.2
23
24
200
11.9
10.0
C3D3L206KM02+++***
20.0
57.0
43.5
29.5
52.5
20.3
1.2
23
24
200
11.9
10.0
C3D3L206KM0A+++***
20.0
57.0
45.0
30.0
52.5
12.7
1.2
23
24
200
11.9
10.0
C3D3L206JM02+++***
20.0
57.0
45.0
30.0
52.5
20.3
1.2
23
24
200
11.9
10.0
C3D3L206JM0A+++***
25.0
57.0
50.0
35.0
52.5
20.3
1.2
23
24
200
9.6
12.6
C3D3L256+M0A+++***
30.0
57.0
55.0
45.0
52.5
20.3
1.2
23
24
200
8.0
15.1
C3D3L306+M0A+++***
35.0
57.0
55.0
45.0
52.5
20.3
1.2
23
24
200
6.8
17.6
C3D3L356+M0A+++***
40.0
57.0
65.0
45.0
52.5
20.3
1.2
23
24
200
6.0
20.1
C3D3L406+M0A+++***
45.0
57.0
65.0
45.0
52.5
20.3
1.2
23
24
200
5.3
22.6
C3D3L456+M0A+++***
Note: 1. “+”=capacitance tolerance code K=±10%, J=±5%
2. “+++”= lead form and packaging code
3. “***”= Internal use
4. When the b=10.0mm, the digit 12 is “1”; When the b=20.0mm, the digit 12 is “2”; When the b=15.0mm, the digit 12 is “4”;
5. “Imax”=Maximum r.m.s current at 10kHz, Θamb=70℃, △Θcase=15.0℃.
6. “★” = Arc-bottom of the outer shell.
Page 11 of 15
C3D
Typical waveforms
These capacitors are only suitable for DC applications. It means the voltage applied to the
capacitors must be unidirectional ripple voltage.
Note:
●The peak voltage(UP+) shall not be greater then the rated DC voltage(U N).
●The peak-to-peak ripple voltage(UP-P) shall not be greater then 0.3× (UN).
●The maximum component surface temperature rise must be lower than 15℃.
Measuring the component temperature
Note:
●The temperature is measured in unloaded (Tamb) and maximum loaded condition (T c)
●The temperature rise is given by △T = Tc - Tamb
●To avoid thermal radiation or convection, the capacitor must be tested in a closed area from
air circulation
Over voltages according to IEC 61071:
1.1 UN
30% of on-load-dur.
1.15 UN
30min/day
1.2 UN
5min/day
1.3 UN
1.5 UN
1min/day
100ms every time, 1000 times during the whole life of the capacitor
Lifetime expectancy (typical curve)
Page 12 of 15
C3D
No.
Test Method And Performance
Item
5.14.2 External inspection
Initial measurements
Performance
Legible marking and finish as
specified
Dimensions: see specific drawing
Capacitance at 1kHz
tg at 10kHz
Testing Method
IEC 61071
Check for finish, marking and
overall dimensions
Tensile Ua1
Wire diameter
1
5.14.1.1 Robustness of
terminations
d ≤0.8mm
0.8 mmd ≤1.2mm
There shall be no visible damage
Bending Ub1
Wire diameter
load
10N
20N
load
d≤0.8 mm
5N
0.8 mmd≤1.2 mm
10N
4×90°, duration 2s to 3s
5.14.1.6 Resistance to
soldering heat
There shall be no visible damage.
Final measurements
|C/C|≤0.5%(relative to the initial value)
Increase of tg: 0.005
Capacitance at 1kHz
tg at 10kHz
5.14.3.1 Vibration
There shall be no evidence damage
5.14.3.1 Impacts
2
Final measurements
3
f=10 Hz to 55Hz
a=±0.35mm
Test duration per axis = 10
frequency cycles (3 axes
offset from each other by
90C),
1 octave/min, the total times
are 135min for 3 axes.
1 000times,
Acceleration: 390m/s2
Pulse duration: 6ms
Capacitance at 1kHz
tg at 10kHz
Test voltage: 1.1UNDC
Number of discharges: 5
Time lapse every 2 min
(10min total)
Within 5 min after the surge
discharge test, the capacitor
shall be subjected to a
voltage
test
between
terminals: 1.5UNDC, 60s
5.9 Surge discharge test
Final measurements
Solder temperature:
260˚C5˚C
Immersion time: 10s1s
|C/C|≤1.0%
tg: 1.2×tg0(the initial tg)+0.0001
Page 13 of 15
C3D
No.
Item
Testing Method
IEC 61071
Performance
Capacitance at 1kHz
tg at 10kHz
Voltage: 1.5U
Duration: 10s
If fewer than five clearing
occur during this time, the
voltage shall be increased
slowly until five clearings
have occurred since the start
of the test or until the voltage
has reached 2.5UNDC
If fewer than five clearings
have occurred when the
voltage has reached 2.5UNDC,
for a time of 10s,the test shall
be finished.
NDC
4
5.11 Self-healing
5
6
7
5.13.1Change of
temperature
|C/C|≤0.5%
tg: 1.1×tg0(the initial tg)+0.0001
Capacitance at 1kHz
tg at 10kHz
There shall be no evidence of
deterioration
Final measurements
|C/C|≤2.0%(relative to the initial value)
Increase of tg:0.015
Capacitance at 1kHz
tg at 10kHz
Test: Na
A=-40˚C,B=+85˚C
5 cycles, Duration: t=30min
5.13.2Damp heat, steady
state
deterioration.
Temperature: 40˚C 2˚C
Humidity: 933 %RH
Duration: 56 days
5.5.1 Voltage test between
terminals
There shall be no
puncturing or flashover.
permanent
1.5U , 60s
5.6.1 Voltage test between
terminals and case
There shall be no
permanent
NDC
Final measurements
Capacitance at 1kHz
tg at 10kHz
5.10.1Thermal stability test
Final measurements
Throughout
the last
6h, the
temperature of the case near of the
top rise shall not increase by more
than 1˚C
tg:1.2×tg0(the initial tg)+0.015
Page 14 of 15
2 000VAC, 10s
Temperature: ambient
temperature
Test current: 1.1Irms
Test frequency: 10kHz
Test time: 48h
During the last 6h, the
of the top rise shall be
measured per 1.5h.
C3D
No.
Item
Performance
Testing Method
IEC 61071
Capacitance at 1kHz
tg at 10kHz
Measuring procedure:
(1) 1.3U , 85℃, 500h
NDC
8
(2) Charging and discharging:
Times: 1 000
dv/dt: according to the
technical data
5.15 Endurance
(3) 1.3U , 85℃, 500h
NDC
Final measurements
|C/C|≤3.0%(relative to the initial
value)
Page 15 of 15
