HT8051A
High speed rail to rail output comparator
Feature
General Description
140ns propagation delay (@100mV Overdrive)
HT8051A is a high speed, low power dissipation
Rail to Rail output, CMOS/TTL Compatible
comparator. It applies 140ns Propagation Delay at
Internal Hysteresis to ensure clean switching
100mV Overdrive voltage.
DC coupled Input
HT8051A is DC coupled normally, and It includes
Offset voltage: +/-5mV Max.
internal hysteresis(5mV) to ensure clean output switch,
Low HYS voltage Temperature Drift: 5uV/℃.
the HYS voltage has a ultra-low temperature drift
2.7~5.5V power supply Voltage.
Low quiescent current: 200uA
Chip available in SOT23-5 Package
5uV/℃.
HT8051A consists of a high speed Class AB structure,
which supports rail to rail output.
Applications
Package
High speed Line Receivers;
Threshold Detector /Discriminators;
Sampling Circuits;
IR Receivers.
The package of HT8051A is SOT23 -5
Block Diagram
Bias
Generator
VDD
gm
VINP
DOUT
Comparator
VDD
VINN
GND
Rev. 01
HT8051A
Absolute Maximum Ratings
(If out of these ratings, the filter may be fail or damaged)
Table 1
Symbol
VDD
TA
TSTG
Parameter
Power supply
Rating
5.5
Units
V
Operating ambient Temperature Range
-40~+85
Storage Temperature
-65~+150
Recommended Operating Conditions
Table 2
Symbol
VDD
TA
Parameter
Rating
Units
Power supply
2.7~5.5
V
-40~+85
Rev. 01
HT8051A
Electrical Characteristics
Table 3
Specifications are at VDD=+2.7V~+5.5V Vin+=VDD, Vin-=1.2V RL=10Kohm CL=15pF Vin-=1.2V tt corner & T=30 ºC)
Symbol
Parameter
VCC
Operating Supply Voltage
VOS
Input Offset Voltage
VOS_TC
Vhyst
Vhyst_TC
CIN
Spec
Min
2.7
Typ
3.3
Units
Max
5.5
-5
+/-0.15
+5
V
mV
0.64
1.96
4.7
uV/℃
4
5
10.8
mV
Input Hysteresis Voltage Temp Drift
4.8
5.4
uV/℃
Input Capacitance
Differential
1.8
Common Mode
3.6
Input Offset voltage Temp Drift
pF
RIN
Input Resistance
>100
GΩ
IQ
Quiescent Current
200
uA
ISC
Output short to VDD
25
mA
Vin_cm
Common mode Input voltage
GND+0.2
VOH
Output Voltage High Swing
VDD-0.3
VOL
Output Voltage Low Swing
VDD-0.2
V
V
GND+0.3
mV
CMRR
Common Mode Rejection Ratio
70
dB
PSRR
Power supply rejection ratio
63
dB
tR
Rising time
35
ns
tF
Falling time
28
ns
TPD+
Propagation Delay(Low to High)
140
ns
TPD-
Propagation Delay(High to Low)
135
ns
*Note1: The input offset voltage is the average of the input-referred trip points. The input hysteresis is the difference between the
Rev. 01
HT8051A
PAD Definition
OUT
1
GND
2
VINP
3
5
VDD
4
VINN
HT8051A
Table 4 Pad definition
Pad
Name
I/O
Analog/Digital
Description
1
OUT
O
A
Comparator Output PAD, High Voltage level is Pulled to
VDD, Low Voltage is GND.
2
GND
GROUND
GROUND
Ground pin. Connect to the most negative supply, ALL GND
pads are connected on die.
3
VINP
I
A
Video signal input PAD, DC coupled.
4
VINN
I
A
DC Reference voltage input PAD.
5
VDD
POWER
POWER
Power supply (3.3V/5V), connect to positive voltage supply.
Rev. 01
HT8051A
Application Circuits
Comp
OUT
1K Ohm
1
Input
signal
1K Ohm
3
GND
VINP
VDD
0.1uF
3.3V/5V
HT805A
2
OUT
10uF
5
GND
VDD
VINN
4
Vref
0.1uF
GND
GND
Rev. 01
HT8051A
Package
SOT23-5
Symbol
Unit(mm)
Min
Typ
Max
A
1.35
A1
0.04
0.15
A2
1.00
1.10
1.20
b
0.38
0.48
b1
0.37
0.40
0.43
c
0.11
0.21
c1
0.10
0.13
0.16
D
2.72
2.92
3.12
E
2.60
2.80
3.00
E1
1.40
1.60
1.80
e
0.95BSC
θ
0°
8°
L
0.30
0.60
Rev. 01
很抱歉,暂时无法提供与“HT8051ARTZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.58120
- 10+2.03040
- 30+1.80360
- 100+1.51200
- 500+1.38240
- 1000+1.29600
