TDC400VS330M35*25 VS 数据手册
LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS
TDC Series
105℃ 2,000Hrs assured.
Non-solvent proof.
Downsized.
For SMPS, Inverter.
RoHS compliant.
Halogen-free capacitors are also available.
TDA
TDC
Downsized
SPECIFICATIONS
ltem
Characteristics
Rated Voltage Range
160 ∼ 500 VDC
Operating Temperature Range
-25 ∼ +105℃
Capacitance Tolerance
±20% (M)
(at 20℃, 120Hz)
I=0.02CV or 3mA, whichever is smaller.
Where, I:Leakage current(㎂)
C:Nominal capacitance(㎌)
V:Rated voltage(VDC)
(at 20℃, 5 minutes)
Leakage Current
※ Dissipation Factor(Tan δ)
Rated Voltage(VDC)
160∼400
420∼500
Tanδ(Max.)
0.15
0.20
(at 20℃, 120Hz)
Temperature Characteristics
(Max.Impedance ratio)
Rated Voltage(VDC)
160∼400
420∼500
Z(-25℃)/Z(20℃)
4
8
(at 120HZ)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the
rated voltage is applied for 2,000 hours at 105℃.
Load Life
Capacitance change
Tanδ
Leakage Current
±20% of the initial value
200% of the initial specified value
The initial specified value
exposing them at 105℃ for 1,000 hours without voltage applied.
The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24
hours and not more than 48 hours before the measurements.
Shelf Life
Capacitance change
Tanδ
Leakage Current
Others
Satisfied characteristics KS C IEC 60384-4
※ For capacitors with CV products
100,000 Higher Tanδvalue may apply.
※ When the capacitance exceeds 1,000㎌, 0.01 shall be added every 1,000㎌ increase.
DIMENSIONS OF TDC Series
RATED RIPPLE CURRENT
When capacitors are operated in any other condition
at 120HZ, the maximum ripple current must be
multiplied by the figure shown in the table.
ØD=Ø22~Ø35
VN/VS type
PC board pin-out
Frequency multiplying factor
Freq.(Hz)
VDC
1 6 0 ∼ 2 5 0 V DC
3 1 5 ∼ 5 0 0 V DC
60
0.81
0.77
120
1.00
1.00
300
1.17
1.16
1k
1.32
1.30
10k~
1.45
1.41
Marking : BROWN SLEEVE, SILVER INK
The standard design has no bottom plate.
214
Unit(mm)
RATINGS OF TDC Series
VDC
ØD
160
22
25.4
200
30
35
22
25.4
250
30
35
180
220
270
330
390
470
560
680
820
22×20
1.20
22×25
1.32
22×30
1.46
22×30
1.66
22×35
1.87
22×40
2.09
1,000
1,200
VDC
ØD
25.4×20
1.39
25.4×25
1.51
25.4×25
1.68
25.4×30
1.88
25.4×30
2.14
25.4×35
2.38
25.4×40
2.66
30×20
1.31
30×20
1.54
30×25
1.68
30×25
1.96
30×25 35×25
2.15
2.04
30×30 35×25
2.40
2.55
30×35 35×30
2.69
2.86
22×25
1.20
22×25
1.28
22×25
1.31
22×30
1.45
22×40
1.67
22×45
1.75
22×50
2.04
25.4×20
1.27
25.4×20
1.43
25.4×25
1.53
25.4×30
1.67
25.4×35
1.75
25.4×40
2.04
22
25.4
315
22
25.4
30×20
1.43
30×20
1.53
30×25
1.67
30×25
1.74
30×30
2.04
30×35
2.30
35×20
1.67
35×20
1.72
35×25
2.04
35×30
2.30
35×30
2.65
120
150
180
220
270
330
390
470
560
25.4
35
22×25
0.75
22×25
0.82
22×30 25.4×25
0.91
0.94
25.4×25
1.13
25.4×30 30×25
1.19
1.17
25.4×40 30×30 35×20
1.41
1.28
1.30
30×35 35×30
1.40
1.49
30×40 35×30
1.44
1.64
30×45 35×35
1.71
1.82
35×40
2.00
30
22×20
0.78
22×25 25.4×20
1.00
0.95
25.4×20
1.10
25.4×25 30×20
1.20
1.26
30×25
1.44
30×25
1.57
30×30
1.80
30×30
1.94
30×35
2.29
30×45
2.59
350
30
35
35×20
1.30
35×20
1.49
35×20
1.57
35×25
1.72
35×30
2.10
35×30
2.36
35×35
2.63
400
30
35
82
100
22
22×25
0.72
22×30 25.4×25
0.84
0.89
22×35 25.4×30
0.98
0.94
22×40 25.4×30 30×25
1.04
1.07
1.13
25.4×35 30×30
1.24
1.27
25.4×40 30×35 35×25
1.39
1.43
1.49
25.4×50 30×40 35×30
1.55
1.60
1.66
25.4×50 30×45 35×30
1.72
1.81
1.83
35×35
2.07
22
25.4
22×20
0.55
22×25 25.4×20
0.66
0.67
25.4×25
0.76
25.4×25
0.86
25.4×30
0.97
25.4×35
1.12
25.4×40
1.26
25.4×45
1.44
25.4×50
1.51
30
35
30×20
0.89
30×25
1.02
30×30
1.12
30×30
1.27
30×35
1.43
30×40
1.60
30×45
1.81
35×20
1.02
35×20
1.11
35×25
1.27
35×30
1.44
35×30
1.63
35×35
1.80
Case Size ØD×L(mm)
Rated Ripple Current(Arms/105℃, 120Hz)
TDC
Series
215
VDC
ØD
420
22
25.4
450
30
35
68
82
100
120
150
180
220
270
330
390
470
216
22×20
0.58
22×25
0.66
22×30
0.75
22×40
0.86
22×45
0.96
22×50
1.11
25.4×25
0.69
25.4×25
0.77
25.4×30
0.88
25.4×35
0.97
25.4×40
1.14
25.4×45
1.29
30×20
0.75
30×25
0.88
30×30
1.02
30×30
1.14
30×40
1.30
30×45
1.48
35×20
1.05
35×25
1.12
35×30
1.35
35×35
1.49
35×40
1.64
35×45
1.79
22
25.4
500
30
22×20
0.50
22×25 25.4×25
0.59
0.62
25.4×25
0.70
25.4×30
0.75
25.4×30 30×25
0.88
0.87
25.4×35 30×25
1.01
1.00
30×35
1.10
30×40
1.24
35
35×30
1.25
35×35
1.42
35×40
1.63
35×45
1.78
22
25.4
30
22×35
0.50
22×40 25.4×30
0.53
0.55
22×45 25.4×35
0.61
0.64
22×50 25.4×40 30×30
0.66
0.71
0.73
25.4×45 30×35
0.81
0.80
25.4×50 30×40
0.86
0.93
30×45
0.94
30×50
1.07
30×60
1.28
35
35×30
0.95
35×35
0.98
35×40
1.13
35×45
1.29
35×50
1.47
35×60
Case Size ØD×L(mm)
Rated Ripple Current(Arms/105℃, 120Hz) 1.71
TDC400VS330M35*25 VS 价格&库存
很抱歉,暂时无法提供与“TDC400VS330M35*25 VS”相匹配的价格&库存,您可以联系我们找货
