TPH2501-TR
TPH2501-TR
    3PEAK(思瑞浦)
    TPH2501-TR
TPH2501-TR 数据手册
TPH2501/TPH2502/TPH2503  /TPH2504 250MHz,  Precision,  Rail‐to‐Rail  I/O,  CMOS Op‐amps     Features Description  Unity-Gain Bandwidth: 250MHz  Gain Bandwidth Product: 120MHz  High Slew Rate: 180V/μs  Offset Voltage: 500μV Max.  Low Noise: 6.5nV/√Hz  Rail-to-Rail Input and Output  High Output Current: > 100mA  Excellent Video Performance: The TPH2501/3, THP2502, TPH2504 are single, dual, quad low power, high speed unity gain stable rail-to-rail input/output operational amplifiers. On only 6.5mA of supply current they feature an impressive 250MHz gain-bandwidth product, 180V/μs slew rate and a low 6.5nV/√Hz of input-referred noise, TPH2503 offers a shutdown current of only 1μA. The combination of high bandwidth, high slew rate, low power consumption and low broadband noise makes these amplifiers unique among rail-to-rail input/output op amps with similar supply currents. They are ideal for lower supply voltage high speed signal conditioning systems. Diff Gain: 0.02%, Diff Phase: 0.3°  0.1dB Gain Flatness: 25MHz Low Input Bias Current: 0.3pA  Thermal Shutdown  Supply Range: 2.5V to 5.5V  Operating Temperature Range: –40°C to 125°C The TPH2501 family maintains high efficiency performance from supply voltage levels of 2.5V to 5.5V and is fully specified at supplies of 2.7V and 5.0V. The TPH2501 family can be used as a plug-in replacement for many commercially available op amps to reduce power or to improve I/O range and performance. Applications  Low Voltage, High Frequency Signal Processing      Video Processing The TPH2501 is single channel version available in 5-pin SOT23 package. The TPH2502 is dual channel version available in 8-pin SOP and MSOP packages. The TPH2503 is in 6-pin SOT23 package with shutdown function. The TPH2504 is quad channel version available in 14-pin SOP and TSSOP packages. Optical Networking, Tunable Lasers Photodiode Trans-impedance Barcode Scanner Fast Current Sensing Amplifiers 3PEAK and the 3PEAK logo are registered trademarks of 3PEAK INCORPORATED. All other trademarks are the property of their respective owners. Pin Configuration (Top View) TPH2504 14-Pin SOP/TSSOP TPH2502 8-Pin SOP/MSOP (-S and -T Suffixes) Noninverting Small−Signal Frequency Response  (-S and -V Suffixes) Out D Vs Out A In A In A Out B In A In D In A In B Vs Vs In B In B TPH2501 5-Pin SOT23/SC-70 VO = 0.1VPP Vs In C In B In C Out B Out C (-T and -C Suffix) Out 5 In D Normalized Gain (dB) Out A TPH2503 6-Pin SOT23/SC-70 Vs (-T and -C Suffix) G = 1, RF = 24Ω 0 ‐5 ‐10 G = 2, RF = 620Ω G = 5, RF = 620Ω Vs +In -In Out Vs Vs SHDN +In -In G = 10, RF = 620Ω ‐15 100k     www.3peakic.com 1M 10M 100M 1000M Frequency (Hz) Rev. A 1    TPH2501/TPH2502/TPH2503/TPH2504 250MHz, Precision, Rail‐to‐Rail I/O, CMOS Op‐amps Order Information Model Name TPH2501 TPH2502 TPH2503 TPH2504 Order Number Package Marking Information Transport Media, Quantity TPH2501-TR 5-Pin SOT23 Tape and Reel, 3,000 501 TPH2501-CR 5-Pin SC70 Tape and Reel, 3,000 501 TPH2502-SR 8-Pin SOP Tape and Reel, 4,000 TPH2502 TPH2502-VR 8-Pin MSOP Tape and Reel, 3,000 TPH2502 TPH2503-TR 6-Pin SOT23 Tape and Reel, 3,000 503 TPH2504-SR 14-Pin SOP Tape and Reel, 2,500 TPH2504 TPH2504-TR 14-Pin TSSOP Tape and Reel, 3,000 TPH2504 Absolute Maximum Ratings Note 1 Supply Voltage: V+ – V– Note 2............................7.0V – Current at Supply Pins……………............... ±60mA + Input Voltage............................. V – 0.3 to V + 0.3 Input Current: +IN, –IN Note 3.......................... Operating Temperature Range........–40°C to 125°C ±20mA Maximum Junction Temperature................... 150°C Output Current: OUT.................................... ±160mA Storage Temperature Range.......... –65°C to 150°C Output Short-Circuit Duration Note 4…............. Infinite Lead Temperature (Soldering, 10 sec) ......... 260°C Note 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. Note 2: The op amp supplies must be established simultaneously, with, or before, the application of any input signals. Note 3: The inputs are protected by ESD protection diodes to each power supply. If the input extends more than 500mV beyond the power supply, the input current should be limited to less than 10mA. Note 4: A heat sink may be required to keep the junction temperature below the absolute maximum. This depends on the power supply voltage and how many amplifiers are shorted. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. ESD, Electrostatic Discharge Protection Symbol Parameter Condition Minimum Level Unit HBM Human Body Model ESD MIL-STD-883H Method 3015.8 4 kV CDM Charged Device Model ESD JEDEC-EIA/JESD22-C101E 2 kV Thermal Resistance 2  Package Type θJA θJC Unit 5-Pin SOT23 250 81 °C/W 6-Pin SOT23 170 130 °C/W 8-Pin SOP 158 43 °C/W 8-Pin MSOP 210 45 °C/W 14-Pin SOP 120 36 °C/W 14-Pin TSSOP 180 35 °C/W Rev. A www.3peakic.com          TPH2501/TPH2502/TPH2503/TPH2504     250MHz, Precision, Rail‐to‐Rail I/O, CMOS Electrical Characteristics The specifications are at TA = +25°C, RF = 0Ω, RL = 1kΩ, and connected to VS/2, Unless otherwise noted. SYMBOL VOS VOS TC IB PARAMETER CONDITIONS MIN TYP MAX UNITS -500 +500 2 μV μV/°C 3 pA Input Offset Voltage VCM = VDD/2 + 0.5V Input Offset Voltage Drift -40°C to 125°C ±50 1 TA = 27 °C 0.3 TA = 85 °C 150 pA TA = 125 °C 300 pA 0.001 pA Input Bias Current IOS Input Offset Current en Input Voltage Noise Density f = 1MHz 6.5 nV/√Hz in Input Current Noise Input Capacitance 50 2.7 1 85 fA/√Hz CIN f = 1MHz Differential Common Mode VCM = -1V to 3V, VS = 5.4V CMRR PSRR Common Mode Rejection Ratio Common-mode Input Voltage Range Power Supply Rejection Ratio AVOL Open-Loop Large Signal Gain VCM 65 V– -0.1 pF dB V+-0.1 V VCM = VS/2, VS = 2.4V to 5.5V 80 120 dB RLOAD = 2kΩ 85 110 dB G = +1, VO = 100mVPP, RF = 25Ω 250 MHz G = +2, VO = 100mVPP 90 MHz G = +10 120 MHz G = +2, VO = 100mVPP 25 MHz VS = +5V, G = +1, 4V Step 200 V/μs VS = +5V, G = +1, 2V Step 180 V/μs VS = +3V, G = +1, 2V Step 160 V/μs G = +1, VO = 200mVPP, 10% to 90% 2 ns G = +1, VO = 2VPP, 10% to 90% 7 ns VS = +5V, G = +1, 2V Output Step 25 ns 40 ns 50 ns -78 dBc Frequency Response f−3dB Small-Signal Bandwidth GBW Gain-Bandwidth Product Bandwidth for 0.1dB Gain Flatness f0.1dB SR tF tS tR HD2 HD3 GE PE Xtalk Slew Rate Rise-and-Fall Time Settling Time, 0.1% Settling Time, 0.01% Overload Recovery Time Harmonic Distortion, 2nd-Harmonic Harmonic Distortion, 3rd-Harmonic Differential Gain Error VIN * Gain = VS G = +1, f = 1MHz, VO = 2VPP, RL = 200Ω, VCM = 1.5V G = +1, f = 1MHz, VO = 2VPP, RL = 200Ω, VCM = 1.5V NTSC, RL = 150Ω -90 dBc 0.02 % Differential Phase Error Channel-to-Channel Crosstalk TPH2502 Channel-to-Channel Crosstalk TPH2504 NTSC, RL = 150Ω 0.3 degrees -100 dB -84 dB www.3peakic.com f = 5MHz Rev. A 3    TPH2501/TPH2502/TPH2503/TPH2504 250MHz, Precision, Rail‐to‐Rail I/O, CMOS Op‐amps Electrical Characteristics The specifications are at TA = +25°C, RF = 0Ω, RL = 1kΩ, and connected to VS/2, Unless otherwise noted. SYMBOL VOL, VOH RI PARAMETER Output Swing from Supply Rail Input Impedance CONDITIONS RLOAD = 100kΩ mV Ω || pF f = 1kHz, IOUT = 0 ISC Output Short-Circuit Current VDD Supply Voltage Rev. A 30 Common-Mode Open-Loop Output Impedance 4  2 Ω || pF RO Shutdown Current(TPH2503) UNITS 1013 G = 1, f =1kHz, IOUT = 0 ISD MAX 1013 || 2 Closed-Loop Output Impedance Quiescent Current per Amplifier TYP Differential ROUT IQ MIN || 2 0.01 Ω 21 Ω Sink current 100 160 mA Source current 100 290 mA 2.5 5.5 V 6.5 7.5 mA 1 5 μA www.3peakic.com          TPH2501/TPH2502/TPH2503/TPH2504     250MHz, Precision, Rail‐to‐Rail I/O, CMOS Typical Performance Characteristics VS = 5V, G = +1, RF = 0Ω, RL = 1kΩ, and connected to VS/2, unless otherwise specified. Noninverting Small−Signal Frequency Response Inverting Small−Signal Frequency Response 5 5 VO = 0.1VPP G = 1, RF = 24Ω Normalized Gain (dB) Normalized Gain (dB) VO = 0.1VPP 0 ‐5 G = 2, RF = 620Ω G = 5, RF = 620Ω ‐10 0 ‐5 G = -2, RF = 620Ω G = -5, RF = 620Ω ‐10 G = -10, RF = 620Ω G = 10, RF = 620Ω ‐15 100k 1M 10M 100M ‐15 100k 1000M Frequency (Hz) G = +1 VO = 0.1VPP RS = 0Ω 0 ‐5 CL = 47pF ‐15 CL = 5.6pF ‐20 ‐25 100k 1M 10M 100M 100M 1000M Noninverting Small−Signal Step Response CL = 100pF ‐10 10M Frequency (Hz) Output Voltage (50mV/div) Normalized Gain (dB) 5 1M                               Frequency Response for Various CL 10 G = -1, RF = 620Ω Input Output 1000M Frequency (Hz) Time (20ns/div)             Inverting Large-Signal Step Response        Quiescent Current vs. Temperature 9 Supply Current(mA) Output Voltage (200mV/div) 10 Input Output 8 VS= +5V 7 6 5 4 VS= +2.5V 3 2 1 0 ‐50 Time (20ns/div) www.3peakic.com             ‐25 0 25 50 75 Temperature(℃) Rev. A 100 125          5    TPH2501/TPH2502/TPH2503/TPH2504 250MHz, Precision, Rail‐to‐Rail I/O, CMOS Op‐amps Typical Performance Characteristics VS = 5V, G = +1, RF = 0Ω, RL = 1kΩ, and connected to VS/2, unless otherwise specified. CMRR and PSRR Vs. Temperature Frequency Response For Various RL 160 3 140 RL = 10kΩ PSRR 100 Normalized Gain(dB) CMRR(dB) 120 CMRR 80 60 40 0 G = +1 RF = 0Ω VO = 0.1VPP CL = 0pF ‐3 ‐6 RL = 1kΩ RL = 100Ω RL = 50Ω ‐9 20 0 ‐50 ‐25 0 25 50 75 100 ‐12 100k 125 Temperature(℃) 1M 10M 100M 1000M Frequency(Hz)                                Frequency Response Vs. Capacitive Load Channel-To-Channel Crosstalk 3 ‐80 G = +1 VO = 0.1VPP Crosstalk, Input−Referred (dB) CL = 5.6pf ,RS = 0Ω Normalized Gain(dB) 0 ‐3 CL = 47pf ,RS = 50Ω CL = 100pf ,RS =30Ω ‐6 ‐9 ‐12 100k 1M 10M 100M ‐100 ‐110 ‐120 ‐130 ‐140 ‐150 100k 1000M Frequency(Hz) ‐90 1000M      10k Voltage Noise (nV/√Hz) Output Impedance (Ω) 100M Voltage Spectral Density Vs. Frequency 100 10 1 0.1 1k 100 10 1 1M 10M Frequency (Hz) 6  10M Frequency (Hz) Closed-Loop Output Impedance Vs. Frequency 0.01 100k 1M             Rev. A 100M 10 1000M             1k 100k 10M Frequency (Hz) www.3peakic.com             TPH2501/TPH2502/TPH2503/TPH2504     250MHz, Precision, Rail‐to‐Rail I/O, CMOS Typical Performance Characteristics VS = 5V, G = +1, RF = 0Ω, RL = 1kΩ, and connected to VS/2, unless otherwise specified. Open Loop Gain Vs. Temperature Open Loop Gain And Phase 160 160 140 140 120 Open−Loop Gain (dB) Open−Loop Gain (dB) 150 160 140 130 120 110 100 90 120 Phase 100 100 80 80 60 60 40 40 Gain 20 20 0 0 -20 -20 -40 -40 -60 80 ‐55 ‐30 ‐5 20 45 70 95 10 120 Temperature (℃)             1k 100k 10M -60 1000M Frequency (Hz)                        Input Bias Current Vs. Temperature 0.9 Input Bias Current(pA) 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 ‐0.1 ‐40 ‐10 20 50 80 110 140 Temperature(℃)                                           www.3peakic.com Rev. A 7    TPH2501/TPH2502/TPH2503/TPH2504 250MHz, Precision, Rail‐to‐Rail I/O, CMOS Op‐amps Pin Functions -IN: Inverting Input of the Amplifier. V- or -Vs: Negative Power Supply. It is normally tied to +IN: Non-Inverting Input of Amplifier. ground. It can also be tied to a voltage other than ground OUT: Amplifier Output. The voltage range extends to as long as the voltage between V+ and V– is from 2.5V to within mV of each supply rail. 5.5V. If it is not connected to ground, bypass it with a V+ or +Vs: Positive Power Supply. Typically the voltage capacitor of 0.1μF as close to the part as possible. is from 2.5V to 5.5V. Split supplies are possible as long SHDN: High on this pin logic low to shut down the as the voltage between V+ and V– is between 2.5V and device. Range: Logic high enables the device and 5.5V. A bypass capacitor of 0.1μF as close to the part as logic low shut down the device. This pin defaults to logic high if left open. possible should be used between power supply pins or between supply pins and ground. Operation The TPH2501,TPH2502,TPH2504 is a CMOS, rail-to-rail I/O, high-speed, voltage-feedback operational amplifier designed for video, high-speed, and other applications. It is available as a single, dual, or quad op amp. The amplifier features a 250MHz gain bandwidth, and 180V/μs slew rate, but it is unity-gain stable and can be operated as a +1V/V voltage follower. The TPH2501/TPH2502/TPH2504 is specified over a power-supply range of +2.7V to +5.5V (±1.35V to ±2.75V). However, the supply voltage may range from +2.5V to +5.5V (±1.25V to ±2.75V). Supply voltages higher than 7.5V (absolute maximum) can permanently damage the amplifier. Parameters that vary over supply voltage or temperature are shown in the typical characteristics section of this datasheet. Applications Information Rail-to-Rail Inputs and Outputs The TPH2501,TPH2502,TPH2504 op amps are designed to be immune to phase reversal when the input pins exceed the supply voltages, therefore providing further in-system stability and predictability. Figure 1 shows the input voltage exceeding the supply voltage without any phase reversal. Figure 1. No Phase Reversal Choice of Feedback Resistor and Gain Bandwidth Product For applications that require a gain of +1, no feedback resistor is required. Just short the output pin to the inverting input pin. For gains greater than +1, the feedback resistor forms a pole with the parasitic capacitance at the inverting 8  Rev. A www.3peakic.com          TPH2501/TPH2502/TPH2503/TPH2504     250MHz, Precision, Rail‐to‐Rail I/O, CMOS input. As this pole becomes smaller, the amplifier’s phase margin is reduced. This causes ringing in the time domain and peaking in the frequency domain. Therefore, RF has some maximum value that should not be exceeded for optimum performance. If a large value of RF must be used, a small capacitor in the few Pico farad range in parallel with RF can help to reduce the ringing and peaking at the expense of reducing the bandwidth. As far as the output stage of the amplifier is concerned, the output stage is also a gain stage with the load. RF and RG appear in parallel with RL for gains other than +1. As this combination gets smaller, the bandwidth falls off. Consequently, RF also has a minimum value that should not be exceeded for optimum performance. For gain of +1, RF=0 is optimum. For the gains other than +1, optimum response is obtained with RF between 300Ω to 1kΩ. The TPH2501, TPH2502 and TPH2504 have a gain bandwidth product of 120MHz. For gains ≥5, its bandwidth can be predicted by the following equation: Gain × BW = 120MHz Video Performance For good video performance, an amplifier is required to maintain the same output impedance and the same frequency response as DC levels are changed at the output. This is especially difficult when driving a standard video load of 150Ω, because the change in output current with DC level. Special circuitry has been incorporated in the TPH2501, TPH2502 and TPH2504 to reduce the variation of the output impedance with the current output. This results in dG and dP specifications of 0.03% and 0.3°, while driving 150Ω at a gain of 2. Driving high impedance loads would give a similar or better dG and dP performance. Driving Capacitive Loads and Cables The TPH2501, TPH2502 and TPH2504 can drive 10pF loads in parallel with 1kΩ with less than 5dB of peaking at gain of +1. If less peaking is desired in applications, a small series resistor (usually between 5Ω to 50Ω) can be placed in series with the output to eliminate most peaking. However, this will reduce the gain slightly. If the gain setting is greater than 1, the gain resistor RG can then be chosen to make up for any gain loss which may be created by the additional series resistor at the output. When used as a cable driver, double termination is always recommended for reflection-free performance. For those applications, a back-termination series resistor at the amplifier’s output will isolate the amplifier from the cable and allow extensive capacitive drive. However, other applications may have high capacitive loads without a back-termination resistor. Again, a small series resistor at the output can help to reduce peaking. Output Drive Capability The TPH2501,TPH2502 and TPH2504 output stage can supply a continuous output current of ±100mA and still provide approximately 2.7V of output swing on a 5V supply. For maximum reliability, it is not recommended to run a continuous DC current in excess of ±100mA. Refer to the typical characteristic curve Output Voltage Swing vs Output Current. For supplying continuous output currents greater than ±100mA, the TPH250x may be operated in parallel. The TPH250x will provide peak currents up to 200mA, which corresponds to the typical short-circuit current. Therefore, an on-chip thermal shutdown circuit is provided to protect the TPH250x from dangerously high junction temperatures. At 160°C, the protection circuit will shut down the amplifier. Normal operation will resume when the junction temperature cools to below 140°C. www.3peakic.com Rev. A 9    TPH2501/TPH2502/TPH2503/TPH2504 250MHz, Precision, Rail‐to‐Rail I/O, CMOS Op‐amps Single Supply Video Line Driver The TPH2501, TPH2502 and TPH2504 are wideband rail-to-rail output op amplifiers with large output current, excellent dG, dP, and low distortion that allow them to drive video signals in low supply applications. Figure 2 is the single supply non-inverting video line driver configuration inverting video ling driver configuration. The signal is AC coupled by C1. R1 and R2 are used to level shift the input and output to provide the largest output swing. RF and RG set the AC gain. C2 isolates the virtual ground potential. RT and R3 are the termination resistors for the line. C1, C2 and C3 are selected big enough to minimize the droop of the luminance signal.   Figure 2. 5V Single Supply Non-Inverting and Inverting Video Line Driver Power Supply Bypassing and Printed Circuit Board Layout As with any high frequency device, a good printed circuit board layout is necessary for optimum performance. Lead lengths should be as sort as possible. The power supply pin must be well bypassed to reduce the risk of oscillation. For normal single supply operation, where the VS- pin is connected to the ground plane, a single 4.7μF tantalum capacitor in parallel with a 0.1μF ceramic capacitor from VS+ to GND will suffice. This same capacitor combination should be placed at each supply pin to ground if split supplies are to be used. In this case, the VS- pin becomes the negative supply rail. For good AC performance, parasitic capacitance should be kept to a minimum. Use of wire wound resistors should be avoided because of their additional series inductance. Use of sockets should also be avoided if possible. Sockets add parasitic inductance and capacitance that can result in compromised performance. Minimizing parasitic capacitance at the amplifier’s inverting input pin is very important. The feedback resistor should be placed very close to 10  Rev. A www.3peakic.com          TPH2501/TPH2502/TPH2503/TPH2504     250MHz, Precision, Rail‐to‐Rail I/O, CMOS the inverting input pin. Strip line design techniques are recommended for the signal traces. Video Sync Pulse Remover Many CMOS analog to digital converters have a parasitic latch up problem when subjected to negative input voltage levels. Since the sync tip contains no useful video information and it is a negative going pulse, we can chop it off. Figure 29 shows a gain of 2 connections. Figure 3 shows the complete input video signal applied at the input, as well as the output signal with the negative going sync pulse removed.             Figure 3. Sync Pulse Remover and Waveform Input ESD Diode Protection The TPH250x incorporates internal electrostatic discharge (ESD) protection circuits on all pins. In the case of input and output pins, this protection primarily consists of current-steering diodes connected between the input and power-supply pins. These ESD protection diodes also provide in-circuit input overdrive protection, as long as the current is limited to 20 mA as stated in the Absolute Maximum Ratings table. Many input signals are inherently current-limited to less than 20 mA; therefore, a limiting resistor is not required. Figure 4 shows how a series input resistor (RS) may be added to the driven input to limit the input current. The added resistor contributes thermal noise at the amplifier input and the value should be kept to the minimum in noise-sensitive applications. Current-limiting resistor required if input voltage exceeds supply rails by >0.5V. +2.5V Ioverload 20mA max TPH2501 VIN Vout 5kΩ -2.5V   Figure 4. Input ESD Diode www.3peakic.com Rev. A 11    TPH2501/TPH2502/TPH2503/TPH2504 250MHz, Precision, Rail‐to‐Rail I/O, CMOS Op‐amps Package Outline Dimensions SC70-5 /SOT-353 Dimensions Dimensions In Millimeters In Inches Min Max Min Max A 0.900 1.100 0.035 0.043 A1 0.000 0.100 0.000 0.004 A2 0.900 1.000 0.035 0.039 b 0.150 0.350 0.006 0.014 C 0.080 0.150 0.003 0.006 D 2.000 2.200 0.079 0.087 E 1.150 1.350 0.045 0.053 E1 2.150 2.450 0.085 0.096 e 0.650TYP 0.026TYP e1 1.200 0.047 L 0.525REF 0.021REF L1 0.260 0.460 0.010 0.018 θ 0° 8° 0° 8° Symbol   1.400 0.055   SOT23-5 Dimensions Dimensions In Millimeters In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.400 0.012 0.016 C 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950TYP 0.037TYP e1 1.800 0.071 L 0.700REF 0.028REF L1 0.300 0.460 0.012 0.024 θ 0° 8° 0° 8° Symbol 12  Rev. A 2.000 0.079 www.3peakic.com          TPH2501/TPH2502/TPH2503/TPH2504     Package Outline Dimensions 250MHz, Precision, Rail‐to‐Rail I/O, CMOS SOT23-6       Symbol Dimensions Dimensions In Millimeters In Inches Min Max Min Max A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.400 0.012 0.016 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e www.3peakic.com 0.950TYP 0.037TYP e1 1.800 2.000 0.071 0.079 L1 0.300 0.460 0.012 0.024 θ 0° 8° 0° 8° Rev. A 13    TPH2501/TPH2502/TPH2503/TPH2504 250MHz, Precision, Rail‐to‐Rail I/O, CMOS Op‐amps Package Outline Dimensions SOT-23-8 Symbol 14  Rev. A Dimensions Dimensions In In Millimeters Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 e 0.65(BSC) 0.026(BSC) e1 0.975(BSC) 0.038(BSC) L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° www.3peakic.com          TPH2501/TPH2502/TPH2503/TPH2504     250MHz, Precision, Rail‐to‐Rail I/O, CMOS Package Outline Dimensions SOP-8   A2 C θ L1 A1 e E D Symbol E1 b www.3peakic.com Dimensions Dimensions In In Millimeters Inches Min Max Min Max A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 C 0.190 0.250 0.007 0.010 D 4.780 5.000 0.188 0.197 E 3.800 4.000 0.150 0.157 E1 5.800 6.300 0.228 0.248 e 1.270 TYP 0.050 TYP L1 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° Rev. A 15    TPH2501/TPH2502/TPH2503/TPH2504 250MHz, Precision, Rail‐to‐Rail I/O, CMOS Op‐amps Package Outline Dimensions MSOP-8     Dimensions Dimensions In In Millimeters Inches Min Max Min Max A 0.800 1.200 0.031 0.047 A1 0.000 0.200 0.000 0.008 A2 0.760 0.970 0.030 0.038 b 0.30 TYP 0.012 TYP C 0.15 TYP 0.006 TYP D 2.900 e 0.65 TYP E 2.900 3.100 0.114 0.122 E1 4.700 5.100 0.185 0.201 L1 0.410 0.650 0.016 0.026 θ 0° 6° 0° 6° Symbol     E E1       e   b D     3.100 0.114 0.122 0.026 A1 R1 R θ L1 16  Rev. A L L2 www.3peakic.com          TPH2501/TPH2502/TPH2503/TPH2504     Package Outline Dimensions 250MHz, Precision, Rail‐to‐Rail I/O, CMOS TSSOP-14       Dimensions   E1 E Symbol MIN TYP MAX A - - 1.20 A1 0.05 - 0.15 A2 0.90 1.00 1.05 b 0.20 - 0.28 c 0.10 - 0.19 D 4.86 4.96 5.06 E 6.20 6.40 6.60 E1 4.30 4.40 4.50       e   A A2   c D   In Millimeters e   L A1     R1 R 0.65 BSC 0.45 0.60 0.75 L1 1.00 REF L2 0.25 BSC R 0.09 - - θ 0° - 8° θ L1 www.3peakic.com L L2 Rev. A 17    TPH2501/TPH2502/TPH2503/TPH2504 250MHz, Precision, Rail‐to‐Rail I/O, CMOS Op‐amps Package Outline Dimensions SOP-14         Dimensions   In Millimeters Symbol MIN TYP MAX A 1.35 1.60 1.75 A1 0.10 0.15 0.25 A2 1.25 1.45 1.65 b 0.36 D 8.53 8.63 8.73 E 5.80 6.00 6.20 E1 3.80 3.90 4.00         e L 0.49 1.27 BSC 0.45 0.60 L1 1.04 REF L2 0.25 BSC θ 0° 0.80 8°       18  Rev. A www.3peakic.com
TPH2501-TR 价格&库存
很抱歉,暂时无法提供与“TPH2501-TR”相匹配的价格&库存,您可以联系我们找货
