MD88XX
上海明达微电子有限公司
PFM Step-up DC/DC Converter
■ DESCRIPTION:
MD88XX series are high efficiency, low ripple PFM step-up DC-DC Converter. The converter can
start up by supply voltage as low as 0.75V, and capable of delivering maximum 300mA output current at
5V output with 3V input voltage. Quiescent current drawn from power source is as low as 4uA. All of
these features make MD88XX series be suitable for portable devices, which are supplied by a single
battery to four-cell batteries.
MD88XX integrates output voltage feedback and compensation networks, startup circuits,
oscillation circuits, PFM control circuits, stable reference circuits, overcurrent protection circuits and
trimming technology, so it can afford high precision and low temperature-drift coefficient of the output
voltage.
MD88XX is available in SOT-89-3, SOT-23-3, SOT-89-5 and SOT-23-5 packages, which is PB free.
And in 5-pin packages, such as SOT-23-5, the device can be switch on or off easily by CE pin, to
minimize the standby supply current.
■ FEATURES:
■ APPLICATIONS:
Low Start-up voltage (when Iout is 1mA): 0.75V
Deliver 300mA at 5.0V Output voltage with 3.0V
input Voltage
Low quiescent current: 4uA(TYP)
Low Shutdown current: 0.1uA
High power conversion efficiency: 85%(TYP)
Output voltage accuracy: ±2.5%
Power Source for PDA, DSC, MP3 Player,
Electronic toy and wireless mouse
Power Source for a Single or Dual-cell
Battery-Powered Equipments
Power Source for LED
■ BLOCK DIAGRAM:
www.md-ic.com.cn
-1-
MD88XX
上海明达微电子有限公司
■ ORDERING INFORMATION ( MD88XX )
Code
Output Voltage
Package Type
MD8818*
1.8V
MD8827*
2.7V
SOT-89-3
MD8830
3.0V
SOT-89-5
MD8833
3.3V
SOT-23-3
MD8836
3.6V
SOT-23-5
MD8850*
5.0V
Marking
MD88XX
Note: “XX” represents output voltage.
“*” indicates out of stock, and reservation must be made in advance.
■PIN CONFIGURATION:
PIN DEFINATION
PIN Code
Symbol
Description
4
Vss(GND)
Ground
2
Vout
SOT-89-3
SOT-89-5
SOT-23-3
SOT-23-5
1
4
1
2
2
2
Output Feedback Pin, Power supply for
internal
3
5
3
5
Lx
Switching Pin
3
3
NC
No Connection
1
1
CE
Chip Enable
www.md-ic.com.cn
-2-
MD88XX
上海明达微电子有限公司
■ ABSOLUTE MAXIMUM RATING:
Parameter
Symbol
Value
Unit
Output Voltage Range
VOUT
VSS-0.3~VSS+12
V
CE Pin Voltage
VCE
VSS-0.3~VOUT+0.3
V
LX Voltage
VLX
VSS-0.3~VSS+12
V
LX Pin Output Current
ILX
1000
mA
0.5
W
0.5
W
0.25
W
0.25
W
SOT-89-3
Power
Dissipation
SOT-89-5
PD
SOT-23-3
SOT-23-5
Ambient Temperature
Ta
-40~85
Storage Temperature
Ts
-40~125
Lead Temperature & Time
Ts
260
℃,10S
℃,S
■ ELECTRICAL CHARACTERISTICS:
VIN=VOUT*0.6;IOUT =10mA;Ta=25℃ (Except special instruction)
Value
Parameter
Symbol
Test Condition
Unit
MIN
TYP
MAX
Output Voltage Accuracy
△Vout
-2.5
+2.5
Input Voltage
Vin
10
V
Start-up Voltage
Vstart (Fig.1)
0.75
0.9
V
Hold-on Voltage
Vhold (Fig.1)
0.7
V
Input Current
Iin (Fig.1)
Iout=0mA
15
uA
Quiescent Current
IDD (Fig.2)
VS = VOUT+0.5V
4
7
uA
Shutdown Current
ISHDN
CE=GND
0.5
uA
Iout=1mA,
Vin :0→2V
Iout=1mA,
www.md-ic.com.cn
Vin :2→0V
-3-
MD88XX
上海明达微电子有限公司
CE “H” threshold voltage
VCEH
0.9
V
VCEL
0.6
V
Switch ON Resistance
RSWON
0.4
0.5
Ω
Switch Leakage Current
ILEAK(Fig.3)
VS = VOUT+0.5V,VX=6V
0.5
uA
Oscillator Frequency
FOSC(Fig.3)
VS = VOUT*0.95
300
350
400
kHz
Oscillator Duty Cycle
DOSC(Fig.3)
VS = VOUT*0.95
65
75
85
Efficiency
η
85
Note: “F1g.1”, “Fig.2” and “Fig.3” in the table above indicate the label of the test circuit below.
■ TEST CIRCUITS:
■ APPLICATION CIRCUITS:
SOT-89-3 and SOT-23-3 footprint
www.md-ic.com.cn
-4-
MD88XX
上海明达微电子有限公司
SOT-89-5 and SOT-23-5 footprint
■ SELECTION THE EXTERNAL COMPONENTS:
The four main energy loss of Boost structure DC-DC converter in full load are the ESR of inductor, the
voltage of Schottky diode, on resistor of internal N-channel MOSFET and its driver. Though at very low load
condition, the quiescent current of chip do affect efficiency certainly. In order to improve the efficiency, MD88XX
integrates low on-resistor N-channel MOSFET and well design driver circuits. The switch energy loss is limited at
very low level.
Thus it can be seen, the inductor and schottky diode affect the conversion efficiency greatly. The inductor and
the capacitor also have great influence on the output voltage ripple of the converter. So it is necessary to choose a
suitable inductor, a capacitor and a right schottky diode to obtain high efficiency, low ripple and low noise.
1、INDUCTOR SELECTION
The following aspects need to be considered when selecting inductor:
Firstly, we should define the minimum value of the inductor that can ensure the boost DC-DC to operate in
the continuous current-mode condition.
L min ≥
D(1 − D) 2 RL
2f
The above expression is got under conditions of continuous current mode, neglect Schottky diode’s voltage,
ESR of both inductor and capacitor. The actual value is greater that it. If inductor’s value is less than Lmin,the
efficiency of DC-DC converter will drop greatly, and the DC-DC circuit will not be stable.
Secondly, consider the ripple of the output voltage,
DI =
D • Vin
Lf
www.md-ic.com.cn
Im ax =
Vin
DVin
2
(1 − D) RL 2 Lf
-5-
MD88XX
上海明达微电子有限公司
If inductor value is too small, the current ripple through it will be great. Then the current through diode and
power switch will be great. Because the power switch on chip is not ideal switch, the energy of switch will
improve. The efficiency will fall.
Thirdly, in general, smaller inductor values supply more output current while larger values start up with
lower input voltage and acquire high efficiency.
The working frequency of MD88XX is up to 350kHz, the purpose of which is to decrease the size of external
inductor. An inductor value of 3uH to 1mH works well in most applications. If DC-DC converter delivers large
output current (for example: output current is great than 50mA), large inductor value is recommended in order to
improve efficiency.
The ESR of inductor will affect efficiency greatly. Suppose ESR value of inductor is rL,Rload is load
resistor,then the energy can be calculated by following expression:
Dη ≈
rL
Rload (1 − D) 2
Consider all above,inductor value of 27uH, ESR
很抱歉,暂时无法提供与“MD8850”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.67672
- 50+0.55576
- 150+0.49528
