TP75176E-SR
TP75176E-SR
    3PEAK(思瑞浦)
    SOP8_150MIL
    3PEAK 3~5.5V 2.2mA 10Mbps SMT SOP8_150MIL
TP75176E-SR 数据手册
3PEAK TP75176E ±15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers Features  Description High Data Rates: 10Mbps At 5V Supply : 6Mbps At 3.3V Supply  13/14ns (Max) Tx/Rx Propagation Delays; 10ns (Typ) Skew  Full Fail-safe (Open, Short, Terminated) Receivers  Up to 32 Nodes on a Bus (1 unit load)  Wide Supply Voltage 3V to 5.5V  Low Quiescent Supply Current: 2.2 mA  -8V to +13V Common Mode Input Voltage Range  Bus-Pin Protection: – ±15 kV HBM protection – ±9 kV IEC61000-4-2 Contact Discharge – +4 kV IEC61000-4-4 Fast Transient Burst  Pb-Free Plus Anneal Available (RoHS Compliant) 3PEAK’s TP75176E is a ±15kV HBM ESD Protected, 3V~5.5V powered, single transceiver that meets both the RS-485 and RS-422 standards for balanced communication. It also features the larger output voltage and higher data rate - up to 10Mbps - required by high speed PROFIBUS applications, and is offered in Industrial and Extended Industrial (-40°C to +125°C) temperature ranges. This transceiver requires a 3V~5.5V tolerance supply, and delivers at least a 2.1V differential output voltage on 5V supply condition. This translates into better noise immunity(data integrity), longer reach, or the ability to drive up to three 120Ω terminations in “star” or other non-standard bus topologies, at the exceptional 10Mbps data rate. Receiver (Rx) inputs feature a “Full Fail-Safe” design, which ensures a logic high Rx output if Rx inputs are floating, shorted, or terminated but undriven. Rx outputs feature high drive levels (typically >25mA @ VOL = 1V) to ease the design of optically isolated interfaces. The TP75176E is available in an SOP-8 and MSOP-8 package, and is characterized from –40°C to 125°C. Applications 3PEAK and the 3PEAK logo are registered trademarks of 3PEAK INCORPORATED. All other trademarks are the property of their respective owners. ®  PROFIBUS DP and FMS Networks  SCSI “Fast 40” Drivers and Receivers  Motor Controller/Position Encoder Systems  Factory Automation  Field Bus Networks  Industrial/Process Control Networks Pin Configuration (Top View) 2V/div Loopback Test At 10Mbps/5V TP75176E 8-Pin SOP/MSOP -S and -V Suffixes 1 8 VCC RE 2 7 B/Z DE 3 6 A/Y 5 GND 4 www.3peakic.com.cn 2V/div RO R D DI Time (50ns/div) Rev. B02 1 TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers Order Information Model Name Order Number Package Transport Media, Quantity Marking Information TP75176E TP75176E-SR 8-Pin SOP Tape and Reel, 4,000 75176E TP75176E TP75176E-VR 8-Pin MSOP Tape and Reel, 3,000 75176E TP75176E TP75176E-FR 8-Pin DFN Tape and Reel, 4,000 75176 DRIVER PIN FUNCTIONS INPUT ENABLE D DE OUTPUTS A DESCRIPTION B NORMAL MODE H H H L Actively drives bus High L H L H Actively drives bus Low X L Z Z Driver disabled X OPEN Z Z Driver disabled by default OPEN H H L Actively drives bus High RECEIVER PIN FUNCTIONS DIFFERENTIAL INPUT ENABLE OUTPUT VID = VA – VB /RE R DESCRIPTION NORMAL MODE 2 VIT+ < VID L H Receive valid bus High VIT– < VID < VIT+ L ? Indeterminate bus state VID < VIT– L L Receive valid bus Low X H Z Receiver disabled X OPEN Z Receiver disabled Open, short, idle Bus L H Indeterminate bus state Rev. B.02 www.3peakic.com.cn TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers Absolute Maximum Ratings VDD to GND.......................................................................................................................................-0.3V to +7V Input Voltages DI, DE, RE………………………………………………………………………….…………………….....-0.3V to (VCC + 0.3V) Input/Output Voltages A/Y, B/Z, A, B, Y, Z………………………………………………………………………..………………. -15V to +15V A/Y, B/Z, A, B, Y, Z (Transient Pulse Through 100Ω, Note 1)………………………………………………………………………………………….……….…… ±100V RO……………………………………………………………………………………………………………. -0.3V to (VCC +0.3V) Short Circuit Duration Y, Z…………………………………………………………………………………………………………….Continuous ESD Rating………………………………………………………………………………………………….. See Specification Table Recommended Operating Conditions Note 2 Supply Voltage………………………………………………………………………………….…………….3V~5.5V Temperature Range…………………………………………………………………………………….……-40°C to +125°C Bus Pin Common Mode Voltage Range …………………………………………………………….…… -8V to +13V Thermal Resistance, ΘJA (Typical) 8-Pin SOP Package ……………………………………………………………….…………………..……158°C/W 8-Pin MSOP Package …………………………………………………………….……………….…..……210°C/W Maximum Junction Temperature (Plastic Package) ………………………………………….………….+150°C Maximum Storage Temperature Range …………………………………………………………………. -65°C to +150°C Note 1: Tested according to TIA/EIA-485-A, Section 4.2.6 (±100V for 15μs at a 1% duty cycle). Note 2: Do not operate at or near the maximum ratings listed for extended periods of time. Exposure to such conditions may adversely impact product reliability and result in failures not covered by warranty. www.3peakic.com.cn Rev. B.02 3 TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers Electrical Characteristics Test Conditions: VCC = 5V, Over operating free-air temperature range(unless otherwise noted) PARAMETER CONDITIONS RL = 54 Ω VCC = 5V |VOD| Driver differential-output voltage magnitude RL = 54 Ω with VA or VB from –7 to +12 V, VCC = 5V (RS-485) RL = 54 Ω with VA or VB from –7 to +12 V, VCC = 3V (RS-485) VIH Logic Input High Voltage DI, DE, RE VIL Logic Input Low Voltage DI, DE, RE ⊿|VOD| Change in magnitude of driver differential-output voltage RL = 54 Ω, CL=50 pF, VOC(SS) ⊿VOC Steady-stage common-mode output voltage Change in differential driver common-mode output voltage See Figure 1A VCC = 5V Center of two 27 Ω load resistors MIN TYP 2.3 2.5 2.2 2.4 1.2 1.5 1 V 0.5 See Figure 1A See Figure 1A -0.02 -0.002 0.02 Vcc/20.2 VCC/2 Vcc/2 +0.2 -0.2 0 0.2 VOC(PP) 500 COD Differential output capacitance 8 VIT+ Positive-going receiver differential-input voltage threshold VIT- Negative-going receiver differential-input voltage threshold VHYS(1) Receiver differential-input voltage threshold hysteresis (VIT+ – VIT– ) VOH Receiver high-level output voltage IOH= -8 mA VOL Receiver low-level output voltage IOL= 8 mA II Driver input, driver enable and receiver enable input current DI, DE, RE IOZ Receiver high-impedance output current VO = 0 V or VCC, /RE at VCC |IOS| Driver short-circuit output current │IOS│ with VA or VB from –7 to +12 V ICC 4 Bus input current(driver disabled) Supply current(quiescent) Rev. B.02 -200 4.500 -0.02 -10 V V mV mV -130 mV 75 mV 4.650 V 0.235 0.350 V 0.01 0.020 μA 0.005 0.02 μA 120 300 mA VI= 12 V VI= -7 V V pF -50 VCC = 4.5 to 5.5 V or VCC = 0 V, DE at 0 V UNITS V Peak-to-peak driver common-mode output voltage II MAX 1 -0.8 Driver and receiver enabled DE = VCC, /RE = GND, No LOAD 2.2 2.5 Driver enabled, receiver disabled DE = VCC, /RE = VCC, No LOAD 1.5 1.8 Driver disabled, receiver enabled DE = GND, /RE = GND, No LOAD 0.5 0.6 Driver and receiver disabled DE = GND, /RE = VCC, D= Vcc No LOAD 0.0012 0.002 mA mA www.3peakic.com.cn TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers Switching CHARACTERISTICS PARAMETER CONDITIONS MIN VOD ≥ ±1.5V, RL = 54Ω, CL = 100pF (Figure 4) 10 TYP MAX UNITS DRIVER fMAX Maximum Data Rate tr, tf Driver differential-output rise and fall times tPHL, tPLH Driver propagation delay tSK(P) tPHZ, tPLZ tPHZ, tPLZ 26 RL = 54 Ω, CL=50pF See Figure 2 Driver pulse skew, |tPHL – tPLH| ns 14 10 Driver disable time Driver enable time Mbps 50 Receiver enabled See Figure 3 Receiver disabled ns 10 ns 125 RECEIVER tr, tf Receiver output rise and fall times tPHL, tPLH Receiver propagation delay time tSK(P) Receiver pulse skew, |tPHL – tPLH| 10 tPHZ, tPLZ Receiver disable time 28 tPZL(1), tPZH(1) tPZL(2), tPZH(2) 3.4 CL=15 pF See Figure 5 55 Driver enabled See Figure 6 11 Driver disabled See Figure 6 15 ns ns Receiver enable time ns ESD IEC61000-4-2,Air-Gap Discharge RS-485 Method Pins (A, Y, IEC61000-4-2, Contact Discharge B, Z, A/Y, Method B/Z) Human Body Model, From Bus Pins to GND All Other Pins www.3peakic.com.cn Human Body Model, per MIL-STD-883 ±15 kV ±9 kV ±15 kV ±2 kV Rev. B.02 5 TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers Test Circuits and Waveforms Vcc RL/2 DE Vcc Z DI D Z DI VOD Y 375Ω DE D VOD RL=60Ω Y RL/2 VOC 375Ω FIGURE 1A. VOD AND VOC FIGURE 1B. VOD WITH COMMON MODE LOAD FIGURE 1. DC DRIVER TEST CIRCUITS CL=100pF DE Vcc DI Z D Y 3V DI 1.5V 0V tPLH RDIFF CL=100pF tPHL OUT(Z) VOH OUT(Y) VOL DIFF OUT(Y-Z) SIGNAL GENERATOR 1.5V 90% +VOD 90% 10% tR 10% tF -VOD SKEW=|tPLH-tPHL| FIGURE 2A. TEST CIRCUIT FIGURE 2B. MEASUREMENT POINTS FIGURE 2. DRIVER PROPAGATION DELAY AND DIFFERENTIAL TRANSITION TIMES DE DI SIGNAL GENERATOR Z 500Ω D Y SW CL VCC GND DE PARAMETER OUTPUT RE DI 3V NOTE 10 CL tZH,tZH(SHDN) (pF) NOTE 10 SW OUT(Y,Z) tHZ Y/Z X 1/0 GND 15 tLZ Y/Z X 0/1 VCC 15 tZL,tZL(SHDN) tZH Y/Z 0 (Note 9) 1/0 GND 100 NOTE 10 tZL Y/Z 0 (Note 9) 0/1 VCC 100 tZH(SHDN) Y/Z 1 (Note 12) 1/0 GND 100 tZL(SHDN) Y/Z 1 (Note 12) 0/1 VCC 100 FIGURE 3A. TEST CIRCUIT OUT(Y,Z) 1.5V 1.5V 0V tHZ OUTPUT HIGH 2.3V VOL-0.5V VOH 0V tLZ 2.3V VCC VOL+0.5V VOL OUTPUT LOW FIGURE 3B. MEASUREMENT POINTS FIGURE 3. DRIVER ENABLE AND DISABLE TIMES 6 Rev. B.02 www.3peakic.com.cn TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers Test Circuits and Waveforms(continue) DE Vcc DI + Z 54Ω D Y CD VOD - 3V DI 0V SIGNAL GENERATOR DIFF OUT(Y-Z) FIGURE 4A. TEST CIRCUIT +VOD -VOD 0V FIGURE 4B. MEASUREMENT POINTS FIGURE 4. DRIVER DATA RATE RE B R A 0V RO 15pF +1.5V A 0V 0V -1.5V tPLH SIGNAL GENERATOR VCC RO FIGURE 5A. TEST CIRCUIT tPHL 1.5V 1.5V 0V FIGURE 5B. MEASUREMENT POINTS FIGURE 5. RECEIVER PROPAGATION DELAY AND DATA RATE SIGNAL GENERATOR RE B GND A R 1kΩ RO VCC SW GND 15pF NOTE 10 RE PARAMETER tHZ DE 0 A +1.5V SW tZH,tZH(SHDN) GND NOTE 10 RO tLZ 0 -1.5V VCC tZH(Note 10) 0 +1.5V GND tZL,tZL(SHDN) tZL(Note 10) 0 -1.5V VCC NOTE 10 tZH(SHDN)(Note 13) 0 +1.5V GND RO tZL(SHDN)(Note 13) 0 -1.5V VCC FIGURE 6A. TEST CIRCUIT 3V 1.5V 1.5V 0V tHZ OUTPUT HIGH 1.5V VOH-0.5V VOH 0V tLZ 1.5V VCC VOL+0.5V VOL OUTPUT LOW FIGURE 6B. MEASUREMENT POINTS FIGURE 6. RECEIVER ENABLE AND DISABLE TIMES www.3peakic.com.cn Rev. B.02 7 TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers Detailed Description Application RS-485 and RS-422 are differential (balanced) data transmission standards used for long haul or noisy environments. RS-422 is a subset of RS-485, so RS-485 transceivers are also RS-422 compliant. RS-422 is a point-to-multipoint (multidrop) standard, which allows only one driver and up to 10 (assuming one unit load devices) receivers on each bus. RS-485 is a true multipoint standard, which allows up to 32 one unit load devices (any combination of drivers and receivers) on each bus. To allow for multipoint operation, the RS-485 specification requires that drivers must handle bus contention without sustaining any damage. Another important advantage of RS-485 is the extended common mode range (CMR), which specifies that the driver outputs and receiver inputs withstand signals that range from +12V to -7V. RS-422 and RS-485 are intended for runs as long as 4000’, so the wide CMR is necessary to handle ground potential differences, as well as voltages induced in the cable by external fields. Receiver (Rx) Features TP75176E utilize a differential input receiver for maximum noise immunity and common mode rejection. Input sensitivity is better than ±200mV, as required by the RS-422 and RS-485 specifications. Rx outputs feature high drive levels (typically 25mA @ VOL = 1V) to ease the design of optically coupled isolated interfaces. Rx inputs function with common mode voltages as great as ±7V outside the power supplies (i.e., +12V and -7V), making them ideal for long networks where induced voltages are a realistic concern. All the receivers include a “full fail-safe” function that guarantees a high level receiver output if the receiver inputs are unconnected (floating), shorted together, or connected to a terminated bus with all the transmitters disabled. Receivers easily meet the data rates supported by the corresponding driver, and all receiver outputs are three-stable via the active low RE input. Driver (Tx) Features TP75176E driver is a differential output device that delivers at least 2.5V across a 54Ω load (RS-485), and at least 2.8V across a 100Ω load (RS-422). The drivers feature low propagation delay skew to maximize bit width, and to minimize EMI, and all drivers are three-stable via the active high DE input. High Data Rate RS-485/RS-422 are intended for network lengths up to 4000’, but the maximum system data rate decreases as the transmission length increases. Devices operating at 10Mbps are limited to lengths less than 100’. Twisted pair is the cable of choice for RS-485/RS-422 networks. Twisted pair cables tend to pick up noise and other electromagnetically induced voltages as common mode signals, which are effectively rejected by the differential receiver in this IC. Proper termination is imperative to minimize reflections. In point-to-point, or point-to-multipoint (single driver on bus) networks, the main cable should be terminated in its characteristic impedance (typically 120Ω) at the end farthest from the driver. In multi-receiver applications, stubs connecting receivers to the main cable should be kept as short as possible. Multipoint (multi-driver) systems require that the main cable be terminated in its characteristic impedance at both ends. Stubs connecting a transceiver to the main cable should be kept as short as possible. The TP75176E may also be used at slower data rates over longer cables, but there are some limitations. The Rx is optimized for high speed operation, so its output may glitch if the Rx input differential transition times are too slow. Keeping the transition times below 500ns, which equates to the Tx driving a 1000’ (305m) CAT 5 cable, yields excellent performance over the full operating temperature range. For below test waveform, the transmitter was driven at 10Mps and/or with 100’ (31m) CAT 5 cable, the transmitters were loaded with an RS-485 receiver in parallel with 54Ω. 8 Rev. B.02 www.3peakic.com.cn TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers 5V 5V RO 1 RE 2 7 DE 3 6 DI 4 R 8 VCC 100 nF B/Z 54Ω D 5 A/Y GND 2V/div 2V/div Figure 7. Loopback Test Circuit DI DI 2V/div 2V/div RO RO Time (100ns/div) Time (50ns/div) Figure 8. Loopback Test At 10Mbps/5V Figure 9. Loopback Test At 6Mbps/3V Vcc RO VCC 1 R 8 VCC B/Z RE 2 7 DE 3 6 DI 4 100 nF 120 Ω 5 D GND 5 A/Y D 4 DI 6 3 DE 7 2 120 Ω A/Y Vcc B/Z GND VCC 100 nF 30M CAT-5 CABLE R 8 1 RE RO 5V/div DI = 10Mbps 5V/div Figure 10. 10Mbps Data Rate With 30M CAT5 Cable Test Circuit DI = 10 Mbps 5V/div 5V/div RO RO Time (100ns/div) Figure 11. 5V Driver And Receiver Five Pulse Waveforms Driving 100 Feet (30 Meters) www.3peakic.com.cn Time (100ns/div) Figure 12. 5V Driver And Receiver Single Pulse Waveforms Driving 100 Feet (30 Meters) Rev. B.02 9 TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers 2V/div DI = 6 Mbps 2V/div 2V/div 2V/div DI = 6 Mbps RO RO Time (200ns/div) Time (200ns/div) Figure 13. 3.3V Driver And Receiver Five Pulse Figure 14. 5V/div DI = 5 Mbps Waveforms Driving 100 Feet (30 Meters) DI = 5 Mbps 5V/div 5V/div 5V/div Pulse Waveforms Driving 100 Feet (30 Meters) RO 3.3V Driver And Receiver Single RO Time (200ns/div) Time (200ns/div) Figure 15. 5V Driver And Receiver Five Pulse Figure 16. 2V/div 2V/div 2V/div DI = 3 Mbps Waveforms Driving 100 Feet (30 Meters) 2V/div Pulse Waveforms Driving 100 Feet (30 Meters) RO 5V Driver And Receiver Single DI = 3 Mbps RO Time (200ns/div) Figure 17. 3.3V Driver And Receiver Four Pulse Pulse Waveforms Driving 100 Feet (30 Meters) 10 Rev. B.02 Time (200ns/div) Figure 18. 5V Driver And Receiver Single Waveforms Driving 100 Feet (30 Meters) www.3peakic.com.cn TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers Full Fail-Safe All the receivers include a “full fail-safe” function that guarantees a high level receiver output if the receiver inputs are unconnected (floating), shorted together, or connected to a terminated bus with all the transmitters disabled. Receivers easily meet the data rates supported by the corresponding driver, and all receiver outputs are three-stable via the active low RE input. Hot Plug Function When a piece of equipment powers up, there is a period of time where the processor or ASIC driving the RS-485 control lines (DE, RE) is unable to ensure that the RS-485 Tx and Rx outputs are kept disabled. If the equipment is connected to the bus, a driver activating prematurely during power-up may crash the bus. To avoid this scenario, the TP75176E devices incorporate a “Hot Plug” function. Circuitry monitoring VCC ensures that, during power-up and power-down, the Tx and Rx outputs remain disabled, regardless of the state of DE and RE, if VCC is less than ~2.5V. This gives the processor/ASIC a chance to stabilize and drive the RS-485 control lines to the proper states. COMPETITOR FIGURE 19. Hot Plug Performance (TP75176E) vs Competitor Without Hot Plug Circuitry ESD Protection All pins on these devices include 2kV Human Body Model (HBM) ESD protection structures, but the RS-485 pins (driver outputs and receiver inputs) incorporate advanced structures allowing them to survive ESD events in excess of ±15kV HBM and ±9kV (1/2 duplex) IEC61000-4-2. The RS-485 pins are particularly vulnerable to ESD strikes because they typically connect to an exposed port on the exterior of the finished product. Simply touching the port pins, or connecting a cable, can cause an ESD event that might destroy unprotected ICs. These new ESD structures protect the device whether or not it is powered up, and without degrading the RS-485 common mode range of -8V to +13V. This built-in ESD protection eliminates the need for board level protection structures (e.g., transient suppression diodes), and the associated, undesirable capacitive load they present. Transient Protection The bus terminals of the TP75176E transceiver family possess on-chip ESD protection against ±15 kV HBM and ±9 kV IEC61000-4-2 contact discharge. The International Electrotechnical Commision (IEC) ESD test is far more severe than the HBM ESD test. The 50% higher charge capacitance, CS, and 78% lower discharge resistance, RD of the IEC model produce significantly higher discharge currents than the HBM model. As stated in the IEC 61000-4-2 standard, contact discharge is the preferred transient protection test method. Although IEC air-gap testing is less repeatable than contact testing, air discharge protection levels are inferred from the contact discharge test results. www.3peakic.com.cn Rev. B.02 11 TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers Figure 20. HBM and IEC-ESD Models and Currents in Comparison (HBM Values in Parenthesis) The on-chip implementation of IEC ESD protection significantly increases the robustness of equipment. Common discharge events occur because of human contact with connectors and cables. Designers may choose to implement protection against longer duration transients, typically referred to as surge transients. Figure 9 suggests two circuit designs providing protection against short and long duration surge transients, in addition to ESD and Electrical Fast Transients (EFT) transients. Table 1 lists the bill of materials for the external protection devices. EFTs are generally caused by relay-contact bounce or the interruption of inductive loads. Surge transients often result from lightning strikes (direct strike or an indirect strike which induce voltages and currents), or the switching of power systems, including load changes and short circuits switching. These transients are often encountered in industrial environments, such as factory automation and power-grid systems. Figure 10 compares the pulse-power of the EFT and surge transients with the power caused by an IEC ESD transient. In the diagram on the left of Figure 10, the tiny blue blip in the bottom left corner represents the power of a 10-kV ESD transient, which already dwarfs against the significantly higher EFT power spike, and certainly dwarfs against the 500-V surge transient. This type of transient power is well representative of factory environments in industrial and process automation. The diagram on the fright of Figure 10 compares the enormous power of a 6-kV surge transient, most likely occurring in e-metering applications of power generating and power grid systems, with the aforementioned 500-V surge transient. Figure 21. Power Comparison of ESD, EFT, and Surge Transients In the case of surge transients, high-energy content is signified by long pulse duration and slow decaying pulse Power The electrical energy of a transient that is dumped into the internal protection cells of the transceiver is converted into thermal energy. This thermal 12 Rev. B.02 www.3peakic.com.cn TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers energy heats the protection cells and literally destroys them, thus destroying the transceiver. Figure 11 shows the large differences in transient energies for single ESD, EFT, and surge transients as well as for an EFT pulse train, commonly applied during compliance testing. Figure 22. Comparison of Transient Energies Table 1. Bill of Materials Device Function Order Number Manufacturer 485 5-V, 250-kbps RS-485 Transceiver TP75176E R1, R2 10-Ω, Pulse-Proof Thick-Film Resistor CRCW0603010RJNEAHP Vishay TVS Bidirectional 400-W Transient Suppressor CDSOT23-SM712 Bourns TBU1, TBU2 Bidirectional TBU-CA-065-200-WH Bourns MOV1, MOV2 200mA Transient Blocking Unit 200-V, MetalOxide Varistor MOV-10D201K Bourns 485 B A Figure 23. 485 3PEAK B A Transient Protections Against ESD, EFT, and Surge Transients The left circuit shown in Figure 12 provides surge protection of ≥ 500-V transients, while the right protection circuits can withstand surge transients of 5 kV www.3peakic.com.cn Rev. B.02 13 TP75176E Typical Performance Characteristics 100 Driver Output Current (mA) 90 80 70 +25 ℃ RD=15Ω 60 +85 ℃ 50 RD=54Ω 40 RD=20Ω 30 20 RD=100Ω 10 0 1 1.5 2 2.5 3 3.5 Differential Output Voltage (V) FIGURE 24. DRIVER OUTPUT CURRENT vs VOLTAGE DIFFERENTIAL OUTPUT VOLTAGE Output Current (mA) 4.5 RDIFF=100Ω 4 3.5 RDIFF=54Ω 3 2.5 2 1.5 1 0.5 0 0.5 100 90 80 70 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 D i f f eren t i al O u t p ut Vo l t age ( V) ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers -40 -20 0 20 40 60 80 100 120 140 T e m p e r a t u℃) re ( FIGURE 25. DRIVER DIFFERENTIAL OUTPUT vs TEMPERATURE Y OR Z = LOW Y OR Z = HIGH -7 -6 -5 -4 -3 -2 -1 0 1 2 3 4 5 6 7 8 9 10 11 12 Output Voltage(V) FIGURE 26. DRIVER OUTPUT CURRENT vs SHORT 14 Rev. B.02 www.3peakic.com.cn TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers Package Outline Dimensions SOP-8 (SOIC-8) A2 C θ L1 A1 e E D Symbol E1 b Dimensions In In Millimeters Inches Min Max Min Max A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 C 0.190 0.250 0.007 0.010 D 4.780 5.000 0.188 0.197 E 3.800 4.000 0.150 0.157 E1 5.800 6.300 0.228 0.248 e www.3peakic.com.cn Dimensions 1.270 TYP 0.050 TYP L1 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° Rev. B.02 15 TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers Package Outline Dimensions MSOP-8 Dimensions Dimensions In In Millimeters Inches Min Max Min Max A 0.800 1.200 0.031 0.047 A1 0.000 0.200 0.000 0.008 A2 0.760 0.970 0.030 0.038 b 0.30 TYP 0.012 TYP C 0.15 TYP 0.006 TYP D 2.900 e 0.65 TYP E 2.900 3.100 0.114 0.122 E1 4.700 5.100 0.185 0.201 L1 0.410 0.650 0.016 0.026 θ 0° 6° 0° 6° Symbol E E1 A A2 e b D 3.100 0.114 0.122 0.026 A1 R1 R θ L1 16 Rev. B.02 L L2 www.3peakic.com.cn TP75176E ± 15kV ESD Protected, 10Mbps, Full Fail-safe, RS-485 Transceivers Package Outline Dimensions DFN-8 www.3peakic.com.cn Rev. B.02 17
TP75176E-SR 价格&库存
很抱歉,暂时无法提供与“TP75176E-SR”相匹配的价格&库存,您可以联系我们找货
TP75176E-SR
    • 5+5.34770
    • 50+4.21580
    • 150+3.73070
    • 500+3.13010
    • 2500+2.85290
    库存:3630
    TP75176E-SR
    • 5+0.98999
    • 20+0.89999
    • 100+0.80999
    • 500+0.72000
    • 1000+0.67800
    • 2000+0.64800
    库存:2777
    TP75176E-SR
      • 4000+0.67879
      库存:4000
