PBR951
NPN silicon epitaxial transistor
DESCRIPTION
The PBR951
is an NPN silicon epitaxial transistor designed for low
noise amplifier at VHF, UHF and CATV band.
It has dynamic range and good current characteristic.
MARKING:W2W
FEATURES
• Low Noise and High Gain
NF = 1.1 dB TYP., Ga = 11 dB TYP. @VCE = 10 V, IC = 7 mA, f = 1.0 GHz
• High Power Gain
JS
MAG = 13 dB TYP. @VCE = 10 V, IC = 20 mA, f = 1.0 GHz
ABSOLUTE MAXIMUM RATINGS (TA = 25 C)
MI
VCBO
V
Collector to Emitter Voltage
VCEO
12
V
Emitter to Base Voltage
VEBO
3.0
V
IC
mA
100
PT
200
mW
Junction Temperature
Tj
150
C
Storage Temperature
Tstg
to +150
C
Collector Current
Total Power Dissipation
O
CR
Collector to Base Voltage
65
Se
ELECTRICAL CHARACTERISTICS (TA = 25 C)
ICBO
Emitter Cutoff Current
IEBO
DC Current Gain
hFE*
MIN.
TYP.
50
120
UNIT
1.0
A
VCB = 10 V, IE = 0
1.0
A
VEB = 1.0 V, IC = 0
7
Feed-Back Capacitance
Cre**
0.55
S21e2
11.5
NF
1.1
GHz
1.0
2.0
Pulse Measurement PW 350 s, Duty Cycle 2 %
pF
VCB = 10 V, IE = 0, f = 1.0 MHz
t
uc
fT
300
TEST CONDITIONS
nd
Gain Bandwidth Product
Noise Figure
MAX.
co
Collector Cutoff Current
Insertion Power Gain
SYMBOL
mi
CHARACTERISTIC
dB
dB
or
** The emitter terminal and the case shall be connected to the guard terminal of the three-terminal capacitance bridge.
www.jsmsemi.com
第1/3页
PBR951
TYPICAL CHARACTERISTICS (TA = 25 C)
FEED-BACK CAPACITANCE vs.
COLLECTOR TO BASE VOLTAGE
TOTAL POWER DISSIPATION vs.
AMBIENT TEMPERATURE
Cre-Feed-back Capacitance-pF
200
100
JS
PT-Total Power Dissipation-mW
2
Free Air
50
f = 1.0 MHz
1
0.5
0.3
0.5
MI
CR
INSERTION GAIN vs.
COLLECTOR CURRENT
mi
|S21e|2-Insertion Gain-dB
Se
hFE-DC Current Gain
O
50
10
50
5
VCE = 10 V
f = 1.0 GHz
5
10
50 70
nd
3.0
2.0
1.0
0.5
0.3
|S21e|2
10
0.2
VCE = 10 V
30
Gmax
or
Gmax-Maximum Gain-dB
5.0
t
uc
INSERTION GAIN, MAXIMUM GAIN
vs. FREQUENCY
10
5.0 10
1
IC-Collector Current-mA
GAIN BANDWIDTH PRODUCT vs.
COLLECTOR CURRENT
0.5 1.0
30
10
co
1
fT-Gain Bandwidth Product-MHz
10
DC CURRENT GAIN vs.
COLLECTOR CURRENT
VCE = 10 V
VCB-Collector to Base Voltage-V
100
0.1
2
TA-Ambient Temperature-°C
200
10
0.5
1
VCE = 10 V
IC = 20 mA
0.1
0.2
0.4 0.6 0.81.0
2
f-Frequency-GHz
www.jsmsemi.com
第2/3页
PBR951
NOISE FIGURE vs.
COLLECTOR CURRENT
NF-Noise Figure-dB
6
5
4
3
2
1
5
10
15
12
6
3
MI
JS
1
18
VCE = 10 V
f = 1.0 GHz
NF-Noise Figure-dB
7
NOISE FIGURE, FORWARD INSERTION
GAIN vs. COLLECTOR TO EMITTER VOLTAGE
5
f = 1.0 GHz
IC = 20 mA
4
2
|S21e|
3
2
NF
1
2
4
6
8
10
VCE-Collector to Emitter Voltage-V
O
CR
Se
mi
nd
co
or
t
uc
www.jsmsemi.com
第3/3页
很抱歉,暂时无法提供与“PBR951”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.23845
- 100+0.19179
- 300+0.16846
- 3000+0.15097
- 6000+0.13697
- 9000+0.12997
