Surface Mount Aluminium Electrolytic Capacitors
HV
125℃ High temperature
■ Endurance:125℃, 1000~2000 hours
■Recommended Applications: Automatic Mounting and Reflow Soldering,Industrial, Automobile, Meter
■ Corresponding product to RoHS
■ Specifications
Item
Category Temperature Range
Rated Voltage Range
Rated Capacitance Range
Capacitance Tolerance
Leakage Current (20℃)
Dissipation Factor(MAX)
(tanδ) (120Hz ,20℃)
Characteristics
-40 ~ +125℃
10 ~ 50VDC
47~ 1000μF
± 20 % at 120Hz , 20℃
I≦0.01CV or 3μA ,whichever is greater. (After rated voltage applied for 2 minutes)
I:Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V)
Shown in the table of standard rating
WV
Low Temperature Stability
Impedance Ratio (MAX)
Z(120HZ)
Z(-25℃) / Z(20℃)
Z(-40℃) / Z(20℃)
10
16
25
35
50
2
3
2
3
2
3
2
3
2
3
After applying rated voltage for 1000~2000hrs at 125℃,Stay back to 20 ℃ temperature measurement,the capacitors shall meet the
following requirements.
Capacitance Change
Dissipation Factor
Endurance
Within ±20% of the initial value
Not more than 200% of the specified value
DΦ
6.3x7.7-8x6.2
≧8x10.2
Life
Leakage Current
1000hrs
Not more than the specified value
2000hrs
After placed at 125℃without voltage applied for 1000 hours,Stay back to 20 ℃ temperature measurement,
the capacitor shall meet the same requirement as Endurance.
Shelf Life
■MARKING
■Dimensions [mm]
●General structure
●Vibration resistant structure
(Notes)Φ8~Φ10&6 3X7 7=L±0 3
Dimensions
E04
G02
G03
H03
L
7.7
6.2
10.2
10.2
ФD
6.3
8.0
8.0
10.0
A
6.6
8.3
8.3
10.3
H
7.8 Max
9.5 Max
10.0 Max
12.0 Max
W
0.65±0.1
0.65±0.1
0.90±0.2
0.90±0.2
P
1.8
2.2
3.1
4.6
K
0.35+0.15/-0.2
0.35+0.15/-0.2
0.70±0.20
0.70±0.20
■ Multiplier for Ripple Current
Frequency (Hz)
Coefficient
120
0.70
1K
0.80
10K
0.90
100K
1.00
Product specifications in this catalog are subject to change without notice.Please refer to the website directory.
HV
■STANDARD RATINGS
Rated Voltage
(SurageVoltage)
(V)
Cap
(μF)
Case size
ФDxL(mm)
tanδ
Ripple current
100
8X6.2
6.3x7.7
8x6.2
8x10.2
8x10.2
8x10.2
10x10.2
10x10.2
10x10.2
6.3x7.7
6.3x7.7
8x6.2
8x10.2
8x10.2
8x10.2
10x10.2
6.3x7.7
8x6.2
6.3x7.7
8x6.2
8x10.2
8x10.2
8x10.2
10x10 2
10x10.2
10x10.2
0.26
0.26
0.26
0.26
0.26
0.26
0.26
0.26
0.26
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.18
0.18
0.18
0.18
0.18
0.18
0.18
0 18
0.18
0.18
75
70
75
130
130
130
180
180
180
70
70
75
130
130
180
180
70
75
70
75
130
130
130
180
180
150
10(13)
220
330
470
680
1000
47
100
16(20)
150
220
330
470
47
100
25(32)
150
220
330
(mA/rms 125℃)
(120Hz)
Rated Voltage
(SurageVoltage)
(V)
Cap
(μF)
10
22
33
47
35(44)
100
120
150
220
10
22
50(63)
33
47
82
100
150
220
Case size
ФDxL(mm)
tanδ
Ripple current
8x6.2
8x10.2
6.3x7.7
6.3x7.7
8x6.2
6.3x7.7
8X6.2
8x10.2
8x6.2
8x10.2
10x10.2
8x10.2
10x10.2
8x10.2
10x10.2
8x6.2
8x10.2
6.3x7.7
8x6.2
8x10.2
8x10.2
8x10.2
10x10.2
10x10 2
10x10.2
10x10.2
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0 12
0.12
0.12
40
50
70
70
75
70
75
130
75
130
180
130
180
130
180
70
75
70
75
130
130
130
180
180
180
(mA/rms 125℃)
(120Hz)
很抱歉,暂时无法提供与“VHV107M035S0ANG03S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.32084
- 10+1.09404
- 30+0.99684
