B5817 WS-B5819WS
HD SD0.75
SOD323 Plastic-Encapsulate Diodes
Schottky Rectifier
Features
● VR 20V-40V
● IO 1A
SOD3 23
Applications
● Low Voltage
Rectification
● Low Power Consumption Applications
● High Efficiency DC/DC Conversion
M
arking
● B5817WS:SJ
B5818WS:SK
B5819WS:SL
Parameter
Symbol
B5818WS
B5817WS
B5819WS
Unit
Non-Repetitive Peak Reverse Voltage
VRM
40
V
Peak Repetitive Peak Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VRRM
VRWM
VR
40
V
VR(RMS)
14
21
28
V
RMS Reverse Voltage
Average Rectified Output Current
IO
1
A
IFSM
9
A
Repetitive Peak Forward Current
IFRM
1.5
A
Power Dissipation
Pd
500
mW
RθJA
400
℃/W
TJ
125
TSTG
-55~+150
Non-repetitive Peak Forward Surge Current
@t=8.3ms
Thermal Resistance Junction to
Ambient
Junction temperature
Storage Temperature
Electrical Characteristics (Ta=25℃ Unless otherwise specified)
Symbol
Parameter
Test
conditions
IR= 1mA
Reverse breakdown voltage
V(BR)
Reverse voltage leakage current
IR
VR=20V
VR=30V
VR=40V
B5817WS
Forward voltage
VF
B581 8WS
B581 9WS
Diode capacitance
CD
B5817WS
B5818WS
B5819WS
B5817WS
B5818WS
B5819WS
Min
Max
40
V
1
I F=1A
0.45
IF=3A
0.75
IF=1A
0.55
IF=3A
0.875
I F=1A
0.6
IF=3A
0.9
VR=4V, f=1MHz
High Diode Semiconductor
Unit
120
mA
V
V
V
pF
1
Typical Characteristics
Forward
10
Characteristics
Reverse
10
Pulsed
(mA)
a
T
a =
25
T
REVERSE CURRENT IR
=1
00
(A)
IF
FORWARD CURRENT
1
0.1
0.0
Characteristics
Pulsed
Ta=100℃
1
0.1
Ta=75℃
0.01
Ta=25℃
1E-3
0.4
0.8
1.2
FORWARD VOLTAGE
1.6
VF
2.0
1
(V)
10
REVERSE VOLTAGE
40
(V)
VR
Power Derating Curve
Capacitance Characteristics
600
200
(mW)
f=1MHz
PD
160
120
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
Ta=25℃
80
40
400
300
200
100
8
12
REVERSE VOLTAGE
16
VR
(V)
50
75
AMBIENT TEMPERATURE
100
Ta
125
2
SOD323 Package Outline Dimensions
0.80
SOD323 Suggested Pad Layout
JSHD
JSHD
3
Reel Taping Specifications For Surface Mount Devices-SOD323
1.46
2.9
1.25
4
很抱歉,暂时无法提供与“B5819WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.22534
- 200+0.18403
- 600+0.16108
- 3000+0.12697
- 9000+0.11503
- 21000+0.10861
