HX6286
Specifications
Sensitivity Unipolar Hall Effect Switch
HX6286 is an unipolar Hall effect sensor IC. It incorporates advanced chopper stabilization
technology to provide accurate and stable magnetic switch points. The design, specifications and
performance have been optimized for applications of solid state switches.
The output transistor will be switched on (BOP) in the presence of a sufficiently strong South
pole magnetic field facing the marked side of the package. Similarly, the output will be switched
off (BRP) in the presence of a weaker South field and remain off with “0” field.
The package type is in a Halogen Free version was verified by third party organization.
Halogen Free package is available by customer’s option.
Features and Benefits
DMOS Hall IC Technology.
Reverse bias protection on power supply pin.
Solid-State Reliability.
Chopper stabilized amplifier stage.
Unipolar, output switches with absolute value of South pole from magnet.
Operation down to 3.0V.
High Sensitivity for direct reed switch replacement applications.
100% tested at 125 for K Spec.
Custom sensitivity / Temperature selection are available.
Good ESD Protection.
Applications
Solid state switch
Limit switch
Current limit
Interrupter
Current sensing
Magnet proximity sensor for reed switch replacement
Ordering number
Part No.
Temperature Suffix
Package Type
HX6286UA
(-40℃to + 125℃)
(-40℃to + 85℃)
(TO-92S)
HX6286ESO
Functional Diagram
VDD
(SOT-23)
Out
Voltage
Regulator
Amp
Hall
Sensor
GND
1/4
HX6286
Specifications
Absolute Maximum Ratings At (Ta=25℃ )
Characteristics
Supply voltage,(VDD)
Values
28
Unit
V
Output Voltage,(Vo)
28
V
Reverse Voltage , (VDD)
-28
V
Magnetic flux density
Unlimited
Gauss
Output current , (IOUT)
50
mA
Operating Temperature Range, (Ta)
-40 to +125
Storage temperature range, (Ts)
-55 to +150
Maximum Junction Temp,(Tj)
150
(θja)
206
℃/W
(θjc)
148
℃/W
606
mW
Thermal Resistance
Package Power Dissipation, (PD)
Note: Do not apply reverse voltage to VDD and VOUT Pin, It may be caused for Miss function or damaged device.
Electrical Specifications
DC Operating Parameters
TA=+25℃, VDD=12V
Parameters
Test Conditions
Min
Typ
3.0
Max
Units
24.0
V
5.0
mA
Supply Voltage,(VDD)
Operating
Supply Current,(IDD)
BBOP
400.0
mV
Output Leakage Current, (Ioff)
IOFF B
很抱歉,暂时无法提供与“HX6286ESO”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.19756
- 50+0.96759
- 150+0.86903
- 500+0.74604
- 3000+0.61327
- 6000+0.58042
