BT16A07
BT16A07
    TNK(讯康)
    SMD
    BT16A07
BT16A07 数据手册
10/100 Base-T Single Port Transformer Module Designed to meet IEEE802.3ab requirement Designed to meet IR 255℃ peak requirement Primary inductance 350uH min ROHS Compliant Operating temperature range:0℃to+70℃ Storage temperature range:-25℃to+125℃ Electrical Specifications @ 25℃ Part Insertion Return Loss Cross Talk CMRR Ratio Loss (dB Min) (dB Min) (dB Min) Tx Rx 0.5~100MHz (dB Max) 1:1 1:1 -1.0 30.1-60 60.1-80 0.5-40 40.1-100 MHz MHz MHz MHz MHz MHz -16 -14 -12 -35 -30 -30 0.50-100 Mechanical 8.89 CWW LK DCR Hi-Pot (pF Max) (uH Max) (Ω Max) (Vrms) 35 0.5 1.2 1500 Schematics 8.89 1.27 1.27 9.54±0.5 BT16A07 7 YYWW Channel1-Port1 TD+ TCT TD- 1 2 3 1CT:1CT 0.64 12.7±0.5 6 RCT 7 RD+ RD- 0.64 Dimension:mm Unless otherwise specified,tolerances:±0.25(mm) Data sheet subject to change without notice 东莞市讯康电子科技股份有限公司 地址:广东省东莞市塘厦镇林村里牙塘工业区 145 号 TEL:(86)769-87923451 FAX:(86)769-87923450 WEBSITE:http://www.tnk.net.cn 8 16 TX+ 14 TXChannel2-Port1 0.46 2.29 BT16A07 0.5-30 6.86 Number Turn 1CT:1CT 15 CMT 11 RX+ 9 10 RXCMR
BT16A07 价格&库存
很抱歉,暂时无法提供与“BT16A07”相匹配的价格&库存,您可以联系我们找货
BT16A07
    • 1+3.69360
    • 10+3.03480
    • 30+2.70000
    • 100+2.37600
    库存:199
