BY251 - BY2000
STANDARD RECOVERY RECTIFIER DIODES
Features
Periodische Spitzensperrspannung
Plastic material has UL classification 94V-0
Gehäusematerial UL94V-0 klassifiziert
Kunststoffgehäuse
Weight approx. – Gewicht ca.
B
A
A
Mechanical Data
C
D
Case: DO-201AD, Molded Plastic
Terminals: Plated Leads Solderable per
MIL-STD-202, Method 208
Polarity: Cathode Band
Weight: 1.2 grams (approx.)
Mounting Position: Any
Marking: Type Number
DO-201AD
Dim
Min
Max
A
25.40
¾
B
7.20
9.50
C
1.20
1.30
D
4.80
5.30
All Dimensions in mm
Maximum Ratings TA = 25C unless otherwise specified
Type
Typ
Repetitive peak reverse voltage
VRRM [V]
Surge peak reverse voltage
Stoßspitzensperrspannung
VRSM [V]
BY251
200
200
BY252
400
400
BY253
600
600
BY254
800
800
BY255
1300
1300
BY1600
1600
1600
BY1800
1800
1800
BY2000
2000
2000
Max. average forward rectified current, R-load
Dauergrenzstrom in Einwegschaltung mit R-Last
TA = 50°C
IFAV
3 A 3)
Repetitive peak forward current – Periodischer Spitzenstrom
f > 15 Hz
IFRM
20 A 3)
Peak forward surge current, 50/60 Hz half sine-wave
Stoßstrom für eine 50/60 Hz Sinus-Halbwelle
TA = 25°C
IFSM
100/110 A
Rating for fusing, Grenzlastintegral, t < 10 ms
TA = 25°C
i2 t
50 A2s
Tj
TS
-50...+150°C
-50...+175°C
Junction temperature – Sperrschichttemperatur
Storage temperature – Lagerungstemperatur
Characteristics
Forward voltage – Durchlass-Spannung
Tj = 25°C
IF = 3 A
t
VF
< 1.1 V
Leakage current – Sperrstrom
Tj = 25°C
VR = VRRM
IR
< 5 µA
VR = 4 V
Cj
20 pF
rr
typ. 1500 ns
Thermal resistance junction to ambient air
Wärmewiderstand Sperrschicht – umgebende Luft
RthA
< 25 K/W 1)
Thermal resistance junction to leads
Wärmewiderstand Sperrschicht – Anschlussdraht
RthL
< 10 K/W
Typical junction capacitance
Typische Sperrschichtkapzität
Reverse recovery time
Sperrverzug
IF = 0.5 A through/über
IR = 1 A to IR = 0.25 A
120
10
2
[A]
100
Tj = 125°C
10
80
Tj = 25°C
60
1
40
10
IF
IFAV
10-2
TA
50
100
150
[°C]
Rated forward current versus ambient temperature
Zul. Richtstrom in Abh. von der Umgebungstemp.
100a-(3a-1.1v)
0.4
VF
0.8
1.0
2
[A]
10
îF
1
1.4
[V] 1.8
Forward characteristics (typical values)
Durchlasskennlinien (typische Werte)
10
1
1.2
10
102
[n]
Peak forward surge current versus number of cycles at 50 Hz
Durchlaß-Spitzenstrom in Abh. von der Zahl der Halbwellen bei 50 Hz
103
很抱歉,暂时无法提供与“BY255”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.61615
- 50+0.50535
- 150+0.44994
- 1000+0.36291
- 2000+0.32965
- 5000+0.31304
