FR101 THRU FR107
FAST RECOVERY RECTIFIERS
Reverse Voltage - 50 to 1000 V
Forward Current - 1 A
Features
• High current capability
• High reliability
• Low leakage
Mechanical Data
• Case: Molded plastic, DO-41
• Epoxy: UL 94V-0 rate flame retardant
• Lead: Axial leads, solderable per MIL-STD-202,
Method 208 guaranteed
• Polarity: Color band denotes cathode end
• Mounting Position: Any
Maximum Ratings and Electrical Characteristics
Ratings at 25 OC ambient temperature unless otherwise specified. Single phase, half-wave, 60 Hz, resistive or
inductive load, for capacitive load, derate current by 20%.
Parameter
Symbols FR101 FR102 FR103 FR104 FR105 FR106 FR107 Units
Maximum Recurrent Peak Reverse Voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS Voltage
VRMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
VDC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current 0.375"
(9.5 mm) Lead Length at TA = 55 OC
IF(AV)
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine-Wave Superimposed on Rated Load (JEDEC
Method)
IFSM
30
A
VF
1.3
V
IR
5
500
µA
CJ
15
pF
RJA
50
Maximum Forward Voltage at 1 A
O
Maximum Reverse Current
at Rated DC Blocking Voltage
TA = 25 C
TA = 100 OC
Typical Junction Capacitance 1)
Typical Thermal Resistance
2)
Maximum Reverse Recovery Time
3)
Operating and Storage temperature range
trr
Tj, Tstg
150
C/W
O
250
500
nS
- 55 to + 150
C
O
1)
Measured at 1 MHz and applied reverse voltage of 4 V D.C.
Thermal resistance from junction to ambient 0.375"(9.5 mm) lead length P.C.B mounted.
3)
Reverse recovery test conditions: IF = 0.5 A, IR = 1 A, Irr = 0.25 A.
2)
Dated : 14/07/2008 H
FR101 THRU FR107
很抱歉,暂时无法提供与“FR107”相匹配的价格&库存,您可以联系我们找货
