2SD1664
BIPOLAR TRANSISTOR (NPN)
FEATURES
Complementary to 2SB1132
Low Collector-emitter saturation voltage
Surface Mount device
SOT-89
MECHANICAL DATA
Case: SOT-89
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Moisture Sensitivity: Level 1 per J-STD-020
Weight: 0.055 grams (approximate)
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Parameter
Symbol
Value
Unit
Collector-Base Voltage
VCBO
40
V
Collector-Emitter Voltage
VCEO
32
V
Emitter-Base Voltage
VEBO
5
V
Collector Current
Collector Power Dissipation
IC
1
A
PC
500
mW
Junction Temperature
TJ
150
°C
Storage Temperature
TSTG
-55 ~+150
°C
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Ma
Parameter
Symbol Min Typ
Unit
x
Conditions
Collector-base breakdown voltage
V(BR)CBO
40
V
IC=50uA,IE=0
Collector-emitter
voltage
V(BR)CEO
32
V
IC=1mA,IB=0
V(BR)EBO
5
V
IE=50uA,IC=0
breakdown
Emitter-base breakdown voltage
Collector cut-off current
ICBO
0.5
uA
VCB=20V, IE=0
Emitter cut-off current
IEBO
0.5
uA
VEB=4V, IC=0
DC current gain
hFE
VCE=3V, IC=1mA
390
VCE(sat)
Transition frequency
Collector output capacitance
82
0.3
V
fT
150
MHz
Cob
15
pF
IC=0.5A,IB=50mA
VCE=5V,IC=50mA,f=100MHz
VCB=10V, IE=0, f=1MHz
CLASSIFICATION OF hFE
Rank
P
Q
R
Range
82-180
120-270
180-390
Marking
DAP
DAQ
DAR
©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD
E-mail:hkt@heketai.com
1/4
2SD1664
Typical Characteristics
Static Characteristic
COMMON
EMITTER
Ta=25℃
0.80mA
125
0.72mA
Ta=100℃
0.64mA
100
hFE —— IC
300
DC CURRENT GAIN hFE
COLLECTOR CURRENT IC (mA)
150
0.56mA
0.48mA
75
0.40mA
0.32mA
50
200
Ta=25℃
100
0.24mA
25
0.16mA
COMMON EMITTER
VCE= 3V
IB=0.08mA
4
6
COLLECTOR-EMITTER VOLTAGE
VBEsat
1.2
VCE
8
IC
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
Ta=100℃
0.4
0.01
0.1
COLLECTOR CURRENT
fT
IC
1
(A)
IC
Ta=100℃
Ta=25℃
0.01
0.1
COLLECTOR CURRENT
IC
IC
100
10
1E-3
1
0.1
β=10
(A)
1000
Cob / Cib
IC
1
(A)
VCB / VEB
f=1MHz
IE=0 / IC=0
300
Ta=25℃
CAPACITANCE C (pF)
TRANSITION FREQUENCY fT (MHz)
500
VCEsat ——
1000
Ta=25℃
0.0
1E-3
0.01
COLLECTOR CURRENT
(V)
β=10
0.8
1E-3
100
Cib
100
Cob
10
30
VCE=5V
Ta=25℃
10
3
10
100
COLLECTOR CURRENT
PC
COLLECTOR POWER DISSIPATION
PC (mW)
600
IC
1
0.1
1
REVERSE VOLTAGE
(mA)
10
V
(V)
Ta
500
400
300
200
100
50
75
AMBIENT TEMPERATURE
100
Ta
125
150
2/4
2SD1664
SOT-89 Package Outline Dimensions
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
1.400
1.600
0.055
0.063
b
0.320
0.520
0.013
0.020
b1
0.400
0.580
0.016
0.023
c
0.350
0.440
0.014
0.017
D
4.400
4.600
0.173
0.181
D1
1.550REF
0.061REF
E
2.300
2.600
0.091
0.102
E1
3.940
4.250
0.155
0.167
e
1.500TYP
0.060TYP
e1
3.000TYP
0.118TYP
L
0.900
1.200
0.035
0.047
SOT-89 Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
3/4
2SD1664
SOT-89 Tape and Reel
SOT-89 Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SOT-89
4.85
4.45
1.85
Ø1.50
1.75
5.50
4.00
8.00
2.00
12.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SOT-89 Tape Leader and Trailer
SOT-89 Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
13.20
16.50
±2
±1
±1
±1
±1
±1
±1
±1
4/4
很抱歉,暂时无法提供与“2SD1664”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.13501
- 100+0.12601
- 300+0.11701
- 500+0.10801
- 2000+0.10351
- 5000+0.10081
