SPECIFICATIONS
Current Rating:
1.5 Amps
Insulation Resistance:1000MΩ Min
Contact Resistance:
20mΩ Max
Withstanding Voltage: AC 500V
Operation Temperature:-40°to+105°
Contact Material:
Brass
Standard:
PA6T
Insrlator Material:
Polyester(UL 94V-0)
Contact Plating:
Gold Flash
Max.Processing Temp: 240°C for30-60seconds
(260°C for5seconds)
RECOMMEND P.C.B LAYOUT
PCB TOLERANCE:±0.05 (TOP VIEW)
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(9)
Pin Spacing:200=2.0mm
Product Name:PH=Pin Header
No.of Rows:1=Single Row; 2=Dual Row
No.of Pins Per Row:1~40
Insulator Material Height: 15=1.5mm; 20=2.0mm
Connector Type:S=Straight; R=Right; Angle M=SMT
Contact Material Length: 87=8.7mm 105=10.5mm
No.of Insulator Material: 1=1PCS; 2=2PCS; 3=3PCS
Contact Plating:
SN=Tin;G0=Gold Flash;S0=Gold Flash/Tin;AU08=Au 0.8u"
(10)Insulator Material Option:
A=BK-PBT;B=BK-PA6T;C=BK-PA46;D=KB-LCP;S=Special
深圳市金航标电子有限公司
WWW.BDS666.COM
KH-2PH180-1X4P-L8.7
0755-83044319
UNLESS OTHEWIXE SPECIFIED TOLERANCE
X :±0.3
X.X :±0.2
X.XX:±0.1
X°
:±5°
X.X° :±1°
X.XX°:±0.5°
CHECKED: LI BEI LIN
12/03/07
DRAWM NAME:
SIZE
REV
A4
A
CHECKED:
2.0PH
No. of DIM.A
1xnPin H2.0 180 ° L8.7
SCALE
PROUCT NO.
UNIT
PROJECT
APPROVED:
PAGE
1/1
DIM.B
No. of DIM.A
DIM.B
No. of DIM.A
DIM.B
No. of DIM.A
DIM.B
KH-2PH180-1X4P-L8.7 价格&库存
很抱歉,暂时无法提供与“KH-2PH180-1X4P-L8.7”相匹配的价格&库存,您可以联系我们找货
