MDA1365-150M
MDA1365-150M
    KOHER(科或)
    IND_13.5X12.6MM_SM
    固定电感器 IND_13.5X12.6MM_SM 15µH ±20% 11A
MDA1365-150M 数据手册
MDA Series SMD Low Profile High Current Molded Inductor Size 1365 FEATURES ■ ■ ■ ■ ■ ■ ■ ■ ■ Shielded construction Capable of corresponding high frequency . Low loss realized with low DCR. High performance (Isat) realized by metal dust core. Ultra low buzz noise, due to composite construction. 100% Lead(Pb)-Free and RoHS compliant. High reliability -Reliability test complied to AEC-Q200 Operating temperature: -55 to +155 °C (including self-temperature rise) Quantity: 500PCS APPLICATION ■ ■ ■ ■ ■ ■ Headlamps, tail lamps and interior lighting HVAC Doors, window lift and seat control Audio subsystem Digital instrument cluster In-Vehicle Infotainment and navigation Dimensions: [mm] 0.47μH-1.50μH 2.3±0.3 Marking 14.5 5.0 6.2±0.3 E 12.6±0.2 13.5±0.5 Land Pattern: [mm] 8.0 Dimensions: [mm] 2.2μH-47μH 2.3±0.3 Marking 14.5 5.0 6.2±0.3 E 12.6±0.2 13.5±0.5 Land Pattern: [mm] 8.0 Electrical Properties: Tolerance Temperature Rise Current Typ. (A) Saturation Current Typ. (A) DC Resistance Typ. (mΩ) DC Resistance Max. (mΩ) E 0.47 ±20% 42.0 68.0 0.88 1.02 4.7±0.3 MDA1365-R68M 0.68 ±20% 36.5 55.0 1.25 1.50 4.0±0.3 MDA1365-1R0M 1.00 ±20% 33.0 45.0 1.50 1.80 4.0±0.3 Part No Inductance @ 100KHz/1V (μH) MDA1365-R47M KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com www.kohergroup.com Part No Inductance @ 100KHz/1V (μH) Tolerance Temperature Rise Current Typ. (A) Saturation Current Typ. (A) DC Resistance Typ. (mΩ) DC Resistance Max. (mΩ) E MDA1365-1R5M 1.50 ±20% 29.0 35.0 2.20 4.00 4.0±0.3 MDA1365-2R2M 2.20 ±20% 25.0 28.5 3.70 4.20 4.7±0.3 MDA1365-3R3M 3.30 ±20% 22.0 27.0 5.30 6.20 4.7±0.3 MDA1365-4R7M 4.70 ±20% 20.0 25.0 6.80 8.00 4.7±0.3 MDA1365-5R6M 5.60 ±20% 18.0 23.0 8.30 9.80 4.7±0.3 MDA1365-6R8M 6.80 ±20% 16.5 21.0 9.80 11.3 4.7±0.3 MDA1365-8R2M 8.20 ±20% 15.0 19.0 12.0 13.8 4.7±0.3 MDA1365-100M 10.0 ±20% 13.0 17.0 13.0 15.8 4.7±0.3 MDA1365-150M 15.0 ±20% 11.0 13.5 22.0 26.0 4.7±0.3 MDA1365-220M 22.0 ±20% 10.0 10.0 31.0 35.0 4.7±0.3 MDA1365-330M 33.0 ±20% 9.00 9.00 46.0 55.0 4.7±0.3 MDA1365-470M 47.0 ±20% 8.00 7.60 58.0 67.0 4.7±0.3 Saturation Current will cause L to drop approximately 30% Temperature Rise Current: The actual value of DC current when the temperature rise is △T=40°C Typical Electrical Characteristics: MDA1365-R68M 0.48 80 0.8 80 1.2 80 0.36 60 0.6 60 0.9 60 0.24 40 0.4 40 0.6 40 0.12 20 0.2 20 0.3 20 14 28 42 56 0 70 0.0 0 12 DC CURRENT(A) 24 36 48 0 60 0.0 0 10 DC CURRENT(A) MDA1365-1R5M 20 30 40 TEMP. RISE(℃) 100 INDUCTANCE (uH) 1.5 TEMP. RISE(℃) 100 INDUCTANCE (uH) 1.0 0.00 0 0 50 DC CURRENT(A) MDA1365-2R2M MDA1365-3R3M 4.0 100 1.6 80 2.4 80 3.2 80 1.2 60 1.8 60 2.4 60 0.8 40 1.2 40 1.6 40 0.4 20 0.6 20 0.8 20 0.0 0 9 18 27 36 DC CURRENT(A) KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com 0 45 0.0 0 7 14 21 DC CURRENT(A) 28 0 35 0.0 0 7 14 21 28 TEMP. RISE(℃) 100 INDUCTANCE (uH) 3.0 TEMP. RISE(℃) 100 INDUCTANCE (uH) 2.0 TEMP. RISE(℃) INDUCTANCE (uH) MDA1365-1R0M 100 TEMP. RISE(℃) INDUCTANCE (uH) MDA1365-R47M 0.60 0 35 DC CURRENT(A) www.kohergroup.com MDA1365-5R6M 4.8 80 6.4 80 8 80 3.6 60 4.8 60 6 60 2.4 40 3.2 40 4 40 1.2 20 1.6 20 2 20 6 12 18 24 0 30 0.0 0 6 DC CURRENT(A) 18 24 0 30 0 0 5 DC CURRENT(A) MDA1365-8R2M 10 15 0 25 20 DC CURRENT(A) MDA1365-100M MDA1365-150M 20 100 8 80 12 80 16 80 6 60 9 60 12 60 4 40 6 40 8 40 2 20 3 20 4 20 0 0 5 10 15 20 0 25 0 0 3 DC CURRENT(A) 6 9 12 0 15 0 0 3.5 DC CURRENT(A) MDA1365-220M 7.0 10.5 14.0 TEMP. RISE(℃) 100 INDUCTANCE (uH) 15 TEMP. RISE(℃) 100 INDUCTANCE (uH) 10 TEMP. RISE(℃) 0 17.5 DC CURRENT(A) MDA1365-330M MDA1365-470M 60 100 24 80 32 80 48 80 18 60 24 60 36 60 12 40 16 40 24 40 6 20 8 20 12 20 0 0 3 6 9 12 DC CURRENT(A) KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com 0 15 0 0 3 6 9 DC CURRENT(A) 12 0 15 0.0 0 2.5 5.0 7.5 10.0 TEMP. RISE(℃) 100 INDUCTANCE (uH) 40 INDUCTANCE (uH) 100 TEMP. RISE(℃) 30 TEMP. RISE(℃) INDUCTANCE (uH) 12 TEMP. RISE(℃) 100 INDUCTANCE (uH) 10 TEMP. RISE(℃) 100 INDUCTANCE (uH) 8.0 0.0 0 INDUCTANCE (uH) MDA1365-6R8M 100 TEMP. RISE(℃) INDUCTANCE (uH) MDA1365-4R7M 6.0 0 12.5 DC CURRENT(A) www.kohergroup.com
MDA1365-150M 价格&库存
很抱歉,暂时无法提供与“MDA1365-150M”相匹配的价格&库存,您可以联系我们找货
