SH-1012-001
SH-1012-001
    SUNWAVE(信威电子)
    SEN_24.6X6.4MM_TM
    霍尔槽型位置传感器 3.8~30V 10mA
SH-1012-001 数据手册
1 2 FM-RD-020 3 5 4 REV.B REV. 6 DETAIL PLACE 1.0 NAME DATE XCC 20220824 A R2.5 A 6.4 19 24.6 Direction of rotation 12.4 3.3 R38.1 R44.45 8.6 11.9 3.5 B 3.81Min 4.1 B Trailing edge of tooth Leading edge of tooth C C Block circuit wiring diagram Hall sensor Trigger circuit and amplifier Vs(+) Output (O)N.H. Ground(-) Speed Sensing Interface D Vcc +5 High Vcc +5 Impedance Input 10K Ohm 100 Ohm 100 Ohm 100 pF Capacitor 1 2 SUNWAVE ELECTRONICS CO.,LTD. Ground Black (-) Vcc Red (+) Input Green (O) 3 DO NOT SCALE DRAWING UNLESS OTHERWISE SPECIFIED: (1) ALL DIMENSIONS IN MM. (2) RADIUS & CHAMFERS:0.20MM (3) DRAFT ANGLE: 0-0.5 (4) TOLERANCE: 0mm TO 25mm 0.16mm 25mm TO 50mm 0.20mm 50mm TO 100mm 0.25mm 100mm TO 150mm 0.31mm 150mm TO 500mm ADD 0.06mm FOR EACH ADDITIONAL 50mm ANGULAR 0.5 4 PEOJECT MODEL DESCRIPTION PART NO. ANGLE OF VIEW DRAWN DATE CHECKED DATE APPR'D DATE SCALE DWG. SIZE D A4 UNIT MATERIAL SHEET mm QTY. FINISH 5 1 OF DWG.NO. 6 1
SH-1012-001 价格&库存
很抱歉,暂时无法提供与“SH-1012-001”相匹配的价格&库存,您可以联系我们找货
SH-1012-001
  • 1+7.59110
