ES7243E
ES7243E
    EVEREST(顺芯)
    QFN20_3X3MM_EP
    QFN20_3X3MM_EP 24Bit 101dB I2S,PCM
ES7243E 数据手册
ES7243E High Performance Stereo Audio ADC FEATURES • • • • • • • • • • • APPLICATIONS High performance multi-bit delta-sigma audio ADC 101 dB signal to noise ratio -90 dB THD+N Low noise PGA 24-bit, 8 to 48 kHz sampling frequency I2S/PCM master or slave serial data port Support TDM up to 16 channels 256/384Fs, USB 12/24 MHz and other non standard audio system clocks Auto level control (ALC) and noise gate Support digital mic Low power • • • • • • • Mic Array Soundbar Audio Interface Digital TV A/V Receiver DVR NVR ORDERING INFORMATION ES7243E -40°C ~ +85°C QFN-20 BLOCK DIAGRAM TDMIN AINLP/AINLN AINRP/AINRN Multi-bit Delta-sigma Modulator DSP Audio Data Interface 2 Clock Manager Sample Rate Detector IC Interface MCLK CCLK CDATA AD0 AD1 1 SDOUT/AD2 SCLK LRCK Everest Semiconductor 1. 2. 3. 4. 5. 6. Confidential ES7243E PIN OUT AND DESCRIPTION ................................................................................................ 4 TYPICAL APPLICATION CIRCUIT.......................................................................................... 5 CLOCK MODES AND SAMPLING FREQUENCIES ............................................................... 6 MICRO-CONTROLLER CONFIGURATION INTERFACE ...................................................... 6 DIGITAL AUDIO INTERFACE.................................................................................................. 8 ELECTRICAL CHARACTERISTICS ..................................................................................... 10 ABSOLUTE MAXIMUM RATINGS................................................................................................ 10 RECOMMENDED OPERATING CONDITIONS .............................................................................. 10 Note: for VDDD=1.8V, sampling frequency must be less than 24 kHz. ..................................... 10 ADC ANALOG AND FILTER CHARACTERISTICS AND SPECIFICATIONS ........................................ 10 DC CHARACTERISTICS ................................................................................................................ 11 I2C SWITCHING SPECIFICATIONS (SLOW SPEED MODE/HIGH SPEED MODE) ........................... 11 SERIAL AUDIO PORT SWITCHING SPECIFICATIONS ................................................................... 12 7. CONFIGURATION REGISTER DEFINITION ........................................................................ 13 REGISTER 0X00 –RESET, DEFAULT 0001 1110 ........................................................................... 13 REGISTER 0X01 – CLOCK MANAGER, DEFAULT 0000 0000 ....................................................... 13 REGISTER 0X02 – CLOCK MANAGER, DEFAULT 0000 0000 ....................................................... 13 REGISTER 0X03 – CLOCK MANAGER, DEFAULT 0010 0000 ....................................................... 14 REGISTER 0X04 – CLOCK MANAGER, DEFAULT 0000 0000 ....................................................... 14 REGISTER 0X05 – CLOCK MANAGER, DEFAULT 0000 0000 ....................................................... 14 REGISTER 0X06 – CLOCK MANAGER, DEFAULT 0000 0011 ....................................................... 14 REGISTER 0X07 – CLOCK MANAGER, DEFAULT 0000 0001 ....................................................... 15 REGISTER 0X08 – CLOCK MANAGER, DEFAULT 1111 1111 ....................................................... 15 REGISTER 0X09 – CLOCK MANAGER, DEFAULT 1100 0001 ....................................................... 15 REGISTER 0X0A – SDP, DEFAULT 1000 0001 ............................................................................. 15 REGISTER 0X0B – SDP, DEFAULT 1100 0000.............................................................................. 16 REGISTER 0X0C – SDP, DEFAULT 0000 0000.............................................................................. 16 REGISTER 0X0D – ADC CONTROL, DEFAULT 0000 0000 ............................................................ 17 REGISTER 0X0E – ADC CONTROL, DEFAULT 0000 0000............................................................. 17 REGISTER 0X0F – ADC CONTROL, DEFAULT 0000 0000 ............................................................. 17 REGISTER 0X10 – ADC CONTROL, DEFAULT 0000 0000............................................................. 18 REGISTER 0X11 – ADC CONTROL, DEFAULT 0000 0000............................................................. 18 REGISTER 0X12 – ADC CONTROL, DEFAULT 0000 0000............................................................. 19 REGISTER 0X13 – ADC CONTROL, DEFAULT 0000 0000............................................................. 19 REGISTER 0X14 – ADC CONTROL, DEFAULT 0000 1100............................................................. 20 Revision 2.0 2 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E REGISTER 0X15 – ADC CONTROL, DEFAULT 0000 1100............................................................. 20 REGISTER 0X16 – ANALOG, DEFAULT 1111 1111 ...................................................................... 20 REGISTER 0X17 – ANALOG, DEFAULT 0000 0000 ...................................................................... 20 REGISTER 0X18 – ANALOG, DEFAULT 0010 0100 ...................................................................... 20 REGISTER 0X19 – ANALOG, DEFAULT 1000 1000 ...................................................................... 21 REGISTER 0X1A – ANALOG, DEFAULT 0100 0100 ...................................................................... 21 REGISTER 0X1B – ANALOG, DEFAULT 0100 0100 ...................................................................... 22 REGISTER 0X1C – ANALOG, DEFAULT 0100 0100 ...................................................................... 23 REGISTER 0X1D – ANALOG, DEFAULT 0000 0000...................................................................... 23 REGISTER 0X1E – ANALOG, DEFAULT 0000 0101 ...................................................................... 24 REGISTER 0X1F – ANALOG, DEFAULT 0000 1100 ...................................................................... 24 REGISTER 0X20 – ANALOG, DEFAULT 0000 0000 ...................................................................... 24 REGISTER 0X21 – ANALOG, DEFAULT 0000 0000 ...................................................................... 25 REGISTER 0XF7 – TEST MODE, DEFAULT 1111 0000 ................................................................. 25 REGISTER 0XF8 – TEST MODE, DEFAULT 0000 0000 ................................................................. 26 REGISTER 0XF9 – TEST MODE, DEFAULT 0000 0000 ................................................................. 26 REGISTER 0XFA – I2C CONFIGURE, DEFAULT 0000 0000........................................................... 26 REGISTER 0XFC – FLAG, DEFAULT 0000 0000 ............................................................................ 26 REGISTER 0XFD – CHIP ID1, DEFAULT 0111 1010 ...................................................................... 26 REGISTER 0XFE – CHIP ID2, DEFAULT 0100 0011 ...................................................................... 26 REGISTER 0XFF – CHIP VERSION, DEFAULT 0000 0000 ............................................................. 27 8. 9. PACKAGE .............................................................................................................................. 28 CORPORATE INFORMATION .............................................................................................. 29 Revision 2.0 3 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E 1. PIN OUT AND DESCRIPTION AINRP AD0 CDATA CCLK MCLK 16 17 18 19 20 VDDP TDMIN SDOUT/AD2 GNDD VDDD 1 2 3 4 5 15 14 13 12 11 ES7243E AINRN REFP GNDA VDDA REFQ 10 9 8 7 6 AINLN AINLP AD1 LRCK SCLK Pin Name CCLK, CDATA AD0, AD1 MCLK SCLK LRCK TDMIN SDOUT/AD2 AINLP, AINLN AINRP, AINRN VDDP VDDD/GNDD VDDA/GNDA REFP REFQ Revision 2.0 Pin number 19, 18 17,8 20 6 7 2 3 9, 10 16, 15 1 5, 4 12, 13 14 11 Input or Output Pin Description I/O I I I/O I/O I O I2C clock and data I2C addresses Master clock Serial data bit clock Serial data left and right channel frame clock TDM data in Serial data output/ I2C address AD2 I Analog left and right inputs I I I O O Power supply for the digital input and output Digital power supply Analog power supply Filtering capacitor connection Filtering capacitor connection 4 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E 2. TYPICAL APPLICATION CIRCUIT 0R AGND AGND AGND 1uF IIC CPU/DSP TDMIN VA 14 12 * 16 AINRP 15 13 GNDA AINRN 1uF AGND 9 AINLP TDMIN PGND AINRP 1uF AINRN ES7243E MCLK SCLK LRCK SDOUT 2 21 VDDA AD0 AD1 CCLK CDATA 20 6 7 3 IIS ** REFQ AGND17 8 19 18 1uF AGND GNDD VDDP 4 1uF 11 5 * *100nF 100nF VDDD VDDD 1 VDDP REFP GND(SYS) In the layout, chip is treated as a analog device AINLP 1uF 10 AINLN AINLN 1uF 100K AGND AGND For the best performance,decoupling and filtering capacitors should be located as close to the device package as possible Additional paralle capacitors(typically 0.1 μF) can be used, larger value capacitors(typically 10 μF) would also help * AGND AGND AGND 1uF IIC CPU/DSP 20 6 7 3 IIS 2 21 TDMIN 100K AGND VA * 12 ** 14 11 1 1uF AGND GNDD AD0 AD1 CCLK CDATA VDDA AGND17 8 19 18 1uF REFQ 4 VDDP * *100nF 100nF VDDD VDDD 5 VDDP REFP 0R GND(SYS) In the layout, chip is treated as a analog device AINRP AINRN 16 ES7243E MCLK SCLK LRCK SDOUT TDMIN PGND AINR 1uF 15 AGND 1uF GNDA 13 AINLP 9 AINLN 10 AGND 1uF AINL AGND 1uF AGND For the best performance,decoupling and filtering capacitors should be located as close to the device package as possible Additional paralle capacitors(typically 0.1 μF) can be used, larger value capacitors(typically 10 μF) would also help * Revision 2.0 5 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E 3. CLOCK MODES AND SAMPLING FREQUENCIES The device supports standard audio clocks (64Fs, 128Fs, 256Fs, 384Fs, 512Fs, etc), USB clocks (12/24 MHz), and some common non standard audio clocks (25 MHz, 26 MHz, etc). The device can work either in master clock mode or slave clock mode. In slave mode, LRCK and SCLK are supplied externally, and LRCK and SCLK must be synchronously derived from the system clock with specific rates. In master mode, LRCK and SCLK are derived internally from device master clock. 4. MICRO-CONTROLLER CONFIGURATION INTERFACE The device supports standard I2C micro-controller configuration interface. External microcontroller can completely configure the device through writing to internal configuration registers. I2C interface is a bi-directional serial bus that uses a serial data line (CDATA) and a serial clock line (CCLK) for data transfer. The timing diagram for data transfer of this interface is given in Figure 1a and Figure 1b. Data are transmitted synchronously to CCLK clock on the CDATA line on a byte-by-byte basis. Each bit in a byte is sampled during CCLK high with MSB bit being transmitted firstly. Each transferred byte is followed by an acknowledge bit from receiver to pull the CDATA low. The transfer rate of this interface can be up to 400 kbps. A master controller initiates the transmission by sending a “start” signal, which is defined as a high-to-low transition at CDATA while CCLK is high. The first byte transferred is the slave address. It is a seven-bit chip address followed by a RW bit. The chip address must be 0010 x, where x equals AD2 AD1 AD0. The RW bit indicates the slave data transfer direction. Once an acknowledge bit is received, the data transfer starts to proceed on a byte-by-byte basis in the direction specified by the RW bit. The master can terminate the communication by generating a “stop” signal, which is defined as a low-to-high transition at CDATA while CCLK is high. In I2C interface mode, the registers can be written and read. The formats of “write” and “read” instructions are shown in Table 1 and Table 2. Please note that, to read data from a register, you must set R/W bit to 0 to access the register address and then set R/W to 1 to read data from the register. Table 1 Write Data to Register in I2C Interface Mode start Chip Address 0010 AD2 AD1 AD0 Revision 2.0 R/W 0 ACK Register Address RAM ACK Data to be written DATA 6 Latest datasheet: www.everest-semi.com or info@everest-semi.com ACK June 2019 Stop Everest Semiconductor Confidential Chip Addr CDATA Write ACK bit 1 to 7 Reg Addr ES7243E ACK bit 1 to 8 Write Data ACK bit 1 to 8 CCLK START STOP Figure 1a I2C Write Timing Table 2 Read Data from Register in I2C Interface Mode Chip Address 0010 AD2 AD1 AD0 Chip Address 0010 AD2 AD1 AD0 Start Start Chip Addr CDATA bit 1 to 7 Write ACK R/W 0 R/W 1 Reg Addr ACK ACK ACK bit 1 to 8 Register Address RAM Data to be read Data Chip Addr bit 1 to 7 Read ACK ACK NACK Stop Read Data NO ACK bit 1 to 8 CCLK START START STOP Figure 1b I2C Read Timing Revision 2.0 7 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E 5. DIGITAL AUDIO INTERFACE The device provides many formats of serial audio data interface to the output from the ADC through LRCK, SCLK and SDOUT pins. These formats are I2S, left justified, DSP/PCM mode and TDM. ADC data is out at SDOUT on the falling edge of SCLK. The relationships of SDOUT, SCLK and LRCK with these formats are shown through Figure 2a to Figure 2h. ES7243E can be cascaded up to 8-ch through single I2S or TDM, please refer to the user guide for detail description. 1 SCLK L Channel LRCK R Channel SCLK MSB LSB LSB MSB Figure 2a I2S Serial Audio Data Format LRCK L Channel R Channel SCLK SDOUT LSB MSB MSB LSB Figure 2b Left Justified Serial Audio Data Format 1 SCLK LRCK R Channel L Channel SCLK SDOUT MSB LSB MSB LSB Figure 2c DSP/PCM Mode A Serial Audio Data Format LRCK R Channel L Channel SCLK SDOUT MSB LSB MSB LSB Figure 2d DSP/PCM Mode B Serial Audio Data Format Revision 2.0 8 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential 1 SCLK ES7243E 1 SCLK Channel 3 Channel 1 LRCK Channel 4 Channel 2 SCLK SDOUT MSB LSB LSB MSB MSB LSB LSB MSB Figure 2e TDM I2S Serial Audio Data Format LRCK Channel 3 Channel 1 Channel 4 Channel 2 SCLK SDOUT MSB LSB LSB MSB MSB LSB LSB MSB Figure 2f TDM Left Justified Serial Audio Data Format 1 SCLK LRCK Channel 4 Channel 3 Channel 2 Channel 1 SCLK SDOUT MSB LSB MSB LSB MSB LSB LSB MSB Figure 2g TDM DSP/PCM Mode A Serial Audio Data Format LRCK Channel 4 Channel 3 Channel 2 Channel 1 SCLK SDOUT MSB LSB MSB LSB MSB LSB MSB LSB Figure 2h TDM DSP/PCM Mode B Serial Audio Data Format Revision 2.0 9 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E 6. ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS Continuous operation at or beyond these conditions may permanently damage the device. PARAMETER Analog Supply Voltage Level Digital Supply Voltage Level Analog Input Voltage Range Digital Input Voltage Range Operating Temperature Range Storage Temperature MIN -0.3V -0.3V GNDA-0.3V GNDD-0.3V -40°C -65°C MAX +3.6V +3.6V VDDA+0.3V VDDP+0.3V +85°C +150°C RECOMMENDED OPERATING CONDITIONS PARAMETER VDDA VDDD VDDP MIN 1.7 1.7 1.7 TYP 3.3 3.3 3.3 MAX 3.6 3.6 3.6 UNIT V V V Note: for VDDD=1.8V, sampling frequency must be less than 24 kHz. ADC ANALOG AND FILTER CHARACTERISTICS AND SPECIFICATIONS Test conditions are as the following unless otherwise specify: VDDA=3.3V, VDDD=3.3V, GNDA=0V, GNDD=0V, ambient temperature=25°C, Fs=48 KHz, MCLK/LRCK=256. PARAMETER ADC Performance Signal to Noise ratio (A-weigh) THD+N Channel Separation (1KHz) Interchannel Gain Mismatch Gain Error Filter Frequency Response Passband Stopband Passband Ripple Stopband Attenuation Analog Input Full Scale Input Level Input Impedance Revision 2.0 MIN TYP MAX UNIT 96 -95 95 101 -90 100 0.1 104 -85 105 dB dB dB dB % 0 0.5465 ±5 0.4535 ±0.05 70 VDDA/3.3 8 (0 dB PGA) 6 (33 dB PGA) 10 Latest datasheet: www.everest-semi.com or info@everest-semi.com Fs Fs dB dB Vrms KΩ June 2019 Everest Semiconductor Confidential ES7243E DC CHARACTERISTICS PARAMETER Normal Operation Mode VDDD=3.3V, VDDP=3.3V, VDDA=3.3V (16 kHz) VDDD=1.8V, VDDP=1.8V, VDDA=1.8V (16 kHz) Power Down Mode Digital Voltage Level Input High-level Voltage Input Low-level Voltage Output High-level Voltage Output Low-level Voltage MIN TYP MAX UNIT 26 7.5 0 0.7*VDDP VDDP 0 mW uA V V V V 0.5 I2C SWITCHING SPECIFICATIONS (SLOW SPEED MODE/HIGH SPEED MODE) PARAMETER CCLK Clock Frequency Bus Free Time Between Transmissions Start Condition Hold Time Clock Low time Clock High Time Setup Time for Repeated Start Condition CDATA Hold Time from CCLK Falling CDATA Setup time to CCLK Rising Rise Time of CCLK Fall Time CCLK Symbol FCCLK TTWID TTWSTH TTWCL TTWCH TTWSTS TTWDH TTWDS TTWR TTWF MIN 4.7/1.3 4.0/0.6 4.7/1.3 4.0/0.6 4.7/0.6 0.25/0.1 MAX 100/400 UNIT KHz us us us us us us us us us 3.45/0.9 1.0/0.3 1.0/0.3 SDA TTWSTS TTWSTH TTWCL SCL TTWDH TTWID TTWDS TTWCH S TTWF TTWR P S Figure 3 I2C Timing Revision 2.0 11 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E SERIAL AUDIO PORT SWITCHING SPECIFICATIONS PARAMETER Symbol MCLK frequency MCLK duty cycle LRCK frequency LRCK duty cycle (Note 2) SCLK frequency SCLK pulse width low TSLKL SCLK Pulse width high TSCLKH SCLK falling to LRCK edge (master mode only) TSLR LRCK edge to SCLK rising (slave mode only) TLSR SCLK falling to SDOUT valid VDDD=3.3V T VDDD=1.8V SDO LRCK edge to SDOUT valid (Note 3) VDDD=3.3V T VDDD=1.8V LDO Note 2: one SCLK period of high time in DSP/PCM modes. MIN 40 40 16 16 10 MAX 49.2 60 200 60 26 10 16 39 11 25 UNIT MHz % KHz % MHz ns ns ns ns ns ns Note 3: only apply to MSB of Left Justified or DSP/PCM mode B. LRCK TSLR TLSR TSCLKH TSCLKL SCLK TSDO TLDO SDOUT Figure 4 Serial Audio Port Timing Revision 2.0 12 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E 7. CONFIGURATION REGISTER DEFINITION REGISTER 0X00 –RESET, DEFAULT 0001 1110 Bit Name CSM_ON Bit 7 MSC 6 SEQ_DIS 5 RST_DIG 4 RST_CMG 3 RST_MST 2 RST_ADC_DIG 1 Description Chip FSM ON/OFF control 0 - csm power down(default) 1 - csm power up Master/Slave select for SDP 0 - slave mode(default) 1 - master mode Power up sequence enable control 0 - power up sequence enable(default) 1 - power up sequence disable Digital circuits reset 0 - Not reset(default) 1 - Reset Clock manager circuit reset 0 - Not reset (default) 1 - Reset Master circuit reset 0 - Not reset (default) 1 - Reset Adc digital circuit reset 0 - Not reset (default) 1 - Reset REGISTER 0X01 – CLOCK MANAGER, DEFAULT 0000 0000 Bit Name MCLK_ON Bit 5 BCLK_ON 4 CLKADC_ON 3 ANACLKADC_ON 1 Description MCLK ON/OFF control 0 - MCLK off (default) 1 - MCLK on BCLK ON/OFF control 0 - BCLK off (default) 1 - BCLK on Clock clk_adc ON/OFF control 0: clk_adc off(default) 1: clk_adc on Clock anaclk_adc ON/OFF control 0 - anaclk_adc off(default) 1 - anaclk_adc on REGISTER 0X02 – CLOCK MANAGER, DEFAULT 0000 0000 Bit Name MCLK_SEL Bit 7 MSTBCLK_SEL 6 MSTCLK_SEL 5:4 Revision 2.0 Description Internal mclk select 0 - from MCLK PAD(default) 1 - from BCLK PAD Master BCLK derive clocks 0 - from bclk_out[divided by DIV_BCLK](default) 1 - from anaclk_adc At master mode, source clock select 13 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor BCLK_FITBIT 2 MCLK_INV 1 BCLK_INV 0 Confidential ES7243E 0 - internal mclk(default) 1 - dig_mclk 2 - DSP_clk 3 - CF_clk BCLK out control when master mode 0 - continual bclk(default) 1 - master bclk stop after data transfer out Internal mclk invert 0 - normal(default) 1 - invert BCLK invert 0 - normal(default) 1 - BCLK invert REGISTER 0X03 – CLOCK MANAGER, DEFAULT 0010 0000 Bit Name ADC_OSR Bit 5:0 Description ADC Over Sample Rate control 0~14 - not used 15 - 60*fs 16 - 64*fs(default) ... 31 - 124*fs 32 - 128*fs ... 63 - 252*fs REGISTER 0X04 – CLOCK MANAGER, DEFAULT 0000 0000 Bit Name DIV_PRE Bit 7:4 MULT_PRE 1:0 Description Pre-divided mclk 1~15 - divide by 2~16 0 - divide by 1(default) Pre-multiplication 0 - 1x(default) 1 - 2x 2 - 4x 3 - 8x REGISTER 0X05 – CLOCK MANAGER, DEFAULT 0000 0000 Bit Name DIV_CLKCF Bit 7:4 DIV_CLKDSP 3:0 Description CF clock divider 1~15 - divide by 2~16 0 - divide by 1(default) DSP clock divider 1~15 - divide by 2~16 0 - divide by 1(default) REGISTER 0X06 – CLOCK MANAGER, DEFAULT 0000 0011 Bit Name DIV_BCLK Bit 6:0 Revision 2.0 Description BCLK divider at master mode 0~2 - divide by 1~3 14 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E 3 - divide by 4(default) 4~127 - divide by 5~128 REGISTER 0X07 – CLOCK MANAGER, DEFAULT 0000 0001 Bit Name TRI_BCLK Bit 6 TRI_LRCK 5 TRI_SDOUT 4 DIV_LRCK[11:8] 3:0 Description BCLK Tri-state control 0 - normal(default) 1 - Tri-state LRCK Tri-state 0 - normal(default) 1 - Tri-state SDOUT Tri-state 0 - normal(default) 1 - Tri-state Master LRCK divider bit 11 to bit 8 0~4095 - divide by 1~4096 512 - divide by 512(default) REGISTER 0X08 – CLOCK MANAGER, DEFAULT 1111 1111 Bit Name DIV_LRCK[7:0] Bit 7:0 Description Master LRCK divider bit 7 to bit 0 0~4095 - divide by 1~4096 512 - divide by 512(default) REGISTER 0X09 – CLOCK MANAGER, DEFAULT 1100 0001 Bit Name S1_SEL Bit 7:6 S1_TIME 5:0 Description SEL S1 00 – NA 01 – default 10 – state2 11 – state3 Timer for S1 For LRCK=48KHz: 0 - 21us 1 - 104us(default) 2 - 5ms … 63 - 167ms(max) REGISTER 0X0A – SDP, DEFAULT 1000 0001 Bit Name S3_SEL Bit 7:6 S3_TIME 5:0 Revision 2.0 Description SEL S3 00 – NA 01 – default 10 – state2 11 – state3 Timer for S3 For LRCK=48KHz: 0 - 21us 1 - 104us(default) 15 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E 2 - 5ms … 63 - 167ms(max) REGISTER 0X0B – SDP, DEFAULT 1100 0000 Bit Name SDP_OUT_MUTE Bit 7:6 SDP_LRP 5 SDP_WL 4:2 SDP_FMT 1:0 Description SDP out mute control 0 - unmute 1 - mute R channel 2 - mute L channel 3 - mute L/R channels(default) I2S/Left Justify case: 0 - L/R normal polarity(default) Left/Right=High/Low (LJ) Left/Right=Low/High (I2S) 1 - L/R invert polarity Left/Right=Low/High (LJ) Left/Right=High/Low (I2S) DSP mode case: 0 - Mode A, MSB is available on 2nd SCLK rising edge after LRCK rising edge(default) 1 - Mode B, MSB is available on 1st SCLK rising edge after LRCK rising edge SDP word length 0 – 24-bit(default) 1 – 20-bit 2 – 18-bit 3 – 16-bit 4 – 32-bit others - 24-bit SDP format 0 - I2S(default) 1 - LJ 2 - reserved 3 - DSP REGISTER 0X0C – SDP, DEFAULT 0000 0000 Bit Name TDM_FLAG Bit 5:4 TDM_MODE 3:0 Revision 2.0 Description NFS flag at slot0/LSB 0 - no flag(default) 1 - first chip, generate flag '1' at slot0/LSB 2 - sync chip, get tdm flag '1' and sync, and send flag '1' at current slot 3 - all LSB is flag '0' TDM mode selection 0 - ADC no TDM(default) 1 - 2FS 2 - 3FS 3 - 4FS 4 - 5FS 5 - 6FS 6 - 7Fs 7 - 8FS 8 - ADC + TDM shift (1FS) 16 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E 9 - TDM loop other - not used REGISTER 0X0D – ADC CONTROL, DEFAULT 0000 0000 Bit Name ADC_DATASEL Bit 7:6 ADC_INV 5:4 ADC_RAMCLR ADC_SCALE 3 2:0 Description ADC data mux 0 - output L - R (default) 1 - output L - L 2 - output R - R 3 - output R - L ADC polarity inverted 0 - normal(default) 1 - ADCR invert 2 - ADCL invert 3 - ADCL/R invert ADC ram clear when lrck/adc_mclk active ADC gain scale up 0 - 0dB(default) (recommended when ADC_OSR=0x1C~0x20) 1 - 6dB (recommended when ADC_OSR=0x18~0x1B) 2 - 12dB (recommended when ADC_OSR=0x14~0x17) 3 - 18dB (recommended when ADC_OSR=0x11~0x13) 4 - 24dB (recommended when ADC_OSR=0x10) 5 - 30dB 6 - 36dB 7 - 42dB REGISTER 0X0E – ADC CONTROL, DEFAULT 0000 0000 Bit Name ADC_VOLUME Bit 7:0 Description ADC volume control 0x00 - '-95.5dB' (default) 0x01 - '-90.5dB' … 0.5dB/step 0xBE - '-0.5dB' 0xBF - '0dB' 0xC0 - '+0.5dB' … 0xFF - '+32dB' ADC_VOLUME is the maxgain when ALC on REGISTER 0X0F – ADC CONTROL, DEFAULT 0000 0000 Bit Name ADC_HPF Bit 7 ALC_EN 6 ADC_AUTOMUTE_EN 5:4 Revision 2.0 Description ADC offset freeze 0 - freeze offset(default) 1 - dynamic HPF ADC auto level control 0 - ALC disable(default) 1 - ALC enable ADC auto mute control 0/1 - ADC automute dis (default) 2 - ADC automute enable 17 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor ADC_RAMPRATE 3:0 Confidential ES7243E 3 – internal use ADC VC ramp rate 0 - disable (default) For LRCK=48KHz: 1 - 0.25dB/80us 2 - 0.25dB /160us 3 - 0.25dB /320us 4 - 0.25dB /640us 5 - 0.25dB /1.28ms 6 - 0.25dB /2.56ms 7 - 0.25dB /5.12ms 8 - 0.25dB /10.24ms 9 - 0.25dB /20.48ms 10 - 0.25dB /40.96ms 11 - 0.25dB /81.92ms 12 - 0.25dB /163.84ms 13 - 0.25dB /327.68ms 14 - 0.25dB /655.36ms 15 - 0.25dB /1.3s REGISTER 0X10 – ADC CONTROL, DEFAULT 0000 0000 Bit Name ADC_AUTOMUTE_NG Bit 6:4 ADC_AUTOMUTE_WS 3:0 Description ADC automute noise gate 0 - '-96dB'(default) 1 - '-90dB' 2 - '-84dB' 3 - '-78dB' 4 - '-72dB' 5 - '-66dB' 6 - '-60dB' 7 - '-54dB' ADC automute detection For LRCK=48KHz: 0 - 40us(default) 1 – 60us 2 – 120us ... 10 – 30ms 11 – 60ms others: not used REGISTER 0X11 – ADC CONTROL, DEFAULT 0000 0000 Bit Name AUTOMUTE_SDP Bit 5 ADC_AUTOMUTE_VOL 4:0 Revision 2.0 Description ADC automute SDP control 0 - not mute(default) 1 - mute sdp, SDP_OUT_MUTE=3 ADC auto mute out gain select 0 - mute to -95.5dB(default) … -4dB/step 23 - mute to 0dB 31 - mute to +32dB 18 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E REGISTER 0X12 – ADC CONTROL, DEFAULT 0000 0000 Bit Name AUTOMUTE_PGA Bit 3 AUTOMUTE_MOD 2 AUTOMUTE_MRST 1 AUTOMUTE_DIG 0 Description ADC automute PDN_PGA control 0 - not mute(default) 1 - mute pga ADC automute MOD control 0 - not mute(default) 1 - mute mod ADC automute MOD reset control 0 - not mute(default) 1 - mute mod reset ADC automute digital circuit control 0 - not mute(default) 1 - mute ADC digital REGISTER 0X13 – ADC CONTROL, DEFAULT 0000 0000 Bit Name ALC_WINSIZE Bit 7:4 ALC_LEVEL 3:0 Revision 2.0 Description ALC rate selection For LRCK=48KHz: 1 - 0.25dB/40us 2 - 0.25dB /80us 3 - 0.25dB /160us 4 - 0.25dB /320us 5 - 0.25dB /640us 6 - 0.25dB / 1.28ms 7 - 0.25dB / 2.56ms 8 - 0.25dB /5.12ms 9 - 0.25dB /10.24ms 10 - 0.25dB /20.48ms 11 - 0.25dB /40.96ms 12 - 0.25dB /81.92ms 13 - 0.25dB /163.84ms 14 - 0.25dB /327.68ms 15 - 0.25dB /655.36ms ALC target level 0 - '-30.0dB' (default) 1 - '-27.0dB' 2 - '-24.0dB' 3 - '-22.0dB' 4 - '-19.0dB' 5 - '-17.0dB' 6 - '-15.0dB' 7 - '-13.5dB' 8 - '-12.0dB' 9 - '-10.5dB' 10 - '-9.0 dB' 11 - '-7.5 dB' 12 - '-6.0 dB' 13 - '-4.5 dB' 14 - '-3.0 dB' 15 - '-1.5 dB' 19 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E REGISTER 0X14 – ADC CONTROL, DEFAULT 0000 1100 Bit Name ADC_HPFS1 Bit 4:0 Description ADCHPF stage1 coeff 0x0C (default) REGISTER 0X15 – ADC CONTROL, DEFAULT 0000 1100 Bit Name ADC_HPFS2 Bit 4:0 Description ADCHPF stage2 coeff 0x0C (default) REGISTER 0X16 – ANALOG, DEFAULT 1111 1111 Bit Name PDN_ANA Bit 7 PDN_ADCVREFGEN 6 MODTOP1_RST 5 MODTOP2_RST 4 PDN_MOD1 3 PDN_MOD2 2 PDN_PGA1 1 PDN_PGA2 0 Description 0 – enable analog circuits 1 – power down analog circuits(default) 0 – enable analog ADC bias circuits 1 – power down analog ADC bias circuits(default) 0 – disable(default) 1 – reset modulator1 0 – disable(default) 1 – reset modulator2 0 – enable analog ADC modulator1 1 – power down analog ADC modulator1(default) 0 – enable analog ADC modulator2 1 – power down analog ADC modulator2(default) 0 – enable analog PGA1 1 – power down analog PGA 1(default) 0 – enable analog PGA2 1 – power down analog PGA2(default) REGISTER 0X17 – ANALOG, DEFAULT 0000 0000 Bit Name VMIDSEL Bit 1:0 Description 0 – power down(default) 1 – speed charge1 2 – normal vmid operation 3 – speed charge3 REGISTER 0X18 – ANALOG, DEFAULT 0010 0100 Bit Name ADCBIAS_SW Bit 5:4 ADCFL_SW 3:0 Revision 2.0 Description 0 –bias setting level0, (default) 1 –bias setting level1 2 –bias setting level2 3 –bias setting level3(highest bias) 0000 – not allowed 0001 - bias setting level1(lowest) 0010 - bias setting level2 0011 - bias setting level3 0100 - bias setting level4 0101 - bias setting level5 0110 - bias setting level6 0111 - bias setting level7 20 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E 1000 - bias setting level8 1001 - bias setting level9 1010 - bias setting level10 1011 - bias setting level11 1100 - bias setting level12 1101 - bias setting level13 1110 - bias setting level14 1111 - bias setting level15(highest) REGISTER 0X19 – ANALOG, DEFAULT 1000 1000 Bit Name PGA1BIAS_SW Bit 7:4 PGA2BIAS_SW 3:0 Description 0000 – not allowed 0001 - bias setting level1(lowest) 0010 - bias setting level2 0011 - bias setting level3 0100 - bias setting level4 0101 - bias setting level5 0110 - bias setting level6 0111 - bias setting level7 1000 - bias setting level8 1001 - bias setting level9 1010 - bias setting level10 1011 - bias setting level11 1100 - bias setting level12 1101 - bias setting level13 1110 - bias setting level14 1111 - bias setting level15(highest) 0000 – not allowed 0001 - bias setting level1(lowest) 0010 - bias setting level2 0011 - bias setting level3 0100 - bias setting level4 0101 - bias setting level5 0110 - bias setting level6 0111 - bias setting level7 1000 - bias setting level8 1001 - bias setting level9 1010 - bias setting level10 1011 - bias setting level11 1100 - bias setting level12 1101 - bias setting level13 1110 - bias setting level14 1111 - bias setting level15(highest) REGISTER 0X1A – ANALOG, DEFAULT 0100 0100 Bit Name ADCI1BIAS_SW Bit 7:4 Revision 2.0 Description 0000 – not allowed 0001 - bias setting level1(lowest) 0010 - bias setting level2 0011 - bias setting level3 0100 - bias setting level4 21 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor ADCI23BIAS_SW 3:0 Confidential ES7243E 0101 - bias setting level5 0110 - bias setting level6 0111 - bias setting level7 1000 - bias setting level8 1001 - bias setting level9 1010 - bias setting level10 1011 - bias setting level11 1100 - bias setting level12 1101 - bias setting level13 1110 - bias setting level14 1111 - bias setting level15(highest) 0000 – not allowed 0001 - bias setting level1(lowest) 0010 - bias setting level2 0011 - bias setting level3 0100 - bias setting level4 0101 - bias setting level5 0110 - bias setting level6 0111 - bias setting level7 1000 - bias setting level8 1001 - bias setting level9 1010 - bias setting level10 1011 - bias setting level11 1100 - bias setting level12 1101 - bias setting level13 1110 - bias setting level14 1111 - bias setting level15(highest) REGISTER 0X1B – ANALOG, DEFAULT 0100 0100 Bit Name ADCSMBIAS_SW Bit 7:4 ADCCMBIAS_SW 3:0 Revision 2.0 Description 0000 – not allowed 0001 - bias setting level1(lowest) 0010 - bias setting level2 0011 - bias setting level3 0100 - bias setting level4 0101 - bias setting level5 0110 - bias setting level6 0111 - bias setting level7 1000 - bias setting level8 1001 - bias setting level9 1010 - bias setting level10 1011 - bias setting level11 1100 - bias setting level12 1101 - bias setting level13 1110 - bias setting level14 1111 - bias setting level15(highest) 0000 – not allowed 0001 - bias setting level1(lowest) 0010 - bias setting level2 0011 - bias setting level3 0100 - bias setting level4 0101 - bias setting level5 22 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E 0110 - bias setting level6 0111 - bias setting level7 1000 - bias setting level8 1001 - bias setting level9 1010 - bias setting level10 1011 - bias setting level11 1100 - bias setting level12 1101 - bias setting level13 1110 - bias setting level14 1111 - bias setting level15(highest) REGISTER 0X1C – ANALOG, DEFAULT 0100 0100 Bit Name ADCVRPBIAS_SW Bit 7:4 ADCCPPBIAS_SW 3:0 Description 0000 – not allowed 0001 - bias setting level1(lowest) 0010 - bias setting level2 0011 - bias setting level3 0100 - bias setting level4 0101 - bias setting level5 0110 - bias setting level6 0111 - bias setting level7 1000 - bias setting level8 1001 - bias setting level9 1010 - bias setting level10 1011 - bias setting level11 1100 - bias setting level12 1101 - bias setting level13 1110 - bias setting level14 1111 - bias setting level15(highest) 0000 – not allowed 0001 - bias setting level1(lowest) 0010 - bias setting level2 0011 - bias setting level3 0100 - bias setting level4 0101 - bias setting level5 0110 - bias setting level6 0111 - bias setting level7 1000 - bias setting level8 1001 - bias setting level9 1010 - bias setting level10 1011 - bias setting level11 1100 - bias setting level12 1101 - bias setting level13 1110 - bias setting level14 1111 - bias setting level15(highest) REGISTER 0X1D – ANALOG, DEFAULT 0000 0000 Bit Name LP_VRP Bit 7 LP_VRPOUT 6 Revision 2.0 Description 0 – default 1 – low power 0 – default 23 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor LP_ADCMOD1 5 LP_ADCMOD2 4 LP_ADCMODF1 3 LP_ADCMODF2 2 LP_ADCMODI1 1 LP_ADCMODI2 0 Confidential ES7243E 1 – low power 0 – default 1 – low power 0 – default 1 – low power 0 – default 1 – low power 0 – default 1 – low power 0 – default 1 – low power 0 – default 1 – low power REGISTER 0X1E – ANALOG, DEFAULT 0000 0101 Bit Name LP_PGA1 Bit 5 LP_PGA2 4 LP_PGA11 3 LP_PGA12 2 LP_PGA21 1 LP_PGA22 0 Description 0 – default 1 – low power 0 – default 1 – low power 0 – default 1 – low power 0 – default 1 – low power 0 – default 1 – low power 0 – default 1 – low power REGISTER 0X1F – ANALOG, DEFAULT 0000 1100 Bit Name ADC_DMIC_ON Bit 5 REFSEL 4 VX2OFF 3 VX1SEL 2 VMIDLVL 1:0 Description 0 – default 1 – enable Dmic 0 – default 1 – internal use 0 – enable internal reference voltage 1 – off(default) 0 – level1 1 – level2(default) 0 –’vdda/2’ (default) 1 – vmid level1 2 – vmid level2 3 – vmid level3 REGISTER 0X20 – ANALOG, DEFAULT 0000 0000 Bit Name SELMIC1 Bit 4 PGA1GAIN_SETTING 3:0 Revision 2.0 Description 0 – default 1 – select MIC1 as PGA1 input PGA1 gain 0 – 0dB(default) 24 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E 1 – 3dB 2 – 6dB 3 – 9dB 4 – 12dB 5 – 15dB 6 – 18dB 7 – 21dB 8 – 24dB 9 – 27dB 10 – 30dB 11 – 33dB 12 – 34.5dB 13 – 36dB 14 – 37.5dB REGISTER 0X21 – ANALOG, DEFAULT 0000 0000 Bit Name SELMIC2 Bit 4 PGA2GAIN_SETTING 3:0 Description 0 – default 1 – select MIC2 as PGA2 input PGA2 gain 0 – 0dB(default) 1 – 3dB 2 – 6dB 3 – 9dB 4 – 12dB 5 – 15dB 6 – 18dB 7 – 21dB 8 – 24dB 9 – 27dB 10 – 30dB 11 – 33dB 12 – 34.5dB 13 – 36dB 14 – 37.5dB REGISTER 0XF7 – TEST MODE, DEFAULT 1111 0000 Bit Name PULLUPSE_BCLK Bit 7 PULLUPSE_LRCK 6 PULLDNSE_TDMIN 5 PULLDNSE_SDOUT 4 SDOUT_DRIVE 2 Revision 2.0 Description BCLK pullup control 0 - BCLK no pullup 1 - BCLK pullup(default) LRCK pullup control 0 - LRCK no pullup 1 - LRCK pullup(default) TDMIN pulldown control 0 - TDMIN no pulldown 1 - TDMIN pulldown(default) SDOUT pulldown control 0 - SDOUT no pulldown 1 - SDOUT pulldown(default) SDOUT driver select 25 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor BCLK_DRIVE 1 LRCK_DRIVE 0 Confidential ES7243E 0 - SDOUT normal driver(default) 1 - SDOUT weak driver BCLK driver select 0 - BCLK normal driver(default) 1 - BCLK weak driver LRCK driver select 0 - LRCK nromal driver(default) 1 - LRCK weak driver REGISTER 0XF8 – TEST MODE, DEFAULT 0000 0000 Bit Name SDOUT_FAST PATHSEL DELYSEL ADC_DLY_SEL Bit 7 6 5:4 3 Description Internal use Internal use Internal use Internal use REGISTER 0XF9 – TEST MODE, DEFAULT 0000 0000 Bit Name DLL_PWD Bit 0 Description Internal use REGISTER 0XFA – I2C CONFIGURE, DEFAULT 0000 0000 Bit Name I2C_RETIME Bit 1 INI_REG 0 Description I2C signals retime 0 - normal(default) 1 - retime mode Initial registers 0 - normal(default) 1 - reset registers to default REGISTER 0XFC – FLAG, DEFAULT 0000 0000 Bit Name FLAG_CSM_CHIP Bit 5:4 FLAG_ADCAM 0 Description CSM flag, read only 0 - S0 1 - S1 2 - S2 3 - S3 ADC automute flag, read only 0 - no mute 1 - mute flag REGISTER 0XFD – CHIP ID1, DEFAULT 0111 1010 Bit Name CHIP_ID1 Bit 7:0 Description 0X7A, read only REGISTER 0XFE – CHIP ID2, DEFAULT 0100 0011 Bit Name CHIP_ID2 Bit 7:0 Revision 2.0 Description 0X43, read only 26 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Everest Semiconductor Confidential ES7243E REGISTER 0XFF – CHIP VERSION, DEFAULT 0000 0000 Bit Name CHIP_VER Bit 7:0 Revision 2.0 Description 0X00, read only 27 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019 Revision 2.0 Confidential 28 Latest datasheet: www.everest-semi.com or info@everest-semi.com 8. PACKAGE Everest Semiconductor June 2019 ES7243E Everest Semiconductor Confidential ES7243E 9. CORPORATE INFORMATION Everest Semiconductor Co., Ltd. No. 1355 Jinjihu Drive, Suzhou Industrial Park, Jiangsu, P.R. China, Zip Code 215021 苏州工业园区金鸡湖大道 1355 号国际科技园, 邮编 215021 Email: info@everest-semi.com Revision 2.0 29 Latest datasheet: www.everest-semi.com or info@everest-semi.com June 2019
ES7243E 价格&库存
很抱歉,暂时无法提供与“ES7243E”相匹配的价格&库存,您可以联系我们找货
ES7243E
    • 1+2.36670
    库存:90
