ES3JB
ES3JB
    SUNMATE(森美特)
    SMB(DO-214AA)
    超快速恢复二极管 VR=600V IO=3A VF=1.7V Trr=35ns
ES3JB 数据手册
ES3AB - ES3JB SURFACE MOUNT SUPER FAST RECOVERY DIODES VOLTAGE RANGE: 50 - 600V CURRENT: 3.0 A Features ! Glass Passivated Die Construction ! ! Ideally Suited for Automatic Assembly Low Forward Voltage Drop, High Efficiency ! Low Power Loss ! Super-Fast Recovery Time !    Plastic       Case     Material        has     UL    Flammability                                   B                   SMB(DO-214AA) Classification Rating 94V-O A Mechanical Data ! ! ! ! ! Case: SMB/DO-214AA, Molded Plastic Terminals: Solder Plated, Solderable per MIL-STD-750, Method 2026 Polarity: Cathode Band or Cathode Notch Dim Min Max A 3.30 3.94 C D J Marking: Type Number H Weight: 0.093 grams (approx.) Maximum Ratings and Electrical Characteristics G E B 4.06 4.70 C 1.91 2.21 D 0.15 0.31 E 5.00 5.59 G 0.10 0.20 H 0.76 1.52 J 2.00 2.62 All Dimensions in mm TA = 25C unless otherwise specified Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Characteristic Symbol Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage RMS Reverse Voltage Average Rectified Output Current Unit VRRM VRWM VR 50 100 150 200 300 400 600 V VR(RMS) 35 70 105 140 210 280 420 V IO 3.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 100 A Forward Voltage @IF = 3.0A VFM @TA = 25°C @TA = 100°C IRM 5.0 500 µA Reverse Recovery Time (Note 1) trr 35 nS Typical Junction Capacitance (Note 2) Cj 45 pF RJL 16 °C/W Tj, TSTG -65 to +150 °C Peak Reverse Current At Rated DC Blocking Voltage @TL = 75°C ES3AB ES3BB ES3CB ES3DB ES3EB ES3GB ES3JB Typical Thermal Resistance (Note 3) Operating and Storage Temperature Range 0.95 1.25 1.7 V Note: 1. Measured with IF = 0.5A, IR = 1.0A, Irr = 0.25A. See figure 5. 2. Measured at 1.0 MHz and applied reverse voltage of 4.0 V DC. 3. Mounted on P.C. Board with 8.0mm2 land area. 1 of 2 www.sunmate.tw FIG. 1- FORWARD CURRENT DERATING CURVE 3.0 2.4 1.8 Single Phase Half Wave 60Hz Resistive or inductive Load 1.2 0.6 0 0 25 50 75 100 125 150 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES RATINGS AND CHARACTERISTIC CURVES ES3AB THRU ES3JB FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 100 80 60 40 20 175 0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 AMBIENT TEMPERATURE, C NUMBER OF CYCLES AT 60 Hz 20 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 1 0.1 ES3AB-ES3DB ES3EB-ES3GB ES3JB 0.01 0 0.4 0.8 1.2 1.6 1.8 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 10 1,000 100 10 TJ=100 C 1 TJ=25 C 0.1 0.01 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 0 20 40 60 80 100 200 100 10 TJ=25 C TRANSIENT THERMAL IMPEDANCE, C/W PERCENTAGE OF PEAK REVERSE VOLTAGE,% FIG. 5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE, pF 100 FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 100 1 0.1 1.0 10 100 REVERSE VOLTAGE,VOLTS t,PULSE DURATION,sec. 2 of 2 www.sunmate.tw
ES3JB 价格&库存
很抱歉,暂时无法提供与“ES3JB”相匹配的价格&库存,您可以联系我们找货
