SS52 - SS510
SURFACE MOUNT SCHOTTKY BARRIER DIODES
VOLTAGE RANGE: 20 - 100V
CURRENT: 5.0 A
Features
Schottky Barrier Chip
Ideally Suited for Automatic Assembly
Low Power Loss, High Efficiency
For Use in Low Voltage Application
Guard Ring Die Construction
Plastic Case Material has UL Flammability
Classification Rating 94V-O
SMC/DO-214AB
B
Dim
Min
Max
5.59
6.22
B
6.60
7.11
C
2.75
3.18
D
0.15
0.31
8.13
A
Mechanical Data
A
! Case: SMC/DO-214AB, Molded Plastic
! Terminals: Solder Plated, Solderable
per MIL-STD-750, Method 2026
! Polarity: Cathode Band or Cathode Notch
! Marking: Type Number
! Weight: 0.21 grams (approx.)
C
D
J
H
Maximum Ratings and Electrical Characteristics
G
E
E
7.75
G
0.10
0.20
H
0.76
1.52
J
2.00
2.62
All Dimensions in mm
TA = 25C unless otherwise specified
Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Characteristic
Symbol
SS52
SS53
SS54
SS55
VRRM
VRMS
VDC
21
30
40
28
40
50
35
50
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 5.0A
Maximum DC reverse current TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
SS56 SS58 SS510
60
42
60
100
70
100
80
56
80
Unit
V
V
V
I(AV)
5.0
A
IFSM
150.0
A
VF
IR
CJ
RθJA
TJ ,
TSTG
0.70
0.55
0.85
0.5
200
50.0
-65 to +125
-65 to +150
-65 to +150
V
mA
pF
C/W
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
1 of 2
www.sunmate.tw
FIG. 1- FORWARD CURRENT DERATING CURVE
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES SS52 THRU SS510
5.0
4.0
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
3.0
2.0
SS52-SS56
SS58-SS510
1.0
50
75
100
125
150
175
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
150
120
90
60
30
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
50
CURRENT,AMPERES
TJ=25 C
10.0
1
0.1
SS52-SS54
SS55-SS56
SS58-SS510
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.01
0.4
0.6
0.8
1.0
1.2
1.4
TRANSIENT THERMAL IMPEDANCE,
C/W
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
2000
TJ=25 C
100
10
0.1
1.0
10
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
1.6
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
1000
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
100
REVERSE VOLTAGE,VOLTS
t,PULSE DURATION,sec.
2 of 2
www.sunmate.tw
很抱歉,暂时无法提供与“SS56”相匹配的价格&库存,您可以联系我们找货
